[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Viel Erfolg, meine TUF non-OC hat ordentlich geträllert :d
Warum sollte sie es auch nicht tun? Was die Spulen betrifft ists das gleiche Layout wie bei der Strix und es sind sicher auch die gleichen Spulen montiert.
Ich erwarte auch nichts anderes, aber es gibt ja immer wieder Leute die entweder Glück hatten, denen das nichts ausmacht, oder bei denen das Restsystem einfach lauter ist :d
An der jeweiligen EAN-Nummer erfährt man die exakten Innen-Maße
K.A. warum manche Shops das nicht, wie EK machen. Meist ist (sollte) "16/10" real 15,9/9,5mm und "16/12" 16,1/11,1mm sein
Die "Non-available-Edition" dient nur als Teaser, um uns in den ASUS-Shop zu locken und diesen dann mit der Strix OC im Warenkorb zu verlassen :d
Schon krass, wie die Preise jetzt fallen :-)
und du meinst, das könnte der Grund für meinen "undichten" loop sein? Das würde ja lediglich einen Drain und neue Schläuche bedeuten...
Es gibt Fittinge oder Tüllen für Schläuche mit 10mm Innendurchmesser.
Ekwb bietet Schläuche an mit 11,1mm Innendurchmesser.
Kombiniert man manche Fittinge/Tüllen mit einem solchen Schlauch, dann kann/muss es aber nicht undicht werden..
Ob das bei dir der Fall ist kann hier keiner von außen beurteilen.
Gleiches gilt für Schläuche mit angegebenen 10mm ID. Gibt halt einfach Schwankungen in arg Produktion...
Für mich unverständlich wie man bei diesem Geschäftsgebaren, Asus (Masse an fiependen Karten), weiter Geld in den Rachen werfen kann.
Deine Frage wurde ja unter deinem Beitrag beantwortet ;)
Ich würde den Loop mal mit einem Leak-Tester abdrücken. Den Leakshield sollte man besser ausbauen dafür
Das kann alle Hersteller betreffen, dann darf man gar keine Karte kaufen.
Warum gibt es dann Karten, die nicht fiepen oder rasseln? Heißt, am Ende lügen diese User oder sind einfach taub?
Denn bei der TUF / Strix geht es nicht um das normale Fiepen, was jede Karte irgendwo hat. Meine Strix hatte ein ganz fieses und mega lautes Zirpen oder buzzen oder wie auch immer man das nennen mag. Ich glaube dass das hier als rasseln bezeichnet wird. Und das kann keiner überhören oder als nicht störend empfinden. Das war jenseits jeder Toleranz.
Joa die TUF zirpt im Gaming mal mehr mal weniger.
Kann damit leben und merke das nicht so sehr mit Kopfhörer. Kann das für mich ausblenden,
Die Karte hat halt eine gute Kühlung und gute Lüfter wie auch eine gut funktionierende Lüftersteuerung .
Dazu ein 600 Watt PL , wenn man testen und benchen mag zum spaß.Hochwertig wirkt sie auch in der Hand. Kein Plastikmüll.
Ich bin froh im Idle meine Ruhe zu haben , weil hat man auch den KH mal nicht an. Hatte zuvor ein Mainboard z490 Master welches im IDLE bei Mausbewegung gezirpt hat und
bei meiner Kühlung hatte einer der NZXT Lüfter Lagergeräusche gemacht und wurden gegen A12x25 Chromax getauscht . Seitdem ist Ruhe. Ist halt nervig in einem Airflow Gehäuse.
Ist bei vielen teuren Produkten heutzutage nicht alles so perfekt. Muss man sagen wie es ist .
Unter Wasser sollte man ganz klar eine Karte bevorzugen die möglichst wenig Spulengeräusche macht , weil da fällt es mehr auf , wenn man auf absolut silent im Gaming Betrieb seine
Wasserkühlung ausgelegt hat. Da kann auch einem egal sein , wenn Lüfter und Kühler ggf. von der Karte minderwertig sind.
Naja von meinen 5 Karten war keine ohne Spulengeräusche, die Asus und die Suprim haben sich besonders schlecht präsentiert was das angeht, schade weil die Kühlung der Karten super ist 😅
Ich unterstelle keine lügen, wird schon richtig leise geben oder die Gegebenheiten verhindern, dass man es hört, genauso wie es Leute gibt die den brummenden Fan der FE nicht hören.
Und wenn möglich VGPU weiter reduzieren...
Hab heute wieder mit dem EVC2 herumgespielt und "online" (während dem Bench) UV betrieben. Ab < 0,85V war die TUF "lautlos"
Habe die TUF auch bei Amazon bestellt, auf ein Neues. Ein bisschen fiepen darf sie, aber es sollte nicht so extrem sein. Ansonsten geht sie ohne schlechtes Gewissen wieder zurück.
Herzliche Glückwünsche. Zurzeit fällt der Preis für die Grafikkarte . Ich hatte zuerst eine Gigabyte RTX 4090 Gaming OC für 1879 EUR gekauft, dann könnte ich eine Inno3D iChill X3 für 1725 EUR ergattern, und ich habe Gigabyte an einen freund weiter verkauft. Am letzten Wochenende hatte ich die Inno3D RTX 4090 eingebaut, unter der Last ist Fiepen zu hören. Wenn Musik an ist, höre ich dann nichts. HOF 666W Bios ist drauf, PT habe ich bei 550W belassen. Bei Cyberpunk 2077 verbraucht die Karte ca. 415W. Die Karte muss für die nächsten 4 Jahre halten, danach schauen wir mal.
@parity_bit
Ab wann genau hat deine Inno3d zum Singen angefangen? War im Lastbetrieb das Fiepen stark zu hören bzw. störend? Wie verhielt sich die Karte vor dem BIOS-Wechsel?
So wie ich deinen Post verstanden habe, wirst du die Inno3d wohl behalten, oder?
Danke dir für deine Antworten :)
Die Inno3d fiept sehr sehr leise, also praktisch im Alltag nicht hörbar. Man hört es unter Last nur, wenn man wirklich mit dem Ohr rangeht und sich konzentriert. Ist wirklich eine sehr leise Karte, einziger Nachteil sind eben die 450W PL aber der Boost ist dafür mit 2800Mhz out of the Box gut :).
@Brandur Der Nachteil lässt sich ja durch einen Bios Flash beheben. Obwohl ich die Karte im Dauerbetrieb eh im Sweetspot bei 70-80% Powerlimit sehe.
Zum normalen Spielen reicht das 450W PL total :), benchen tue ich mit der Karte ja nicht.
Wie hoch gehen Eure HotSpot Temperaturen eigentlich? Bei mir sind GPU und VRAM sehr nah beieinander, meist 2-3° Differenz. Der HotSpot kann schon höher sein aber wird der in der GPU gemessen oder sind das zum Beispiel auch Spannungswandler oder so? Heute zum Beispiel nach 7h gaming waren GPU bei 54°, VRAM bei 56° und HotSpot bei 71° (max. Werte, der Durchschnitt ist weit geringer), ist das normal?
@parity_bit
Ich habe bisher noch nicht genau beobachtet, wann das Fiepen losgeht, weil ich in dieser Woche nicht viele Zeit damit verbracht habe. Jedenfalls ist meine alte GTX 1080TI lauter. Ich werden am Wochenende mal genauer beobachten. Nach dem BIOS-Wechsel verhielt sich die Karte ganz normal, das Aufspielen von BIOS hat vielleicht 2 Minuten gedauert. Ich werde die Karte beibehalten, weil der Preis doch sehr günstig ist.
Danke dir. Ja der Preis ist schon gut. Und letztlich ist es auch eine 4090. Wenn du zufrieden bist, so würde ich an deiner Stelle die Inno3d dann definitiv behalten.
Funktioniert das Galax HOF VBIOS auf jeder 4090 oder sind Kombinationen bekannt die Probleme mit sich bringen? Z. B. ein Displayport ohne Funktion o. ä.?
Ich hätte auch gerne Zeit für 7h Gaming.
Naja ich arbeite Schicht und wenn ich dann nach einem 24h Dienst nach Hause komme, kann ich den Tag über zocken :). Geht aber auch nicht jeden Tag.
Eure HotSpot Temperaturen sind niedriger, wo werden die denn ausgelesen? Core der GPU?
Ich habe mal eine Frage zu den 16Pin Kabeln und der Temp davon.
Ich habe die Zotac 4090 AMP Extreme AIRO und das be quiet DP13, vor 2 Tagen alles verbaut und mega happy. :d
Aber selbst im O11D XL ist das relativ "sehr" eng. :fresse:
Ist das fine so mit dem Kabel bei mir, oder zu risikoreich schon? (Ich warte, wie viele, auf die CableMod Winkeladapter.)
Ich hatte nach Einbau mal einen 3DMark TimeSpy (non Extreme) laufen lassen mit 100% PT. Also alles @Stock und Background Apps an.
Die Temps sind super etc. nur das Kabel wurde wohl sehr warm im lauf, da das Glasfenster wo das Kabel anliegt schon sehr warm war, nicht heiß, aber halt sehr warm. Ist das normal? :d
Das waren die Temps.
Aktuell habe ich sie auf 80% PT laufen.
Gezockt habe ich in den 2-3 Tagen nur WoW Dragonflight und da lutsch die Karte kaum was an Watt; 70-150W und ist da sogar meist im 0-Fan Modus. (1440p) :ROFLMAO:
Schönes Wochenende schon mal an alle.:bigok:
Anhang anzeigen 849784Anhang anzeigen 849785
Es ist immer noch egal wie das Kabel geknickt wird, solange du das Kabel wirklich richtig eingesteckt hast.
Ähnliche Themen
