[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Kann mal jemand mit Lukü testen was bei dabei an Temperatur raus kommt?
Stock Lüfterkurve (ohne "Fenstermod" oder ähnliches, einfach daily usage)
Bisschen OC (sodass in Furmark mit den Settings ca. 2750 MHz anliegen und +1000 RAM)
133% PT
Ca. 520-550W verbrauch
Furmark 4k Preset
Besserer Block wäre gut. Wenn´s nur Welche gäbe... :rolleyes2:
Gibt es irgendwo einen Vergleich zw. Byksky und EK (PBP und ABP)?
Wenn man nicht vor hat die Karte auf Wasser umzubauen kann man das gesparte Geld in ein paar Packungen Oropax investieren, die wird man nämlich mit der Karte brauchen :fresse2:
Ist die bekannt laut zu sein? Hab mich mal auf Reddit und bei generellen Reviews umgeguckt und da scheint die generell eigtl gut weg zu kommen.
Zu den neuen Karten nicht bei der 3000ner Serie war Byksi und EK zumindest ehr Schlusslicht bei der Leistung.
Und wie gesagt bei über 500 W würde ich auch auf Liquid setzen!
Meisten fahren solche Geschütze wie Mora auf und gehen dann mit Sonnencreme bei :fresse2:
Meine Karte war annehmbar bis absolut grausam was das Lüftergeräusch angeht, je nach Lüftergeschwindigkeit.
Ist glaub ich das 4. mal das ich es poste.
133% PT
Furmark 4k Preset
Aus dem laufenden Furmark-Betrieb heraus
1920x1080 ohne AA
Mit 4K habe ich 74°C (~550W)
Ok danke. Ja einige Sachen gehen doch gerne mal verloren hier :d Bis zum 49% RPM Geräusch klingt das ja eigentlich echt ok.
Lüfter sind mir egal, hatte die Karte unter Last Spulenfiepen?
Die Karte ist laut 3 verschiedenen Test 1DB leiser als die 4090 FE :) Mit undervolting wird man keinen Unterschied merken zu den anderen Customs. 1790 Euro ist ein Top Preis.
Ein anderer Block und auch Liquid wird nichts groß ändern an diesem Verhalten von Ada, aber gut - testen, wundern - dann akzeptieren, also wenn der Wille da ist!
133% PT
Furmark 4k Preset
Morgen bekomme ich eine SuprimX, die soll ja mit das Beste an Kühlsystem haben neben der Strix. Kann ich dann mal testen.
Beste Grüße
Dafür, dass der 3090-Byksky so "schlecht" war, hatte ich ganz gute Temperaturen
Nu ja das war klar das das kein Spaziergang bei bis zu 600W wird.
Von daher würde ich ehr auf so etwas wie Aquacomputer oder Watercool und inzwischen Alphacool setzen EK halt wen es um Optik geht Byksi sehe ich ganz weit hinten .
Aber wen man ehrlich ist wer will hier 24/7 1,1V mit 3000mhz+ fahren !
Dann weißte halt das noch besser gegangen wäre.
Nu ja eigentlich wen man ein gutes Case hat wo man die Warme Luft schnell raus bekommt Brauch es bei ein Paar Karten eigentlich keinen Wasserkühler mehr!
Darum schau ich auf die Strix und die Suprim!
Leider nicht zu bekommen bis her.
Auch schon ausverkauft jetzt. War ein Schnapper.
42% war fast genau so schlimm wie 52% IRL. Das Mirko meines A52s ist nur nicht sensibel genug um es in einem YT video rüberzubringen.
Wenn meine Phantom welches hatte wurde es komplett vom Lüftergeräusch übertönt.
Das belegt nur das die Dezibel Nummer nicht alles ist.
Für mich war der Ton den die Phantom Lüfter erzeugen 10x aufdringlicher und nerftötender als der Ton den die Lüfter meiner FE erzeugen bei selber Lautstärke.
Nö, aber die Quintessenz aus vielen vielen Foreneinträgen in der Recherche weltweit, ist ja nicht so, dass ich mich nicht gewundert hätte als der Block drauf war - aber für das Verhalten gibt es eben schlicht einen Grund und das ist der TSMC Fertigungs-Node für Ada. Ich muss mal schauen, ob ich das noch wiederfinde, hatte zwei oder drei Einträge in einem Chinaforum, die es mit Flüssigmetall probiert hatten, wo es kaum etwas gebracht hat gegenüber Pampe. ;)
Hatte mit meiner 3090 mit XOC bios bei 560watt auch 60-63C° Mora 420 finde klar war der unterschied halt größer zur luftkühlung vorallem die diferenz des hotspot zur normal temperatur noch mal 7C° weniger als bei luft.
Kann ich so nicht unterschreiben ich hab das gelesen das das Problem viele hatte mit Lüfter Brummen aber meine GS die ich mal kurz da hatte war sehr leise ohne Spulenfiepen und kein Lüfter Brummen
Promocode geht auch mit einigen 4080..
Paranormal Tales 😍
Naja bei Asus und MSI brauchst du selbst nach dem Umbau auf Wasser Oropax 😂.
Dein Video klingt aber auch schon echt heftig. Meine Phantom ist nur zu einem Bruchteil so laut wie es bei dir auf dem Video rüber kommt.
Komischerweise findet man zur Palit Gamerock 4090 und auch zu den beiden 4080 Karten von Palit zur Lüfterproblematik eher wenig, die haben ja die gleichen Lüfter.
Will jetzt nicht sagen, dass die Lüfter komplett unhörbar sind. Die Motoren der Lüfter sind schon leicht wahrnehmbar, aber das Spulenfiepen der Asus und MSI Karten ist definitiv um einiges nerviger. Davon hat die Phantom so gut wie nichts.
Meine 2 Tufs fiepsen nicht. Ich höre in meinem Silentgehäuse nur den Lüfter von 0 auf 1000 anlaufen...
das neue cablemod kabel ist nun unterwegs. per fedex
sollte bei den anderen die das problem auch hatten, genauso sein
Ähnliche Themen
Antworten
6K
Aufrufe
396K
