[Sammelthread] Abit AW9D / MAX (Intel i975X)
Ich bin mal so frei und eröffne, da heute offiziell die ABIT AW9D Series vorgestellt wurde, einen Sammelthread:) !
Specs:
AW9D
Preis: http://www.geizhals.at/eu/a214105.html
Bios Downloads:
http://www.abit.com.tw/page/de/download/download_bios_detail.php?pFILE_TYPE=Bios&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AW9D&pSOCKET_TYPE=LGA775
CPU
* Designed for Intel® LGA775 processors with1066/800MHz FSB
* Supports Intel® Core™ 2 Duo & Pentium® Extreme Edition & Pentium® D & Pentium® 4 Processors
* Supports Intel® Hyper-Threading / XD-bit / EM64T / EIST Technology / Virtualization Technology
* Intel® Quad Core ready.
Chipset
*Intel® 975X / Intel® ICH7R Express Chipset
Memory
* 4 X 240-pin DIMM sockets support max. memory capacity 8GB
* Supports Dual channel DDR2 800/667 Un-buffered / Non-ECC memory
Graphics
* Supports Dual PCI-Express X16 slots (dual ATI® CrossFire™ Graphics)
LAN
* On-board PCI-E Gigabit LAN controller supports 10/100/ 1000M Ethernet
Audio
* abit AudioMAX™ HD 7.1 CH
* Supports Jack Sensing and S/PDIF In/Out
* Dolby® Master Studio Certificated
Expansion Slots
* 2xPCI-EX16, 2xPCI-EX1, 1xPCI, 1xAudioMAX™
Internal I/O Connectors
* 1 x Floppy port, 1 x UDMA 100/66/33 connector,
* 4 x SATA 3Gb/s connectors
* 2 x USB 2.0 headers
* 1 x FP-Audio header, 1 x CD-IN
Back Panel I/O
* 1 x PS/2 Keyboard, 1 x PS/2 Mouse
* 4 x USB 2.0, 1 x RJ-45 LAN
Serial ATA
* ICH7R: 4 x SATA 3Gb/s supports Intel® Matrix Storage SATA RAID 0/1/0+1/5
* Support SATA AHCI, providing native command queuing and native hot plug
abit Engineered
* abit µGuru™ Technology
* abit OTES™ Technology
* Quick Power & Reset Buttons
* Low ESR and high ripple conductive polymer aluminum solid capacitors
RoHS
* RoHS Compliancy
Form Factor
* ATX form factor 305 x 245mm
* PCB Color: Black
AW9D-MAX
http://img208.imageshack.us/my.php?image=aw9dmaxangle500lz4.jpg
http://img209.imageshack.us/my.php?image=aw9dmaxtop500al3.jpg
http://img234.imageshack.us/my.php?image=maxof9.jpg
Preis: http://www.geizhals.at/eu/a214107.html
Lieferumfang:
- AudioMax HD 7.1 Soundkarte
- SLI Bridge
- Quick Setup Manual, ausführliches Manual, **** Manual
- Jumper Settings Aufkleber
- 7! SATA Kabel
- 3 SATA RAID Floppys (32 und 64 Bit Sil, Intel RAID)
- Treiber CD
- Optisches Audiokabel
- Je 1 IDE und Floppy Kabel, gerundet
- Bracket mit 2x USB und 1x Firewire
Bios Downloads:
http://www.abit.com.tw/page/de/download/download_bios_detail.php?pFILE_TYPE=Bios&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AW9D-MAX&pSOCKET_TYPE=LGA775
CPU
* Supports Intel® Core™ 2 Duo(Extreme Edition) & Pentium® Extreme Edition & Pentium® D & Pentium® 4 Processors
Chipset
Memory
Graphics
LAN
* On-board Dual PCI-E Gigabit LAN controller supports 10/100/ 1000M Ethernet
Audio
Expansion Slots
* 2xPCI-EX16,2xPCI-EX1,1 xPCI, 1x AudioMAX™
* 7 x SATA 3Gb/s connectors
* 2 x USB 2.0 headers, 2 x IEEE1394 headers
Back Panel I/O
* 4 x USB 2.0, 2 x RJ-45 LAN,
* 1 x eSATA
Serial ATA
* ICH7R: Support SATA AHCI, providing native command queuing and native hot plug & play
* Silicon Image:3132: 4 x SATA 3Gb/s, two SATA connectors of the same area can support SATA RAID 0/1
IEEE 1394
* 2 ports IEEE1394a at 400 Mb/s transfer rate
abit Engineered
* abit Silent OTES™ 2 Technology
* Back-light Blue LED's
RoHS
* RoHS Compliancy
Form Factor
* PCB Color: Black & Blue
FAQ zum ABIT AW9D-MAX (Vielen Dank an Sicness):
Wichtige Links:
Produktseite bei abit
BIOS download
Manual download
abits interne Kompatibilitätstests
Thread @ XtremeSystems.org
Gelten die folgenden Angaben auch für das non-Max oder Fatality?
Nein, beide Boards sind bis heute nicht erhältlich. Daher gilt dieses FAQ ausschliesslich für die Max Version.
Passt meine PCI-Karte in den PCI Slot wenn ich CF/SLI nutze?
Wenn die GraKa nen Single Slot Kühler hat wird der PCI nicht blockiert, bei einer Flachen WaKü a la Inno oder AC ebenfalls nicht.
Hey, da ist ja ne SLI Bridge dabei. Wird SLI offiziell unterstützt?
Nein, SLI ist nur mit gehackten Treibern möglich.
Bei mir funzt µGuru nicht richtig! Was ist los?
Das Problem tritt beim Release Bios in Verbindung mit einem Raid auf!
Lösung ist das neue .12 Bios!
Laufen 7900/7950GX2 problemlos auf dem Board?
Ja, die 7900GX2 läuft absolut problemlos.
Meine 7950GX2 bringt nur die halbe Leistung! Was ist hier los?
Laut dem User Dr.Wakeman liegt das an der µGuru Software.
Es verträgt sich nicht mit den aktuellen Forceware Treibern!
Der SLI Algorithmus läuft weder mit SFR, AFR oder AFR2.
Gibt es bekannte Probleme mit irgendwelchen RAMs?
Bisher nur eine Meldung, OCZ XTC Gold PC6400 C5 mit Elpida Chips laufen nicht mit 1:1, mit anderen Teilern jedoch problemlos. Micron D9 laufen einwandfrei.
Kann ich die Heatpipe entfernen und die Passivkühler in Kombination mit meiner Chipsatzwakü nutzen?
Nein, die Heatpipes sind fest verlötet. Es müssten in diesem Fall seperate passive Kühlkörper besorgt werden.
Falsch! Turrican bestätigt dass die Heatpipe nicht verlötet ist!
Bilder:
Was taugt die Heatpipe Konstruktion?
Die Kühlung arbeitet überraschend effizient, einen gewissen Luftstrom vorrausgesetzt lassen sich moderate Übertaktungen ohne zusätzliche Kühlung bequem bewältigen.
Sehe ich richtig? Das Board hat Lochhalterungen? Ich dachte Intel benutzt Ösen.
Richtig, abit bildet hier eine Ausnahme.
Wie hoch geht denn nun der FSB?
Die bisher höchsten Meldungen liegen im Bereich 450-460MHz, jedoch sind hier wohl die Chipsatztimings straffer als bei anderen 975X Boards. Sicher ist aber wohl ~420 MHZ!
hipro5 schrieb:
I also would like to add that ABIT "played" my Fadbodies a bit tighter that ASUS or Bad Axe......In 2k5 I got about 80 to 100 points more with ABIT with the EXACT same config as with ASUS/INTEL.......No big deal especially on air BUT when you go for the max, it counts.....Those points will be 200 - 300 on LN2 so as for me it counts.....
Ist es besser als die anderen 975X Bretter?
Lässt sich bisher noch nicht sagen, das Board hat bisher noch kein offizielles BIOS Update erfahren und ist wesentlich kürzer am Markt als Asus & Co. Es ist in jedem Fall vielversprechend und scheinbar sein Geld wert.
Welche Spannungsoptionen sind vorhanden?
VCore: 1,32V - 1,725V
VDIMM: 1,80V - 2,65V
MCH: 1,50V - 2,00V
Hat das Board auch das Shutdown Problem nach Übertaktung (vgl. Asus P5WDH)?
Nein.
Welche Straps und Teiler gibt es?
PSB533: 1:2
PSB800: 3:4, 3:5, 1:2
PSB1066: 1:1, 4:5, 2:3
Wieviele Lüfter kann ich anschliessen und was kann die Lüftersteuerung?
Das Board hat 7 Lüfteranschlüsse, jeder Lüfter ist zwischen 6 und 12V regelbar. Ausgenommen ist der CPU Lüfter, dieser kann nach Temperatur geregelt werden.
Was taugt die **** Software?
Die Software liest unter Windows Temperaturen, Spannungen, Lüftergeschwindigkeit und sogar Power Cycles aus. Übertakten in Windows ist hiermit kinderleicht möglich und funktioniert absolut einwandfrei, sofern man nicht die Grenzen der Hardware überschreitet ;)
Gibt es schon Alternativen zur **** Software?
W1zzard wird diese Woche (18.09.2006 ff) ein AW9D-Max bekommen und Support fürs Brett in SysTool einbauen.
Hilfe! Mein Board bootet einwandfrei aber ich habe trotzdem ein Piepkonzert! Ich benutze eine Wasserkühlung.
Sehr wahrscheinlich handelt es sich um das Notsignal des Boards zu Warnung vor 0 RPM am CPU Lüfter Anschluss. Das lässt sich im BIOS (abit EQ) deaktivieren.
Was hat es mit den LEDs auf sich?
Das Board besitzt blaue LEDs, die folgende Optionen besitzen: Alle LEDs an, aus oder verschieden blinkende Modi.
Ich habe von einem fehlerhaften 8 Pin EPS Stecker gelesen. Muss ich beim Board Kauf aufpassen?
Nein, ein solch fehlerhaftes Modell ist bisher weltweit nur ein einziges Mal aufgetaucht und der Fall wurde von abit direkt untersucht. Dies wird nicht mehr vorkommen.
Mein Netzteil hat nur einen 4 Pin 12V Stecker, kann ich das Board auch damit betreiben?
Ja.
Funktioniert EIST mit einem übertaktetem System?
Ja.
Hat abit auch ein BIOS Flashtool für Windows?
Ja, das abit Flashmenu ist im **** Softwarepaket enthalten und funktioniert problemlos.
Kann ich den Multi meiner CPU verstellen?
Ja, seit dem beta BIOS vom 15.09. ist es möglich, den Multi nach unten hin zu ändern. Dies gilt sowohl für ES als auch Retail CPUs.
Seit Alpha Bios 13 ist es auch möglich Multi nach oben zu verändern!
Wie gut ist der Support seitens abit für das Board?
Exzellent. abit ist bestrebt alle auftretenden Probleme so schnell wie möglich aus der Welt zu schaffen und arbeitetet dazu mit Speicherherstellern und einigen Leuten von Anandtech und XtremeSystems.org zusammen. Fortschritte werden umgehend in BIOS Updates umgesetzt.
Welche RAM Bänke soll ich nutzen? 1 und 3 oder 2 und 4?
Macht nach bisherigem Kenntnisstand keinen Unterschied.
Ein paar Bilder des Boards und der OVP bitte!
Die LEDs möcht ich auch mal sehen!
Das BIOS dann bitte auch noch.
Warum zum Teufel komme ich nur bis zu einem FSB von 350MHZ?
Fürs schnelle Testen (natürlich auf eigene Gefahr!!) am besten folgendes einstellen:
C1 und EIST disabled
VMCH: 1,75V-1,9V
DDR2 Voltage: 2,0-2,1V
Ram Timings by SPD / oder manuell
Vcore: 1,4V
Speicherteiler 1:1
Dann Testen und vorsichtig heran tasten! Gegebenfalls dann Spannungen nach unten senken!
Das ABIT ist anscheinend sehr abhängig vom richtigem RAM!
Deshalb nicht gleich aufgeben:)
WICHTIG:
Laut Hipro aus Xtremesystems undervoltet die MCH Spannung mit 0,2V!
Hier der Link zum Statement und Mod:
http://www.forumdeluxx.de/forum/showpost.php?p=4447534&postcount=1118
Hier die Vcore Tabelle von w1zzard (THX):
MIPS Wasserkühler für das ABIT AW9D-MAX
Preise:
Freezer: 39,90€
Mosfet Bridge: 43,00€
Komplettset : 155,00€
die freezer sind wie immer aufgebaut, d.h. kupferboden 5mm, messingdeckel
5mm.
Unterschiede zwischen AW9D und AW9D MAX:
Das MAX hat ne Blaue LED Rückseitenbeleuchtung+
den angewinkelten IDE Port + Firewire
Links & Downloads:
Final Bios 12 (THX@Kabautermann):
http://www.hardwarextreme.de/dave/aw9d12.rar
BIOS Downloads vom ABIT ftp server:
ftp://ftp.abit.com.tw/pub/download/bios/
Die Biosversionen fürs Non-MAX und MAX sind anscheinend die gleichen, da nur ein
AW9D Verzeichnis vorhanden ist!
Thread zum Retail Board bei Xtremesystems (Sicness:):
http://www.xtremesystems.org/forums/showthread.php?t=115839
Thread zum Retail Board im ABIT Forum (Danke Sicness):
http://forum.abit-usa.com/showthread.php?t=112896
Vielen Dank an TuricanM3 und Latest für die Pics und Scines für die FAQ
Da werde ich mir lieber nen E8400er im E0 Stepping holen.
Sagt mal bescheid wenn Ihr das 1,8er Bios gefunden habt
Wieso muss man das 1.8er BIOS finden? Wer's braucht, ich kann's ohne weiteres hochladen.
Edit: Linky http://www.hs-augsburg.de/~ingmar_k/bios/aw9d_18.zip
Und zum Thema Q6600 kannn ich nur immer wieder sagen: Es liegt nicht an den CPUs! Es ist das AW9D. Mein Xeon X3220 (der grade verkauft wurde BTW), lief anfangs nichtmal auf Standardtakt stabil. Das heißt er schien stabil zu laufen, es gab aber immer wieder sporadische Abstürze, wohingegen sonst alle Stabilitätstest liefen. Es ist ein simples Problem der zu niedrigen GTL-Ref auf dem Board, wie ich es schon oft erwähnt habe. Passt man diese Spannung an, laufen auch Quadcores stabil drauf. Übertakktungswunder wird man aber nicht erwarten dürfen. Auch wenn ich's nie wirklich getestet habe, ist das wohl abzusehen. ;)
Danke.
Welche Neuerungen hat das 1.8er ?
Und warum ist es nicht mehr offiziel ?
Es war nie offiziell. Und deshalb gibt's auch keine Release-Notes. Alle nötigen Infos stehen aber schon lange hier im Thread. ;)
Muss mal wieder den Thread beleben.
Habe meinen E6600@3200Mhz gegen einen E8600@3600Mhz (EO)Stepping getauscht.
Funktioniert alles wunderbar.
Meine Bios Einstellungen:
Bios Version 1.7
401Mhz*9
PSB1333
CPU:dRAM 1:1
CPU Core 1.3250V (Wird im Bios so angezeigt)
DDR" Voltage 2.00V
MCH 1.52V
Läuft absolut Prime und Orthos Stabil und wird nicht wärmer als 53 Grad.
Wenn ich den Rechner Neustarte funktioniert alles wunderbar,
aber wenn ich Ihn ausschalte und danach wieder einschalte dann macht er ca 1 Minute lange eine Neustart Endlosschleife mit dem Postcode 87(Check CPU Core Voltage).
Danach fährt er dann irgendwann normal hoch.
Was kann das sein ??
Es haben ja mehrere mit nem E8400 EO Stepping erfolgreich auf dem Aw9d-Max betrieben ??
Hast du eventuell ne Warnfunktion oder dergl. für die VCore aktiviert? Schau dich mal in Ruhe und sorgfältig im BIOS um. ;)
Hab alle Warnfunktionen ausgeschaltet, leider ohne erfolg.
Aber nach spätestens 2 Min. fährt er dann hoch.
Ist aber bestimmt nicht gesund bzw. sinn und zweck ;-)
Tritt das Problem auch auf, wenn Du nicht übertaktest?
CMOS-Clear schon probiert?
1,52Vmch erscheint mir auch sehr wenig für 401MHz FSB,
selbst mit dem übertaktungsfreudigeren 1333er Strap.
Bist Du sicher, dass das in allen Lebenslagen reicht?
Kannst ja mal Memtest86+ mit ner Endlosschleife Test 5
laufen lassen, wenn er freezed hast Du zu wenig Vmch.
Sehr gute Punkte. ;)
Das werde ich Heute Abend direkt mal versuchen.
Danke schonmal.
Ich berichte ;)
Na ich persönlich denke weniger, dass es an der MCH liegt. Wenn das Clear-CMOS beim CPU-Wechsel vergessen wurde, hast du höchstwahrscheinlich schon deine Problemursache. Aber probieren geht über studieren.
Obwohl ich nen CMOS-clear nach dem wechsel gemacht habe.
Und natürlich auch für ne Stunde die Batterie entfernt.
Habe gerade nochmal ganz ordnungsgemäß einen CMOS Reset gemacht.
Aber es bleibt unverändert.
Werde mir den gleichen Prozzi Testweise mal im CO Stepping holen mal schauen ;)
Glaube nicht, dass man die VID ändern kann.
Ist die wirklich 1.325V wie im BIOS angezeigt?
Was zeigt, äh, zum Beispiel CoreTemp für ne VID an?
Was passiert wenn Du manuell ne andere VCore einstellst?
VCore dürfte wohl leider nur höher gehen bei dem Board...
Wie gut geht die CPU eigentlich mit dem 10er Multi
den sie ja eigentlich haben sollte?
Und wie gut geht der ganze Spaß dann mit dem 1066er Strap?
Der E8400 hat nen 9er Multi.
In der Signatur ist noch der alte Prozzi.
Vcore ist Standartmäßig 1,250 im Bios
CoreTemp:1,1750
CPUZ:1,200
Zeigen alle andere Werte an.
Habs mit 1,350 Vcore im Bios auch schon ausprobiert.
Geht leider auch nicht.
Genau wie der 1066er stap.
Werde mal nen CO E8400 ausprobieren.
OK, die angezeigten unterschiedlichen Werte passen zu der These,
dass es ein Problem beim Auslesen der VID Deines 8400 gibt.
Liegt vielleicht unterhalb der Skala Deines Boards ;)
Da kann ich nur viel Glück wünschen, dass ein C0 besser läuft.
Die Vid kann man mit Isolierband und etwas Silberleitlack ohne Weiteres (wenn man weiß was man tut) verändern. Alles was man dazu noch zusätzlich braucht ist das Datenblatt von Intel mit der Belegung der LGA775 Lands. ;)
wurde eigentlich mit der inoffiziellen 1,8 er version einige Vid´s hinzugefügt.
Konnte hier im Sammelfred nix über die 1.8 version lesen ??
Es wurden in der 1.8er "Beta" neue Microcodes eingepflegt. Es gilt allerdings als "etwas" buggy.
buggy = fehlerhaft
LOL
Ich weiss schon was Buggy heisst :-)
Läuft das 1,8er nicht so stabil oder warum
sollte man es lieber nicht draufmachen ??
So, mit CO Stepping lüppt alles ohne Probleme :)
3,6Ghz sind auch möglich.
MCH liegt bei 1.52v.
Wird auch nicht wärmer wie nen EO !
Hallo leute, bin Neu hier und hab euch über Dr. Google gefunden ^^
Ich sah gleich bei "ENZYME" das du auch den E8400 hast und das auf 3,6 GHz und auch das Abit AW9D-Max hast.. hier sind etlich Seiten zu lesen, also falls dus schonmal hier beschrieben haben solltest tuts mir leid das ich nochmal Frage.
Würdest du mir bitte bitte sagen was man im Bios einstellen muss das der Prozessor auf 3,6 GHz läuft... ?? Einfach alles wie es bei dir eingestellt ist :)
Wäre dir sehr sehr dankbar dafür.
Mein System:
Abit AW9D-Max Mainboard
Intel E8400 @ 3 GHz
2 x 2 GB DDR2 800 ram
650 Watt Markennetzteil.
Guter CPU Lüfter, marke müsste man nachschauen.
Bios Version 1.7
400Mhz x 9
PSB1333
CPURAM 1:1
CPU VCore 1.250V (Wird im Bios so angezeigt)
DDR Voltage 2.00V
MCH 1.52V
Hatte mit nen EO probleme.
Der ältere CO läuft um längen besser und kühler !!
Eventuell VCore auf 1,3 erhöhen.
Wie gesagt jede CPU ist anders.
Und das Board ist sehr Eigen wenn es um Ram Speicher geht :(
