So i have swapped over to my
sample #3 9950X3D with the strongest IMC, and for the last week i have been finetuning the settings/voltages and pushing the memory as hard as i could for a fully stable daily memory profile
At the end of my journey i reached a wooping fully stable
8744MT/s CL32 with the APEX and these new G.SKill 6000 CL26 sticks
- 9950X3D with core tuning level2 running PBO
- ROG CROSSHAIR X870E APEX @ baseclock 100.5mhz
- G.SKILL 6000MT/s CL26 @ 1.78VDD 1.55VDDQ cooled by custom heatsinks + 2x60mm noctua fans
- FCLK @ 2211mhz / memory @ 8744MT/s CL32 (2200 /8700 multipliers with 100.5mhz baseclock)
- Nitro 1-3-1 with synced tPHYRDL @ 38/38
- Large custom watercooling with a mora
Decided to complete all the following stability tests in a single boot to show that i dont cherry pick settings for spesific benchmarks 🤝
6.5hours karhu @ 379mb/s 💪
5.5hours RunMemTestPro @ 36609mb/s
1 hour OCCT Large AVX512
1 hour TestMem5 1usmus cfg
1 hour y-cruncher all tests enabled
1 hour LinX @ ~1900GFLOPS
For a performance comparison picked the following: (was running out of screenspace😅)
AIDA cache and memory benchmark
Clam latency benchmark
Clam bandwidth benchmark
MaxxMem2
I can complete pretty much all benchmark @ golden ratio 8800/2200 CL32 (8844/2211), but karhu will fail it after awhile, so the promised land is still alittle out of reach for fully stable daily settings atm
Have also updated all my y-cruncher runs for hwbot, but haven't uploaded yet since i need to swap to my 2*24GB m-die sticks before i can finished of with the 10B run for this cpu
