[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Die müssten doch auch die Nvidia Referenz Platine haben. Und dort geht mehr als 450 Watt?
Nö, aber die Quintessenz aus vielen vielen Foreneinträgen in der Recherche weltweit, ist ja nicht so, dass ich mich nicht gewundert hätte als der Block drauf war - aber für das Verhalten gibt es eben schlicht einen Grund und das ist der TSMC Fertigungs-Node für Ada. Ich muss mal schauen, ob ich das noch wiederfinde, hatte zwei oder drei Einträge in einem Chinaforum, die es mit Flüssigmetall probiert hatten, wo es kaum etwas gebracht hat gegenüber Pampe. ;)
Mit immer kleinen Fertigungsstrukturen wird es auch zusehend schwieriger zu kühlen. Bei den aktuellen CPUs ist 80-90°C fast schon Standard. Was mich ja mal total abeschreckt.
Ich kann das ein Stück weit mit sehr kühlem Wasser kompensieren, aber das Delta wird wohl immer größer werden.
Schade, da schaut man einen Nachmittag nicht rein dann gibt's ne günstige 4090. Der Promocode geht nur bis zum 01.12. seh ich das richtig?
Wohl bis Donnerstag Abend laut dem Tweet. Vllt lohnt sich immer mal wieder reinzugucken, die 4090 Phantom war zwischendurch durchaus nochmal verfügbar.
Scheint es mir nur so oder sinken Preise und Nachfrage? Eigentlich müsste man bei NBB eine 4080 kaufen, benutzen und Ende Januar zurück senden. Glaube dass die Karten durch die Bank günstiger bis dahin sind.
die 4080 ist ans sich eine gute karte aber preislich nicht sinnvoll platziert da die leute, die über 1400 euro für eine gpu ausgeben gleich zur 4090 greifen, besonders bei dem leistungsunterschied.
der rest kauf unter 1000 euro, deutlich
das geht so schnell :d
Scheint ja ordentlich was los zu sein bei CableMod...
IMPORTANT NOTICE TO OUR CUSTOMERS
To Our Lovely Customers,
Over the past few weeks, the overwhelming support from the community has been absolutely staggering. Our entire team has been pulling some long hours in or to fulfill the orders that have come in.
Having said that, we have had to make the tough decision to begin limiting PSU cable orders to single cables only in order to fulfill currently backlog orders in a more timely manner. Starting from today, customers will only be able to add a single PSU cable to their order. Due to the amount of logistics required, we will be unable to combine multiple orders into single shipments.
Please note that this only affects PSU cables - keyboard cables, charging cables, and controller cables are handled by a separate production team, and are affected by this limitation. We're sorry for any inconvenience caused, but we feel this is the fairest solution for people that have been waiting for their cable orders to ship.
If you're looking for a simple 12VHPWR cable, we will have a number of unsleeved CableMod Basics 12VHPWR cables ready to ship by this Friday (Dec 2). You check them out here:
https://store.cablemod.com/cablemod-basics-12vhpwr-cables/
For those that still need multiple cables to complete their builds, we are also implementing a waiting list system. By signing up at the link below, you will be added to the queue for production slots once they are made available. Once your slot if available, you will receive an email and you will have 24 hours to place your order. If your order is not received during this 24 window, your slot will be given to the next customer in the queue.
Signing up is completely free, and there is no obligation to make a purchase once your slot is made available. However, if you miss your 24 hour purchase window, you will need to sign up again in order to be placed in the queue.
Waitlist Signup here
If you urgently require multiple cables for a build, may we suggest looking on vendors such as Amazon, where many of our premade cable kits can be found.
As always, thank you for being a CableMod customer, and for your patience during this time.
Sincerely,
The CableMod Team
Ausgehend von 100% Powerlimit, also 450 Watt, wird das Delta Wasser zu GPU wie bei allen anderen auch so grob um die 20°C liegen.
Ob Strix oder Zotac spielt doch keine Rolle. Weder in der Perfomance noch in der Kühlung.
Kann ich bestätigen, Delta liegt bei mir bei 450W ,2860MHz Boost, bei etwa 20°C, im UV komme ich auf ein Delta von etwa 18°C mit nem Bykski Block. Selbst wenn ich die Karte voll aufdrehe, bleibe ich bei 20°C Delta.
Jo, und bei mir sinds 30-33°C Delta...
Entweder bin ich dann zwei mal zu doof, den Block zu montieren oder er hat sonst nen Fehler...
Seis drum, wie @IronAge schon sagte, wer billig kauft, kauft zwei mal...
Wieso billig? Ich hatte auf meiner 3080 nen Bykski Block der gut gefunzt hat und dieser macht auch seinen Job. Kann natürlich sein, dass deiner fehlerhaft ist, kann dir aber bei jedem Hersteller passieren. Im Overclocker Forum meine ich war das, da ist einer da passen 1 - 2 Gewinde nicht mittig auf die Löcher der Karte, Phanteks Block. Und einer hatte bei einer Schraube gar keinen Abstandshalter mit Gewinde, musste einen von nem anderen Block montieren. Corsair hatte bei der letztzen Gen Probleme mit Wasseraustritt am Anschlussterminal. Mich stört eigentlich nur die Optik des Bykski-Blocks, gerade bei der 4090 weil die so breit ist und ich vertikal montieren musste. Ich überlege einen von EKWB zu ordern, mag die Optik, aber der Preis ist einfach etwas zu hoch. Vielleicht warte ich auch bis Alphacool den Block bringt. Der Granzon Block ist mega, aber mit 350€ auch mega teuer... und vom EKWB mit aktiver Backplate will ich garnicht reden, 399€ 🥴
Nein, Kühlwunder erwarte ich von keinem der anderen Blöcke, bei mir dreht es sich nur um die Optik, aber ich glaube ich bleibe einfach beim Bykski Block, da investiere ich die Kohle doch lieber in nen Mo-Ra.
4090 Strix und Bykski Kühler?
So teile mir bitte die Links mit...
Kannst du mal bitte nen TSE-Bench mit max. möglichem Takt machen? Danke... ;)
Hab auch eine "Strix OC", aber keine Echte :d
Hast du Pads nachgepresst?
Hoffe, das sind keine aus Silikon. Dann geht das nämlich nicht
Beim 3090-Byksky waren es welche aus Silikon
Oder aber du hast ein starkes, positives Offset (was ich aber nicht glaube)
Bei der 3090 Strix war es jedenfalls stark negativ (GPU-Temp war 5K unter Wasser-Temp @idle)
Dann sind wir schon zu zweit, die zu doof sind :)
Ich hab jetzt mal die Supersoft Pads bestellt und werde die Karte ein drittes Mal demontieren. Mal sehen, ob es was bringt, diese Pads für die VRAMS zu verwenden. Man kann die Karte so ja locker verwenden, aber wozu WaKü wenn sie fast so heißt ist wie unter Luft...
Hier gab es Leute die berichtet haben , dass die 10 Kelvin Delta haben^^
Gerade die Gaming OC verfügbar bei LDLC
  • Danke
Reaktionen: hwk
Ähnliche Themen
