[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Bisschen Off - Topic
Welche CPU eignet sich um die RTX 4090 zu befeuern ? Aktuell Game ich noch auf dem 5800X und überlege auf dem 3DX zu Wechseln
Auf AM5 wollte ich erst mit Zen 5 wechseln …
Settings sind stets UHD - Max. Presets
Die cpu die deine Wunsch fps erreicht. Die gpu hat damit nix zu tun
Du wirst die 4090 in cs go in 4k nicht auslasten können weil die cpu vorher dicht macht. Erreichst du aber deine gewünschten fps, isses doch wurscht
Ich Falle mit dem 12700 3200c16 auf 85 fps in spidermann, auf weniger als 110 fps in farcry 6, auf weniger als 110fps in zelda botw, etc...
Ich bin also jetzt schon cpu limitiert in 3440x1440. In diesen games werde ich mit der 4090 keine Zuwächse bekommen.
Ich könnte natürlich auf den 13700k gehen aber diese Ausgabe sehe ich derzeit nicht ein. Ergo lebe ich damit.
In Spielen die auf der cpu deutlich besser laufen kann ich die 4090 auch deutlich besser ausfahren.
Du siehst, es ist spiele abhängig und man kann das nicht pauschal festmachen dass eine neue cpu deine 4090 durchweg bedienen kann.
Schau dir deine spiele an. Schau wo deine aktuelle cpu steht und schau wo die neuen Optionen stehen und dann kannst du schauen welche cpu für dich sinn macht und welche nicht und ob überhaupt.
Natürlich 720p Tests anschauen. Du willst ja sehen wo die cpu ihre Grenzen hat damit du weißt ob die deine Wunsch fps erreicht.
Merke, es gibt keine cpu passend zur gpu sondern einzig eine cpu passend zu deinen Vorstellungen.
Passend zur 4090 eingetroffen :bigok:
Sahneteil, gehe voll steil. Befeuer ihn mit meiner alten 2080ti, und das garnicht mal schlecht
38" Ultra wide sind so dermaßen genial. Die par pixel in der Höhe zu 4k fehlen mir nie.
Was die uns vorliegenden Muster angeht, ist das Störgeräusch (im Englischen "Coil Whine" genannt) etwas auffälliger als bei der RTX 3090 Ti.
Quelle: https://www.pcgameshardware.de/Gefo...t-Benchmarks-RTX-4090-vorbestellen-1404846/5/
kann dir aber auch andere Quellen nennen. aber das mit coil whine ist halt chip lotterie, trotzdem ist es halt fakt, dass die fe lauter ist als die custome karten, daher haben die leute hier nichts falsches erzählt was das Surren/coil whine angeht
Du solltest wenn Du schon externe quellen zittierst und andere belehren möchtest aber auch dazu sagen das sich beim pcgameshardware Test bzw Deiner darauf basierten Aussage das die 4090 lauter ist (coil wine) auf die 3090 Ti bezogen ist.
Pcgameshardware und deren Messungen sagen hier nämlich auch, dass die 4090 leiser ist als die 3090 😉
ich habe beide Karten und die 4090 ist leiser als die 3090 insofern würde ich das dann so auch bestätigen.
Danke dir für die ausführliche Erläuterung
Das hat mir sehr geholfen 👍
Mein Fazit
Ich bleibe bei meiner CPU
Nicht signiert, lässt der Defender selbst mit Ausnahme nicht durch.
Trotzdem Danke.
Die sind schon dran die TUF zu integrieren. Ich hab das Tool auch erst durch den Thread hier kennengelernt. Keine Ahnung wie lange sowas dauert. Zumal der letzte Stable-Release 2021 war. Vielleicht werden die Profile "sideloaded"? Hier kann man sich beteiligen:
4090 TuF
"Meine" Gaming OC ist schon ein bischen weiter ;-)
4090 TuF
Habe ich bei Gitlab auch schon entdeckt. Bei der 3090 Strix hat die Integration ca. einen Monat gedauert. Das schöne an Opensource-Projekten ist, dass sich da Leute hinterklemmen, die auch wirklich daran interessiert sind Probleme zu lösen.
4090 TuF
also endweder bin ich für das tool zu blöd oder der Support steht nicht. Weder mein MSI Board, noch die MSI Karte noch meine Corsair RAMS werden mir in dem Tool angezegt.
Hier die Kompatibilitätsliste
ja d asteht ne menge, aber auch ne menge nichts aussagendes. wenn ich nur von msi und dem ram gehe alles compatibel, saber im programm zeigt er mir se ned an.
Das Projekt hat auch einen eigenen Discord. Da bekommt man eigentlich zeitnah Hilfe
Ich hab die 12900k und spiele auch immer auf max settings 3440x1440 Ultrawide. Neue cpu habe ich eigentlich auch kein bock. Kp ob ich da immer ins limit laufe da kein 4K Monitor. Aber hab mich zu sehr an 21:9 gewöhnt kann nicht mehr zurück zu 16:9😅
Das Update kam von nVidia OTA ohne das man einen neuen Treiber installieren musste, es ist eigentlich nur ein Update im Profil, es werden keine Treiberdateien ausgetauscht meines Wissens. Offenbar kann der Treiber das selbst nachladen.
Ich hatte das schon über den manuellen Weg bei mir gefixt, dazu hat man lediglich die SLI Profile mit einem nVidia Tool exportiert, einen Eintrag angepasst und dann wieder importiert. Fand es lustig das die SLI Profile das Problem beeinflussen obwohl gar kein SLI mehr zum Einsatz kommt.
Ist allerdings kein richtiger Fix für mich, da er die gewonnene Leistung durch den neuen Treiber wieder um ~5 FPS reduziert. Bin mit diesem "Fix" wieder permanent im CPU Limit mit einer GPU Auslastung von 94-95%. Mache ich diesen "Fix" wieder rückgängig über das SLI Profile Tool, habe ich wieder permanent 98-99% GPU Auslastung und gewinne 5 FPS. Ich kann mit einer kaputten Map temporär leben. Das nervige ist, dass nach jedem Neustart das Profil wieder automatisch aktualisiert wird.
Siehe auch hier in den Kommentaren (nicht mein Kommentar): https://www.reddit.com/r/nvidia/com...medium=android_app&utm_source=share&context=3
Sorry für OT.
Was hast Du denn für Probleme?
Worauf soll ich denn reinfallen?
Mich wundert nur, dass die Karte unter UVP angebotzen wird.
Ok, war wohl schon mal benutzt. Gehört hier bestimmt einem aus dem Forum weil sie gezirpt hat :-)
Ich hab kein Problem, aber Karte Unbenutzt unter UVP bei Ebay kleinanzeigen. Ist sowas von Fake, das wird keiner machen. Also das meine ich mit viel spass damit ^^ und reinzufallen.
Neu, unbenutzt und originalverpackt - hört sich aber schon anders an, oder soll da noch zusätzlich gross und fett UNGEÖFFNET stehen?
Selbstabholung wird ja angeboten - ob das Angebot echt ist kann man doch leicht rausfinden wenn man dem Verkäufer Selbstabholung und Barzahlung anbietet ;-)
Ja. OVP schreiben alle welche noch die originale Verpackung haben. Wenn es unbenutzt ist schreibt man eigentlich "noch versiegelt".
Würde mich nicht wundern, wenn auch bei Fake angeboten Abholung angeboten wird und mehr vertrauen zu schaffen.
Ja dann schreib ihn mal an und frag wann du die Karte abholen kannst. Da wirst du zu 100% keine Antwort bekommen. Das ganze richtet sich nur an Ahnungslose die mit Paypal Friends zahlen. Gibt immer ein paar die darauf reinfallen. Der niedrige Preis ist nur damit so viele wie möglich in Versuchung kommen.
Nicht nur scheinbar, es ist tatsächlich so.
Das Abwarten bis November wird sicher hilfreich sein, außer man muss sich von einer Software Pünktchen generieren lassen.
@SH
kürzlich hatte ich darum gebeten, die veralteten Informationen über Kühlerwechsel und Garantie zu überarbeiten bzw. das tun zu lassen. Höchstwahrscheinlich bin ich nicht der einzige, der das nützlich fände.
Weshalb antwortest Du darauf nicht?
Nicht gesehen. Aber die aktuelle Tabelle ist von sep 2020. Also „nur“ 2 Jahre alt. Wenn du eine neue und aktualisierte Tabelle mit Quellen hast, ändere ich es gerne 👍 danke dir
Zu wunderbaren Scalperpreisen 👎 Ich packs net auf die 1949 UVP Inno3d mal 350 € raufzuhauen.
Zu dem Preis kauf ich sicher nicht, aber scheinbar genug anderer........
Das sehe ich auch so.
Ob es Computeruniverse ist oder kleinere Klitschen wie PC-King oder Snogard oder .... die verlangen teils horrende Preise.
Die Preise liegen sogar höher als bei Caseking.
Notebooksbilliger ist da nicht besser.
Deswegen sind die Karten bei Mediamarkt und Saturn auch ja so schnell weg.
Und bei Notebooksbilliger sind jetzt schon seit ein paar Stunden die inno3d auf Lager.
Ich verfolge ja auch auf Ebay kleinanzeigen die Preise. Da werden die Verkäufer sogar die 4090 FE nicht los für ihre Mondpreise.
Und das ist auch gut so!
Nur bei Ebay sind ein paar Drollige dabei.
Bin mal gespannt, ob das Finanzamt mit ihrer Software dafür die Leute genau beobachtet. Bei mehreren solcher Verkäufe werden die sich schon melden.
also die 3090 kann ich getrost ignorieren, weil ich die aktuelle gpu immer mit der leistungsstärksten Gpu aus der letzten Architektur vergleiche und das ist die 3090 ti und jetzt komm mir nicht damit, dass dies nicht der nachfolger der 4090 ist. nur weil du jetzt eine 3090 gehabt hast, soll ich die 4090 nicht mehr 3090 ti vergleichen?
Die 3090ti ist ne quatschkarte. Kam viel zu spät.
Ähnliche Themen
