[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Man weiß ja noch garnicht was alles so noch kommt in bezug auf Mainboards etc.
Der 24 Pin sollte ja auch mal abgelöst werden.
Würde auch nicht einfach fix das NT tauschen, wenn das alte noch genug Leistung hat und noch nicht sooo alt ist.
Der 4-Pol-Molex auch bitte... :)
Der ist wirklich nicht mehr zeitgemäß :fresse:
(65MB -5,25"-HDD von 1988)
pict0375xnq-jpg.1165569
GPU Temp unter Last 60-65 °C bei 520W und 33°C Wasser...
Hab den Kühler jetzt nochmal neu montiert, aber auch da keine Änderung...
Mora 360 LT + Airplex Modularity 360...
Das ist schon echt schwach...
Montage war sehr einfach, aber aber das ist auch alles postitive an dem Block...
Vollkommen normale Temp für Ada, die wird auch mit einem anderen Block nicht anders ausfallen, meine sind auch nicht anders, habe auch den Bykski auf der TUF. Leider wird hier der Fehler gemacht und mit Turing/Ampere Temps verglichen, was man schlicht nicht mehr kann unter Wasser, erstens viel kleineres Fertigungsverfahren, Cuda Cores ohne Ende, die RT- und Tensoreinheiten heizen heftig, wie gesagt, normale Temp mit Block bei den Watt und Wassertemp, da ist nichts schwach, lediglich die persönliche Erwartung muss den geänderten Umständen der Fertigung usw. angepasst werden.
Nvidia hat hier also einen Chip geliefert, der mit Wasser gar nicht so gut gekühlt werden kann wie mit Luft?
^^Hm, bei 450 - 600 Watt war die Temp bei meiner TUF der GPU mit dem Luftkühler für mich persönlich ne Zumutung auf Dauer, wenn die Lüfter zu langsam liefen. Darüber hinaus war die Hitze im Case einfach schrecklich, ist alles weg mit dem Block, alles hat sich extrem aufgeheizt, der RAM auf dem Board, die PCH Temp, VRM Temp auch. Klar, bei 350 Watt rum macht der Luftkühler einen sehr guten Job auf der TUF, bei 450 Watt und höher ging es dann aber auch schnell Richtung 80 Grad, wenn das Case zu war und die Lüfter im ertragbaren Rahmen liefen, nee, das ist schon Welten besser mit Block, über 60 Grad kommt man ja wirklich nur, wenn man dauerhaft 500 - 600 Watt usw. fährt. Mehr OC ist aber kaum drin bei Ada gegenüber Luftkühler.
Hallo bei LDLC Frankreich gibt es gerade die GAINWARD 4090 Phantom mit 10 % Promo Code um €1801,90.-- inkl Europa Versand !!!
Für alle die sich paar Euros vom Weihnachtsgeld sparen wollen 8-)
@Trill
Alles kein Thema, aber der Luftkühler hielt die Strix auch bei Vollast bei unter 60°C...
Mit dem Bykski Block knallt die Temp bei Last instant auf 63 °C hoch und das kann mit Sicherheit nicht an Ada liegen...
Gibt es jetzt weder Priority Links noch Drops der Fe? Ist es in anderen Ländern auch so?
@Trill
Hast du von anderen mal Vergleichswerte gecheckt? Bei welcher Lüfterdrehzahl hat der Luftkühler das erreicht?
Was hast du sonst noch im Kreislauf?
Beste Grüße
Ah, da werden ja auch schon die ASUS Blöcke gelistet.
Compatibility approved: Physical. Das war meine TUF ;)
Jetzt kommt´s darauf an, wie "Coming soon" definiert wird (3 Monate, 6 Monate etc...) :rolleyes2:
Von WC und AqC kann man wohl so schnell nichts erwarten. Wir paar User sind einfach zu unwichtig. Die haben andere, lukrativere Abnehmer :cry:
Hast du einen Vergleich zu Luft bei den 520W?
Mal Nachfragen. Notfalls anbieten das sie die eigene Karte nehmen können um diese einzuscannen.
Beste Grüße
Schon klar...
Abgesehen von der Strukturbreite hatte ich mit meiner 3090 Strix OC 3090 FTW3 Ultra auch 520W. Dem Block isses egal, ob 20, 7, 4 oder weniger nm.
520W sind 520W und der 4090-GPU-Die ist "nur" 3,12% kleiner (608,4 vs 628mm²). Aber dann so ein hohes deltaT?
@kmwteam @Dwayne_Johnson
12900k noch im Loop....
Luft: Gehäuse offen, Zimmer ~23°C , 20 Min Furmark, 520W,Lüfter auf 100%, ~61°C
Bykski: Gehäuse offen, Zimmer ~23°C, 20 Min Furmark, 520W,Wasser 34°C, ~67°C
Vergleichswerte gibts aktuell kaum, aber ein Delta von 30° unter Wasser ist halt auch sehr dürftig...
@Trill
Instant, nun, ist bei mir ähnlich - Beispiel: Ich starte Cyberpunk mit RT alles an, das Game zieht instant 450 Watt beim Start, Wasser ist bei 26 Grad, dann habe ich zunächst ca. 49 Grad auf der GPU, also auch direkt, die dann mit der Wassertemp langsam höher geht, liegt das Wasser bei 30 Grad habe ich auf der GPU dann ca. 55 Grad, habe auch nen Mo-ra 3 extern, Wasser bleibt dann so bei 30 Grad, die Temp der GPU verändert sich auch kaum.
Und so ist es schlicht auch ok, aber mach deine Erfahrung mit einem anderen Block, das Verhalten/Temps wird nicht groß anders sein, die 4 (5) nm Fertigung mit der Masse an Transistoren wirken hier eben als die Bremse, dass die Temp nicht schneller rauskommt aus dem Die. Daher ist der Unterschied zum Luftkühler auch nicht so auffallend, wie vorher bei Turing/Ampere.
Was ich jetzt so gesehen hatte bei Der 8auer, der hatte die Ino ICHILL drauf und bei 400W ein Delta von 20 Grad und das GPU only am Mora.
Beste Grüße
Mit Wasser sogar mehr als Luft? :oops:
Ich wette die Pads um die GPU herum "klauen" dir Anpressdruck ;)
War bei meiner FE auch so. Hat mich echt verrückt gemacht, das zigmalige Zerlegen und Pads nachpressen
Geht aber nicht, wenn du Silikon-Pads hast!!!
Und wie ich sehe, hast du die Byksky-BP montiert. Unter diese passt dieses Federstahl-Kreuz nicht, richtig?
Ohne dieses Kreuz fehlt dir zusätzlich noch GPU-Anpressdruck ;)
Schon klar...
Ja, das Delta scheint erschreckt hoch, ist aber die neue Realität bei Ada, weltweit in den Foren, wenn man so liest. Die Temp bekommt man schlicht nicht schneller raus aus dem Die. Und mein Anpressdruck passt, mehr geht nicht.
Naja, 100% Luft ist aber auch nicht wirklich auszuhalten. Für nen benchrun okay aber sonst?
Beste Grüße
@scars mein EKWB auf der TUF ebenfalls, nach 5 min bin ich bei 28 Grad Wasser und 62 Grad GPU, bei 540-550W
Nach 20 min wäre mein Wasser und GPU wohl ziemlich genau da wo dein Bykski ist, Mora420 und Z690 Formula + 13900k im Loop
Ich häng mir glaub noch nen 2. 420er dran, einfach nur um das Wasser dauerhaft Kühler zu halten.
Die 3090 mit XOC Bios 600 Watt hat sich aber ähnlich verhalten, auch hier ist die Temperatur einfach nur noch eskaliert wenn wirklich dauerhaft 600Watt gezogen wurden.
Hmm ...
100% Luft sind auch kein Zustand ;)
Und ~65°C unter Volllast ist auch jammern auf hohem Niveau, klar...
Was mir nur nicht reingeht, ist der direkte Sprung sobald Last drauf kommt...
Ich starte CP oder Doom Eternal und sobald die Karte was zu tun springt die Temperatur instant hoch und bleibt dann aber auch...
Demnächst kann ich auch bald "liefern"...
Der Vergleich ist dann nicht so fair, weil ich auf LM setzen will. Wenn ich dann trotzdem 60°C hab, raste ich aus :d
Spricht im Endeffekt um so mehr dafür das die Hitze einfach nicht gescheit übertragen wird, liegt aber scheinbar nicht am Block sondern an AD102. Haben alle das gleiche Verhalten. Bin gespannt ob LM hier noch was rausreissen kann @Dwayne_Johnson
Ich war ebenfalls enttäuscht als ich die Temps gesehen habe nach Umbau
Kannst du mal was testen? Ist aber bissl Arbeit... ;)
Nimm mal den internen Radi raus bzw. überbrücke ihn mit Schlauch, damit nur der ext. Mora arbeitet
Momentan nimmst du ja Wärmeenergie über den int. Radi auf
Oder int. Radi nur für CPU und Mora für GPU. Brauchst halt eine zweite Pumpe etc
Aber guck zuerst nach dem GPU-Anpressdruck. Ich denke, da stimmt was nicht
btw:
An alle, die einen Block drauf haben...
Ist der GPU-Die sehr plan oder wieder mit "Buckel"?
Wie gesagt, dass die Temperatur direkt hochspringt, ist normal mit Ada - wenn man eine neue Realität bzw. ein verändertes Verhalten nicht akzeptieren möchte, nun, persönliches Problem, wie man so schön sagt. Ich für meinen Teil war wieder heilfroh als der Luftkühler weg war und bin auch vollkommen zufrieden!
Wenn man nicht vor hat die Karte auf Wasser umzubauen kann man das gesparte Geld in ein paar Packungen Oropax investieren, die wird man nämlich mit der Karte brauchen :fresse2:
Liquid Metal und ein besserer Wasserkühler sollte noch Mal was bringen !
Ähnliche Themen
