[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
so ist es @LtSnoopy, das kann man als "quick fix" auch machen, dennoch hat der Hersteller das auszutauschen was er ja auch tut.
noch dazu sind nicht alle User in der Lage das zu bewerkstelligen.
Hat hier jemand zufällig auch das Problem, dass die 4090 nach dem Zocken (CODMW2) nicht mehr in den Zero Fan Modus geht? (bei mir aktuell die Gainward 4090 PhantomGS). (-> durchgehend 30% Lüftergeschwindigkeit, egal welche Temps) Erst nach dem Neustart schalten die Lüfter wieder ab.
Es scheint ja kein Modell nicht irgendwelche störenden Geräusche von sich zu geben, mal mehr mal weniger ausgeprägt. Und das bei einem so hochpreisigen Produkt.
Ich hatte keine 3090 oder 3090 ti, aber bei so einem fetten Kühler müssen doch starke Lüfeter installiert werden, damit der auch ordentlich durchgepustet wird. Dass das dann Geräusche macht, ist doch unausweichlich. Ich kann das nur mit meinen alten Karten vergleichen und da waren sowohl die 1070 FE als auch die 2080 ti Windforce lauter als jetzt die Phantom GS.
man muss zu dem Beispiel aber auch sagen, das dass abbiegen der Kabel direkt am Stecker nicht ratsam ist.
be quiet empfiehlt auch an deren 12VHPWR Kabel eine Biegung erst in 2-3cm mit 90Grad durchzuführen.
so sollte man das tun Beispiel Bild von be quiet:
Aber ja jeweils 1 Pin sind an meiner ersten Lieferung war auch nicht sauber verankert, wurde aber anstandslos ausgetauscht.
Die Teile sind eine einzige Fehlkonstruktion. Wenn man sich mal den Modellbau-Bereich anschaut, kann man ohne Probleme 600 Watt über zwei stinknormale Kupferkabel durchschieben, eben mit einem vernünftigen Stecker. Die kannst Du biegen und ziehen wie Du willst, da passiert garnichts.
Hier so überempfindliche, hochfeine, leicht verletzbare Drähtchen zu verwenden, die nur hauchzart auf Bruchteils-Millimeter schmalen Metallplättchen verlötet sind (= leichte Zugkraft, kaputt) ... eine einzige Fehlentscheidung. VOR ALLEM da diese Adapter wegen baulicher Probleme (Gehäusegröße, Stecker auf Oberseite der Graka) auch noch in vielen Fällen gebogen werden müssen; nur die fettesten, riesigsten E-ATX cases können hier "korrekt" verwendet werden. Das MUSS NVIDIA vorher bewusst gewesen sein.
Das wird in Sammelklagen und Bränden enden. Einfach nur Dumm.
meine Gainward Phantom geht auch zurück
ich hab ne absolut lautlose 3080ti von EVGA und werd nur gegen sowas austauschen
die Karte wär sonst super, egal welche FPS surrt gar nichts, aber sobald der Lüfter anspringt rattert bzw. surrt es einfach zu laut
Hatte ich auch, die Karte war dann auch bei 2610 MHz festgetackert. Bei mir lag das Problem am Afterburner und auch dem Tool von Gainward, ich musste aber jedes Mal den Treiber neu installieren, damit das aufhörte, extrem nervig. Erst mit dem neuen EVGA Precision X1 funktioniert alles wie es soll.
Hier so überempfindliche, hochfeine, leicht verletzbare Drähtchen zu verwenden ist eine einzige Fehlentscheidung. Das wird in Sammelklagen und Bränden enden. Einfach nur Dumm.
das sind keine drähtchen das ist ein 16AWG Kabel
Und die Usache ist der Strecker welcher aus der Verankerung rutscht oder gerissen wird.
Beispiel eines anderen Users (noch dazu ein schlechtes wo wieder direkt am Stecker durch die Biegung zug auf die Steckkontakte erzeugt wurde)
So ne Karte müsste easy 3 GHz bei 1.05v schaffen oder sogar bisschen weniger schaffen.
Ich habe übrigens tatsächlich mal aus Spaß geguckt, was so geht mit der Karte ohne sie stundenlang zu stressen. Ich glaube nicht, dass sie 3 GHz bei 1.05 V schafft (denke mal knapp drunter), kann es aber auch nicht genau verifizieren, weil die Karte immer wieder ins Powerlimit reinrennt und sich dann runtertaktet (450 W).
Mit 1 V gingen 2880 MHz (Verbrauch so bei knapp 430 W ohne, dass sie sich runtertaktet).
Ist der Bin trotzdem noch gut?
Custom-Kabel, Winkelstecker oder NVidia-Version2. Spätestens, wenn Nvidia die Version 2 verteilt, spricht über dieses Problem niemand mehr. Bis dahin bleibt es echt ärgerlich. Also sollte Nvidia schnellstmöglich handeln. Ich nehme an, intern wird massiv an einer Lösung gearbeitet und dann kommt man direkt mit der Lösung. Alles andere würde einen Verkaufstopp oder gar Benutzungsstopp auslösen. Das wäre ein Super-Gau und sicher nicht die angestrebte Vorgehensweise.
Das Problem hier ist natürlich die Verteilung von neuen Adaptern. Wenn die Teile in Fernost hergestellt werden, dauern Schiffslieferungen minimum 2 Wochen, wenn überhaupt. Hier rechnet man normalerweise mit 3-6 Wochen. Und da wir hier von Steckern sprechen, würde eine QA Phase - normalerweise - minimum 1-2 Monate andauern (ein neuer Adapter müsste zudem erstmal vor irgendeinem Qualitätscheck entwickelt werden). Und dann kommt auch noch die Produktionszeit als solche. Mal ganz abgesehen davon, dass wegen der schlechten PR NVIDIA vermutlich nicht denselben Hersteller wiederverwenden wird. Ich sehe also nicht, wie NVIDIA hier in "kurzer" Zeit eine Lösung anbieten könnte.
Da müsste man schon ein bereits fertiges Kabel (zB Cablemods) großflächig einkaufen, in schnellster Zeit qualitätsassesment betreiben, umbranden und an alle Ex-Käufer per Luftpost verschicken. Das ganze ist allerdings teuer. Dementsprechend sehe ich das nicht als realistisch. Zudem wäre ein solcher "Erstatzadapter" gefundenes Fressen für US-Bürger mit ihrer Sammelklagenwut, da hier NVIDIA quasi ein Schuldeingeständnis präsentieren würde.
Mal ganz abgesehen davon, dass Fälle hier im Forum - wie mit dem BeQuiet Kabel - zeigen, dass auch Drittanbieter-Adapter/Kabel von ähnlichen Problemen betroffen sind/sein können.
teuer..... nvidia kackt geld.
Intel hat bei der bekannte LGA1700 Problematik der gebogenen CPUs auftretend bei verschiednen Boardherstellern auch nichts gemacht.
Ok, ein Herstellerübergreiffender Adapter ist ne andere Nummer, da müsste eigentlich was kommen.
da wird vermutlich garnichts kommen, Intel hat bei der bekannte LGA1700 Problematik der gebogenen CPUs auftretend bei verschiednen Boardherstellern auch nichts gemacht.
Klar ein Herstellerübergreiffender Adapter ist ne andere Nummer, da müsste eigentlich was kommen.
Irgendetwas wird mit Sicherheit hier kommen. Intels Problematik hatte keine Sicherheitsrelevanz, wohingegen hier bei NVIDIA ein möglicher Brandherd entstehen kann. Da spaßen US Behörden nicht. Die Frage ist also nur, wie schnell kann NVIDIA hier reagieren und/oder wie schnell reagieren die US-Behörden.
Auf unsere europäischen Behörden würde ich hier nicht setzen, die wissen vermutlich nichtmal, was NVIDIA ist. Würde mich ernsthaft wundern, wenn morgen ein Journalist durch den Bundestag geht und jeden Abgeordneten fragt (Wissen sie, was NVIDIA oder eine RTX 4090 ist?) und auch nur ein einziger darauf eine gescheite Antwort wüsste. Da müssten wir natürlich Verständnis haben, immerhin ist das Internet ja für uns alle noch Neuland (HustHustKotzreizVerdeckVersuch).
Gibt übrigens schon wieder einen neuen Fall von einem Adapter, der in Begriff ist, zu schmelzen:
Die Teile sollte man als Brandbeschleuniger vermarkten..
eine gebogene cpu erzeugt aber keinen hausbrand
Das Problem ist bekannt, liegt am neuen Treiber.
Wenn man schon in einem Hardwarethema politisch wird und ablästert, sollte man wenigstens nicht selbst Blödsinn reden.
Behörden, teils mit Handlungszwang, mit Abgeordneten des Bundestages gleich zu setzen, ist einfach Quatsch. Das sind ganz andere Ebenen.
Davon mal ab, Kongressabgeordnete in USA haben bezüglich der Existenz der 4090 wohl keine bessere Kenntnis.
Jain: AMD stellt die Karten zwar am 03.11.22 vor, aber die Karten selber und somit Testberichte/Reviews kommen erst Anfang Dezember:
Na ja God of War kommt am 9 November bis ich das durch habe ist auch schon Ende November 😂 da kommt es auf eine Woche mehr oder weniger nicht an und vielleicht hat sich absolut verrückte Situation um die die 4090 dann auch gelegt weil auch noch die 4080 an den Start geht!
Und es sind zumindest UVP Preise und Verfügbarkeit gegeben wo man beim Bestellen nicht gleich einen Herzklabaster bekommt.
Glaub ich nicht. Du wirst immer mal wieder schauen und wenn es ein Modell gibt zuschlagen :)
Kann ihn schon verstehen, mir gehts genauso. Ich stehe auch vor Neuanschaffung und möchte eine 4090, aber habe keine Lust und Zeit für dieses Drop-Camping à la PS5.
Abgesehen davon, dass aktuell die Kabel/Adaptersuche und Ungewissheit die Vorfreude etwas trübt.
Ich verstehe ihn auch. Ich glaube nur nicht das er das durchhält. Er möchte ja eigentlich eine 4090.
Kann ich nachvollziehen. Darauf hätte ich auch keine Lust. Wenn ich nicht meine Inno3d zufällig entdeckt hätte und die fast 2 Stunden Verfügbar war bei CU und auch noch den zufällig den Block gefunden hätte, würde ich noch auf der 3090 sein. Ich kann bei diesen Drop Geschichten auch nicht mithalten.
neues 12vhpwr kabel eingebaut, das alte mal fotografiert:
sieht noch gut aus...
aber ich würde mal sagen richtig die 550+ Watt ausgereizt habe ich nur die ersten 2-3 Tage, seit ca. 4 Tagen habe ich die Karte gedrosselt aus Angst.-.
und ja das amazon kabel ist viel besser. lässt sich leicht biegen und passt gut ins Gehäuse; jetzt kann man mit gutem Gewissen auf den 90° Cablemod adapter warten :d
die auslastung ist ja nicht das problem. sofern der adapter intakt ist, passiert nix. sonst hätte ja jeder das problem nach wenigen stunden. :)
ein verlängerungskabel hilft ja nicht wirklich :d
wollte es der Vollständigkeit halber aber gesagt haben, und bei 70 - 150W dass ich die letzten Tage gefahren habe bin ich mir da nicht so sicher..
Aber genau da fängt doch schon das Problem an. Bisher hat man Stecker verbunden und fertig. Die meisten Wissen das doch nicht mal. Gleichzeitig sind die Karten so groß und die Grafikkarten so ausgerichtet, dass man nur extrem wenig Platz an der Seite bei sehr vielen Gehäusen hat. Man hat also einen PC, eine neue 4090 und wird diese auch anschließen wollen. Auch von Nvidia gibt es ja keine Angabe, wie breit das Gehäuse incl. einem nicht geknickten Kabel sein muss.
- Performance der 4090 sehr gut
- Lüfter für normale Leute überdimensioniert
- viel Coil Whining
- viele billige Lüfter
- Adapter Chaos
- gefühlt sind die meisten 4090 irgendwo bei DHL, entweder zum Kunden oder wieder zum Händler
Hätten die TDP auf 350 Watt setzen sollen, 2 normale Stromanschlüsse benutzen, Kühler kleiner und hochwertiger verbauen und dann die Grafikkarte 100€ günstiger anbieten sollen.
Ähnliche Themen
