Das ist eine gute Frage. Es sieht zumindest so aus. Ich hoffe, dass ich noch was in den Einstellungen / PCI register einstellen kann. Man muss bedenken, dass ich oben mit CL2,5 getestet habe.Allerdings sehen die AIDA Werte unterirdisch aus… ist der KT600 was das angeht echt so schlecht?
# | NB chipset | Interface | SC / DC | CPU Multi | FSB | DIMM | dimm timings | CB 2003 | SuperPI 1M | SuperPI 32M | AIDA read | AIDA write | AIDA copy | AIDA latency |
13 | VIA KT600 | - | SC | 12x | 166Mhz | 166MHz | 2-2-2-6 | - | 56,422 s | 49m 04,172s | 2363 MB/s | 2339 MB/s | 2339 MB/s | 133,9 ns |
14 | VIA KT600 | - | SC | 12x | 166Mhz | 200MHz | 2-3-2-6 | - | 56,032 s | 48m 48,641s | 2441 MB/s | 2300 MB/s | 2353 MB/s | 133,2 ns |
15 | VIA KT600 | - | SC | 10x | 200MHz | 200MHz | 2-3-2-6 | - | 53,640 s | 46m 46,062s | 2853 MB/s | 2810 MB/s | 2809 MB/s | 119,6 ns |
16 | VIA KT600 (tweaked) | - | SC | 12x | 166Mhz | 166MHz | 2-2-2-6 | - | 54,484 s | 47m 33,672s | 2450 MB/s | 2372 MB/s | 2394 MB/s | 122,8 ns |
17 | VIA KT600 (tweaked) | - | SC | 12x | 166Mhz | 200MHz | 2-3-2-6 | - | 54,032 s | 47m 05,469s | 2522 MB/s | 2332 MB/s | 2412 MB/s | 122,8 ns |
18 | VIA KT600 (tweaked) | - | SC | 10x | 200MHz | 200MHz | 2-3-2-6 | - | 52,093 s | 45m 22,547s | 2902 MB/s | 2844 MB/s | 2855 MB/s | 112,6 ns |
PCI register b0d0f0
offset 54 (CPU FSB Frequency select)
[2] PCI Master 8QW Operation
1 = enable
offset 55 (DRAM control)
[0] Write recovery time
DDR333 2T=0 / 3T=1
DDR400 3T=0 / 5T=1
[1] auto precharge for TLB read or CPU writeback
1= enable
[6] fast read-to-read-turn-around
1= enable
offset 66 (DRAM arbitration control)
[6] DRAM Access
2T=0 / 3T=1
offset 6B (DRAM arbitration control)
[5] Burst refresh
1= enable
offset 6C (DRAM drive control)
[0] DDR400 Twtr timing control
1T=0 / 2T=1
[5-4] SCMD/ MA early clock select (for 1T command)
00= latest
11= earliest
[7-6] CKE early clock select
00= latest
11= earliest
offset D4 (BIU control 1)
[0] fast write-to-read turnaround
1= enable
offset DF (BIU control 5)
[4] 166/200 performance improvement in host CPU master read ready logic
1= enable
[5] 166/200 performance improvement in master request logic
1= enable
[6] delay 1T for speculative read command
1= enable
[7] transparent MD to HD in synchronous mode for performance improvement
1= enable
ECS K7S5A (Pro)?At which motherboard are we looking here
I know, why you're recapping it. I expect a mighty XP-M with SD-RAMFor those who have seen many: At which motherboard are we looking here 😁
Yep, sharp like always. I will see what to do with it. It depends on some factors if it will run in TC.ECS K7S5A Rev. 3.1
Das Pro hat den einen Metallchip (keine Ahnung was das ist) nicht.
Das ist für mich der spannendste Teil vom TC. Bin auch auf den Northwood-128 Teil gespannt. Ein paar Celerons habe ich hier.… könnte ein schönes Duell zwischen Tualatin, P4 und Athlon XP werden, die gab es alle drei mit SD.
As far as I know the bug was fixed within the Cheapo BIOS. I didn't test this aspect myself yet, but I read about it.Well it has a 166MHz devider. It just does not boot it… Hardware bug.
Also KT266A mit SD-RAM sind mir unbekannt, alle setzten auf DDR-RAM.Für das schnellste SD-RAM System würde ich mir ein KT266A Board mit SD-RAM suchen. Sind selten, gibts aber. Der KT266A ist ne Ecke schneller als der SiS 735. Was natürlich recht cool ist, ist dass das K7S5A einen Teiler für 166 FSB hat (mit Mod BIOS), aber ich denke viel weiter geht das auch nicht vom FSB.
Was es nicht alles gab.
