[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
OK ich glaub Prime-Kunden werden definitiv bevorzugt lmao.. meine PNY von Amazon, gestern bestellt und ursprünglich für 19. Dez terminiert, dann auf 9.-12. korrigiert, kam nun letztendlich über Nacht.. Ridiculous.:ROFLMAO:
Muss allerdings noch auf ein Kabel warten bevor ich sie einbaue.
Gerade mal Crysis 2 Remastered angetestet. Das sioeht ja immer noch besser aus als manche Games von heute. Die Stadt ist schöner als bei Miles Morales.
Ich glaube so langsam mit der 4090 kann man die Games von vor 5-10 Jhren endlich flüssig in 4k spielen. Wahrscheinlich kann man Gotham Knights und Calysto auch in 5 Jahren mit einer 6090 spielen :-)
Ist echt so. Klassiker mit Downsampling etc. mal so richtig maxed-out zocken macht derzeit mehr Laune als moderne Games anzuwerfen.
Jepp. Ghost Recon Wildlands und RDR2 in voller 4K Pracht auf ultra sind einfach ne ganz andere Erfahrung als damals auf 1080p und "high". Ich entdecke diese Spiele komplett neu. Wenn das next gen update raus geht es dann auch mit Witcher 3 los.
Hat hier jemand Erfahrung mit Graka-Bestellungen bei MM/Saturn? Habe am Sonntag bei MM eine 4090 geordert, als Lieferdatum war der 8.12. angegeben. Seither hat sich nichts getan. Im Orderbuch steht nach wie vor "Lieferung bis Donnerstag, 08.12.2022" in grau und darunter "Deine Bestellung ist eingegangen". Die scheinen die Karten also gar nicht auf Lager zu haben?
Also die 4090 Strix is bisher recht leise .. hab aber nur 3D Mark getestet bisher ... die Fiept nich sondern surrt eher dunkel bis mittel hell .. kann einige sicherlich nerven
aber wenn man seine Boxen anhat und zockt wird man das nich hören... aber ich muss erstmal schauen wie das ausserhalb von 3D Mark is
4090 Strix Komplett @stock mit 3 x 8 Pin angeschlossen :
Und mit +190 core und + 1000 VRAM :
Und mein alter Score mit der 3080 Strix mit Max OC und Wasser Block :
Ich hab da mal zwei Fragen an die FE-Besitzer:
1.) Der FE liegt doch "nur" der Dreizack bei, oder doch der Vierer? Frage wegen dem 600W Bios der bei 3x8pin doch schon etwas grenzwertig wäre bei manchen NTs...:unsure:
2.) Mit welchen Programmen konntet ihr die Beleuchtung der FE ändern/einstellen? Die LEDs können aber nur weiß oder geht auch andere Farbe?
1. Der Vierzack liegt bei
2. Mit Asus Aura funktioniert es. Die Schrift vorne bleibt weiß, aber die LED bei den Lüftern können alle Farben.
hahahaha :d Zum Glück war Hermes gerade da. NBB hat es direkt in der Umverpackung von Foxconn verschickt, darauf waren einige interessante Infos:
Es waren 200 Kartons, d.h. 200 Karten in dieser Sendung aus der Fabrik (sofern Direktlieferung an NBB) & Die Karte wurde schon im September hergestellt?? Kann ich fast nicht glauben.
Leierplattenhersteller = https://www.unimicron.com/en/
Same. Hat mich heute sehr gewundert bei der Hermes Lieferung. War schon darauf vorbereitet den NBB Karton auf alle erdenklichen EntnahmeMöglichkeiten überprüfen zu müssen ( obwohl bei uns meist der gleiche Fahrer kommt und er wirklich gestresst aber immer korrekt ist ) da die orangenen Kartons sehr auffällig sind und Gewicht hat bei denen meistens Wert. Habe auch die Aufkleber studiert.
Brauche jetzt nur noch ein gewinkeltes Kabel da die Karte wirklich durch Zufall - habe von der Preisänderung gelesen und die Nvidia Seite aufgerufen -> Kaufen Button war grün -> und dann auch gekauft ( mit 2-3 Schreckmomenten bei der Bezahlung ) ^^ - heute angekommen ist.
4090 Strix bei Elex 2 mit 98 - 117 FPS und Marvels Spiderman mit Ray max und mit 80 - 110 FPS kein Fiepen kein Surren zumindest durch meine Ohren nicht hörbar.
Nur bei 3D Mark gibts halt das Surren was aber auch nich so wild is aber beim Gaming scheint die echt leise zu sein
Shice ihr habt recht. Post wird rausgeballert. :o
Meine 4090 PNY von Amazon kam heute an und befindet sich jetzt seit ca. 2h im Rechner.
Ersteindruck: Was ein effizientes Biest :)
Klar, eine TUF ist hochwertiger, aber da ich eh eine geschlossene Seitenwand habe, ist mir Optik und RGB völlig egal. Man muss aber sagen, dass die PNY durch die Backplate sehr stabil ist. Hängt praktisch gar nicht durch im Vergleich zu meiner 3080 TUF. D.h. der GPU Halter hat kaum was zu tun.
Hatte zwar jetzt noch nicht soviel Zeit zum Rumspielen, aber hier schon ein paar Punkte bezogen auf die letzten Posts:
- Es laufen alle drei Lüfter
- Stock boostest sie bis 2745 MHz
- Unter normalen FPS Bedienungen ist die Karte super leise was Spulenfiepen oder -rasseln anbelangt.
- Bei extremen FPS > 350 und hohem anliegendem Verbrauch hört man je nach Last natürlich was, aber selbst das ist nicht sonderlich störend bei geschlossener Seitenwand und Gehäuse unterm Tisch.
- Ist der Verbrauch relativ gering, aber die FPS dafür hoch, ist dieses Geräusch auch nochmal leiser und aus normaler Entfernung nicht hörbar.
- Kühler ist ein Traum. Nochmals deutlich leiser als meine 3080 TUF mit silent BIOS
- Karte kommt Stock bei 2745 MHz und so 445W auf max 68°C im Time Spy
- Erster UV Versuch 2550@875mV / RAM+1000 MHz waren zumindest im Time Spy stabil: Temperatur max 57°C, Lüfter dauerhaft bei 30% -> Genial :)
Nach all den Horrorberichten hier im Forum zu sämtlichen Herstellern kann ich die PNY auf jeden Fall sehr empfehlen.
/EDIT: Bei NBB übrigens gerade sofort lieferbar für den Amazonpreis: https://www.notebooksbilliger.de/pn...g+verto+epic+x+rgb+782808?nbbct=4001_geizhals
Hatte damals ja gesagt ist ne Top Karte und alle waren skeptisch :P
4090 Strix Heutige Fiep Testrunde beendet .. folgendes beruht auf meine Karte und mein Gehör beim normal auf dem Stuhl sitzen und zocken .. mein PC steht etwa 50cm von mir weg und Gehäuse is offen
1. 3D Mark mit Ray = Leichtes bis Mittleres Surren... für mich nich sonderlich stöhrend
2. Elex 2 = nix was ich hören konnte beim normalen Zocken
3. Marvels Spiderman mit Ray = nix was ich hören konnte beim normalen Zocken
4. Cyberpunk mit Ray = Surren ähnlich dem von 3D Mark aber für mich nich stöhrend und geht größtenteils im Spielsound unter
5. Control mit Ray = nix was ich hören konnte beim normalen Zocken
6. Borderlands 3 = leichtes Surren .. wird weniger wenn man im Game in den Himmel schaut und dann noch nur 200 Watt anliegen und ab 230 Watt fängt das Surren in diesem game an .. stöhrt mich 0 is so seicht das der Game Sound das locker übertönnt.
4K und überall ausser bei 3D Mark mit 117 FPS Cap ... Es is kein Fiepen da ein Fiepen hochfrequenter is daher mehr ein Surren weils eher dumpfer is
Die Karte wurde bei meinen Tests bisher 63 Grad warm bei etwa 420 Watt und 21 Grad Zimmertemp und offenen Gehäuse ( weil Glastür geht nich zu wegen der Strix )
Tjoa bin bisher zufrieden mit der 4090 Strix und werde sie wohl behalten .. als nächstes kommt dann der EK Kühler drauf und dann kann ich sie auch normal einbauen und die Glastür dann auch zu machen :d
Ich drück die Daumen, das Terminal vom EK ist ja gute 2cm lang, nicht dass Du dann das Gehäuse immer noch nicht zu bekommst, war für mich der Grund für ein Glacier-Kühler mit Terminal an der kurzen Seite.
Bist du Dir da sicher ? Meine Asus Karte habe ich auf einen Bykski Block umgebaut. Die Türe hätte ich dennoch nicht zu bekommen. Die Platine ist ja schon sehr "hoch". Abhilfe hat bei mir nur das Vertikale Einbaukit + Riserkabel gebracht. (Gehäuse ist bei mit ein O11 XL)
Hab das hier seit 2020 .. nur musste ich das Ding halt erstmal abmontieren wegen der 4090 Strix weil die mit dem Luftkühler zu lang is und gegen mein AGB kommt ( max Länge bei mir aktuell 33cm wegen dem AGB )
daher steht die 4090 Strix grad bei mir schräg .. wenn ich den EK Kühler aber hab kann ich den Vertical Mount aber wieder drann machen.
Erstmal sieht es so aus ( die Stromführung werd ich am WE nochmal überarbeiten ) --------------- Aber wenn der EK 4090 Strix Block da is siehts wieder so aus : ( Dort noch mit der 3080 Strix )
Ähnliche Themen
