Sind das rechts so gDesklet Elemente?
Gibts LXDE eigentlich mittlerweile auf deutsch? Und wie läuft das mittlerweile so von der Stabilität her?Mein neuer:
LXDE + Compiz Fusion @ ArchLinux
(Hintergrund heißt "Magicmoon" ist gibs bei interfacelift)
@Plentman:
http://conky.sourceforge.net/
Das Design ist aber komplett selbstgemacht. Kanns auch gerne bei Bedarf posten.
# Conky sample configuration
# the list of variables has been removed from this file in favour
# of keeping the documentation more maintainable.
# Check http://conky.sf.net for an up-to-date-list.
# set to yes if you want Conky to be forked in the background
background no
# X font when Xft is disabled, you can pick one with program xfontsel
#font 5x7
#font 6x10
#font 7x13
#font 8x13
#font 9x15
#font *mintsmild.se*
#font -*-*-*-*-*-*-34-*-*-*-*-*-*-*
font arial
# Use Xft?
use_xft no
# Xft font when Xft is enabled
xftfont Bitstream Vera Sans Mono:size=8
# Text alpha when using Xft
xftalpha 0.8
# Print everything to stdout?
# out_to_console no
# MPD host/port
# mpd_host localhost
# mpd_port 6600
# mpd_password tinker_bell
# Print everything to console?
# out_to_console no
# mail spool
mail_spool $MAIL
# Update interval in seconds
update_interval 5.0
# This is the number of times Conky will update before quitting.
# Set to zero to run forever.
total_run_times 0
# Create own window instead of using desktop (required in nautilus)
own_window yes
# If own_window is yes, you may use type normal, desktop or override
own_window_type override
# Use pseudo transparency with own_window?
own_window_transparent yes
# If own_window_transparent is set to no, you can set the background colour    here
own_window_colour hotpink
# If own_window is yes, these window manager hints may be used
#own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
# Use double buffering (reduces flicker, may not work for everyone)
double_buffer yes
# Minimum size of text area
minimum_size 280 5
# Draw shades?
draw_shades no
# Draw outlines?
draw_outline yes
# Draw borders around text
draw_borders no
# Draw borders around graphs
draw_graph_borders yes
# Stippled borders?
stippled_borders 8
# border margins
border_margin 4
# border width
border_width 1
# Default colors and also border colors
default_color white
default_shade_color black
default_outline_color black
# Text alignment, other possible values are commented
#alignment top_left
alignment top_right
#alignment bottom_left
#alignment bottom_right
#alignment none
# Gap between borders of screen and text
# same thing as passing -x at command line
gap_x 12
gap_y 35
# Subtract file system buffers from used memory?
no_buffers yes
# set to yes if you want all text to be in uppercase
uppercase no
# number of cpu samples to average
# set to 1 to disable averaging
cpu_avg_samples 2
# number of net samples to average
net_avg_samples 2
# Force UTF8? note that UTF8 support required XFT
override_utf8_locale no
# Add spaces to keep things from moving about? This only affects certain objects.
use_spacer no
# Allow each port monitor to track at most this many connections (if 0 or not set, default is 256)
#max_port_monitor_connections 256
# Maximum number of special things, e.g. fonts, offsets, aligns, etc.
#max_specials 512
# Maximum size of buffer for user text, i.e. below TEXT line.
#max_user_text 16384
# variable is given either in format $variable or in ${variable}. Latter
# allows characters right after the variable and must be used in network
# stuff because of an argument
# stuff after 'TEXT' will be formatted on screen
TEXT
$color       $kernel  -  Uptime: $uptime
$hr
			CPU
${color #606060} ${cpugraph 0000ff 00ec00}
$color Usage: $cpu% 	 		         Temperature: ${exec sensors | grep "Core0" | awk '{print $3-"+"}'}C
$hr
$color RAM Usage: $mem/$memmax - $memperc% ${membar}
$color Swap Usage: $swap/$swapmax - $swapperc% ${swapbar}
$color File system: / ${fs_used /}/${fs_size /} ${fs_bar /}
$color Processes: $processes $color Running: $running_processes
$color 	Name 		 PID 	CPU% MEM%
${color #ec0000} 	${top name 1} ${top pid 1} ${top cpu 1} ${top mem 1}
$color 	${top name 2} ${top pid 2} ${top cpu 2} ${top mem 2}
 	${top name 3} ${top pid 3} ${top cpu 3} ${top mem 3}
 	${top name 4} ${top pid 4} ${top cpu 4} ${top mem 4}
$color 	Mem usage
${color #ec0000} 	${top_mem name 1} ${top_mem pid 1} ${top_mem cpu 1} ${top_mem    mem 1}
$color 	${top_mem name 2} ${top_mem pid 2} ${top_mem cpu 2} ${top_mem    mem 2}
 	${top_mem name 3} ${top_mem pid 3} ${top_mem cpu 3} ${top_mem mem 3}
$color$hr
$color 		    Nvidia 8800 GT
		 ${exec nvclock -i | grep "GPU t"}
		${exec nvclock -i | grep "Board"}
		     Fan @ ${exec nvclock -i | grep "PWM" | awk '{print $4}'}
$color$hr
 		     Networking
 LAN: ${addrs wlan0}        ${execi 15 iwconfig wlan0 | grep "Quality" | awk '{print $1 $2}'}%
 ${color #606060}${downspeedgraph wlan0 32,150 ff0000 0000ec 1000} ${upspeedgraph wlan0    32,150
0000ff ec0000 1000}
$color Down: ${downspeed wlan0} k/s$color ${offset 80}  Up: ${upspeed wlan0} k/s
 Total Down: ${totaldown wlan0}      Total Up: ${totalup wlan0}
 Connections in: ${tcp_portmon 1 32767 count}$color 	   Connections out: ${tcp_portmon 32768 61000 count}$color
$color Inbound Connection ${alignr} Local Service/Port
${tcp_portmon 1 32767 rhost 0} ${alignr} ${tcp_portmon 1 32767    lservice 0}
 ${tcp_portmon 1 32767 rhost 1} ${alignr} ${tcp_portmon 1 32767 lservice 1}
 ${tcp_portmon 1 32767 rhost 2} ${alignr} ${tcp_portmon 1 32767 lservice 2}
 ${tcp_portmon 1 32767 rhost 3} ${alignr} ${tcp_portmon 1 32767 lservice 3}
 ${tcp_portmon 1 32767 rhost 4} ${alignr} ${tcp_portmon 1 32767 lservice 4}
 ${tcp_portmon 1 32767 rhost 5} ${alignr} ${tcp_portmon 1 32767 lservice 5}
$color Outbound Connection ${alignr} Remote Service/Port$color
 ${tcp_portmon 32768 61000 rhost 0} ${alignr} ${tcp_portmon    32768 61000
rservice 0}
 ${tcp_portmon 32768 61000 rhost 1} ${alignr} ${tcp_portmon 32768 61000 rservice    1}
 ${tcp_portmon 32768 61000 rhost 2} ${alignr} ${tcp_portmon 32768 61000 rservice    2}
 ${tcp_portmon 32768 61000 rhost 3} ${alignr} ${tcp_portmon 32768 61000 rservice    3}
 ${tcp_portmon 32768 61000 rhost 4} ${alignr} ${tcp_portmon 32768 61000 rservice    4}
 ${tcp_portmon 32768 61000 rhost 5} ${alignr} ${tcp_portmon 32768 61000 rservice    5}
$color$hr
		         HTPC
	      	      ${execi 500 /home/f/backuphtpc.sh &}
