[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Will nur nun sinnloserweise wohl auch eine 4080 oder 4090 kaufen. Welche aftermarket Stromadapter nimmt man da denn? Gibts da inzwischen gut Auswahl? War da lange nicht mehr aktiv. Ich habe ein Corsair SF750.
Also mit der neuen DLSS 3.1.1 Version die ich drüber gebügelt hab schaut das Bild noch mal etwas sauberer aus würde ich sagen.
Zu Nativ nur ein kleiner unterschied bei der schärfe der Vegetation bei Hogworts .
Das Originale DLSS ist deutlich unschärfer gewesen bin ich der Meinung.
Würde beides schick aus sehen bei mir .
Bin aber immer noch skeptisch ob sich das für mich noch lohnt.
Eventuell das Geld bei Seite packen und Später auf ne 4090 Ti aufstocken.
Performance mässig hätte man da eventuell mehr von.
Die Karte läuft Super 2910 bis 2925 MHz @ Air bei mir mit OC stock V.
Die Luftkühler sind schon echt Stark geworden bei der 4090er.
und das kommt FG dann nicht in die quere?^^
Mal wieder dieser Artikel, ist wohl immer noch nicht so bekannt:
Zitat: "Ein großer Vorteil ist nun allerdings, dass Framelimits, Ingame-Bildratenbegrenzungen und V-Sync zusammen! mit DLSS 3.0 funktionieren"
Also am besten so vorgehen bei Horgwarts und Co:
- V-Sync im Treiber anschalten
- Framelimit paar FPS unter Monitor FPS festtackern (hier erklärt)
- Framegenration im Spiel einschalten
= Hohe FPS mit Hoher Bildqualität mit RT genießen :bigok:
PS:
Hab auf 100HZ gestellt weil ich die 120 nicht halten kann mit RT und FG .
Das bitte nicht tun, der Moni kann weiterhin auf seiner nativen Hertzzahl bleiben, das Framelimit regelt ja.
FrameGeneration macht aber aufgrund seiner Technik Vsync obsolet, da kein Tearing vorhanden ist.
Ist das so? Wie sind dann solche Beiträge zu erklären?
Und soo alt ist FG nun wieder auch nicht, ist immer noch der neuste shice und nicht jeder hat das alles drauf aus dem FF mit den Einstellungen etc :sneaky:
ich hab das jetzt so wie du gesagt hattest
144hz in windows
ingame auf unbegrenzt
NVCP 120fps
NVCP Vsync ON
FG ON
keins :)
Das original Corsair-Kabel ist hart wie ein Brett.
Je nachdem wieviel Platz Du hast, nimm was von Cablemod oder ähnlich.
Kann Dir aber bestätigen, das unser Corsair SF750 locker damit klar kommt.
Wenn Du dann noch mit dem Power Target arbeitest, ist das 0 Thema.
Mit dem NT habe ich schon ganz andere Sachen gemacht :d :fresse: Da mache ich mir eh keine Sorge. Dieses NT Thema, seit Ampere, finde ich eh voll übertrieben.
Hast du mal einen Link zu dem Adapterkabel? Die Karte müsste in ein ITX Case (NR200P), daher brauche ich wohl definitiv ein Aftermarketadapterkabel.
@ssj3rd
Hab jetzt auch auf 120 Hz gestellt und 117 FPS DLSS Qualität in der Version 3.1.1 + Framegeneration .
Die Nagel neue DLSS Version 3.1.1 schaut meiner Meinung nach besser aus.
müsst ihr euch runter laden und im DLSS Ordner von Hogwarts ersetzen .
Die alte DLSS Datei zu Sicherheit kopieren und sichern.
Ach so zum Thema Frame Generation ohne V Sync hab ich auch Tearing bei Hogwarts da rum im Treiber für das Spiel auch auf Ein.
Ach ich vergesse immer, das Du ja auch im NR200 Club bist. :d
Ich hab das hier bestellt: https://eustore.cablemod.com/configurator/?load=ef2591519e62
Microfit auf 3x8pin und 210mm länge.
Unklar ist aber wann die versenden.
Reflex low latency capt automatisch 4 bzw 5 fps unter monitor hz, da braucht man theoretisch kein limitier mehr. Also vsync im nvcp an, ingame aus, gsync an, dlss Q + FG super smooth alles. Latency ca 30-35 (115 fps) ms via nvidia performance overlay gemessen, was für singleplayer games absolut klar geht.
Was hat es denn mit den neueren dlss Versionen auf sich und warum wird das nicht automatisch geupdated?
Wieso testet ihr überhaupt Frame Generation ohne Vsync? Mit Gsync Monitor oder TV hat man eigl. Vsync im Treiber an (ingame aus).
Es hieß erst, Frame Generation deaktiviert Vsync bzw. Vsync funktioniert nicht, wenn FrameGen eingeschaltet ist.
Fakt ist aber, ist hab Vsync im Treiber an und FrameGen lief seit dem Release von Darktide einwandfrei ohne Tearing.
Jo im Treiber immer Vsync Aktiv jedoch mach ich da immer ein Separates Profil wegen dem FPS Limit.
Reflex Low Latency im Treiber aktivieren oder meinst ingame?
Die neueste DLSS Version gibt es so noch nicht implementiert die musst Manuell rein Packen wenn man sie nutzen will.
Vielleicht gibt es da irgendwann ein Update was das Automatisch installiert!
Hatte aber keine Lust darauf zu warten die Datei ist wohl offiziell von NV wenn ich das richtig verstanden habe kann man die in allen Spielen mit älterer Version ersetzen.
Ein Kumpel hat mich darauf aufmerksam gemacht hier aus dem Forum.
die neuste ist gut. selbst die, die mitgeliefert wurde ist ein paar Dekaden alt :d
Bei FG kann VSync nicht über das Spiel erzwunen werden, was auch irgendwie logisch ist (die Framerate ist ja de fakto doppelt so hoch, wie das Spiel Images rendert).
Aber über den Treiber lässt sich VSync erzwingen und das ich auch richtig und wichtig so, da man sonst übelstes Tearing bekommt, auch mit GSync, wenn die Framerate (die FG erzeugt) zu nahe an die Frequenz des Monitors kommt.
Also: VSync im Treiber an, und ggf. noch ein Framelimit im Treiber (nicht RTSS oder im Spiel) auf knapp unterhalb der Frequenz des Monitors.
Echt Mega Danke !
Funzt super.
Ist wohl silberfarben (Nickel). ;)
Silberne Kühler waren bisher immer mit Edelstahl verziert
@ssj3rd
Danke für den Tipp mit Steam-UA :-)
Hab direkt bei Steam mit KK bezahlt. Die Gift-Card-Shops sind regelrechte Scalper. Hätte gut 30% mehr gekostet
Bist Du sicher? Ich kann es nicht widerlegen, auf jeden Fall weiß ich, dass bei vielen Spielen ohne VSync im Treiber und aktiviertem FG (und damit Reflex) am unteren Bildrand übelstes Tearing auftritt. Zumindest scheint also das limittieren unterhalb der Frequenz des Monitors alleine nicht auszureichen.
Er schreibt doch VSync an im Treiber + Low Latancy .
Also bei mir capt es 100% weil 115 fps gehalten werden, wenn es nicht aktiv wäre hätte ich 119-121 fps cap rein durch vsync. Bei anderen settings zb ohne vsync (ingame und im control panel) kann ich es dir nicht beantworten da ich immer vsync + gsync nutze
Jup Hogwarts läuft jetzt bei 115 FPS .
Was für ne Graka hast du eigentlich jetzt (oder bin ich blind)?
Ähnliche Themen
Antworten
6K
Aufrufe
400K
