[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Mal ein kleines Feedback für alle, die eine leise Karte suchen:
Die Spulen der Zotac Amp Extreme Airo sind ziemlich leise bei meinem Exemplar, bisschen hört man sie, aber im vergleich zu anderen Karten schon fast lautlos.
Die Lüfterkurve haben sie aber leider versaut, da die Lüfter bereits bei 46 °C starten und sich dann bei 39 wieder abschalten. Das führt bei mir dazu, dass die Lüfter ständig starten und sich wieder abschalten. Die rpm der Lüfter sind mit 1100 rpm Minimum auch etwas zu hoch und damit unnötig hörbar. Das Klangbild der Lüfter ist auch nicht besonders angenehm.
Das mit der Lüfterkurve lässt sich hoffentlich mit einem anderen Bios beheben.
in diversen yt videos konnte man eine Art Dos like screen: - system font weiss auf schwarzem Background - sehen wo man diverse GPU Infos auslesen/ablesen konnte.. welches tool ist das?
Nvidia-smi
Einfach in die Konsole tippen, liegt im Windows-Pfad.
  • Haha
Reaktionen: SH
hab mal ein Video beim Belastungstest mit 3DMark Speed Way mit meiner FE gemacht,
meiner Ansicht nach absolut unafällige Lüftergeräusche, kein Spuhlenfiepen.
Also ja da ist ein Surren zu hören aber zumindest nach dem Video finde ich das jetzt auch nicht schlimm. Viel Spaß in jedem Fall mit der Karte, hätte ich auch gerne!
also die tuf sieht in echt klar besser aus als auf den bildern.
da ist alles bombenfest und wirkt wirklich massiv. kein vergleich zu karten der letzten generationen.....
karte ist 1a verarbeitet. da ist absolut nix dran. :)
Die Gigabyte von Mediamarkt wurde schon verschickt. Dann werde ich Samstag Mal schauen wie laut das gute Stück ist. :d
Bei Speedway gibts auch kein fiepen sind ja 100 +-20fps ... Musst du bei 200-240 fps testen ;-)
da ist alles bombenfest und wirkt wirklich passiv. kein vergleich zu karten der letzten generationen.....
Die TUF 3090 war auch schon geil gegenüber allen anderen AIB's
Hier wird der Kauf zur Tuf anstatt der Strix empfohlen wenn man auf Wasserkühlung umrüstet.
strix auch einfach wunderschön - keine Ironie -
klar ein schweres stück klotzartig aber das Material ist sehr anmutend! ich mag es total!
und wenn man regelmässig aus und einbaut kann man sich das gym sparen! ^^
Ist das bez. der Spulen dein Ernst? Die Karte surrt doch wie Hölle, sogar trotz der Lüfter stark zu hören.
Mal ein Beweis mehr wie sinnlos solche subjektiven Useraussagen sind. Danke aber für das Video.
die strix gefällt mir auch etwas besser aber die ist einfach nicht zu kriegen und nochmal teurer...
Ui, mir gefällt wie man das ganze Alu "paket" inkl. Lüftern abnehmen kann, sehr einfach. Der eigentliche Kühlblock ist dann immer noch fest dran.
Self made Noctua edition inc? :shot:
Wenn hier alle immer vom spuhlengiepen reden, wie extrem ist das? Hört ihr dad beim
Geschlossenen gehäuse und fas es quasi lauter ist als die lüfter?
Und kommt es mir so vor oder ist es beim msi suprim x am meisten? Oder kommt es mir nir so vor? Oder gibt es tendezen welche marken am
Meisten betroffen sind bzw welche versionen?
bei jedem exemplar unterschiedlich.
Das kann ich so bestätigen, also ich vernehme bei meiner gar kein spulenfiepen bisher, total spooky, wenn ich die anderen Karten hier so höre. Den Speedway Test hab ich allerdings noch nicht in meinem 3dmark freigeschaltet, mach ich gleich mal.
Meine 3090FE hat sehr wohl spulenfiepen dem man mit UV gut beikommt.
Finde auch das die Lüfter viel zu hoch ansetzen mit 1100 u/min und hoffe das man das noch besänftigen kann, weil das einfach unnötig ist.
@scars och menno ich lauer auch immer mal wieder.... Kann man die Uhrzeit erfahren und ist die save wenn sie im wahrenkorb liegt?
Du hast Recht, das Surren kommt von den Spulen aber die Lüfter verursachen ein gleichmäßiges angenehmes Rauschen. Würde ich so auf jeden Fall behalten.
Volle Zustimmung. Habs auch direkt gehört, trotz Lüfter der alles nochmal dämpft. Das ganze im Time Spy und sie hört sich wahrscheinlich an wie alle anderen fiependen Karten die ich auch hatte.
Aber freu mich für die Leute die damit kein Problem haben bzw. es nicht wahrnehmen (können).
ok, ich hab da kein Problem und die Karte ist für mich leiser als die 3090 FE welche ich hatte.
vielleicht hab ich dann bereits nen Tinitus oder bin zu alt.
Grafikkartenteurer.de zieht die Preise ganz schön an. UVP gibts wohl bald nur mehr die FE
Ich finde persönlich rein optisch die TUF schöner als die Strix , aber die Strix hat halt 24+4 Phasen und die TUF 18+4.
Wobei das am ende egal ist . Können wahrscheinlich on Air beide die Chips ausreizen.
Hätte wenn verfügbar auch zur Strix gegriffen. Die TUF war Nr. 2 . FE hätte ich wegen Lüfterproblemen nicht genommen.
Mir ist aufgefallen bei meinen und bei den Ergebnissen der Leute , dass die GPU´s von ihren Stocktakt aus gesehen meistens ca. +250 MHZ können und der Vram +1000-1500 MHZ können im Bereich 50-+60°C GPU
Temp.Da ist die Curve dann schon ein guter Indikator wie gut der Chip ist. Posten auch echt wenige Leute Ergebnisse. Stattdessen regen sich alle über Nebengeräusche auf^^
@***** : Was packt denn deine neue TUF OC ?
So die HD Version ist fertig...
Sorry wegen des Sounds. Musste ein Headset nehmen.
ich sehe das genauso, ich hab jetzt noch paar Druchläufe mit TimeSpy mit über 200FPS laufen lassen und der Geräuchpegel ändert sich nicht. Für mich ich das zufriedenstellend.
Nach den ersten Runden Cyberpunk, Witcher 3 und Doom Eternal bin ich wirklich hin und weg von der 4090 Strix...
Weniger Strom bei viel mehr Leistung als meine 3090 Kingpin, dazu im Gegensatz zur Strix 3090 auch kaum fiepen/rasseln...
Im Desktopbetrieb unhörbar und selbst beim Spielen nicht wirklich laut, ASUS bzw. NV ham mal richtig geliefert...
#PCMR :fresse:
kisspng-pc-master-race-personal-computer-video-games-pc-ga-couples-5b6fc7941e8f30.604737621534...png
Kosten.
Die Strix gibt es glaube ich nur auf dem Papier als non-OC. Die TUF non-OC für 1950€ im ASUS-Shop. Takt ist bei allen gleich, bisher hat jede die 3 Ghz mit 1.1v geschafft. 600 Watt PT und 2x HDMI haben auch beide. Also wenn es eh unter Wasser soll, klar die TUF (non-oc).
Im Video wird auch in der ersten Minute auch noch mal klar erklärt warum die ganzen OC-Modelle überzogenen Preise haben.
Kosten.
Wobei die TUF OC immer noch günstiger als die Strix wäre. Warum dann nur die NON OC?
Tuf zur Strix flashen, unnötig!
Ähnliche Themen
Antworten
6K
Aufrufe
395K
