[Sammelthread] AMD FX-Series "Zambezi" OC Thread
Techtrancer
Urgestein
Wien
AMD FX-Series
"Zambezi"
OC Thread
AMD OC Vorgaben
CPU SPEC
Steppinglisten :
Erste Tests der neuen FX Serie:
CPU-Z:
FX-8150 @ LN2 @ 8,585 ghz ==> AndreYang`s CPU Frequency score: 8585 mhz with a FX-8150
FX-8150 @ LHe @ 8,429 ghz ==> macci`s CPU Frequency score: 8429.38 mhz with a FX-8150
FX-8150 @ LN2 @ 8,101 ghz ==> NAMEGT`s CPU Frequency score: 8101.22 mhz with a FX-8150
FX-8150 @ Air @ 5,313 ghz ==> InComing`s CPU Frequency score: 5312.97 mhz with a FX-8150
FX-8120 @ Air @ 5,308 ghz ==> NAMEGT`s CPU Frequency score: 8101.22 mhz with a FX-8150
WPrime 32m
FX-8150 @ LN2 @ 7,055 ghz @ 4,672s ==> icebob`s wPrime 32m score: 4sec 672ms with a FX-8150
FX-8150 @ LN2 @ 7,033 ghz @ 4,546s ==> Radi`s wPrime 32m score: 4sec 546ms with a FX-8150
FX-8150 @ LN2 @ 6,523 ghz @ 4,890s ==> hokiealumnus`s wPrime 32m score: 4sec 890ms with a FX-8150
FX-8120 @ H20 @ 5,001 ghz @ 6,724s ==> kirbster`s wPrime 32m score: 6sec 724ms with a FX-8120
WPrime 1024m
FX-8150 @ LN2 @ 7,023 ghz @ 141,156s ==> Radi`s wPrime 1024m score: 141sec 156ms with a FX-8150
FX-8120 @ LN2 @ 6,647 ghz @ 157,763s ==> G.Foyle`s wPrime 1024m score: 157sec 763ms with a FX-8120
FX-8120 @ H20 @ 5,163 ghz @ 200,07s ==> equinox`s wPrime 1024m score: 200sec 7ms with a FX-8120
FX-8120 @ H20 @ 5,039 ghz @ 206,963s ==> equinox`s wPrime 1024m score: 206sec 983ms with a FX-8120
FX-8150 @ Air @ 5,016 ghz @ 200,961s ==> Vladutz20`s wPrime 1024m score: 200sec 961ms with a FX-8150
Superpi 1m
FX-8150 @ LN2 @ 8,009ghz @ 10,813s ===> NAMEGT`s SuperPi score: 10sec 813ms with a FX-8150
FX-8150 @ H20 @ 5,900ghz @ 14,945s ===> riska`s SuperPi score: 14sec 945ms with a FX-8150
Bulldozer Overclocking Guide´s
OC TIP's MAINBOARD
Je mehr Spannungswandler ein Mainboard hat, desto stabile hällte es zumeist die Spannung.
Da beim Übertakten oftmals die Spannungswandler sehr warm werden, kann dies zu Instabilität führen. Daher ist es ratsam, sofern ausreichend Platz im Tower ist, die Spannungswandler aktiv zu kühlen.
Weites bringt zumeist auch der Wärmeleitpädtausch gegen ein hochwertiges Wärmeleitpad oder Wärmleitpaste eine bessere Wärmeableitung. Birgt jedoch die Gefahr dass bei falscher Montage ein oder mehrere Spannungswandler nicht gekühlt werden und die Hardware kaputt geht.
Um Spannungsschwankungen zwischen Load und IDL anzupassen und zu minimieren gibt es die LLC (Load Line Calibration) Bei normalem OC für 24/7 Nutzen ist zumeist die goldene Mitte Bzw 50% optimal.
> Mehr Informationen dazu <
> Forumsbeitrag <
OC TIP´S CPU
Bei den FX Prozessoren ist es so dass sich manche Mutil (CPU, HT & NB) Kombinationen besser und andere schlechter miteinander vertragen. Bei Kombinationen die sich gut miteinander vertragen braucht der Prozessor weniger spannung, bleibt kühler und schafft mehr Ramtakt.
Gut vertragen sich gerade CPU Multiplikatoren und derew Halben Multiplikatoren mit geraden CPU-NB & HT Link Multis.
Ebenso vertragen sich ungerade CPU Multiplikatoren und deren Halben gut mit ungerades CPU-NB & HT Link Multis.
Hier ein Screenshot welche sich mit einander gut vetragen. Jeweils GELB und GRÜN gehört zusammen
Hier sowohl als Screenshot bis Reftakt 250 bzw als auch als XLS bis Reftakt 350
AMDFXKalkulator.xlsx
Beim Übertakten empfiehlt es sich Turbo, C3, C6, Cool n' Quiet, Spread Spectrum,.... zu deaktivieren, da er zumeist für mehr Stabilität sorgt
Bei FX CPU´s mit C0 Stepping sind die Coretemps nicht kalibriert. Darum immer nach dem Tempsensor dess Mainboards richten und nicht den Core Temps ==> > Link <
Je kühler, desto besser lassen sie sich Prozessoren takten und desto weniger V-Core und CPU-NB benötigen sie
Je weniger V-CORE und CPU-NB anliegt um so kühler bleiben der Prozessor und besser takten lässt er sich
Wenn der HT Link den selben Takt wie die NB hat, bringt es ein Leistungsplus. Ein hoher HT-Link kann aber auch zu Instabilitäten führen. Ältere Mainboards sind davon äher betroffen als Neuere.
Je höher der tRC des Ramspeicher ist um so weniger V-Core & CPU-NB benötigt der Prozessor und um so kühler bleibt er und lässt sich besser takten Link
OC TIP´S RAM
Bei der Speicherbestückung sollte man darauf achten gleiche Speicher zu verwenden.
Wichtig dabei ist jedoch nicht dass Aussehen der Speicher, sondern die Chipbestückung.
Im Idealfall sind alle Speicher von der selben Charge. Dennoch kann es je nach Selektion auch bei gleichen Chargen zu Streuungen kommen. Wer also besonderes Gute Ramspeicher haben möchte, sollte sich mehrere von einer Charge kaufen und dann die Riegel einzeln testen und selektieren.
Wenn man nur 2 Speicher Sticks verwendet, sollte man testen ob die Inneren oder Äusseren Ramslots besser funktionieren. Dies kann von Speicherbestückung zu Speicherbestückubg variieren.
Manche Chips laufen auf den Inneren besser und andere auf den Äußeren.
Dass weiteren sollte man die Speicher und Slots auch einzeln testen und den besseren Speicher im schlechteren Slot verbauen bzw den schlechteren Speicher im besseren Slot.
Wenn man 4 Speicher Sticks verwendet, empfiehlt es sich jeden Speicher einzeln zu testen. Weiters auch jeden Slot einzeln zu testen. Danach den besten Ramspeicher in den schlechtesten Slot zu verbauen. Zweitbesten Ramspeicher in den zweitschlechtesten Ramslot Usw.....
Es gibt Single Ranked, Dual Ranked, Quad Ranked,...Ramspeicher.
Je höher der Rank, desto mehr wird dass IMC der CPU belastet und so geringer ist zumeist der Maximaltakt. Daher sind Single Ranked Ramspeicher zu bevorzugen.
Weiters wird dass IMC um so mehr belastet, je mehr Ramspeicher verwendet werden.
Bezüglich IMC Belastung kann man grob sagen dass 2 bzw 4 Single Ranked Ramspeicher ähnlich stark belasten wie 2 Bzw 2 Dual Ranked Ramspeicher
Im RAM Menü kann man zwischen Ganged und Unganged wählen. Bei Ganged profitieren Single Thread Anwendungen und bei Unganged Multithread Anwendung.
Jedoch bleibt die CPU bei Ganged etwas kühler und benötigt auch etwas weniger V-Core!
Wenn man tRAS bei den Ramspeicher mit der Summe aus CL + tRCD + tRP bereibt, führt dies zu mehr Stabilität ==> > Link <
Max Lese Latenz auf 56 sowie 4 Bank Akt. Fenster auf 32 bringt ein Leistungsplus ==> > Link<
Zeilen Refresh Zyklus 0-3 von den originalen 60 auf bis zu 350ns anheben kann einen höhren Ramtakt ermöglichen. ==> > Link <
On die Terminierung A & B von den originalen 80 auf bis zu 240 ohm anheben oder auf 60 herunter setzen kann einen höhren Ramtakt und CPU Takt ermöglichen. ==> > Link <
Write to Read Delay + CAS Lese zu Precharge Zeitspanne = Zeitspanne der Schreibewiederherstellung ==> > Link <
Diese Drive Skew Einstellungen haben sich bei mir als stabil bewiesen ==> Link
Vorgehensweise beim Übertakten
1. Deaktivieren: Turbo, C3, Cool n' Quiet, Spread Spectrum, APM,....
2. Neu Booten, da sich die V-Core nach dem Deaktivieren des Turbos ändert
3. AOD starten und kontrollieren ob Grün aktiviert ist und notfalls aktivieren und übernehmen ==> > Link <
4. In AOD kontrollieren ob der Turbo deaktiviert ist und notfalls deaktivieren und übernehmen. ==> Link
5. MIt CPU-Z und AOD kontrollieren ob der Turbo unter Last wirklich dektiviert ist und alle Cores gleich hoch takten
6. Minimale RAM Spannung bei gewünschtem Takt & Timings ausloten (Im Windows undter Load erspart dauernde Biosresets) CPU & NB dabei herunter Takten um die als Fehlerquelle auszuschließen. Mindestens 1 Stunde Prime Custom Blend ist dabei sehr zu Empfehlen. Je länger um so besser. Testspeichermenge dabei so wählen dass gerade nicht ausgelagert wird. Etwas Puffer sollte man allerdings lassen da die Speichernutzung von Windows etwas schwankt. Etwa 3 GB funktionieren im Normalfall als Puffer recht gut. Wer auf Sicherheit bedacht ist macht 24h.
7. Minimale CPU NB Spannung bei gewünschtem Takt ausloten. CPU & RAM dabei herunter Takten um die als Fehlerquelle auszuschließen. Prime Large über mindestens 3-4 Stunden. Wer auf Sicherheit bedacht ist macht 24h.
8. Minale V-Core testen. CPU NB und RAM dabei herunter Takten und es als Fehlerquelle auszuschließen. Prime Large über mindestens 3-4 Stunden. Wer auf Sicherheit bedacht ist macht 24h.
9. CPU NB zusammen mit dem RAM testen. CPU heruntertakten und sie als Fehlerquelle auszuschließen.
Jetzt kann es unter Last zu Einbrüchen der der Spannung kommen und man muss bei Bedarf nachjustieren. (Takt und/oder Spannung) Prime Large über mindestens 3-4 Stunden. Wer auf Sicherheit bedacht ist macht 24h.
10. CPU zusammen mit dem RAM testen. CPU NB heruntertakten um sie als Fehlerquelle auszuschließen
Jetzt kann es unter Last zu Einbrüchen der Spannung kommen und man muss bei Bedarf nachjustieren. (Takt und/oder Spannung) Prime Large über mindestens 3-4 Stunden. Wer auf Sicherheit bedacht ist macht 24h.
11. CPU Zusammen mit der CPU NB testen. RAM dabei heruntertakten um ihn als Fehlerquelle auszuschließen. Jetzt kann es unter Last zu Einbrüchen der Spannung kommen und man muss bei Bedarf nachjustieren. (Takt und/oder Spannung) Weiters kann es hier zu Temperaturproblemen kommen da CPU & NB zusammen eine erhöhte Temperatur als einzeln erzeugt. Prime Large über mindestens 3-4 Stunden. Wer auf Sicherheit bedacht ist macht 24h.
12. Alles zusammen testen. Jetzt kann es abermals unter Last zu Einbrüchen der Spannungen kommen und man muss bei Bedarf nachjustieren. (Takt und/oder Spannung) Prime Large über mindestens 3-4 Stunden. Wer auf Sicherheit bedacht ist macht 24h.
Nützliche Programme
AMD Overdrive (AMD Auslese und Einstellungs Tool ==> > Link <
SIW (Auslesesoftware) ==> > Link <
Everest (Auslesesoftware) ==> > Link <
HWinfo (Auslesesoftware) ==> > Link <
SIV (Auslesesoftware + Stabilitätstest) ==> > Link <
CPU-Z (Auslesen von Taktraten) ==> > Link <
HWMonitor (Auslesesoftware) ==> > Link <
Aida64 (Auslesesoftware) ==> > Link <
Coretemp (Auslesesoftware) ==> > Link <
TMonitor (Liest Taktraten in Echtzeit aus) ==> > Link <
Prime95 (Stabilitätstest) ==> > Link <
LinX (Stabilitätstest) ==> > Link <
y-cruncher (Stabilitätstest) ==> > Link <
BurnInTest (Stabilitätstest) ==> > Link <
Intel Burn Test (Stabilitätstest) ==> > Link <
OCCT (Stabilitätstest) ==> > Link <
Core Demage (Stabilitätstest) ==> > Link <
Memtest (RAM Stabilitätstest) ==> > Link <
Testmem 5 (RAM Stabilitätstest) ==> > Link <
S & M (RAM Stabilitätstest) ==> > Link <
RAMMon (RAM Auslesesoftware) ==> > Link <
Thaiphoon Burner (RAM Auslesesoftware) ==> > Link <
ROG Mem Tweak It (RAM Timings & Sub) ==> > Link <
Realbench (Benchmark) > Link <
WPrime (Benchmark) > Link <
Cinebench (Benchmark) > Link <
SuperPiMod (Benchmark) > Link <
Nuclearus (Benchmark + Stabilitätstest) ==> > Link <
Bildschutz Pro (Bildsignatur) > Link <
Stilt Bulldozer Conditioner (Tuning Tool für SuperPI und mehr) ==> > Link <
Amdmsrtweaker (Softwarelösung zum Aktivieren / Deaktivieren von APM und Turbo sowie Konfigurieren der P Stats
Deaktivieren von APM: Eine TXT mit dem Inhalt "AmdMsrTweaker.exe turbo=0 APM=0" und dem Namen APM.bat erstellen und als .bat sprichern und starten. Damit es reibungslos funktioniert sollte AOD jedoch deinstallieren werden da es ansonsten zu Komplikationen kommt.
Konfigurieren der P Stats:> Link <
Amdmrstweaker kann man auch dem Autostart hinzufügen > Link <
CPU schleifen
Zuerst den Prozessor in den beiliegenden Schaumgummi drücken, damit sich die Pins nicht so leicht verbiegen.
Danach mit Nassschleifpapier mit flächigem Druck auf den Schaumgummi kreuzweise auf einer Glaspaltte schleifen (Handballen)
Wer sich Zeit ersparen möchte, kann am Beginn ein Gröberes in der Stärke 500-600 verwenden
Für den Endschliff empfehle ich 1000-1500
Nach dem Schleifen den Schaumgummi enfernen und mit einer Kreditkarte prüfen ob alle Pins gerade sind
Falls Pin´s verbogen sind, so kann man diese mit der Kreditkarte vorsichtig gerade biegen
Sollte noch Feuchtigkeit auf der CPU oder den Pins sein, entweder trockenen lassen oder einen Föhn zur Hilfe nehmen
Hier Fotos von einer CPU, welche ich vor längerer Zeit geschliffen habe
Hier noch ein weiterer sehr guter Thred bezüglich HS schleifen incl Testergebnisse
Lapped my FX-8350, 4.3GHz OC'ed temps lowered by 9°C - AnandTech Forums
den thread hab leider übersehen!
mir ist es egal welcher thread weiter geführt wird
find nur OC und stepping thread sollte gesplittet sein da es sonst untergeht wenn wer ein ergebnis für die liste postet
und es wäre hald auch gut wenn in der steppingliste ramtakt, ram spannung, nb takt, nb spannung, ht takt, ht spannung, cpu takt und cpu spannung, mainboard (AM3, AM3+,...) und betriebssystem aufscheinen würd da die ergebnisse dann aussagekräftiger und zugleich besser vergleichbar sind
Duplex hat seinen thread dicht gemacht
also kann man diesen hier verwenden :)
Willst du wirklich sämtliche eingestellten Werte wissen ? Ich glaube, das alles zu posten bei einem Eintrag wird den meisten Usern zuviel sein.
nönö
so wie im steppingthread passt es schon :)
hört sich nur nach viel an
ist es aber nicht :d
kannst du die timings auch straffer ziehen?
CL10 ist grottig langsam!
und ev auch im OC thread weiter posten?
dann könnt hier im infosammelthread wieder etwas ruhe einkeheren bis es neuigkeiten von der AMD front gibt
Da der Bulli Thread wieder einmal vom Thema abschweift machen wir einfach hier weiter.
Timings sollte noch was drin sein. Die aktuellen wurden vom Bios eingestellt.
Edit: Wie viel Volt max kann ich denn den Rams geben wenn Standard Spannung 1.35V beträgt?
Für die welche sich dafür Interessieren. Ein paar Tests.
Links jweils auf Standardtakt mit 3.3GHz und rechts auf 4GHz übertaktet
Aida64 Cache & Memory Benchmark
Cinebench Multi
Cinebench Einzel
Truecrypt
WinRar
bin auf tests mit strafferen timings gespannt :)
probier ev mal 7-10-7 oder 7-9-7 ......
falls 5-5-5 oder 6-6-6 oder 7-7-7 mit deinen rams laufen würd wärs natürlich bombig
aber da bräuchtest vermutlich elpida hyper oder so
Naja die Rams wollen wohl doch nicht so. Sobald ich auf 9-11-10 reduziere bootet er schon nicht mehr. Ach wenn ich Spannung von Ram von 1.35 auf 1.5 anhebe. Muss man noch eine andere Spannung erhöhen?
Hi Reous
kannst du mal HT und NB mit 2500 probieren und dazu die Rams dann auf 1600 mit schärferen Timings stellen? Normal sollte um 2500 NB syncron zu HT der Ram am besten abschneiden laut den derzeitigen Test.
lg
Kann ich leider nicht probieren. Ab 2400 fangen Probleme an. Spannungserhöhungen haben bisher nicht viel gebracht.
probier ev mal die cpu-nb anzuheben
kann sein dass sie wegen der strafferen timings mehr spannung brauch
selbiges beim taktanheben der nb
am besten wärs aber wenn du den ram ohne cpu und nb OC mal anständig auslotest um den ram als mögliche fehlerquelle auszuschliessen
Hi
wenns um ram geht ist der Techtrancer der profi ;)
ok zu HT NB versuche wenn möglich sie gleich zu betreiben
als wenn 2200 dann beide so, scheinbar macht das schon
was aus um 2500 sah es am besten aus.
lg
Hab jetzt mal HT/NB mit 2200 und 2400 laufen lassen mit 800mhz 9-9-8 speicher takt
Winrar: 3.370 => 3.497
Cinebench: 4.03 => 4.08
Aida: Memory und L3 Steigerung zwischen 1 - 7%
nice nice
kannst du den ramtakt noch weiter hoch ziehen
oder schaffen deine rams ev auch straffere timings?
Bzw welche sind es genau und kannst ev pics von den rams machen?
Ev lässt sich rausfinden welche chips darauf verbaut sind und folglich auch mit welchen timings sie am besten laufen
@ Reous
Wie lautet dein Stepping ?
Wo hast du deinen Prozzi gekauft ? Mindfactory ?
Gekauft bei VibuOnline aber ist ja der selbe Laden wie Mindfactory.
Stepping siehe Bild
Ram hab ich Corsair Vengeance LP.
Takt geht höher aber dann eben mit schlechteren Timings.
Aktuell hab 887MHz mit 9-10-9 und 1.41V eingestellt. Auf stabilität aber noch nicht getestet.
Edit: Windows neu installieren nach CPU Wechsel ist ja nicht zwingend ratsam oder?
mach mal pics von beiden seiten von den rams
die gibts sicher mit unterschiedlichster chip bestückung
Danke fürs Bild. ;)
Welches Board verwendest du ?
Ich bin mir gerade unschlüssig, ob ich nicht doch zuschlagen soll und mir so einen Prozzi samt Board hole. Tendiere zu einem Gigabyte Board, da mir alleine der Preise für die Asus Boards schlecht wird.
Was meint ihr ? Warten ?
blos kein GB
es sei denn du magst net extrem hohe taktraten fahren
obwohl andrerseits........vom layout und preis/leistungs verhältniss machts GA-990XA-UD3 nen guten eindruck
is hald die frage es OC technisch ist
an welches board hast du gedacht?
Verwende das Asus M5A99X Evo.
Von GB würd ich momentan auch abraten bzw warten bis eine Rev. mit LLC rauskommt.
Wie ist denn so deine Speicherspannungsskalierung im BIOS ? Sehr grob oder ziemlich fein abgestuft.
Spcial hat doch ein GB 990FXA-UD7 in Besitz, er könnte was zum Board sagen.
Habe gerade gesehen, dass die kleinen GB Boards keine Resettaster und CMOS-Clearer haben. Das nervt voll.
Hatte/Habe das UD7 selbst hier bei mir. Es hat mir ganz gut gefallen bis auf die V-Core Schankung von ca 0.04V
Beim Asus sind eigentlich alle wichtige Spannungen in 0.00625V Schritten einstellbar.
@Techtrancer: Meinst du Bilder von den Beschriftungen auf der Kühloberseite der Rams?
Ist bei anderen Herstellern, Asrock, Asus usw. bestimmt auch so,
Nervt wenn man übertakten will, aber Overclocker mussten eh immer mehr bezahlen, für OC Bios und CMOS-Clearer Taster.
Da muss man aufpassen, wenn kein CMOS-Clearer Taster, dann auch kein besonderes OC Bios.
Habe mir gerade nochmal das Sabertooth von Asus angeschaut....naja, obwohl preislich interessant, würde ich es nicht nehmen, der Test von Hardwareluxx darüber war nicht sehr überschwinglich erfreulich.
@ Reous
Läuft dein Asus stabil mit der Vcore oder gibt es auch Schwankungen ?
@ Terrier
Danke, habs auch gerade gesehen, nur die Oberklasseboards haben das. :( Aber knapp 200 € für was eventuell nicht ganz ausgereiftes Board ist mir eigentlich zu schade.
Wer sagt denn was von OC-Profi ? Bei mir gehts nur allgemein um den OC-Spass und die Testerei und ich habe nicht den Bock / zeit, mehrere Boards ausführlich zu testen. Daher sollte es gleich das erste richtige Board sein.
Was ist von den besseren AsRock zu halten ?
irgendwo sollten sticker oder so auf dne rams sein
mir auch, aber dann kann man na klar nicht zum OC Profi werden.
OC mit alter hardware macht doch auch spass!
erst jetzt wo bald DDR4 ansteht wird DDR3 interessant bzw erst jetzt werden die PII so richtig interessant weil die hardware nicht mehr so viel kostet
Zur VCore. Getestet mit einem 1090T
Mein FX6100 scheint nicht der beste zu sein. Nach 1h Prime bei 4.2GHz@1.33V ist wieder der letzte Kern ausgestiegen
