[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Da hat vermutlich einer von gestern abgebrochen und es gab nur die eine Karte 😂
Kann mir jemand knapp erklären, wie ich aus dem Verfügbarkeits thread nen rss feed mache bzw. wie ihr es überwacht.
Nutzt ihr jetzt aktuell die mitgelieferten Stromkabel für eure 4090er oder habt ihr euch andere besorgt?
Ich nutze bisher ohne Probleme den mitgelieferten Adapter. Ich habe Ihn auch mal zwischenzeitlich zur Kontrolle abgemacht (nutze die Karte seit dem ersten Tag). Ich habe dennoch die Alternative von Cablemod (https://store.cablemod.com/product/...ed-12vhpwr-pci-e-cable-for-asus-and-seasonic/) für mein Seasonic bestellt (3x8 auf 1x16), werde aber im Dezember hoffentlich auf nativ ATX 3.0 von Seasonic gehen (https://seasonic.com/news/post/sea-sonic-to-launch-new-vertex/).
Mal eine frage an die Experten hier (ernst gemeint, kenne mich da null aus):
Gibt es einen wirklichen Unterschied zwischen der ASUS 4090 TUF und der selbigen als OC ?
Also könnte man die nonOC nicht einfach händisch über Afterburner auf die selben Werte stellen, wie die OC und man hätte die selbe Karte oder gibt es dort von der Fabrikation unterschiede?
Sorry, falls das eine dumme Frage ist
Ganz genau. 3 Sekunden Arbeit um paar hundert Euro zu sparen :)
Die oc ist ca 300 Euro teurer und wohl gleich schnell
Ich hatte schon eine tuf und msi trio für 1949 aber die waren greischend laut und gingen zurück
Korrekt
OC Versionen sind bei allen 4090 Karten Abzocke. Es ist möglich das non OC Karten Out of the Box höher Takten als OC Karten. Wenn man die non OC für günstiger bekommen kann, sollte man ganz klar diese Version bevorzugen.
Also mit dem nativen Corsair Kabel sieht es so aus bei meiner TUF
Der Anschluss an meiner TUF (und wahrscheinlich auch Strixx) ist ja doch wesentlich anders, abgesehen davon, dass er upside down ist:
https://imgur.com/a/Q7novb9 (mit be quiet adapter)
https://i.imgur.com/jGmPraR.jpeg (mit NV adapter)
Der Adapter sollte doch eigentlich bündig an den Seiten abschließen, so wie hier:
Was zum Geier.
Der NV Adapter hat bei dir einen kleinen Spalt.
Also ich bin mir eigentlich fast sicher, dass meiner bündig abschließt, aber mein PCB sieht um den Anschluss irgendwie auch anders aus oder Bild ich mir das ein (Edit: ne passt, sind identisch :d)? Hab grad kein anderes Bild :d
Dann wirds von der Seite wohl auch nicht bündig sein :>
Hardware gleich. Im bios steht oc und der takt ist leicht höher. Das wars.
Die Gigabyte Gaming OC traktet stock schon VIEL zu hoch für meinen Geschmack mit über 2700Mhz. Total unnötig und alles andere als effizient. Reduziere das PL künftig wohl
Schade, dass man dieses Kabel wohl nur an Corsair Netzteilen verwenden darf oder?
Im Moment funktioniert es bei mir auch mit dem beigefügten Adapter an meinem Seasonic PX 1300 Watt Platinum Netzteil aber würde gerne ein 180 Grad Adapter schnellstmöglich haben wollen oder eben ein vernünftiges 12VHPWR zu 8pin Kabel, was man ohne bedenken stärker beugen kann.
Sieht bei dir ebenfalls nicht richtig aus. Der schließt nicht bündig an den Seiten ab. Wahrscheinlich hast du ebenfalls einen klitzekleinen Spalt oben und bei den Sense-pins.
Das ist nicht mein Bild.
Ich hoffe dein Avatar ist kein schlechtes Omen.
Ich bin guter Dinge. Habe zwischen der Seitenscheibe und Kabel auf jedenfall noch etwas Luft .
Dazu habe ich nach paar Stunden zocken mal den Stecker und Kabel angefasst und empfand ich als warm , aber nicht heiß.
Bei mir rastet der Anschluss jedenfalls ein .
schon schade das des ding nur 1x Anschluss hat. ist mann in 2 jahren ja wieder ein neues nt am kaufen #:)
Du meinst du brauchst 2x 16 Pin für die nächste Graka? Also über 675W TDP? Da glaube ich weniger dran. Der eine 16 Pin reicht für die nächsten Jahre locker aus, selbst fürs Topmodell
An die User, bei denen im Asus Shop die Bestellung nicht ganz abgeschlossen werden konnte (Fehler nach Bezahlung über Paypal):
Einfach mal schauen, ob im Nutzerkonto diese Bestellung als Offen geführt wird. Da gibts dann einen Button in der Art "Zahlungsmethode ändern".
Dort kann man dann die Paypal-Bezahlung erneut ausführen.
Danach ging meine Bestellung von "Offen" auf "Eingegangen".
Ist ca. 2 Minuten später gewesen (beim Drop gestern abend).
Heute ging sie dann auch erfreulicherweise auf "Versandt".
Das schreib ich mir mal in meinem kalender :) in 2 jahren lesen wir uns wieder ^^
PS. Geht auch schon diese Gen :) Siehe HOF 4090 ^^
Ähnliche Themen
Antworten
6K
Aufrufe
396K
