Z
Zidane
Guest
Naja ärgern würde ich mich auch, wenn man 500 Euro für Ram mal eben in den Sand gesetzt hat, und bei der derzeitigen Speichersituation kriegt man die i.d.r nicht mehr weg, bzw. für den Preis.
Da stimme ich Euch zu . Preise werden ja wieder anziehennee - schon gar nicht hier am MP.
Da stimme ich Euch zu . Preise werden ja wieder anziehen![]()
Hi
As I wrote on last email, SPD is only for motherboard to boot it up. There is no other meaning for SPD. For 1:1, you need to reach FSB533 to reach DRR2 1066, if motherboard shows PC2 8400, the problem is motherboard display. For 4GB problem, Asus has great answer on it. Please check the following link
http://support.asus.com/faq/faq.aspx?no=D06D6034-D5C9-49C4-5E1B-CF724DB5C000
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Windows XP 32-bit version operating system.
If you install Windows XP 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met:
1. The memory controller which supports memory swap functionality is used. The latest chipsets like Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture can support the memory swap function.
2. Windows XP Pro X64 Ed. (64-bit) or other OS which can address more than 4GB memory.
Thank you
Denny
GSKILL USA REP
die denken dass du ein 32Bit OS verwendest und das Dir die 3GB im Windows angezeigt werden.
Die scheinen nicht begriffen zu haben dass die 3GB schon beim Boot dastehen.
Ich würde am Ball bleiben.
dieses ram prob hier wird es nicht lösen, aber meinst du ich hätte dann auf nem x-38 das selbe thema? dachte die neuen wären in sachen speicherbestückung etwas weniger zickig. ich glaube hier spielen einfach mehrere faktoren eine rolle. natürlich ist es auch nicht ideal, dass ich die speicher nicht vom selben typ und hersteller habe.
SPD hat nen falschen eintrag, aber das scheint denen irgendwie egal zu sein. denn laut ihrer aussage ist das SPD ja zu nichts anderem gut ausser dass das mobo beim boot den ram erkennt mit den timings.
Was hast du denn für Speicher-Riegel und was für Chips sind denn drauf?
Eigentlich Super-Speicher.
Hast du sie auch einzeln getestet?, bzw. nur die Cellshocks und nur die GSkills?
Und wenn es dir nichts ausmacht schildere bitte alle deine Probleme genauer.-
-Will nicht unbedingt den Thread jetzt durchschauen.
MfG.
Du meinst wohl BIOS?
-Nimm das aktuelle/offizielle 13er.
Verträgt sich das Quad mit einer X-Fi Extreme Music oder gibt es da Probleme?
Ist eigentlich easy!!
-kaputtmachen kannst du eigentlich nix.
Zurückflashen ist genauso ein Kinderspiel, das heisst - das Original-SPD.
BIOS-Flashen ist da meiner Meinung nach um einiges gefährlicher.
Aber wenn man sich unsicher ist, sollte man die Finger davon lassen.
