[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
jap, 4090 ist wesentlich einfacher zu bekommen als 3090
zumindest die teuren
ne karte um 1949 ist auch schwer...
aber die 3090 gabs wochenweise überhaupt nicht, egal zu welchem preis
Es ist auch nicht annähernd mit dem 30er Release vergleichbar.
Bei 4090 gabs jetzt teilweise Zeitfenster von über 30-60mins wo man eine Karte kaufen konnte. Da war bei Ampere nicht ansatzweise dran zu denken.
Wer hier etwas aufmerksam die Verfügbarkeitsmeldungen von ralles Bot verfolgt hat, war locker in der Lage eine Graka zu bekommen.
Ich sehe keinen Unterschied. Ne 3090 war bis Dezember 2020 noch genauso problemlos zu bekommen wie jetzt mit der 4090... ich kann da mitreden, weil ich zwischen September und Dezember insg. 6 Karten im Haus hatte. Vor allem die FE waren leicht zu bekommen, beim ersten Drop der 3070 FE war die 3090 FE ne halbe Stunde bei NBB verfügbar.
besten Dank, also Riser macht wohl nichts negatives aus... hier meins https://www.3dmark.com/pcie/316546
Am 13.10. war die Suprim X gefühlt eine halbe Stunde verfügbar und auch bei Cyberport wurde man am 12.10. locker fündig.
Habe easy zwei Karten ordern können und eine davon behalten.
Aber die ganzen Zauderer und Preisbewussten meinten halt es geht noch besser.
Jetzt ist natürlich das Gejaule groß, zumal sich die Preise gefühlt tendenziell nur in eine Richtung bewegen.
3090 hat wirklich eine Zeitlang garkeiner gekauft.
Bei Release war es schwieriger, dann kam eine Phase wo man eine brandneue 3090 FE nichtmal auf Ebay zum UVP loswurde und dann kam der boom
Beste Aktion war damals die mit der Amazon Strix, die eine Woche vor Verkaufsstart über Stunden zum UVP angeboten wurde und dann tatsächlich 2-3 Monate später auch ankam.
Das waren 120€ über FE. Die jetzige Strix sind 500€ über FE und trotzdem ausverkauft:rolleyes2:
  • Danke
Reaktionen: THK
Was sagen die Spulen?
Rasseln etwas - aber weitaus erträglicher als bei der ASUS Strix OC
Mehr als 195 gehen bei der GPU von der iChill nicht, ab 210 crashed Speed Way.
+1500 MHz gehen schon einmal beim Speicher - lief durch:
Hat schon heute jemand GE invites bekommen?
Braucht man von Cable Mod jetzt eigentlich NUR den rechtwinkligen Adapter (wenn man den verwenden möchte) oder den rechtwinkligen Adapter UND ein 12VHPWR auf 3x bzw. 4x 8 PIN-Kabel?
edit: Muss man wissen, ob man einen oder 2 Artikel bestellt bei der langen Wartezeit. ^^
+ 90 gradadapter wenn du es komplett haben willst.
Hier mal meine Werte.
Original macht meine Suprim 2850 MHz bei den meisten Games. Ich habe den Sweetspot bei 0.9 und 2650 MHz gefunden ,zocke damit schon viele Stunden absolut stabil.
Für 3000 MHz braucht sie nur 1,05 Volt und mehr gebe ich auch nicht drauf.
korrektur
hier die fertigen kits für asus/ seasonic, corsair, evga
Leider sind die Cablemod Kabel für Corsair z.b. für mich nicht zu gebrauchen.
Ich habe ein SF750, dieses Netzteil hat 4 PCI-E Anschlüsse, diese sind aber für GPU UND CPU vorgesehen. Das Cablemod Kabel will aber 4x8Pins... ich habe also damit ein PCI-E Anschluss zu wenig.
nimmst das 3x8pin. reicht für 450w
ich hab auch nur ein 3x8 bestellt da ich die tuf eh undervolteed bzw unterpowertargeted betreibe :)
Nein, du kannst oben 3x 8 pin auswählen und hast trotzdem 600W.
korrektur
Das ist aber doch nicht nur für Asus Karten vorgesehen, oder? Müsste auch für meine Phantom Karte gehen?
Oder gibts noch ne Kombi für Gigabyte/Seasonic?
Sorry, aber ich komme mit dem Shop so überhaupt nicht klar…
Ach wait: Oder ist mit Asus hier auch das Netzteil gemeint, die machen ja auch welche, stimmt ja...
Das passt in jede pcie5 buchse. Es geht um die Pin-Anordnung auf der PSU-Seite. Und RT ist das Kürzel für die Seasonic und Asus-Netzteile, nicht Asus-Karten:d
die markenbegrenzung gilt für netzteile nicht für gpus
asus nts sind seasonic nts
corsair
und evga eigenständig
bequiet haben sie wohl noch nicht mit drin
Jup, Mea Culpa, hatte völlig vergessen das die auch Netzteile basteln :asthanos:
Aber jetzt kann ich auch noch 3 Tage warten und gleich das 90 Grad Teil nehmen, wenn sie dann eins übrig haben :sneaky:
(wartet ja gefühlt wirklich jeder 4090 Besitzer drauf...)
Hoffentlich schnippelt der Igor auch mal die cablemod und Netzteilhersteller Adapter auf. Nicht dass da noch mehr solcher "löt-un-Zinn" verbandelt wurde. Ist ja grausam. Habe mir jetzt erstmal ein cablemodkabel bestellt. 45€ wow.
Will jemand mit mir ne kleine Kabelfirma aufmachen. Ist ja traumhaft wie man hier absahnen kann...
Was passiert eigentlich wenn dieser nvidia Adapter sich langsam auflöst, müssten dann da nicht kürzere kleinere funken entstehen wenn der gebrochene Lötzinn sich durch Mikrovibrationen und Spannungen sachte entfernt bzw. Annähert (an die Kupferplatte oder benachbarte Leitungen)?
Diese schlagartigen Spannungsspitzen auf einer PSU Leitung kann ja nicht gut sein und evtl. Andere Geräte (Festplatten?) Auf dieser Leitung schädigen?
man müsste es dann ja auch bizzeln hören.
ziehts beim Mediamarkt die 19% jetzt ab oder nicht?
hatte ne suprim im warenkorb aber da ging nix weg
Ähnliche Themen
Antworten
6K
Aufrufe
397K
