[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich sehe da grundsätzlich ein riesiges Thema. Nicht zwingend ein Problem, aber etwas was man ansprechen kann.
1) Warum ist der Stromstecker nicht an der kurzen Seite gegenüber der Slotblende wie bei der 2060 FE?
2) Warum gibts so ne Adapter-Katastrophe und nicht was schickes wie EVGA Powerlink?
3) Warum ist die Buchse nicht 45° gedreht wie bei der 3090?
Am Ende hat es alles mit dem PCB und mit dem gewünschten Design zu tun... Ich bin mal gespannt ob es von den ganzen 4090ern v2 Updates geben wird, die einfach funktionieren.
Also bei teilweise 34cm langen Karten hinten an der kurzen Seite nen Kabel klappt wohl nur in einem großen Caselabs.
Beste Lösung eäre wirklich angewinkelt wie bei der 3090 FE.
Bis wir 90 Grad Adapter sehen, dauerts noch.
Ich hatte mit der 4090 Windforce schon so meine Probleme die rein zu bekommen. Tür zu mir Adapter nur wenn ich den hart hart biege.
nur schade, dass man das Seasonic Kabel nicht einfach so im Handel bekommt? :unsure:
Der freistehende Anschluss bzw. das Kunstoffgehäuse der 3090 FE war allerdings auch eine wackelige Angelegenheit, zumindest bei meiner damaligen Karte.
Weil sonst noch weniger Leute die Karten in ihr Gehäuse bekommen :d
ja sowas in der Art währe wirklich besser gewesen also so ein Hardplastik Adapter zum draufstecken ohne Kabel .. also einfach son Hardplastik Teil was man auf die Karte steckt und da dann seine Normalen
8 Pin Kabel reinstecken da weiss man zumindest das man die eigenen 8 Pin Kabel knicken kann da sie ja schon geknickt wurden im vorfeld vom Nutzer ( sofern es nun kein neues Netzteil is )
Gute Frage .. hatte Jay ja in einem seiner Videos auch schonmal angesprochen auch warum nich hinten an der Karte der Stromanschluss is wie bei den EVGA Karten damals.
Aber da würde es ja dann in manchen Gehäusen zu Probs kommen die es ja auch jetzt so schon gibt.
Es wird jedenfalls teils schwer für Nvidia werden das vertrauen der Kunden in die beigelegten Adapter wiederzugewinnen und bin nun gespannt wie Nvidia nun weiter machen wird.
Und der AMD Launch rückt auch immer näher
Installiert man einfach beide Dateien nacheinander? Da gibts ja für die Sup. X einmal eine gaming und eine silent.exe
Bios switch.
Eins auf dem Silent für Siltent installieren und game zu game.
Um das BIOS zu switchen runter fahren den Schieber betätigen und hoch fahren.
Bei mir ist der Adapter hin, nur eingebaut nichts besonders gebogen da seitenteil offen, alles startet aber kein Bild, wenn ich am Adapter wackel gehts irgendwann, aber bei 2000€+ ist das doch ein Risiko was ich nicht unbedingt eingehen möchte schon sehr ärgerlich.
Hast Du den Adapter ausgesteckt und visuell begutachtet? Hitzeschaden?
Welche Version hast du? Siehe hier:
Hat hier eigentlich irgendjemand das 600 Watt Bios von der Liquid auf die Suprim X geflashed?
Wo hat den das Liquid Bios 600 Watt?
Frage an die 4090 FE und ehemals 3090/3080 FE Nutzer, die die alte Karte per RGB angesteuert haben.
Ich stelle fest, dass die 4090 FE keine RGB Steuerung mehr zulässt (taucht in meiner Software (MSI Center) gar nicht als steuerbares Gerät auf). "Kann" die neue Karte kein RGB?
Zotac Amp Extreme Airo 4x 8Pin (300v)
nichts geschmort scheint wohl irgendwas beim Löten schief gegangen zu sein
Es leuchtet nur der Geforce-Schriftzug an der Seite...gesteuert habe ich die allerdings noch nie. Soweit ich weiß kann die auch kein RGB...
Bei den 30er Karten konnte man die Leds am Lüfter farblich steuern, keine Ahnung ob die neue 4090 da auch Leds hat
kein optischer schaden Kabel sieht eigentlich gut aus, aber mit einem anderen von einem Kollegen ging es dann.
Das wäre gutes Material für eine neue News. Sowas wie "WTF!!!??? Nvidia Kabel wohl auch ohne sichtbaren Fehler defekt". Da würden einige schon viel dazu sagen wollen denke ich.
du liest wohl deine eigenen Threads nicht? :d
probier mal das tool von evga https://www.evga.com/precisionx1/ .zumindest 3000 fe karten gingen damit
Ja, die 600Watt sind da. Aber die Lüftersteuerung ist im Arsch. Beide Lüfter drehen auch unterschiedlich schnell. Wahrscheinlich sollte der eine Port die Pumpe ansteuern.
Das Strix Bios ist bezüglich der Lüftersteuerung auch nicht zu empfehlen. Grundsätzlich geht das, aber eigentlich halt Sinnfrei alles. (Ausgabegerät war per HDMI angeschlossen)
Scheint mindestens drei Kombinationen zu geben
150V 4 solder pad (Igor's)
300V 4 solder pad
300V 2 solder joined (GN's)
Mit dem Afterburner eine Lüfterkurve manuell erstellen und drauf zugreifen geht das oder kann man generell dann nicht zugreifen?
Sorry, aber wo von sprichst Du, weder hat meine 3090FE ein Kunstoffgehäuse, noch wackelt der Stecker, der sitzt bombenfest drinnen.
Genau, damit lies sich der Schriftzug an der Seite Dimmen und oben auf der Karte war ganz dezent ein RGB Streifen angebracht.
Die 3090Fe hat einen RGB Streifen?
Ähnliche Themen
Antworten
6K
Aufrufe
312K
