[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Meiner liegt seit gestern auf'n Tisch. Hatte noch keine Zeit aber bin sehr gespannt auf New World, Star Citizen und alle andere CPU limitierten Games.
Star Citizen wird Dich enttäuschen.
Es ist weiterhin eine üble Streaming-Ruckelorgie. Da müssen wir eventuell auf das Gen12-Update warten, das ja irgendwann im Dezember kommen soll, und dass die ihre Serven in den Griff bekommen. Trotzdem viel Spaß damit^^
nvidia-smi.exe -q -d power
  • Danke
Reaktionen: SH
Hat hier jemand aktuell seinen 5950x oder 5900x mit einem 5800x3d getauscht? Macht es sinn. Google seit tagen und finde immer unterschiedliche aussagen.
Ich...baue den aber erst ein, nachdem die 4090FE hier ist. Also Dienstag oder Mittwoch. Und ja habe eine weitere gekauft...hoffe die kommt mal an...
Ich habe hier eine TUF die nicht fiept. 2 Arbeitskollegen haben die Strix gekauft und auch keine fieoen oder sonstiges. Aber auch bekannt mit inno3d und gainward sind recht zufrieden.
Bitte hör auf zu lügen, genau das führt dazu dass Leute diese Karten kaufen und wieder retournieren, weil sie glauben dass es diese Karten auch fiepfrei gibt. Es gibt sie nicht Fiepfrei, alle Karten mit den niedrigen Spulen fiepen, dafür sind die niedrigen Spulen besser für hohes Powerlimit. Nur bei den hohen Spulen ist das fiepen weniger/kaum vorhanden, dafür vertragen die kein hohes Powerlimit, zumindest nicht so gut. Das erklärt auch warum karten alla inno kein höheres Powerlimit haben als die 450 Watt, diese haben die hohen Spulen. Du kannst dir also aussuchen, hohe Spulen, leise Karte, dafür niedigeres Powertarget, oder niedrigen Spulen, laute Karte, hohes Powerlimit ;)
Ja die Ruckelorgie wird leider nicht verschwinden aber die 30-40fps in Orision evtl. etwas pushen. Im Endeffekt hast du schon Recht, viel erwarten darf ich nicht, dennoch bin ich gespannt was überhaupt damit mehr geht. Kann ja auch gut passieren, dass ich wie andere hier garnix bemerke :eek: aber ich spiele auch oft genug noch gewisse Games in 1080p.
Die Frostbite fiept minimal ab ca. 110 FPS. Mit geschlossenem Gehäuse aber nicht zu hören.
Mit geschlossenem Gehäuse hörbar ab ca. 160 FPS. Karte schafft 3090 mhz in Superposition. Speicher gerade schon mir +1500 gestestet. Geht auch. Bin zufrieden.
Die Karte wird dann undervoltet und dann läuft sie schön effizient :)
Das die hohen Spulen keine hohen Leistung vertragen muß ein Gerücht sein um den flachen Klapperschlangen was positives zuzusprechen. -> HOF
Die Karte möchtest du dann behalten ?
Hätte eher gedacht nimmst dann eher ne Strix und baust auf Wasser um .
Genau. Meine beste Karte von allen getesteten ist die Liquid Suprim X. Die macht 3150 mhz in SpeedWay und knapp 3200mhz in Superposition unter Luft. Dazu noch +1900 Speicher. Die kommt morgen auf den Marktplatz.
Weniger Bend ging nicht :heul:
Aber keine Lust gehabt das Gehäuse jetzt offen zu lassen bis das Seasonic Kabel kommt. Wenn was abraucht bis das Seasonic Kabel kommt lasse ich es euch wissen :fresse2:
Fun Fact: Seit die 4090 FE drin ist wird beim Booten statt dem ASUS Logo das normale Windows Logo angezeigt. Die Funktion "Full Screen Logo" hat keinerlei Effekt. Hatte das sonst noch jemand?
Ja …
Und ich könnte schwören das ging vor ein paar Tagen mal … aber es scheint ein Bug in der Firmware zu sein. Betrifft nur die FE.
Es gibt eine Beta Firmware von Nvidia die das Problem löst. Ist aber nicht offiziell @UdoG hat’s gefunden. Beim Z690 Dark hast du gar kein Bild erst in Windows. Leider ist Nvidia wohl gegen das verteilen der Firmware. So das dies wohl besser über PM geschehen muss.
Dachte erst meine FE ist kaputt ;-)
So die Frostbite ist nun eingebaut. Ich bin gespannt :)
Schön kompakt, für so viel Power.
Wie viel Hz hat denn dein Monitor?
Empfehlung. FPS Limit über RTSS minus 3-4 FPS.
Die Overclocking Limits der Frostbite hast du ja schon rausgefunden. Mit 3 GHz und RAM +1500 wäre ich auch zufrieden. Power Limit auf 75-80% und fertig ist die Laube. Die nächsten zwei Jahre musst du dir zum Thema Grafikkarte keine Gedanken mehr machen ;)
Undervolting kannst du probieren, aber ich bin der Überzeugung daß eine Reduzierung des Power Limit bei Ada besser funktioniert.
Es gibt diese Karten fiepfrei. Bitte aufhören dir völlig fremden Geschichten zu unterstellen. Danke
Kleiner Nachtrag bzgl. Verständlichkeit: Das Grafikkarten generell fiepen steht hier komplett außer Frage. Jeder weis das und es ist kein Geheimnis. Die große Frage ist wann die Karten damit anfangen. Ich rede hier von alltäglichen Nutzungsbereichen. Wenn man in Menüs ist oder mal anders über 400 FPS hat, kann das komplett anders aussehen. Aber das ist halt auch zu vernachlässigen. Da man in solchen Bereichen nicht oft und ständig agiert. meine Karte hat bisher bis 300 FPS keinen Ton von sich gegeben, darüber habe ich es nicht getestet. Im Alltag ist die ruhig. Schlimm wird es, wenn die Karte schon bei 70 oder 80 FPS anfängt zu pfeifen.
Alle die hier eine RTX 4090 am laufen haben, mit welchen Netzteil hab ihr eure RTX 4090 am laufen? Und läuft alles in Ordnung mit den 12VHPWR Kabel ohne anbrennen etc.?
Seasonic Focus px 850w. Ja läuft. Ich glaube auch nicht dass die bis das problem sind sondern die ganze Konstruktion dieses Anschlusses. Sowohl Stecker als auch Anschluss seitig.
Das muss man m.E. selbst testen und für sich das beste rausfiltern. Hier gibt es viele die sagen UV ist besser. Ich habe im Arbeits / Bekanntenkreis ein paar 4090 Besitzer. Gibt komplett unterschiedliche Meinungen dazu. Bei mir ist UV besser als PT senken. Bei anderen ist PT der Mittel zum Erfolg.
Viele Wege führen nach Rom. Kann ja jeder der interessiert ist selber ausprobieren. Am Ende kommt dabei raus das die Karten so grob um 350 Watt sehr gut laufen ;)
Dachte da jetzt an cpu limitierte spiele wo man keine 120fps erreicht. Spiderman, farcry z.b. oder plague of requiem markplatzszene. Und wie sieht es nit low fps aus? Weniger einbrüche?
Also ich kann nur vom Wechsel am Freitag vom 5700x zum X3D berichten.
Bei Kingdom Come Deliverance hats schon was gebracht in 4K auf Sehr hoch. Von ca. 90-100 FPS auf 120-130FPS. Die lows sind auch wesentlich besser. Bei AC Valhalla bei den avg FPS kaum was gemerkt, die lows sahen etwas besser aus. TimeSpy normal auch nur leichte Verbesserung bei den CPU Punkten.
Aber da du ja mit dem 5900x auch produktiv unterwegs bist, würd ichs lassen. In meinem Sys 2 ist der auch drin und da werd ich ihn nicht wechseln.
So ist es wohl. ich habe sogar schon von den Kollegen gehört das ~250 Watt gut laufen. Sofern jeder zufrieden ist, ist doch alles super. Mit der 4090 wird m. E. jeder Wunsch bedient.
Habe 2 videos dazu gemacht und die vor bzw nachteile der jeweiligen methode dargestellt.
Corsair Rm750x und Nvidia-Adapter. Läuft.
Gleiches Netzteil. Zotac 4090 mit 3x Adapter und 80% Powertarget. Bisher ohne Probleme. Trotzdem ist mir bei dem ganzen Drama etwas mulmig und ich traue mich noch nicht, die 3080 TI zu verscherbeln, die schön weiter im Wert fällt :rolleyes2:
Hatte eine gaming oc gigabyte und die war wirklich lautlos
Neuer Tag neuer Power Adapter Verschmorungs Fall ... nun Nr 25
Auch pcgh dazu nochmal mit einem neuen Artikel:
Scheinbar ist es egal, ob Adapter, Verlängerung oder natives 12VHPWR-Kabel.
Nvidia hätte einen Temperatursensor am Stecker verbauen sollen.
Oder nen richtigen Anschluss und nicht so ein fuddelding
Bitte mal kurz für Doofe: habe ein Asus ROG Thor 1000W Platinum 2 hier liegen. Noch komplett eingeschweißt, könnte also wirklich ohne Drama noch zurück.
Hat das Ding jetzt den KORREKTEN 12VHPWR Anschluss, oder nicht? Mir ist klar, dass es auf einer Seite 2x 8 Pin ist und bei 450W schluss ist. Aber die 12VHPWR Seite, passt die jetzt an die 4090 oder nicht?
Warum frage ich jetzt so blöd? Wenns nicht passt, mache ich natürlich nicht einmal die Folie ab und so entsteht bis auf den unsinnigen hin und her Transport kein Schaden. Ich möchte halt verhindern dass ich alles aufreisse und dann bringt es mir nix.
Denn: heute kommt mein neues Gehäuse und dann will ich an den Umbau gehen. Kann auch das alte Netzteil nutzen, wollte halt ohne klobigen Adapter auskommen.
Ähnliche Themen
