[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hellblade 2 lief jetzt mal ganz gut. Eben gerade das Alan Wake 2 DLC gespielt.
Geht auch soweit klar. Früher warst froh wenn du 60 FPS hattest in 4K.
Die 3090 war mir ziemlich direkt zu schwach auch mit DLSS. Control lief nicht perfekt und CP 2077 sowieso nicht.
Die 4090 schlägt sich bisher recht gut finde ich. Hat sich schon gelohnt die Karte.
apropo AI
Naja hätte Nvidia nicht den switch machen können von 8nm Samsung auf 5nm TSMC hätte das ganze auch anders ausgesehen.
Von daher gut gelaufen , aber war halt ursprünglich anders geplant.
Naya, immer noch besser als Bio-triple whopper, Bio-Chips, Bio-Verbrennungsmotor, Bio-4090, Bio-Gas-pipeline usw.
So, Zeit für meinen Bio-P0rno. :o
Bio , AI Pffffffff
Vegan das zieht leute
#VeganeRTX5090mitBiolüfternausPlastikwasdieAIvorgeschlagenhat
Update:
Immortals of Aveum
So ... mir die Mühe gemacht und auf beiden Rechnern die gleiche Sequenz mit CapeX getestet.
Ergebnis:
Trotz 7950X3D sind die Frametimes mit NV für den Arsch. Der Ausreißer in der Mitte.
Genau das kommt immer wieder vor.
Irgendwann noch Hellblade 2 (aktuellste UE5-Engine) mit beiden GPU's testen und schauen, wie das in Sachen Gezuckle läuft.
Wenn dann noch „GPU-Pass Through“ in Virtual Desktop ginge, könnte es richtig teuer werden, wenn die 5090 kommt. Apple sollte den „Port“ öffnen :fresse:
Wären da nicht die geisteskranken Preise der „Vision Pro“ :oops:
Neben den nicht existierenden GPUs, gibt es weltweit nicht mal eine Kamera, die zufriedenstellenden Content für die Vision Pro erstellen kann :cautious:
Update:
Immortals of Aveum
Ergebnis:
Lief das Spiel auch korrekt nur auf dem CCX mit Cache?
Part #4
Optisch nicht top, aber für Handarbeit eine klasse Leistung
So mal wieder zum Thema 4090.
Heute habe ich mal die WLP gewechselt, weil Speedway 4K @ Stock 64°C GPU und Hotspot 90,9 °C
Das war mir dann doch nun zu viel des guten.
Hier Screenshot mit neuer WLP und Bilder von der Karte mit alter WLP.
Hotspot sieht jetzt gut aus und Karte bleibt deutlich leiser.
Der TUF Kühler ist echt taff.
Der Abstand zur Wasserkühlung ist ziemlich überschaubar wie man sieht. Deswegen und vielleicht auch als Grund für eine Reinigung des PCs werde ich demnächst meinen Watercool Block umbauen und mit einer Ultra Bodenplatte versehen. Ob ich auch gleich LM nachschieben sollte. :unsure:
Vorerst nur ein Vorher Bild:
Nvidia hat ja jetzt genug Geld gesammelt um entsprechende Leute zu bestechen :d
Diejenigen von euch die eine AIO besitzen, egal welche auch immer 240er 280er 360er oder 420er und die RTX 4090.
Hattet ihr euch entschieden die AIO in Top zu verbauen oder in der Front und wie hattet ihr die entscheidung begründet?
Ich hab die AIO jetzt in Top Verbaut, als ich die RTX 4090 verbaut hatte.
Zuvor mit einer rtx 4080 hatte ich die AIO in der Front und die CPU Temps waren Kühler. (Die Graka lief aber heißer, obwohl 4080 RTX 340Watt zur RTX 4090 450watt jetzt)
Hab’s im Deckel verbaut, damit ich keine Luft mit ziehe, weil sonst der Punkt wo die Anschlüsse wären der höchste wäre und da sich die Luft dort sammelt und diese dann immer mitgezogen werden würde. Sorgt dafür, dass die Pumpe lauter wird oder im schlimmsten Fall schneller defekt geht. Man kann leider bei der AIO schlecht reinschauen wie gut diese befüllt ist. Daher so die Entscheidung. Bei mir zumindest sind die CPU Temps beim Gamen im grünen Bereich.
Heißt heißeste Kerne bei unter 70 Grad Celsius in der Regel.
Die nächste Kingpin Karte wird von PNY kommen, er ist von Evga zu PNY gewechselt
PNY baut doch auch die Founder Edition und die Quadro etc.
Ähnliche Themen
Antworten
6K
Aufrufe
312K
