Ich habe mal auf dem Handy 2 WLAN Logger mitlaufen lassen, die unter anderem die Abbrüche "dokumentieren". (Leserichtung im Log von unten nach oben, im Bild von oben nach unten).
Kann damit jemand was anfangen?
18:02:34: android.net.wifi.RSSI_CHANGED , newRssi = -62
18:02:28: android.net.wifi.SCAN_RESULTS , scan result =
18:02:27: android.net.wifi.RSSI_CHANGED , newRssi = -65
18:02:01: android.net.conn.CONNECTIVITY_CHANGE , Connected to wifi , connected to "Amplifi"
18:01:59: android.net.wifi.STATE_CHANGE , state :CONNECTED , detailed state :CONNECTED
18:01:59: android.net.wifi.RSSI_CHANGED , newRssi = -59
18:01:59: android.net.wifi.STATE_CHANGE , state :CONNECTING , detailed state :OBTAINING_IPADDR
18:01:59: android.net.wifi.supplicant.STATE_CHANGE , newState = COMPLETED
18:01:59: android.net.wifi.STATE_CHANGE , state :CONNECTING , detailed state :AUTHENTICATING
18:01:58: android.net.wifi.supplicant.STATE_CHANGE , newState = FOUR_WAY_HANDSHAKE
18:01:58: android.net.wifi.supplicant.STATE_CHANGE , newState = ASSOCIATED
18:01:58: android.net.wifi.supplicant.STATE_CHANGE , newState = ASSOCIATING
18:01:58: android.net.wifi.supplicant.STATE_CHANGE , newState = SCANNING
18:01:58: android.net.wifi.supplicant.STATE_CHANGE , newState = DISCONNECTED
18:01:57: android.net.wifi.supplicant.STATE_CHANGE , newState = ASSOCIATING
18:01:57: android.net.wifi.supplicant.STATE_CHANGE , newState = DISCONNECTED
18:01:55: android.net.conn.CONNECTIVITY_CHANGE , Connected to mobile network
18:01:54: android.net.wifi.supplicant.STATE_CHANGE , newState = SCANNING
18:01:54: android.net.conn.CONNECTIVITY_CHANGE ,
18:01:53: android.net.wifi.STATE_CHANGE , state : DISCONNECTED , detailed state : DISCONNECTED
18:01:48: android.net.wifi.RSSI_CHANGED , newRssi = -63
18:01:43: android.net.wifi.RSSI_CHANGED , newRssi = -74
18:01:38: android.net.wifi.RSSI_CHANGED , newRssi = -75
18:01:37: android.net.wifi.RSSI_CHANGED , newRssi = -73
