digitalbath
Mr. Oldschool-Bios
- Ort
- Moers
- AMD R7 5800X
- ASRock B550 Steel Legend
- Scythe Fuma 2
- Crucial Ballistix DDR4 3600 32GB
- ASRock B580 Steel Legend
- Acer B277UE
- 2x500GB; 1x1000GB
- Soundkarte
- Xonar Essence / K340 / HD580
- Geometric Future King Arthur
- BeQuiet! PurePower11 600W
- Keyboard
- Corsair K90
- Mouse
- Roccat Kova
- Win11
- Webbrowser
- der rote Fuchs
Ich bekomme seine RAM und alpha timings nicht hin. Da machen meine boards nicht mit.
Nutzt Infra nicht ein AN7?
quälen kann man Asus und Asrock und vielleicht noch MSI. davon gibts genug.
Fand die Serie nicht übel.
My next project will probably be a new revision for the FireRAM, the current design was made a couple of years ago and contains some design errors. I've also got some more experience in hardware/PCB design now so there are some things that i want to improve before ordering new PCB's. But no promises are made here, these are projects that i do in my spare time so i like to work on stuff that motivates me, and this motivation mostly comes from random thoughts/ideas.
I will write it here. I have to redo the BIOS, that I did for you. I did a mistake in the memory setting part. Nothing critical, but instead of set the tRCD value to 2 my code deactivates the bank interleave setting. 😅 I will correct it. The second bad news is that the drive strengh values for the CPUs will not work for now. The system resets it back to the "auto" values. I was able to test it with my S462 KT133 board. My guess is, that this values will only work if I am able to do a reset command via southbridge. Same goes for the S2K timings like the "WRDATA Delay". VIA specifies this also in the datasheet:
