Dec 21 19:17:24 srvhome kernel: [ 0.095555] x86: Booting SMP configuration:
Dec 21 19:17:24 srvhome kernel: [ 0.095557] .... node #0, CPUs: #1 #2 #3 #4
Dec 21 19:17:24 srvhome kernel: [ 0.097243] MDS CPU bug present and SMT on, data leak possible. See
https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Dec 21 19:17:24 srvhome kernel: [ 0.097243] #5 #6 #7
Dec 21 19:17:24 srvhome kernel: [ 0.097243] smp: Brought up 1 node, 8 CPUs
Dec 21 19:17:24 srvhome kernel: [ 0.097243] smpboot: Max logical packages: 1
Dec 21 19:17:24 srvhome systemd[1]: Started Refresh fwupd metadata regularly.
Dec 21 19:17:24 srvhome kernel: [ 0.097243] smpboot: Total of 8 processors activated (57568.57 BogoMIPS)
Dec 21 19:17:24 srvhome kernel: [ 0.100096] devtmpfs: initialized
Dec 21 19:17:24 srvhome kernel: [ 0.100096] x86/mm: Memory block size: 128MB
Dec 21 19:17:24 srvhome kernel: [ 0.100319] PM: Registering ACPI NVS region [mem 0xb9d94000-0xb9d9afff] (28672 bytes)
Dec 21 19:17:24 srvhome kernel: [ 0.100319] PM: Registering ACPI NVS region [mem 0xd8c6d000-0xd9195fff] (5410816 bytes)
Dec 21 19:17:24 srvhome kernel: [ 0.100319] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Dec 21 19:17:24 srvhome systemd[1]: Started Daily rotation of log files.
Dec 21 19:17:24 srvhome kernel: [ 0.100319] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
Dec 21 19:17:24 srvhome kernel: [ 0.100319] pinctrl core: initialized pinctrl subsystem
Dec 21 19:17:24 srvhome kernel: [ 0.100319] PM: RTC time: 18:08:36, date: 2020-12-21
Dec 21 19:17:24 srvhome kernel: [ 0.100319] NET: Registered protocol family 16
Dec 21 19:17:24 srvhome kernel: [ 0.100319] audit: initializing netlink subsys (disabled)
Dec 21 19:17:24 srvhome kernel: [ 0.100319] audit: type=2000 audit(1608574116.032:1): state=initialized audit_enabled=0 res=1
Dec 21 19:17:24 srvhome kernel: [ 0.100319] EISA bus registered
Dec 21 19:17:24 srvhome systemd[1]: Started Daily man-db regeneration.
Dec 21 19:17:24 srvhome kernel: [ 0.100319] cpuidle: using governor ladder
Dec 21 19:17:24 srvhome kernel: [ 0.100319] cpuidle: using governor menu
Dec 21 19:17:24 srvhome kernel: [ 0.100319] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
Dec 21 19:17:24 srvhome kernel: [ 0.100319] ACPI: bus type PCI registered
Dec 21 19:17:24 srvhome systemd[1]: Started Message of the Day.
Dec 21 19:17:24 srvhome kernel: [ 0.100319] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Dec 21 19:17:24 srvhome kernel: [ 0.100319] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
Dec 21 19:17:24 srvhome kernel: [ 0.100319] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
Dec 21 19:17:24 srvhome kernel: [ 0.100319] PCI: Using configuration type 1 for base access
Dec 21 19:17:24 srvhome systemd[1]: Started Clean PHP session files every 30 mins.
Dec 21 19:17:24 srvhome kernel: [ 0.100319] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
Dec 21 19:17:24 srvhome kernel: [ 0.100319] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dec 21 19:17:24 srvhome kernel: [ 0.100558] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Dec 21 19:17:24 srvhome kernel: [ 0.100558] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Dec 21 19:17:24 srvhome systemd[1]: Condition check resulted in Timer to automatically fetch and run repair assertions being skipped.
Dec 21 19:17:24 srvhome kernel: [ 0.100558] fbcon: Taking over console
Dec 21 19:17:24 srvhome kernel: [ 0.100558] ACPI: Added _OSI(Module Device)
Dec 21 19:17:24 srvhome kernel: [ 0.100558] ACPI: Added _OSI(Processor Device)
Dec 21 19:17:24 srvhome kernel: [ 0.100558] ACPI: Added _OSI(3.0 _SCP Extensions)
Dec 21 19:17:24 srvhome kernel: [ 0.100558] ACPI: Added _OSI(Processor Aggregator Device)
Dec 21 19:17:24 srvhome kernel: [ 0.100558] ACPI: Added _OSI(Linux-Dell-Video)
Dec 21 19:17:24 srvhome kernel: [ 0.100558] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
Dec 21 19:17:24 srvhome kernel: [ 0.100558] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
Dec 21 19:17:24 srvhome kernel: [ 0.115152] ACPI: 7 ACPI AML tables successfully acquired and loaded
Dec 21 19:17:24 srvhome systemd[1]: Started Daily Cleanup of Temporary Directories.
Dec 21 19:17:24 srvhome kernel: [ 0.117008] ACPI: Dynamic OEM Table Load:
Dec 21 19:17:24 srvhome kernel: [ 0.117008] ACPI: SSDT 0xFFFFA0F6D621F800 0003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
Dec 21 19:17:24 srvhome kernel: [ 0.117008] ACPI: SSDT 0xFFFFA0F6D615A000 0005AA (v01 PmRef ApIst 00003000 INTL 20051117)
Dec 21 19:17:24 srvhome systemd[1]: Reached target Paths.
Dec 21 19:17:24 srvhome kernel: [ 0.117008] ACPI: SSDT 0xFFFFA0F6D5ED1A00 000119 (v01 PmRef ApCst 00003000 INTL 20051117)
Dec 21 19:17:24 srvhome kernel: [ 0.117460] ACPI: Interpreter enabled
Dec 21 19:17:24 srvhome kernel: [ 0.117485] ACPI: (supports S0 S3 S4 S5)
Dec 21 19:17:24 srvhome kernel: [ 0.117486] ACPI: Using IOAPIC for interrupt routing
Dec 21 19:17:24 srvhome kernel: [ 0.117510] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Dec 21 19:17:24 srvhome systemd[1]: Reached target Timers.
Dec 21 19:17:24 srvhome kernel: [ 0.117775] ACPI: Enabled 11 GPEs in block 00 to 3F
Dec 21 19:17:24 srvhome kernel: [ 0.118591] ACPI: Power Resource [PG00] (on)
Dec 21 19:17:24 srvhome kernel: [ 0.118843] ACPI: Power Resource [PG01] (on)
Dec 21 19:17:24 srvhome kernel: [ 0.119087] ACPI: Power Resource [PG02] (on)
Dec 21 19:17:24 srvhome kernel: [ 0.125728] ACPI: Power Resource [FN00] (off)
Dec 21 19:17:24 srvhome kernel: [ 0.125787] ACPI: Power Resource [FN01] (off)
Dec 21 19:17:24 srvhome kernel: [ 0.125843] ACPI: Power Resource [FN02] (off)
Dec 21 19:17:24 srvhome systemd[1]: Condition check resulted in Unix socket for apport crash forwarding being skipped.
Dec 21 19:17:24 srvhome kernel: [ 0.125897] ACPI: Power Resource [FN03] (off)
Dec 21 19:17:24 srvhome kernel: [ 0.125952] ACPI: Power Resource [FN04] (off)
Dec 21 19:17:24 srvhome kernel: [ 0.126898] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
Dec 21 19:17:24 srvhome kernel: [ 0.126904] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
Dec 21 19:17:24 srvhome kernel: [ 0.127127] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
Dec 21 19:17:24 srvhome kernel: [ 0.127278] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR]
Dec 21 19:17:24 srvhome systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Dec 21 19:17:24 srvhome kernel: [ 0.127279] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
Dec 21 19:17:24 srvhome kernel: [ 0.127890] PCI host bridge to bus 0000:00
Dec 21 19:17:24 srvhome kernel: [ 0.127893] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
Dec 21 19:17:24 srvhome systemd[1]: Listening on D-Bus System Message Bus Socket.
Dec 21 19:17:24 srvhome kernel: [ 0.127894] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
Dec 21 19:17:24 srvhome kernel: [ 0.127896] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
Dec 21 19:17:24 srvhome systemd[1]: Listening on Open-iSCSI iscsid Socket.
Dec 21 19:17:24 srvhome systemd[1]: Listening on Socket unix for snap application lxd.daemon.
Dec 21 19:17:24 srvhome systemd[1]: Starting Socket activation for snappy daemon.
Dec 21 19:17:24 srvhome systemd[1]: Listening on UUID daemon activation socket.
Dec 21 19:17:24 srvhome systemd[1]: Listening on Socket activation for snappy daemon.
Dec 21 19:17:24 srvhome systemd[1]: Reached target Sockets.
Dec 21 19:17:24 srvhome systemd[1]: Reached target Basic System.
Dec 21 19:17:24 srvhome systemd[1]: Starting Accounts Service...
Dec 21 19:17:24 srvhome kernel: [ 0.127898] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
Dec 21 19:17:24 srvhome kernel: [ 0.127899] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
Dec 21 19:17:24 srvhome kernel: [ 0.127901] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
Dec 21 19:17:24 srvhome systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Dec 21 19:17:24 srvhome kernel: [ 0.127903] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
Dec 21 19:17:24 srvhome kernel: [ 0.127904] pci_bus 0000:00: root bus resource [mem 0xdf200000-0xfeafffff window]
Dec 21 19:17:24 srvhome kernel: [ 0.127906] pci_bus 0000:00: root bus resource [bus 00-3e]
Dec 21 19:17:24 srvhome kernel: [ 0.127913] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
Dec 21 19:17:24 srvhome kernel: [ 0.127984] pci 0000:00:01.0: [8086:0c01] type 01 class 0x060400
Dec 21 19:17:24 srvhome kernel: [ 0.128016] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
Dec 21 19:17:24 srvhome systemd[1]: Started D-Bus System Message Bus.
Dec 21 19:17:24 srvhome kernel: [ 0.128125] pci 0000:00:02.0: [8086:0412] type 00 class 0x030000
Dec 21 19:17:24 srvhome kernel: [ 0.128133] pci 0000:00:02.0: reg 0x10: [mem 0xf7800000-0xf7bfffff 64bit]
Dec 21 19:17:24 srvhome kernel: [ 0.128138] pci 0000:00:02.0: reg 0x18: [mem 0xe0000000-0xefffffff 64bit pref]
Dec 21 19:17:24 srvhome kernel: [ 0.128141] pci 0000:00:02.0: reg 0x20: [io 0xf000-0xf03f]
Dec 21 19:17:24 srvhome kernel: [ 0.128152] pci 0000:00:02.0: BAR 2: assigned to efifb
Dec 21 19:17:24 srvhome systemd[1]: Starting Network Manager...
Dec 21 19:17:24 srvhome kernel: [ 0.128214] pci 0000:00:03.0: [8086:0c0c] type 00 class 0x040300
Dec 21 19:17:24 srvhome kernel: [ 0.128221] pci 0000:00:03.0: reg 0x10: [mem 0xf7c30000-0xf7c33fff 64bit]
Dec 21 19:17:24 srvhome kernel: [ 0.128304] pci 0000:00:14.0: [8086:8cb1] type 00 class 0x0c0330
Dec 21 19:17:24 srvhome kernel: [ 0.128321] pci 0000:00:14.0: reg 0x10: [mem 0xf7c20000-0xf7c2ffff 64bit]
Dec 21 19:17:24 srvhome kernel: [ 0.128370] pci 0000:00:14.0: PME# supported from D3hot D3cold
Dec 21 19:17:24 srvhome kernel: [ 0.128433] pci 0000:00:16.0: [8086:8cba] type 00 class 0x078000
Dec 21 19:17:24 srvhome systemd[1]: Started Save initial kernel messages after boot.
Dec 21 19:17:24 srvhome kernel: [ 0.128450] pci 0000:00:16.0: reg 0x10: [mem 0xf7c3a000-0xf7c3a00f 64bit]
Dec 21 19:17:24 srvhome systemd[1]: Starting Remove Stale Online ext4 Metadata Check Snapshots...
Dec 21 19:17:24 srvhome kernel: [ 0.128503] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
Dec 21 19:17:24 srvhome kernel: [ 0.128585] pci 0000:00:19.0: [8086:15a1] type 00 class 0x020000
Dec 21 19:17:24 srvhome kernel: [ 0.128601] pci 0000:00:19.0: reg 0x10: [mem 0xf7c00000-0xf7c1ffff]
Dec 21 19:17:24 srvhome kernel: [ 0.128607] pci 0000:00:19.0: reg 0x14: [mem 0xf7c38000-0xf7c38fff]
Dec 21 19:17:24 srvhome kernel: [ 0.128614] pci 0000:00:19.0: reg 0x18: [io 0xf080-0xf09f]
Dec 21 19:17:24 srvhome kernel: [ 0.128662] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
Dec 21 19:17:24 srvhome kernel: [ 0.128729] pci 0000:00:1a.0: [8086:8cad] type 00 class 0x0c0320
Dec 21 19:17:24 srvhome kernel: [ 0.128747] pci 0000:00:1a.0: reg 0x10: [mem 0xf7c37000-0xf7c373ff]
Dec 21 19:17:24 srvhome kernel: [ 0.128818] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
Dec 21 19:17:24 srvhome kernel: [ 0.128884] pci 0000:00:1c.0: [8086:8c90] type 01 class 0x060400
Dec 21 19:17:24 srvhome kernel: [ 0.128949] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Dec 21 19:17:24 srvhome kernel: [ 0.129066] pci 0000:00:1d.0: [8086:8ca6] type 00 class 0x0c0320
Dec 21 19:17:24 srvhome systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
Dec 21 19:17:24 srvhome kernel: [ 0.129085] pci 0000:00:1d.0: reg 0x10: [mem 0xf7c36000-0xf7c363ff]
Dec 21 19:17:24 srvhome kernel: [ 0.129156] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
Dec 21 19:17:24 srvhome kernel: [ 0.129227] pci 0000:00:1f.0: [8086:8cc4] type 00 class 0x060100
Dec 21 19:17:24 srvhome kernel: [ 0.129378] pci 0000:00:1f.2: [8086:8c82] type 00 class 0x010601
Dec 21 19:17:24 srvhome kernel: [ 0.129391] pci 0000:00:1f.2: reg 0x10: [io 0xf0d0-0xf0d7]
Dec 21 19:17:24 srvhome kernel: [ 0.129397] pci 0000:00:1f.2: reg 0x14: [io 0xf0c0-0xf0c3]
Dec 21 19:17:24 srvhome kernel: [ 0.129403] pci 0000:00:1f.2: reg 0x18: [io 0xf0b0-0xf0b7]
Dec 21 19:17:24 srvhome systemd[1]: Reached target Login Prompts.
Dec 21 19:17:24 srvhome kernel: [ 0.129409] pci 0000:00:1f.2: reg 0x1c: [io 0xf0a0-0xf0a3]
Dec 21 19:17:24 srvhome kernel: [ 0.129415] pci 0000:00:1f.2: reg 0x20: [io 0xf060-0xf07f]
Dec 21 19:17:24 srvhome kernel: [ 0.129421] pci 0000:00:1f.2: reg 0x24: [mem 0xf7c35000-0xf7c357ff]
Dec 21 19:17:24 srvhome kernel: [ 0.129449] pci 0000:00:1f.2: PME# supported from D3hot
Dec 21 19:17:24 srvhome kernel: [ 0.129508] pci 0000:00:1f.3: [8086:8ca2] type 00 class 0x0c0500
Dec 21 19:17:24 srvhome kernel: [ 0.129523] pci 0000:00:1f.3: reg 0x10: [mem 0xf7c34000-0xf7c340ff 64bit]
Dec 21 19:17:24 srvhome systemd[1]: Starting Detect the available GPUs and deal with any system changes...
Dec 21 19:17:24 srvhome kernel: [ 0.129539] pci 0000:00:1f.3: reg 0x20: [io 0xf040-0xf05f]
Dec 21 19:17:24 srvhome kernel: [ 0.129626] pci 0000:00:01.0: PCI bridge to [bus 01]
Dec 21 19:17:24 srvhome kernel: [ 0.129687] acpiphp: Slot [1] registered
Dec 21 19:17:24 srvhome kernel: [ 0.129691] pci 0000:00:1c.0: PCI bridge to [bus 02]
Dec 21 19:17:24 srvhome kernel: [ 0.130296] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
Dec 21 19:17:24 srvhome kernel: [ 0.130345] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Dec 21 19:17:24 srvhome systemd[1]: Starting LSB: Record successful boot for GRUB...
Dec 21 19:17:24 srvhome kernel: [ 0.130392] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 11 12 *14 15)
Dec 21 19:17:24 srvhome kernel: [ 0.130438] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 14 *15)
Dec 21 19:17:24 srvhome kernel: [ 0.130485] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 7 10 11 12 14 15)
Dec 21 19:17:24 srvhome kernel: [ 0.130531] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Dec 21 19:17:24 srvhome systemd[1]: Starting GRUB failed boot detection...
Dec 21 19:17:24 srvhome kernel: [ 0.130577] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Dec 21 19:17:24 srvhome kernel: [ 0.130624] ACPI: PCI Interrupt Link [LNKH] (IRQs *3 4 5 6 7 10 11 12 14 15)
Dec 21 19:17:24 srvhome kernel: [ 0.131833] iommu: Default domain type: Translated
Dec 21 19:17:24 srvhome kernel: [ 0.131942] SCSI subsystem initialized
Dec 21 19:17:24 srvhome kernel: [ 0.131953] libata version 3.00 loaded.
Dec 21 19:17:24 srvhome systemd[1]: Started irqbalance daemon.
Dec 21 19:17:24 srvhome kernel: [ 0.131953] pci 0000:00:02.0: vgaarb: setting as boot VGA device
Dec 21 19:17:24 srvhome kernel: [ 0.131953] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Dec 21 19:17:24 srvhome kernel: [ 0.131953] pci 0000:00:02.0: vgaarb: bridge control possible
Dec 21 19:17:24 srvhome kernel: [ 0.131953] vgaarb: loaded
Dec 21 19:17:24 srvhome kernel: [ 0.131953] ACPI: bus type USB registered
Dec 21 19:17:24 srvhome kernel: [ 0.131953] usbcore: registered new interface driver usbfs
Dec 21 19:17:24 srvhome kernel: [ 0.131953] usbcore: registered new interface driver hub
Dec 21 19:17:24 srvhome kernel: [ 0.131953] usbcore: registered new device driver usb
Dec 21 19:17:24 srvhome kernel: [ 0.131953] pps_core: LinuxPPS API ver. 1 registered
Dec 21 19:17:24 srvhome kernel: [ 0.131953] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <
giometti@linux.it>
Dec 21 19:17:24 srvhome systemd[1]: Starting Initialize hardware monitoring sensors...
Dec 21 19:17:24 srvhome kernel: [ 0.131953] PTP clock support registered
Dec 21 19:17:24 srvhome kernel: [ 0.131953] EDAC MC: Ver: 3.0.0
Dec 21 19:17:24 srvhome kernel: [ 0.131953] Registered efivars operations
Dec 21 19:17:24 srvhome kernel: [ 0.131953] PCI: Using ACPI for IRQ routing
Dec 21 19:17:24 srvhome kernel: [ 0.133061] PCI: pci_cache_line_size set to 64 bytes
Dec 21 19:17:24 srvhome kernel: [ 0.133082] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
Dec 21 19:17:24 srvhome kernel: [ 0.133083] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
Dec 21 19:17:24 srvhome systemd[1]: Starting Dispatcher daemon for systemd-networkd...
Dec 21 19:17:24 srvhome kernel: [ 0.133084] e820: reserve RAM buffer [mem 0xb9912018-0xbbffffff]
Dec 21 19:17:24 srvhome kernel: [ 0.133085] e820: reserve RAM buffer [mem 0xb9924018-0xbbffffff]
Dec 21 19:17:24 srvhome kernel: [ 0.133085] e820: reserve RAM buffer [mem 0xb9d94000-0xbbffffff]
Dec 21 19:17:24 srvhome kernel: [ 0.133086] e820: reserve RAM buffer [mem 0xba1fe000-0xbbffffff]
Dec 21 19:17:24 srvhome kernel: [ 0.133086] e820: reserve RAM buffer [mem 0xd8bbd000-0xdbffffff]
Dec 21 19:17:24 srvhome kernel: [ 0.133087] e820: reserve RAM buffer [mem 0xda000000-0xdbffffff]
Dec 21 19:17:24 srvhome avahi-daemon[884]: Found user 'avahi' (UID 120) and group 'avahi' (GID 126).
Dec 21 19:17:24 srvhome kernel: [ 0.133087] e820: reserve RAM buffer [mem 0x21fe00000-0x21fffffff]
Dec 21 19:17:24 srvhome kernel: [ 0.135829] NetLabel: Initializing
Dec 21 19:17:24 srvhome kernel: [ 0.135829] NetLabel: domain hash size = 128
Dec 21 19:17:24 srvhome kernel: [ 0.135829] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
Dec 21 19:17:24 srvhome kernel: [ 0.135829] NetLabel: unlabeled traffic allowed by default
Dec 21 19:17:24 srvhome kernel: [ 0.136327] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
Dec 21 19:17:24 srvhome kernel: [ 0.136331] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
Dec 21 19:17:24 srvhome systemd[1]: Started Set the CPU Frequency Scaling governor.
Dec 21 19:17:24 srvhome kernel: [ 0.138349] clocksource: Switched to clocksource tsc-early
Dec 21 19:17:24 srvhome kernel: [ 0.143879] *** VALIDATE bpf ***
Dec 21 19:17:24 srvhome kernel: [ 0.143946] VFS: Disk quotas dquot_6.6.0
Dec 21 19:17:24 srvhome kernel: [ 0.143957] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Dec 21 19:17:24 srvhome systemd[1]: Starting Clean php session files...
Dec 21 19:17:24 srvhome kernel: [ 0.143979] *** VALIDATE ramfs ***
Dec 21 19:17:24 srvhome kernel: [ 0.143981] *** VALIDATE hugetlbfs ***
Dec 21 19:17:24 srvhome kernel: [ 0.144037] AppArmor: AppArmor Filesystem Enabled
Dec 21 19:17:24 srvhome kernel: [ 0.144060] pnp: PnP ACPI init
Dec 21 19:17:24 srvhome systemd[1]: Starting Authorization Manager...
Dec 21 19:17:24 srvhome kernel: [ 0.144208] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
Dec 21 19:17:24 srvhome kernel: [ 0.144213] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
Dec 21 19:17:24 srvhome kernel: [ 0.144301] system 00:01: [io 0x0800-0x087f] has been reserved
Dec 21 19:17:24 srvhome kernel: [ 0.144304] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
Dec 21 19:17:24 srvhome kernel: [ 0.144319] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
Dec 21 19:17:24 srvhome kernel: [ 0.144345] system 00:03: [io 0x1854-0x1857] has been reserved
Dec 21 19:17:24 srvhome kernel: [ 0.144349] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
Dec 21 19:17:24 srvhome kernel: [ 0.144433] system 00:04: [io 0x0290-0x029f] has been reserved
Dec 21 19:17:24 srvhome kernel: [ 0.144435] system 00:04: [io 0x02a0-0x02af] has been reserved
Dec 21 19:17:24 srvhome kernel: [ 0.144436] system 00:04: [io 0x0a00-0x0aff] has been reserved
Dec 21 19:17:24 srvhome kernel: [ 0.144439] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
Dec 21 19:17:24 srvhome systemd[1]: Starting Restore /etc/resolv.conf if the system crashed before the ppp link was shut down...
Dec 21 19:17:24 srvhome kernel: [ 0.144475] system 00:05: [io 0x04d0-0x04d1] has been reserved
Dec 21 19:17:24 srvhome kernel: [ 0.144478] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
Dec 21 19:17:24 srvhome kernel: [ 0.144692] pnp 00:06: [dma 0 disabled]
Dec 21 19:17:24 srvhome kernel: [ 0.144720] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
Dec 21 19:17:24 srvhome kernel: [ 0.144996] system 00:07: [mem 0xfed1c000-0xfed1ffff] has been reserved
Dec 21 19:17:24 srvhome kernel: [ 0.144998] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
Dec 21 19:17:24 srvhome systemd[1]: Starting System Logging Service...
Dec 21 19:17:24 srvhome systemd[1]: Starting Secure Boot updates for DB and DBX...
Dec 21 19:17:24 srvhome systemd[1]: Starting Self Monitoring and Reporting Technology (SMART) Daemon...
Dec 21 19:17:24 srvhome systemd[1]: Condition check resulted in Automatically repair incorrect owner/permissions on core devices being skipped.
Dec 21 19:17:24 srvhome systemd[1]: Condition check resulted in Wait for the Ubuntu Core chooser trigger being skipped.
Dec 21 19:17:24 srvhome systemd[1]: Starting Snap Daemon...
Dec 21 19:17:24 srvhome systemd[1]: Starting Switcheroo Control Proxy service...
Dec 21 19:17:24 srvhome systemd[1]: Starting Resets System Activity Data Collector...
Dec 21 19:17:24 srvhome systemd[1]: Starting Login Service...
Dec 21 19:17:24 srvhome kernel: [ 0.145000] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
Dec 21 19:17:24 srvhome kernel: [ 0.145001] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
Dec 21 19:17:24 srvhome kernel: [ 0.145003] system 00:07: [mem 0xf8000000-0xfbffffff] has been reserved
Dec 21 19:17:24 srvhome kernel: [ 0.145005] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
Dec 21 19:17:24 srvhome kernel: [ 0.145006] system 00:07: [mem 0xfed90000-0xfed93fff] has been reserved
Dec 21 19:17:24 srvhome kernel: [ 0.145008] system 00:07: [mem 0xfed45000-0xfed8ffff] has been reserved
Dec 21 19:17:24 srvhome systemd[1]: Starting Thermal Daemon Service...
Dec 21 19:17:24 srvhome kernel: [ 0.145009] system 00:07: [mem 0xff000000-0xffffffff] has been reserved
Dec 21 19:17:24 srvhome kernel: [ 0.145011] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
Dec 21 19:17:24 srvhome kernel: [ 0.145013] system 00:07: [mem 0xf7fe0000-0xf7feffff] has been reserved
Dec 21 19:17:24 srvhome systemd[1]: Starting Disk Manager...
Dec 21 19:17:24 srvhome kernel: [ 0.145015] system 00:07: [mem 0xf7ff0000-0xf7ffffff] has been reserved
Dec 21 19:17:24 srvhome kernel: [ 0.145018] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
Dec 21 19:17:24 srvhome kernel: [ 0.145188] pnp: PnP ACPI: found 8 devices
Dec 21 19:17:24 srvhome kernel: [ 0.145934] thermal_sys: Registered thermal governor 'fair_share'
Dec 21 19:17:24 srvhome kernel: [ 0.145934] thermal_sys: Registered thermal governor 'bang_bang'
Dec 21 19:17:24 srvhome kernel: [ 0.145936] thermal_sys: Registered thermal governor 'step_wise'
Dec 21 19:17:24 srvhome kernel: [ 0.145937] thermal_sys: Registered thermal governor 'user_space'
Dec 21 19:17:24 srvhome kernel: [ 0.145938] thermal_sys: Registered thermal governor 'power_allocator'
Dec 21 19:17:24 srvhome systemd[1]: Starting WPA supplicant...
Dec 21 19:17:24 srvhome kernel: [ 0.150422] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Dec 21 19:17:24 srvhome kernel: [ 0.150445] pci 0000:00:01.0: PCI bridge to [bus 01]
Dec 21 19:17:24 srvhome kernel: [ 0.150450] pci 0000:00:1c.0: PCI bridge to [bus 02]
Dec 21 19:17:24 srvhome kernel: [ 0.150459] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
Dec 21 19:17:24 srvhome kernel: [ 0.150461] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
Dec 21 19:17:24 srvhome kernel: [ 0.150462] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
Dec 21 19:17:24 srvhome kernel: [ 0.150464] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
Dec 21 19:17:24 srvhome kernel: [ 0.150465] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
Dec 21 19:17:24 srvhome kernel: [ 0.150467] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
Dec 21 19:17:24 srvhome avahi-daemon[884]: Successfully dropped root privileges.
Dec 21 19:17:24 srvhome kernel: [ 0.150468] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
Dec 21 19:17:24 srvhome kernel: [ 0.150470] pci_bus 0000:00: resource 11 [mem 0xdf200000-0xfeafffff window]
Dec 21 19:17:24 srvhome kernel: [ 0.150558] NET: Registered protocol family 2
Dec 21 19:17:24 srvhome kernel: [ 0.150668] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
Dec 21 19:17:24 srvhome kernel: [ 0.150708] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
Dec 21 19:17:24 srvhome kernel: [ 0.150809] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
Dec 21 19:17:24 srvhome avahi-daemon[884]: avahi-daemon 0.7 starting up.
Dec 21 19:17:24 srvhome kernel: [ 0.150860] TCP: Hash tables configured (established 65536 bind 65536)
Dec 21 19:17:24 srvhome kernel: [ 0.150889] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
Dec 21 19:17:24 srvhome kernel: [ 0.150907] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
Dec 21 19:17:24 srvhome kernel: [ 0.150942] NET: Registered protocol family 1
Dec 21 19:17:24 srvhome kernel: [ 0.150946] NET: Registered protocol family 44
Dec 21 19:17:24 srvhome kernel: [ 0.150954] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Dec 21 19:17:24 srvhome dbus-daemon[888]: dbus[888]: Unknown username "whoopsie" in message bus configuration file
Dec 21 19:17:24 srvhome kernel: [ 0.175909] pci 0000:00:1a.0: quirk_usb_early_handoff+0x0/0x662 took 24225 usecs
Dec 21 19:17:24 srvhome kernel: [ 0.199904] pci 0000:00:1d.0: quirk_usb_early_handoff+0x0/0x662 took 23424 usecs
Dec 21 19:17:24 srvhome kernel: [ 0.199912] PCI: CLS 64 bytes, default 64
Dec 21 19:17:24 srvhome kernel: [ 0.199945] Trying to unpack rootfs image as initramfs...
Dec 21 19:17:24 srvhome kernel: [ 0.317888] Initramfs unpacking failed: Decoding failed
Dec 21 19:17:24 srvhome systemd[1]: pppd-dns.service: Succeeded.
Dec 21 19:17:24 srvhome kernel: [ 0.324182] Freeing initrd memory: 79872K
Dec 21 19:17:24 srvhome kernel: [ 0.324272] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Dec 21 19:17:24 srvhome kernel: [ 0.324274] software IO TLB: mapped [mem 0xc6e42000-0xcae42000] (64MB)
Dec 21 19:17:24 srvhome kernel: [ 0.324467] check: Scanning for low memory corruption every 60 seconds
Dec 21 19:17:24 srvhome kernel: [ 0.324790] Initialise system trusted keyrings
Dec 21 19:17:24 srvhome kernel: [ 0.324800] Key type blacklist registered
Dec 21 19:17:24 srvhome sensors[961]: acpitz-acpi-0
Dec 21 19:17:24 srvhome kernel: [ 0.324821] workingset: timestamp_bits=36 max_order=21 bucket_order=0
Dec 21 19:17:24 srvhome kernel: [ 0.325631] zbud: loaded
Dec 21 19:17:24 srvhome kernel: [ 0.325859] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Dec 21 19:17:24 srvhome kernel: [ 0.325957] fuse: init (API version 7.31)
Dec 21 19:17:24 srvhome kernel: [ 0.325968] *** VALIDATE fuse ***
Dec 21 19:17:24 srvhome kernel: [ 0.325969] *** VALIDATE fuse ***
Dec 21 19:17:24 srvhome kernel: [ 0.326029] Platform Keyring initialized
Dec 21 19:17:24 srvhome sensors[961]: Adapter: ACPI interface
Dec 21 19:17:24 srvhome kernel: [ 0.328660] Key type asymmetric registered
Dec 21 19:17:24 srvhome kernel: [ 0.328663] Asymmetric key parser 'x509' registered
Dec 21 19:17:24 srvhome kernel: [ 0.328670] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
Dec 21 19:17:24 srvhome kernel: [ 0.328700] io scheduler mq-deadline registered
Dec 21 19:17:24 srvhome kernel: [ 0.329084] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Dec 21 19:17:24 srvhome kernel: [ 0.329122] efifb: probing for efifb
Dec 21 19:17:24 srvhome kernel: [ 0.329130] efifb: No BGRT, not showing boot graphics
Dec 21 19:17:24 srvhome kernel: [ 0.329131] efifb: framebuffer at 0xe0000000, using 1200k, total 1200k
Dec 21 19:17:24 srvhome sensors[961]: temp1: +27.8°C (crit = +105.0°C)
Dec 21 19:17:24 srvhome kernel: [ 0.329133] efifb: mode is 640x480x32, linelength=2560, pages=1
Dec 21 19:17:24 srvhome kernel: [ 0.329134] efifb: scrolling: redraw
Dec 21 19:17:24 srvhome kernel: [ 0.329135] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
Dec 21 19:17:24 srvhome kernel: [ 0.329188] Console: switching to colour frame buffer device 80x30
Dec 21 19:17:24 srvhome kernel: [ 0.329641] fb0: EFI VGA frame buffer device
Dec 21 19:17:24 srvhome kernel: [ 0.329655] intel_idle: MWAIT substates: 0x42120
Dec 21 19:17:24 srvhome kernel: [ 0.329655] intel_idle: v0.4.1 model 0x3C
Dec 21 19:17:24 srvhome sensors[961]: temp2: +29.8°C (crit = +105.0°C)
Dec 21 19:17:24 srvhome kernel: [ 0.329905] intel_idle: lapic_timer_reliable_states 0xffffffff
Dec 21 19:17:24 srvhome kernel: [ 0.330007] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
Dec 21 19:17:24 srvhome kernel: [ 0.330041] ACPI: Power Button [PWRB]
Dec 21 19:17:24 srvhome kernel: [ 0.330071] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
Dec 21 19:17:24 srvhome sensors[961]: coretemp-isa-0000
Dec 21 19:17:24 srvhome kernel: [ 0.330636] ACPI: Power Button [PWRF]
Dec 21 19:17:24 srvhome kernel: [ 0.331609] thermal LNXTHERM:00: registered as thermal_zone0
Dec 21 19:17:24 srvhome kernel: [ 0.331920] ACPI: Thermal Zone [TZ00] (28 C)
Dec 21 19:17:24 srvhome sensors[961]: Adapter: ISA adapter
Dec 21 19:17:24 srvhome kernel: [ 0.332386] thermal LNXTHERM:01: registered as thermal_zone1
Dec 21 19:17:24 srvhome kernel: [ 0.332662] ACPI: Thermal Zone [TZ01] (30 C)
Dec 21 19:17:24 srvhome kernel: [ 0.333039] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Dec 21 19:17:24 srvhome kernel: [ 0.353749] 00:06: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
Dec 21 19:17:24 srvhome kernel: [ 0.355277] Linux agpgart interface v0.103
Dec 21 19:17:24 srvhome sensors[961]: Package id 0: +29.0°C (high = +80.0°C, crit = +100.0°C)
Dec 21 19:17:24 srvhome kernel: [ 0.357221] loop: module loaded
Dec 21 19:17:24 srvhome kernel: [ 0.357640] libphy: Fixed MDIO Bus: probed
Dec 21 19:17:24 srvhome kernel: [ 0.357929] tun: Universal TUN/TAP device driver, 1.6
Dec 21 19:17:24 srvhome kernel: [ 0.358241] PPP generic driver version 2.4.2
Dec 21 19:17:24 srvhome kernel: [ 0.358572] VFIO - User Level meta-driver version: 0.3
Dec 21 19:17:24 srvhome kernel: [ 0.358952] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Dec 21 19:17:24 srvhome kernel: [ 0.359240] ehci-pci: EHCI PCI platform driver
Dec 21 19:17:24 srvhome sensors[961]: Core 0: +28.0°C (high = +80.0°C, crit = +100.0°C)
Dec 21 19:17:24 srvhome kernel: [ 0.359594] ehci-pci 0000:00:1a.0: EHCI Host Controller
Dec 21 19:17:24 srvhome kernel: [ 0.359912] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
Dec 21 19:17:24 srvhome kernel: [ 0.360476] ehci-pci 0000:00:1a.0: debug port 2
Dec 21 19:17:24 srvhome kernel: [ 0.364659] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
Dec 21 19:17:24 srvhome kernel: [ 0.364951] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7c37000
Dec 21 19:17:24 srvhome kernel: [ 0.379865] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
Dec 21 19:17:24 srvhome kernel: [ 0.380209] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
Dec 21 19:17:24 srvhome kernel: [ 0.380824] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 21 19:17:24 srvhome kernel: [ 0.381444] usb usb1: Product: EHCI Host Controller
Dec 21 19:17:24 srvhome kernel: [ 0.381752] usb usb1: Manufacturer: Linux 5.4.0-56-generic ehci_hcd
Dec 21 19:17:24 srvhome kernel: [ 0.382031] usb usb1: SerialNumber: 0000:00:1a.0
Dec 21 19:17:24 srvhome sensors[961]: Core 1: +29.0°C (high = +80.0°C, crit = +100.0°C)
Dec 21 19:17:24 srvhome kernel: [ 0.382437] hub 1-0:1.0: USB hub found
Dec 21 19:17:24 srvhome kernel: [ 0.382719] hub 1-0:1.0: 2 ports detected
Dec 21 19:17:24 srvhome kernel: [ 0.383145] ehci-pci 0000:00:1d.0: EHCI Host Controller
Dec 21 19:17:24 srvhome kernel: [ 0.383420] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
Dec 21 19:17:24 srvhome kernel: [ 0.384000] ehci-pci 0000:00:1d.0: debug port 2
Dec 21 19:17:24 srvhome sensors[961]: Core 2: +27.0°C (high = +80.0°C, crit = +100.0°C)
Dec 21 19:17:24 srvhome kernel: [ 0.388156] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
Dec 21 19:17:24 srvhome kernel: [ 0.388435] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7c36000
Dec 21 19:17:24 srvhome kernel: [ 0.403865] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
Dec 21 19:17:24 srvhome kernel: [ 0.404184] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
Dec 21 19:17:24 srvhome kernel: [ 0.404781] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 21 19:17:24 srvhome kernel: [ 0.405374] usb usb2: Product: EHCI Host Controller
Dec 21 19:17:24 srvhome sensors[961]: Core 3: +26.0°C (high = +80.0°C, crit = +100.0°C)
Dec 21 19:17:24 srvhome kernel: [ 0.405657] usb usb2: Manufacturer: Linux 5.4.0-56-generic ehci_hcd
Dec 21 19:17:24 srvhome kernel: [ 0.405939] usb usb2: SerialNumber: 0000:00:1d.0
Dec 21 19:17:24 srvhome kernel: [ 0.406353] hub 2-0:1.0: USB hub found
Dec 21 19:17:24 srvhome kernel: [ 0.406638] hub 2-0:1.0: 2 ports detected
Dec 21 19:17:24 srvhome kernel: [ 0.406998] ehci-platform: EHCI generic platform driver
Dec 21 19:17:24 srvhome kernel: [ 0.407277] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Dec 21 19:17:24 srvhome systemd[1]: Finished Restore /etc/resolv.conf if the system crashed before the ppp link was shut down.
Dec 21 19:17:24 srvhome kernel: [ 0.407555] ohci-pci: OHCI PCI platform driver
Dec 21 19:17:24 srvhome kernel: [ 0.407850] ohci-platform: OHCI generic platform driver
Dec 21 19:17:24 srvhome systemd[1]: Finished Initialize hardware monitoring sensors.
Dec 21 19:17:24 srvhome systemd[1]: Finished Resets System Activity Data Collector.
Dec 21 19:17:24 srvhome set-cpufreq[916]: Setting powersave scheduler for all CPUs
Dec 21 19:17:24 srvhome systemd[1]: ondemand.service: Succeeded.
Dec 21 19:17:24 srvhome systemd[1]: e2scrub_reap.service: Succeeded.
Dec 21 19:17:24 srvhome systemd[1]: Finished Remove Stale Online ext4 Metadata Check Snapshots.
Dec 21 19:17:24 srvhome sbkeysync[954]: Filesystem keystore:
Dec 21 19:17:24 srvhome kernel: [ 0.408140] uhci_hcd: USB Universal Host Controller Interface driver
Dec 21 19:17:24 srvhome kernel: [ 0.408497] xhci_hcd 0000:00:14.0: xHCI Host Controller
Dec 21 19:17:24 srvhome kernel: [ 0.408773] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
Dec 21 19:17:24 srvhome kernel: [ 0.410340] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000000009810
Dec 21 19:17:24 srvhome kernel: [ 0.410889] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
Dec 21 19:17:24 srvhome kernel: [ 0.411269] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
Dec 21 19:17:24 srvhome kernel: [ 0.411859] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 21 19:17:24 srvhome kernel: [ 0.412473] usb usb3: Product: xHCI Host Controller
Dec 21 19:17:24 srvhome kernel: [ 0.412771] usb usb3: Manufacturer: Linux 5.4.0-56-generic xhci-hcd
Dec 21 19:17:24 srvhome kernel: [ 0.413071] usb usb3: SerialNumber: 0000:00:14.0
Dec 21 19:17:24 srvhome kernel: [ 0.413500] hub 3-0:1.0: USB hub found
Dec 21 19:17:24 srvhome kernel: [ 0.413816] hub 3-0:1.0: 14 ports detected
Dec 21 19:17:24 srvhome kernel: [ 0.414559] xhci_hcd 0000:00:14.0: xHCI Host Controller
Dec 21 19:17:24 srvhome kernel: [ 0.414859] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
Dec 21 19:17:24 srvhome kernel: [ 0.415431] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
Dec 21 19:17:24 srvhome kernel: [ 0.415744] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
Dec 21 19:17:24 srvhome kernel: [ 0.416354] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 21 19:17:24 srvhome kernel: [ 0.416954] usb usb4: Product: xHCI Host Controller
Dec 21 19:17:24 srvhome kernel: [ 0.417264] usb usb4: Manufacturer: Linux 5.4.0-56-generic xhci-hcd
Dec 21 19:17:24 srvhome kernel: [ 0.417579] usb usb4: SerialNumber: 0000:00:14.0
Dec 21 19:17:24 srvhome kernel: [ 0.418019] hub 4-0:1.0: USB hub found
Dec 21 19:17:24 srvhome kernel: [ 0.418337] hub 4-0:1.0: 6 ports detected
Dec 21 19:17:24 srvhome kernel: [ 0.418996] i8042: PNP: No PS/2 controller found.
Dec 21 19:17:24 srvhome kernel: [ 0.419404] mousedev: PS/2 mouse device common for all mice
Dec 21 19:17:24 srvhome kernel: [ 0.419784] rtc_cmos 00:02: RTC can wake from S4
Dec 21 19:17:24 srvhome kernel: [ 0.420269] rtc_cmos 00:02: registered as rtc0
Dec 21 19:17:24 srvhome kernel: [ 0.420574] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
Dec 21 19:17:24 srvhome kernel: [ 0.421152] i2c /dev entries driver
Dec 21 19:17:24 srvhome kernel: [ 0.421452] device-mapper: uevent: version 1.0.3
Dec 21 19:17:24 srvhome kernel: [ 0.421787] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised:
dm-devel@redhat.com
Dec 21 19:17:24 srvhome kernel: [ 0.422346] platform eisa.0: Probing EISA bus 0
Dec 21 19:17:24 srvhome kernel: [ 0.422615] platform eisa.0: EISA: Cannot allocate resource for mainboard
Dec 21 19:17:24 srvhome kernel: [ 0.422889] platform eisa.0: Cannot allocate resource for EISA slot 1
Dec 21 19:17:24 srvhome kernel: [ 0.423160] platform eisa.0: Cannot allocate resource for EISA slot 2
Dec 21 19:17:24 srvhome kernel: [ 0.423425] platform eisa.0: Cannot allocate resource for EISA slot 3
Dec 21 19:17:24 srvhome kernel: [ 0.423684] platform eisa.0: Cannot allocate resource for EISA slot 4
Dec 21 19:17:24 srvhome kernel: [ 0.423976] platform eisa.0: Cannot allocate resource for EISA slot 5
Dec 21 19:17:24 srvhome kernel: [ 0.424226] platform eisa.0: Cannot allocate resource for EISA slot 6
Dec 21 19:17:24 srvhome kernel: [ 0.424469] platform eisa.0: Cannot allocate resource for EISA slot 7
Dec 21 19:17:24 srvhome kernel: [ 0.424700] platform eisa.0: Cannot allocate resource for EISA slot 8
Dec 21 19:17:24 srvhome kernel: [ 0.424920] platform eisa.0: EISA: Detected 0 cards
Dec 21 19:17:24 srvhome kernel: [ 0.425138] intel_pstate: Intel P-state driver initializing
Dec 21 19:17:24 srvhome kernel: [ 0.425937] ledtrig-cpu: registered to indicate activity on CPUs
Dec 21 19:17:24 srvhome kernel: [ 0.426156] EFI Variables Facility v0.08 2004-May-17
Dec 21 19:17:24 srvhome kernel: [ 0.429796] drop_monitor: Initializing network drop monitor service
Dec 21 19:17:24 srvhome kernel: [ 0.430140] NET: Registered protocol family 10
Dec 21 19:17:24 srvhome kernel: [ 0.434468] Segment Routing with IPv6
Dec 21 19:17:24 srvhome kernel: [ 0.434711] NET: Registered protocol family 17
Dec 21 19:17:24 srvhome kernel: [ 0.434957] Key type dns_resolver registered
Dec 21 19:17:24 srvhome kernel: [ 0.435487] RAS: Correctable Errors collector initialized.
Dec 21 19:17:24 srvhome kernel: [ 0.435751] microcode: sig=0x306c3, pf=0x2, revision=0x28
Dec 21 19:17:24 srvhome kernel: [ 0.436115] microcode: Microcode Update Driver: v2.2.
Dec 21 19:17:24 srvhome kernel: [ 0.436117] IPI shorthand broadcast: enabled
Dec 21 19:17:24 srvhome kernel: [ 0.436585] sched_clock: Marking stable (435734873, 377714)->(444479126, -8366539)
Dec 21 19:17:24 srvhome kernel: [ 0.437116] registered taskstats version 1
Dec 21 19:17:24 srvhome kernel: [ 0.437336] Loading compiled-in X.509 certificates
Dec 21 19:17:24 srvhome kernel: [ 0.438084] Loaded X.509 cert 'Build time autogenerated kernel key: 094e0f64537699c38eac1422da4dd7fa08baa936'
Dec 21 19:17:24 srvhome kernel: [ 0.438541] zswap: loaded using pool lzo/zbud
Dec 21 19:17:24 srvhome kernel: [ 0.438865] Key type ._fscrypt registered
Dec 21 19:17:24 srvhome kernel: [ 0.439085] Key type .fscrypt registered
Dec 21 19:17:24 srvhome kernel: [ 0.442989] Key type big_key registered
Dec 21 19:17:24 srvhome kernel: [ 0.444963] Key type encrypted registered
Dec 21 19:17:24 srvhome kernel: [ 0.445189] AppArmor: AppArmor sha1 policy hashing enabled
Dec 21 19:17:24 srvhome kernel: [ 0.445614] integrity: Loading X.509 certificate: UEFI
b
Dec 21 19:17:24 srvhome kernel: [ 0.446097] integrity: Loaded X.509 cert 'ASUSTeK MotherBoard SW Key Certificate: da83b990422ebc8c441f8d8b039a65a2'
Dec 21 19:17:24 srvhome kernel: [ 0.446654] integrity: Loading X.509 certificate: UEFI
b
Dec 21 19:17:24 srvhome kernel: [ 0.447053] integrity: Loaded X.509 cert 'ASUSTeK Notebook SW Key Certificate: b8e581e4df77a5bb4282d5ccfc00c071'
Dec 21 19:17:24 srvhome kernel: [ 0.447589] integrity: Loading X.509 certificate: UEFI
b
Dec 21 19:17:24 srvhome kernel: [ 0.447907] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
Dec 21 19:17:24 srvhome kernel: [ 0.448453] integrity: Loading X.509 certificate: UEFI
b
Dec 21 19:17:24 srvhome kernel: [ 0.448736] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
Dec 21 19:17:24 srvhome kernel: [ 0.449298] integrity: Loading X.509 certificate: UEFI
b
Dec 21 19:17:24 srvhome kernel: [ 0.449719] integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
Dec 21 19:17:24 srvhome kernel: [ 0.450400] integrity: Loading X.509 certificate: UEFI:MokListRT
Dec 21 19:17:24 srvhome kernel: [ 0.450706] integrity: Loaded X.509 cert 'SomeOrg: shim: a01ee84e9b37ace407961cc468c5909447878469'
Dec 21 19:17:24 srvhome kernel: [ 0.451301] integrity: Loading X.509 certificate: UEFI:MokListRT
Dec 21 19:17:24 srvhome kernel: [ 0.451736] integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
Dec 21 19:17:24 srvhome kernel: [ 0.452654] ima: No TPM chip found, activating TPM-bypass!
Dec 21 19:17:24 srvhome kernel: [ 0.452967] ima: Allocated hash algorithm: sha1
Dec 21 19:17:24 srvhome kernel: [ 0.453271] ima: No architecture policies found
Dec 21 19:17:24 srvhome kernel: [ 0.453572] evm: Initialising EVM extended attributes:
Dec 21 19:17:24 srvhome kernel: [ 0.453872] evm: security.selinux
Dec 21 19:17:24 srvhome kernel: [ 0.454171] evm: security.SMACK64
Dec 21 19:17:24 srvhome kernel: [ 0.454467] evm: security.SMACK64EXEC
Dec 21 19:17:24 srvhome kernel: [ 0.454760] evm: security.SMACK64TRANSMUTE
Dec 21 19:17:24 srvhome kernel: [ 0.455049] evm: security.SMACK64MMAP
Dec 21 19:17:24 srvhome kernel: [ 0.455331] evm: security.apparmor
Dec 21 19:17:24 srvhome kernel: [ 0.455604] evm: security.ima
Dec 21 19:17:24 srvhome kernel: [ 0.455895] evm: security.capability
Dec 21 19:17:24 srvhome kernel: [ 0.456151] evm: HMAC attrs: 0x1
Dec 21 19:17:24 srvhome kernel: [ 0.456787] PM: Magic number: 0:590:140
Dec 21 19:17:24 srvhome kernel: [ 0.457036] usb usb4-port5: hash matches
Dec 21 19:17:24 srvhome kernel: [ 0.457320] acpi device:11: hash matches
Dec 21 19:17:24 srvhome kernel: [ 0.457615] rtc_cmos 00:02: setting system clock to 2020-12-21T18:08:36 UTC (1608574116)
Dec 21 19:17:24 srvhome kernel: [ 0.458880] Freeing unused decrypted memory: 2040K
Dec 21 19:17:24 srvhome kernel: [ 0.459457] Freeing unused kernel image memory: 2720K
Dec 21 19:17:24 srvhome kernel: [ 0.491918] Write protecting the kernel read-only data: 22528k
Dec 21 19:17:24 srvhome kernel: [ 0.492531] Freeing unused kernel image memory: 2008K
Dec 21 19:17:24 srvhome kernel: [ 0.492951] Freeing unused kernel image memory: 1212K
Dec 21 19:17:24 srvhome kernel: [ 0.499475] x86/mm: Checked W+X mappings: passed, no W+X pages found.
Dec 21 19:17:24 srvhome kernel: [ 0.499694] x86/mm: Checking user space page tables
Dec 21 19:17:24 srvhome kernel: [ 0.505954] x86/mm: Checked W+X mappings: passed, no W+X pages found.
Dec 21 19:17:24 srvhome kernel: [ 0.506167] Run /init as init process
Dec 21 19:17:24 srvhome kernel: [ 0.567959] ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20190816/utaddress-204)
Dec 21 19:17:24 srvhome kernel: [ 0.569274] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Dec 21 19:17:24 srvhome kernel: [ 0.570153] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C7F (\_GPE.GPBX) (20190816/utaddress-204)
Dec 21 19:17:24 srvhome kernel: [ 0.571522] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20190816/utaddress-204)
Dec 21 19:17:24 srvhome kernel: [ 0.572726] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Dec 21 19:17:24 srvhome kernel: [ 0.572924] i801_smbus 0000:00:1f.3: SPD Write Disable is set
Dec 21 19:17:24 srvhome kernel: [ 0.573936] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C7F (\_GPE.GPBX) (20190816/utaddress-204)
Dec 21 19:17:24 srvhome kernel: [ 0.574580] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
Dec 21 19:17:24 srvhome kernel: [ 0.576460] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20190816/utaddress-204)
Dec 21 19:17:24 srvhome kernel: [ 0.576463] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20190816/utaddress-204)
Dec 21 19:17:24 srvhome kernel: [ 0.576465] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Dec 21 19:17:24 srvhome kernel: [ 0.576465] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C7F (\_GPE.GPBX) (20190816/utaddress-204)
Dec 21 19:17:24 srvhome kernel: [ 0.576467] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20190816/utaddress-204)
Dec 21 19:17:24 srvhome kernel: [ 0.576469] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20190816/utaddress-204)
Dec 21 19:17:24 srvhome kernel: [ 0.576470] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Dec 21 19:17:24 srvhome kernel: [ 0.576471] lpc_ich: Resource conflict(s) found affecting gpio_ich
Dec 21 19:17:24 srvhome kernel: [ 0.577145] ahci 0000:00:1f.2: version 3.0
Dec 21 19:17:24 srvhome kernel: [ 0.580952] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
Dec 21 19:17:24 srvhome kernel: [ 0.582476] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0xf impl SATA mode
Dec 21 19:17:24 srvhome kernel: [ 0.584435] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Dec 21 19:17:24 srvhome kernel: [ 0.584560] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
Dec 21 19:17:24 srvhome kernel: [ 0.586715] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
Dec 21 19:17:24 srvhome kernel: [ 0.620060] cryptd: max_cpu_qlen set to 1000
Dec 21 19:17:24 srvhome kernel: [ 0.625988] AVX2 version of gcm_enc/dec engaged.
Dec 21 19:17:24 srvhome kernel: [ 0.626769] AES CTR mode by8 optimization enabled
Dec 21 19:17:24 srvhome kernel: [ 0.632670] scsi host0: ahci
Dec 21 19:17:24 srvhome kernel: [ 0.633616] scsi host1: ahci
Dec 21 19:17:24 srvhome kernel: [ 0.634463] scsi host2: ahci
Dec 21 19:17:24 srvhome kernel: [ 0.635212] scsi host3: ahci
Dec 21 19:17:24 srvhome kernel: [ 0.636084] scsi host4: ahci
Dec 21 19:17:24 srvhome kernel: [ 0.636872] scsi host5: ahci
Dec 21 19:17:24 srvhome kernel: [ 0.637505] ata1: SATA max UDMA/133 abar m2048@0xf7c35000 port 0xf7c35100 irq 27
Dec 21 19:17:24 srvhome kernel: [ 0.638671] ata2: SATA max UDMA/133 abar m2048@0xf7c35000 port 0xf7c35180 irq 27
Dec 21 19:17:24 srvhome kernel: [ 0.639845] ata3: SATA max UDMA/133 abar m2048@0xf7c35000 port 0xf7c35200 irq 27
Dec 21 19:17:24 srvhome kernel: [ 0.641024] ata4: SATA max UDMA/133 abar m2048@0xf7c35000 port 0xf7c35280 irq 27
Dec 21 19:17:24 srvhome kernel: [ 0.642190] ata5: DUMMY
Dec 21 19:17:24 srvhome kernel: [ 0.642750] ata6: DUMMY
Dec 21 19:17:24 srvhome kernel: [ 0.648657] checking generic (e0000000 12c000) vs hw (e0000000 10000000)
Dec 21 19:17:24 srvhome kernel: [ 0.648658] fb0: switching to inteldrmfb from EFI VGA
Dec 21 19:17:24 srvhome kernel: [ 0.649200] Console: switching to colour dummy device 80x25
Dec 21 19:17:24 srvhome kernel: [ 0.649227] i915 0000:00:02.0: vgaarb: deactivate vga console
Dec 21 19:17:24 srvhome kernel: [ 0.659833] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
Dec 21 19:17:24 srvhome kernel: [ 0.659835] [drm] Driver supports precise vblank timestamp query.
Dec 21 19:17:24 srvhome kernel: [ 0.663873] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem
wns=io+mem
Dec 21 19:17:24 srvhome kernel: [ 0.676285] e1000e 0000:00:19.0 0000:00:19.0 (uninitialized): registered PHC clock
Dec 21 19:17:24 srvhome kernel: [ 0.682007] [drm] Initialized i915 1.6.0 20190822 for 0000:00:02.0 on minor 0
Dec 21 19:17:24 srvhome kernel: [ 0.684902] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
Dec 21 19:17:24 srvhome kernel: [ 0.685144] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input2
Dec 21 19:17:24 srvhome kernel: [ 0.715869] usb 1-1: new high-speed USB device number 2 using ehci-pci
Dec 21 19:17:24 srvhome kernel: [ 0.739869] usb 2-1: new high-speed USB device number 2 using ehci-pci
Dec 21 19:17:24 srvhome kernel: [ 0.751869] usb 3-3: new high-speed USB device number 2 using xhci_hcd
Dec 21 19:17:24 srvhome kernel: [ 0.752090] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 1c:87:2c:5a:bf:74
Dec 21 19:17:24 srvhome kernel: [ 0.752093] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
Dec 21 19:17:24 srvhome kernel: [ 0.752129] e1000e 0000:00:19.0 eth0: MAC: 11, PHY: 12, PBA No: FFFFFF-0FF
Dec 21 19:17:24 srvhome kernel: [ 0.772566] e1000e 0000:00:19.0 eno1: renamed from eth0
Dec 21 19:17:24 srvhome kernel: [ 0.804626] fbcon: i915drmfb (fb0) is primary device
Dec 21 19:17:24 srvhome kernel: [ 0.832687] Console: switching to colour frame buffer device 240x75
Dec 21 19:17:24 srvhome kernel: [ 0.852240] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
Dec 21 19:17:24 srvhome kernel: [ 0.876303] usb 1-1: New USB device found, idVendor=8087, idProduct=8009, bcdDevice= 0.00
Dec 21 19:17:24 srvhome kernel: [ 0.876337] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Dec 21 19:17:24 srvhome kernel: [ 0.876667] hub 1-1:1.0: USB hub found
Dec 21 19:17:24 srvhome kernel: [ 0.876764] hub 1-1:1.0: 6 ports detected
Dec 21 19:17:24 srvhome kernel: [ 0.896292] usb 2-1: New USB device found, idVendor=8087, idProduct=8001, bcdDevice= 0.00
Dec 21 19:17:24 srvhome kernel: [ 0.896336] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Dec 21 19:17:24 srvhome kernel: [ 0.896566] hub 2-1:1.0: USB hub found
Dec 21 19:17:24 srvhome kernel: [ 0.896653] hub 2-1:1.0: 8 ports detected
Dec 21 19:17:24 srvhome kernel: [ 0.900326] usb 3-3: New USB device found, idVendor=0451, idProduct=8043, bcdDevice= 1.00
Dec 21 19:17:24 srvhome kernel: [ 0.900350] usb 3-3: New USB device strings: Mfr=0, Product=0, SerialNumber=1
Dec 21 19:17:24 srvhome kernel: [ 0.900368] usb 3-3: SerialNumber: BE080059537A
Dec 21 19:17:24 srvhome kernel: [ 0.900853] hub 3-3:1.0: USB hub found
Dec 21 19:17:24 srvhome kernel: [ 0.900916] hub 3-3:1.0: 4 ports detected
Dec 21 19:17:24 srvhome kernel: [ 0.959872] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Dec 21 19:17:24 srvhome kernel: [ 0.959904] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Dec 21 19:17:24 srvhome kernel: [ 0.959934] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Dec 21 19:17:24 srvhome kernel: [ 0.959973] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Dec 21 19:17:24 srvhome kernel: [ 0.960616] ata4.00: ATA-9: WDC WD20EFRX-68AX9N0, 80.00A80, max UDMA/133
Dec 21 19:17:24 srvhome kernel: [ 0.960637] ata4.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA
Dec 21 19:17:24 srvhome kernel: [ 0.960660] ata1.00: ATA-9: WDC WD20EFRX-68AX9N0, 80.00A80, max UDMA/133
Dec 21 19:17:24 srvhome kernel: [ 0.960680] ata1.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA
Dec 21 19:17:24 srvhome kernel: [ 0.960815] ata3.00: ATA-9: WDC WD40EFRX-68WT0N0, 80.00A80, max UDMA/133
Dec 21 19:17:24 srvhome kernel: [ 0.960835] ata3.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA
Dec 21 19:17:24 srvhome kernel: [ 0.961273] ata4.00: configured for UDMA/133
Dec 21 19:17:24 srvhome kernel: [ 0.961469] ata1.00: configured for UDMA/133
Dec 21 19:17:24 srvhome kernel: [ 0.961568] ata3.00: configured for UDMA/133
Dec 21 19:17:24 srvhome kernel: [ 0.961624] scsi 0:0:0:0: Direct-Access ATA WDC WD20EFRX-68A 0A80 PQ: 0 ANSI: 5
Dec 21 19:17:24 srvhome kernel: [ 0.961787] sd 0:0:0:0: Attached scsi generic sg0 type 0
Dec 21 19:17:24 srvhome kernel: [ 0.961806] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
Dec 21 19:17:24 srvhome kernel: [ 0.961837] sd 0:0:0:0: [sda] 4096-byte physical blocks
Dec 21 19:17:24 srvhome kernel: [ 0.961860] sd 0:0:0:0: [sda] Write Protect is off
Dec 21 19:17:24 srvhome kernel: [ 0.961877] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Dec 21 19:17:24 srvhome kernel: [ 0.961884] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Dec 21 19:17:24 srvhome kernel: [ 0.983938] ata2.00: ATA-10: WDC WDS120G2G0A-00JH30, UE220400, max UDMA/133
Dec 21 19:17:24 srvhome kernel: [ 0.983958] ata2.00: 234441648 sectors, multi 1: LBA48 NCQ (depth 32)
Dec 21 19:17:24 srvhome kernel: [ 0.990280] ata2.00: configured for UDMA/133
Dec 21 19:17:24 srvhome kernel: [ 0.990381] scsi 1:0:0:0: Direct-Access ATA WDC WDS120G2G0A- 0400 PQ: 0 ANSI: 5
Dec 21 19:17:24 srvhome kernel: [ 0.990572] sd 1:0:0:0: Attached scsi generic sg1 type 0
Dec 21 19:17:24 srvhome kernel: [ 0.990677] sd 1:0:0:0: [sdb] 234441648 512-byte logical blocks: (120 GB/112 GiB)
Dec 21 19:17:24 srvhome kernel: [ 0.990713] scsi 2:0:0:0: Direct-Access ATA WDC WD40EFRX-68W 0A80 PQ: 0 ANSI: 5
Dec 21 19:17:24 srvhome kernel: [ 0.990741] sd 1:0:0:0: [sdb] Write Protect is off
Dec 21 19:17:24 srvhome kernel: [ 0.990759] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Dec 21 19:17:24 srvhome kernel: [ 0.990787] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Dec 21 19:17:24 srvhome kernel: [ 0.990854] sd 2:0:0:0: Attached scsi generic sg2 type 0
Dec 21 19:17:24 srvhome kernel: [ 0.990889] sd 2:0:0:0: [sdc] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
Dec 21 19:17:24 srvhome kernel: [ 0.990913] sd 2:0:0:0: [sdc] 4096-byte physical blocks
Dec 21 19:17:24 srvhome kernel: [ 0.990940] sd 2:0:0:0: [sdc] Write Protect is off
Dec 21 19:17:24 srvhome kernel: [ 0.990956] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
Dec 21 19:17:24 srvhome kernel: [ 0.990970] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Dec 21 19:17:24 srvhome kernel: [ 0.990977] scsi 3:0:0:0: Direct-Access ATA WDC WD20EFRX-68A 0A80 PQ: 0 ANSI: 5
Dec 21 19:17:24 srvhome kernel: [ 0.991111] sd 3:0:0:0: Attached scsi generic sg3 type 0
Dec 21 19:17:24 srvhome kernel: [ 0.991137] sd 3:0:0:0: [sdd] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
Dec 21 19:17:24 srvhome kernel: [ 0.993510] sd 3:0:0:0: [sdd] 4096-byte physical blocks
Dec 21 19:17:24 srvhome kernel: [ 0.994383] sd 3:0:0:0: [sdd] Write Protect is off
Dec 21 19:17:24 srvhome kernel: [ 0.994635] sda: sda1
Dec 21 19:17:24 srvhome kernel: [ 0.995310] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
Dec 21 19:17:24 srvhome kernel: [ 0.996234] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Dec 21 19:17:24 srvhome kernel: [ 0.996494] sd 0:0:0:0: [sda] Attached SCSI disk
Dec 21 19:17:24 srvhome kernel: [ 1.022796] sdd: sdd1
Dec 21 19:17:24 srvhome kernel: [ 1.023923] sd 3:0:0:0: [sdd] Attached SCSI disk
Dec 21 19:17:24 srvhome kernel: [ 1.032201] sdb: sdb1 sdb2
Dec 21 19:17:24 srvhome kernel: [ 1.033728] sd 1:0:0:0: [sdb] Attached SCSI disk
Dec 21 19:17:24 srvhome kernel: [ 1.035847] usb 4-3: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
Dec 21 19:17:24 srvhome kernel: [ 1.056236] usb 4-3: New USB device found, idVendor=0451, idProduct=8041, bcdDevice= 1.00
Dec 21 19:17:24 srvhome kernel: [ 1.057159] usb 4-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Dec 21 19:17:24 srvhome kernel: [ 1.058800] hub 4-3:1.0: USB hub found
Dec 21 19:17:24 srvhome kernel: [ 1.060213] hub 4-3:1.0: 4 ports detected
Dec 21 19:17:24 srvhome kernel: [ 1.179863] usb 3-13: new low-speed USB device number 3 using xhci_hcd
Dec 21 19:17:24 srvhome kernel: [ 1.341327] usb 3-13: New USB device found, idVendor=046a, idProduct=b102, bcdDevice= 4.03
Dec 21 19:17:24 srvhome kernel: [ 1.342259] usb 3-13: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 21 19:17:24 srvhome kernel: [ 1.343146] usb 3-13: Product: USB Wireless Device
Dec 21 19:17:24 srvhome kernel: [ 1.343982] usb 3-13: Manufacturer: HOLTEK
Dec 21 19:17:24 srvhome kernel: [ 1.347852] tsc: Refined TSC clocksource calibration: 3597.914 MHz
Dec 21 19:17:24 srvhome kernel: [ 1.348744] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x33dca08a5e6, max_idle_ns: 440795278676 ns
Dec 21 19:17:24 srvhome kernel: [ 1.349644] clocksource: Switched to clocksource tsc
Dec 21 19:17:24 srvhome kernel: [ 1.350598] hidraw: raw HID events driver (C) Jiri Kosina
Dec 21 19:17:24 srvhome kernel: [ 1.369680] usbcore: registered new interface driver usbhid
Dec 21 19:17:24 srvhome kernel: [ 1.370615] usbhid: USB HID core driver
Dec 21 19:17:24 srvhome kernel: [ 1.373332] input: HOLTEK USB Wireless Device as /devices/pci0000:00/0000:00:14.0/usb3/3-13/3-13:1.0/0003:046A:B102.0001/input/input3
Dec 21 19:17:24 srvhome kernel: [ 1.432021] hid-generic 0003:046A:B102.0001: input,hidraw0: USB HID v1.10 Keyboard [HOLTEK USB Wireless Device] on usb-0000:00:14.0-13/input0
Dec 21 19:17:24 srvhome kernel: [ 1.433108] input: HOLTEK USB Wireless Device Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-13/3-13:1.1/0003:046A:B102.0002/input/input4
Dec 21 19:17:24 srvhome kernel: [ 1.434204] input: HOLTEK USB Wireless Device System Control as /devices/pci0000:00/0000:00:14.0/usb3/3-13/3-13:1.1/0003:046A:B102.0002/input/input5
Dec 21 19:17:24 srvhome kernel: [ 1.491985] input: HOLTEK USB Wireless Device Consumer Control as /devices/pci0000:00/0000:00:14.0/usb3/3-13/3-13:1.1/0003:046A:B102.0002/input/input6
Dec 21 19:17:24 srvhome kernel: [ 1.493126] hid-generic 0003:046A:B102.0002: input,hidraw1: USB HID v1.10 Mouse [HOLTEK USB Wireless Device] on usb-0000:00:14.0-13/input1
Dec 21 19:17:24 srvhome kernel: [ 1.803015] sdc: sdc1 sdc2
Dec 21 19:17:24 srvhome kernel: [ 1.804569] sd 2:0:0:0: [sdc] Attached SCSI disk
Dec 21 19:17:24 srvhome kernel: [ 2.211829] raid6: avx2x4 gen() 34548 MB/s
Dec 21 19:17:24 srvhome kernel: [ 2.259828] raid6: avx2x4 xor() 20868 MB/s
Dec 21 19:17:24 srvhome kernel: [ 2.307827] raid6: avx2x2 gen() 30693 MB/s
Dec 21 19:17:24 srvhome kernel: [ 2.355830] raid6: avx2x2 xor() 18698 MB/s
Dec 21 19:17:24 srvhome kernel: [ 2.403827] raid6: avx2x1 gen() 26230 MB/s
Dec 21 19:17:24 srvhome kernel: [ 2.451827] raid6: avx2x1 xor() 17752 MB/s
Dec 21 19:17:24 srvhome kernel: [ 2.499831] raid6: sse2x4 gen() 18903 MB/s
Dec 21 19:17:24 srvhome kernel: [ 2.547828] raid6: sse2x4 xor() 12042 MB/s
Dec 21 19:17:24 srvhome kernel: [ 2.595828] raid6: sse2x2 gen() 16355 MB/s
Dec 21 19:17:24 srvhome kernel: [ 2.643831] raid6: sse2x2 xor() 10533 MB/s
Dec 21 19:17:24 srvhome kernel: [ 2.691842] raid6: sse2x1 gen() 13664 MB/s
Dec 21 19:17:24 srvhome kernel: [ 2.739842] raid6: sse2x1 xor() 9577 MB/s
Dec 21 19:17:24 srvhome kernel: [ 2.740748] raid6: using algorithm avx2x4 gen() 34548 MB/s
Dec 21 19:17:24 srvhome kernel: [ 2.741634] raid6: .... xor() 20868 MB/s, rmw enabled
Dec 21 19:17:24 srvhome kernel: [ 2.742517] raid6: using avx2x2 recovery algorithm
Dec 21 19:17:24 srvhome kernel: [ 2.744106] xor: automatically using best checksumming function avx
Dec 21 19:17:24 srvhome kernel: [ 2.745717] async_tx: api initialized (async)
Dec 21 19:17:24 srvhome kernel: [ 2.781150] Btrfs loaded, crc32c=crc32c-intel
Dec 21 19:17:24 srvhome kernel: [ 2.870141] EXT4-fs (sdb2): INFO: recovery required on readonly filesystem
Dec 21 19:17:24 srvhome kernel: [ 2.871124] EXT4-fs (sdb2): write access will be enabled during recovery
Dec 21 19:17:24 srvhome kernel: [ 155.719186] EXT4-fs (sdb2): orphan cleanup on readonly fs
Dec 21 19:17:24 srvhome kernel: [ 155.720149] EXT4-fs (sdb2): 3 orphan inodes deleted
Dec 21 19:17:24 srvhome kernel: [ 155.721011] EXT4-fs (sdb2): recovery complete
Dec 21 19:17:24 srvhome kernel: [ 170.775507] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null)
Dec 21 19:17:24 srvhome kernel: [ 171.141934] systemd[1]: Inserted module 'autofs4'
Dec 21 19:17:24 srvhome kernel: [ 171.173938] systemd[1]: systemd 245.4-4ubuntu3.3 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
Dec 21 19:17:24 srvhome kernel: [ 171.195905] systemd[1]: Detected architecture x86-64.
Dec 21 19:17:24 srvhome kernel: [ 171.231776] systemd[1]: Set hostname to <srvhome>.
Dec 21 19:17:24 srvhome kernel: [ 171.580061] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly.
Dec 21 19:17:24 srvhome kernel: [ 171.734398] systemd[1]: Created slice system-modprobe.slice.
Dec 21 19:17:24 srvhome kernel: [ 171.736917] systemd[1]: Created slice system-postgresql.slice.
Dec 21 19:17:24 srvhome kernel: [ 171.739378] systemd[1]: Created slice system-systemd\x2dfsck.slice.
Dec 21 19:17:24 srvhome kernel: [ 171.741884] systemd[1]: Created slice User and Session Slice.
Dec 21 19:17:24 srvhome kernel: [ 171.744295] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Dec 21 19:17:24 srvhome kernel: [ 171.746782] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Dec 21 19:17:24 srvhome kernel: [ 171.749221] systemd[1]: Reached target User and Group Name Lookups.
Dec 21 19:17:24 srvhome kernel: [ 171.751643] systemd[1]: Reached target Slices.
Dec 21 19:17:24 srvhome kernel: [ 171.754094] systemd[1]: Listening on Device-mapper event daemon FIFOs.
Dec 21 19:17:24 srvhome kernel: [ 171.756559] systemd[1]: Listening on LVM2 poll daemon socket.
Dec 21 19:17:24 srvhome kernel: [ 171.758978] systemd[1]: Listening on multipathd control socket.
Dec 21 19:17:24 srvhome kernel: [ 171.761385] systemd[1]: Listening on Syslog Socket.
Dec 21 19:17:24 srvhome kernel: [ 171.763716] systemd[1]: Listening on fsck to fsckd communication Socket.
Dec 21 19:17:24 srvhome kernel: [ 171.765985] systemd[1]: Listening on initctl Compatibility Named Pipe.
Dec 21 19:17:24 srvhome kernel: [ 171.768331] systemd[1]: Listening on Journal Audit Socket.
Dec 21 19:17:24 srvhome kernel: [ 171.770599] systemd[1]: Listening on Journal Socket (/dev/log).
Dec 21 19:17:24 srvhome kernel: [ 171.772907] systemd[1]: Listening on Journal Socket.
Dec 21 19:17:24 srvhome kernel: [ 171.775252] systemd[1]: Listening on Network Service Netlink Socket.
Dec 21 19:17:24 srvhome kernel: [ 171.777648] systemd[1]: Listening on udev Control Socket.
Dec 21 19:17:24 srvhome kernel: [ 171.780015] systemd[1]: Listening on udev Kernel Socket.
Dec 21 19:17:24 srvhome kernel: [ 171.782882] systemd[1]: Mounting Huge Pages File System...
Dec 21 19:17:24 srvhome kernel: [ 171.785789] systemd[1]: Mounting POSIX Message Queue File System...
Dec 21 19:17:24 srvhome kernel: [ 171.788747] systemd[1]: Mounting Kernel Debug File System...
Dec 21 19:17:24 srvhome kernel: [ 171.791630] systemd[1]: Mounting Kernel Trace File System...
Dec 21 19:17:24 srvhome kernel: [ 171.794966] systemd[1]: Starting Journal Service...
Dec 21 19:17:24 srvhome kernel: [ 171.798226] systemd[1]: Starting Set the console keyboard layout...
Dec 21 19:17:24 srvhome kernel: [ 171.801313] systemd[1]: Starting Create list of static device nodes for the current kernel...
Dec 21 19:17:24 srvhome kernel: [ 171.804832] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Dec 21 19:17:24 srvhome kernel: [ 171.808697] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
Dec 21 19:17:24 srvhome kernel: [ 171.808780] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
Dec 21 19:17:24 srvhome kernel: [ 171.809662] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
Dec 21 19:17:24 srvhome kernel: [ 171.816114] systemd[1]: Starting Load Kernel Modules...
Dec 21 19:17:24 srvhome kernel: [ 171.821156] systemd[1]: Starting Remount Root and Kernel File Systems...
Dec 21 19:17:24 srvhome kernel: [ 171.825070] systemd[1]: Starting udev Coldplug all Devices...
Dec 21 19:17:24 srvhome kernel: [ 171.828301] systemd[1]: Starting Uncomplicated firewall...
Dec 21 19:17:24 srvhome kernel: [ 171.831969] systemd[1]: Mounted Huge Pages File System.
Dec 21 19:17:24 srvhome kernel: [ 171.835454] systemd[1]: Mounted POSIX Message Queue File System.
Dec 21 19:17:24 srvhome kernel: [ 171.838533] systemd[1]: Mounted Kernel Debug File System.
Dec 21 19:17:24 srvhome kernel: [ 171.841079] systemd[1]: Mounted Kernel Trace File System.
Dec 21 19:17:24 srvhome kernel: [ 171.843695] systemd[1]: Finished Create list of static device nodes for the current kernel.
Dec 21 19:17:24 srvhome kernel: [ 171.869838] systemd[1]: Finished Set the console keyboard layout.
Dec 21 19:17:24 srvhome kernel: [ 171.876816] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Dec 21 19:17:24 srvhome kernel: [ 174.339507] EXT4-fs (sdb2): re-mounted. Opts: (null)
Dec 21 19:17:24 srvhome kernel: [ 174.341541] systemd[1]: Finished Remount Root and Kernel File Systems.
Dec 21 19:17:24 srvhome kernel: [ 174.343418] systemd[1]: Activating swap /swap.img...
Dec 21 19:17:24 srvhome kernel: [ 174.356739] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Dec 21 19:17:24 srvhome kernel: [ 174.357833] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
Dec 21 19:17:24 srvhome kernel: [ 174.359455] systemd[1]: Starting Load/Save Random Seed...
Dec 21 19:17:24 srvhome kernel: [ 174.362535] systemd[1]: Starting Create System Users...
Dec 21 19:17:24 srvhome kernel: [ 174.365537] systemd[1]: Finished Uncomplicated firewall.
Dec 21 19:17:24 srvhome kernel: [ 174.365607] nct6775: Enabling hardware monitor logical device mappings.
Dec 21 19:17:24 srvhome kernel: [ 174.367756] nct6775: Found NCT6791D or compatible chip at 0x2e:0x290
Dec 21 19:17:24 srvhome kernel: [ 174.368954] ACPI Warning: SystemIO range 0x0000000000000295-0x0000000000000296 conflicts with OpRegion 0x0000000000000290-0x0000000000000299 (\_GPE.HWM) (20190816/utaddress-204)
Dec 21 19:17:24 srvhome kernel: [ 174.368959] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Dec 21 19:17:24 srvhome kernel: [ 174.373406] systemd[1]: Finished Load Kernel Modules.
Dec 21 19:17:24 srvhome kernel: [ 174.377019] systemd[1]: Mounting FUSE Control File System...
Dec 21 19:17:24 srvhome kernel: [ 174.380253] systemd[1]: Mounting Kernel Configuration File System...
Dec 21 19:17:24 srvhome kernel: [ 174.383770] systemd[1]: Starting Apply Kernel Variables...
Dec 21 19:17:24 srvhome kernel: [ 174.387424] systemd[1]: Started Journal Service.
Dec 21 19:17:24 srvhome kernel: [ 174.451859] Adding 4194300k swap on /swap.img. Priority:-2 extents:5 across:4767740k SSFS
Dec 21 19:17:24 srvhome kernel: [ 179.393725] systemd-journald[453]: Received client request to flush runtime journal.
Dec 21 19:17:24 srvhome kernel: [ 184.420480] systemd-journald[453]: File /var/log/journal/97585e8b957e4826997579daca3a1de0/system.journal corrupted or uncleanly shut down, renaming and replacing.
Dec 21 19:17:24 srvhome kernel: [ 219.063321] snd_hda_intel 0000:00:03.0: enabling device (0000 -> 0002)
Dec 21 19:17:24 srvhome kernel: [ 219.063603] snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Dec 21 19:17:24 srvhome kernel: [ 219.066334] asus_wmi: ASUS WMI generic driver loaded
Dec 21 19:17:24 srvhome kernel: [ 219.066972] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
Dec 21 19:17:24 srvhome kernel: [ 219.066973] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
Dec 21 19:17:24 srvhome kernel: [ 219.066974] RAPL PMU: hw unit of domain package 2^-14 Joules
Dec 21 19:17:24 srvhome kernel: [ 219.066974] RAPL PMU: hw unit of domain dram 2^-14 Joules
Dec 21 19:17:24 srvhome kernel: [ 219.066975] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
Dec 21 19:17:24 srvhome kernel: [ 219.068362] asus_wmi: Initialization: 0x0
Dec 21 19:17:24 srvhome kernel: [ 219.068405] asus_wmi: BIOS WMI version: 0.9
Dec 21 19:17:24 srvhome kernel: [ 219.068482] asus_wmi: SFUN value: 0x0
Dec 21 19:17:24 srvhome kernel: [ 219.068485] eeepc-wmi eeepc-wmi: Detected ASUSWMI, use DCTS
Dec 21 19:17:24 srvhome kernel: [ 219.069261] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input7
Dec 21 19:17:24 srvhome kernel: [ 219.080841] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input8
Dec 21 19:17:24 srvhome kernel: [ 219.080907] input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card0/input9
Dec 21 19:17:24 srvhome kernel: [ 219.080963] input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card0/input10
Dec 21 19:17:24 srvhome kernel: [ 219.208068] intel_rapl_common: Found RAPL domain package
Dec 21 19:17:24 srvhome kernel: [ 219.208069] intel_rapl_common: Found RAPL domain core
Dec 21 19:17:24 srvhome kernel: [ 219.208070] intel_rapl_common: Found RAPL domain uncore
Dec 21 19:17:24 srvhome kernel: [ 219.208071] intel_rapl_common: Found RAPL domain dram
Dec 21 19:17:24 srvhome kernel: [ 219.479311] alua: device handler registered
Dec 21 19:17:24 srvhome kernel: [ 219.480741] emc: device handler registered
Dec 21 19:17:24 srvhome kernel: [ 219.482281] rdac: device handler registered
Dec 21 19:17:24 srvhome kernel: [ 219.542981] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Dec 21 19:17:24 srvhome kernel: [ 219.960036] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Dec 21 19:17:24 srvhome kernel: [ 221.249275] audit: type=1400 audit(1608574337.288:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=794 comm="apparmor_parser"
Dec 21 19:17:24 srvhome kernel: [ 221.249278] audit: type=1400 audit(1608574337.288:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=794 comm="apparmor_parser"
Dec 21 19:17:24 srvhome kernel: [ 221.249594] audit: type=1400 audit(1608574337.288:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=801 comm="apparmor_parser"
Dec 21 19:17:24 srvhome kernel: [ 221.249596] audit: type=1400 audit(1608574337.288:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=801 comm="apparmor_parser"
Dec 21 19:17:24 srvhome kernel: [ 221.251271] audit: type=1400 audit(1608574337.288:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=799 comm="apparmor_parser"
Dec 21 19:17:24 srvhome kernel: [ 221.251462] audit: type=1400 audit(1608574337.288:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=796 comm="apparmor_parser"
Dec 21 19:17:24 srvhome kernel: [ 221.251464] audit: type=1400 audit(1608574337.288:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=796 comm="apparmor_parser"
Dec 21 19:17:24 srvhome kernel: [ 221.251465] audit: type=1400 audit(1608574337.288:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=796 comm="apparmor_parser"
Dec 21 19:17:24 srvhome kernel: [ 221.252002] audit: type=1400 audit(1608574337.292:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ippusbxd" pid=797 comm="apparmor_parser"
Dec 21 19:17:24 srvhome kernel: [ 221.255607] audit: type=1400 audit(1608574337.292:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/tcpdump" pid=800 comm="apparmor_parser"
Dec 21 19:17:24 srvhome kernel: [ 245.546018] e1000e: eno1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
Dec 21 19:17:24 srvhome kernel: [ 245.546045] IPv6: ADDRCONF(NETDEV_CHANGE): eno1: link becomes ready
Dec 21 19:18:40 srvhome sbkeysync[954]: /usr/share/secureboot/updates/dbx/MS-2016-08-08.bin [7085 bytes]
Dec 21 19:18:40 srvhome sbkeysync[954]: firmware keys:
Dec 21 19:18:40 srvhome sbkeysync[954]: PK:
Dec 21 19:18:40 srvhome sbkeysync[954]: /CN=ASUSTeK MotherBoard PK Certificate
Dec 21 19:18:40 srvhome sbkeysync[954]: KEK:
Dec 21 19:18:40 srvhome sbkeysync[954]: /C=GB/ST=Isle of Man/L=Douglas/O=Canonical Ltd./CN=Canonical Ltd. Master Certificate Authority
Dec 21 19:18:40 srvhome sbkeysync[954]: /C=US/ST=Washington/L=Redmond/O=Microsoft Corporation/CN=Microsoft Corporation KEK CA 2011
Dec 21 19:18:40 srvhome sbkeysync[954]: /CN=ASUSTeK MotherBoard KEK Certificate
Dec 21 19:18:40 srvhome sbkeysync[954]: db:
Dec 21 19:18:40 srvhome sbkeysync[954]: 7e021f15e3a67b75ace884999bedffe34213792a611e40e562e87e6b9a0cb282
Dec 21 19:18:40 srvhome sbkeysync[954]: f16b5fc361183f587120e602c0d65773afdfe786124184fa70805258d76d594c
Dec 21 19:18:40 srvhome sbkeysync[954]: 04970157de52cdae14cf17ee369881d6245b3a6ab6352eabaee588a0584b0303
Dec 21 19:18:40 srvhome sbkeysync[954]: f58fbdf71be8c37cbbd6944e472c450b1043817b972914487c221033f3079e43
Dec 21 19:18:40 srvhome sbkeysync[954]: /C=US/ST=Washington/L=Redmond/O=Microsoft Corporation/CN=Microsoft Windows Production PCA 2011
Dec 21 19:18:40 srvhome sbkeysync[954]: /C=US/ST=Washington/L=Redmond/O=Microsoft Corporation/CN=Microsoft Corporation UEFI CA 2011
Dec 21 19:18:40 srvhome sbkeysync[954]: /CN=ASUSTeK Notebook SW Key Certificate
Dec 21 19:18:40 srvhome sbkeysync[954]: /CN=ASUSTeK MotherBoard SW Key Certificate
Dec 21 19:18:40 srvhome sbkeysync[954]: dbx:
Dec 21 19:18:40 srvhome sbkeysync[954]: 45c7c8ae750acfbb48fc37527d6412dd644daed8913ccd8a24c94d856967df8e
Dec 21 19:18:40 srvhome sbkeysync[954]: 64575bd912789a2e14ad56f6341f52af6bf80cf94400785975e9f04e2d64d745
Dec 21 19:18:40 srvhome sbkeysync[954]: 939aeef4f5fa51e23340c3f2e49048ce8872526afdf752c3a7f3a3f2bc9f6049
Dec 21 19:18:40 srvhome sbkeysync[954]: 3b0287533e0cc3d0ec1aa823cbf0a941aad8721579d1c499802dd1c3a636b8a9
Dec 21 19:18:40 srvhome sbkeysync[954]: c83cb13922ad99f560744675dd37cc94dcad5a1fcba6472fee341171d939e884
Dec 21 19:18:40 srvhome sbkeysync[954]: 77dd190fa30d88ff5e3b011a0ae61e6209780c130b535ecb87e6f0888a0b6b2f
Dec 21 19:18:40 srvhome sbkeysync[954]: 55b99b0de53dbcfe485aa9c737cf3fb616ef3d91fab599aa7cab19eda763b5ba
Dec 21 19:18:40 srvhome sbkeysync[954]: ca171d614a8d7e121c93948cd0fe55d39981f9d11aa96e03450a415227c2c65b
Dec 21 19:18:40 srvhome sbkeysync[954]: fecfb232d12e994b6d485d2c7167728aa5525984ad5ca61e7516221f079a1436
Dec 21 19:18:40 srvhome sbkeysync[954]: fe63a84f782cc9d3fcf2ccf9fc11fbd03760878758d26285ed12669bdc6e6d01
Dec 21 19:18:40 srvhome sbkeysync[954]: fddd6e3d29ea84c7743dad4a1bdbc700b5fec1b391f932409086acc71dd6dbd8
Dec 21 19:18:40 srvhome sbkeysync[954]: e92c22eb3b5642d65c1ec2caf247d2594738eebb7fb3841a44956f59e2b0d1fa
Dec 21 19:18:40 srvhome sbkeysync[954]: d8cbeb9735f5672b367e4f96cdc74969615d17074ae96c724d42ce0216f8f3fa
Dec 21 19:18:40 srvhome sbkeysync[954]: ce3bfabe59d67ce8ac8dfd4a16f7c43ef9c224513fbc655957d735fa29f540ce
Dec 21 19:18:40 srvhome dbus-daemon[888]: dbus[888]: Unknown group "power" in message bus configuration file
Dec 21 19:18:40 srvhome grub-common[898]: * Recording successful boot for GRUB
Dec 21 19:18:40 srvhome grub-common[898]: ...done.
Dec 21 19:18:40 srvhome sbkeysync[954]: cb6b858b40d3a098765815b592c1514a49604fafd60819da88d7a76e9778fef7
Dec 21 19:18:40 srvhome sbkeysync[954]: c90f336617b8e7f983975413c997f10b73eb267fd8a10cb9e3bdbfc667abdb8b
Dec 21 19:18:40 srvhome sbkeysync[954]: c617c1a8b1ee2a811c28b5a81b4c83d7c98b5b0c27281d610207ebe692c2967f
Dec 21 19:18:40 srvhome sbkeysync[954]: c409bdac4775add8db92aa22b5b718fb8c94a1462c1fe9a416b95d8a3388c2fc
Dec 21 19:18:40 srvhome sbkeysync[954]: bc87a668e81966489cb508ee805183c19e6acd24cf17799ca062d2e384da0ea7
Dec 21 19:18:40 srvhome sbkeysync[954]: b97a0889059c035ff1d54b6db53b11b9766668d9f955247c028b2837d7a04cd9
Dec 21 19:18:40 srvhome sbkeysync[954]: b8f078d983a24ac433216393883514cd932c33af18e7dd70884c8235f4275736
Dec 21 19:18:40 srvhome sbkeysync[954]: b54f1ee636631fad68058d3b0937031ac1b90ccb17062a391cca68afdbe40d55
Dec 21 19:18:40 srvhome sbkeysync[954]: afe2030afb7d2cda13f9fa333a02e34f6751afec11b010dbcd441fdf4c4002b3
Dec 21 19:18:40 srvhome sbkeysync[954]: aeebae3151271273ed95aa2e671139ed31a98567303a332298f83709a9d55aa1
Dec 21 19:18:40 srvhome sbkeysync[954]: ad6826e1946d26d3eaf3685c88d97d85de3b4dcb3d0ee2ae81c70560d13c5720
Dec 21 19:18:40 srvhome sbkeysync[954]: a7f32f508d4eb0fead9a087ef94ed1ba0aec5de6f7ef6ff0a62b93bedf5d458d
Dec 21 19:18:40 srvhome sbkeysync[954]: a6b5151f3655d3a2af0d472759796be4a4200e5495a7d869754c4848857408a7
Dec 21 19:18:40 srvhome sbkeysync[954]: 9e4a69173161682e55fde8fef560eb88ec1ffedcaf04001f66c0caf707b2b734
Dec 21 19:18:40 srvhome sbkeysync[954]: 9998d363c491be16bd74ba10b94d9291001611736fdca643a36664bc0f315a42
Dec 21 19:18:40 srvhome sbkeysync[954]: 8d8ea289cfe70a1c07ab7365cb28ee51edd33cf2506de888fbadd60ebf80481c
Dec 21 19:18:40 srvhome sbkeysync[954]: 8bf434b49e00ccf71502a2cd900865cb01ec3b3da03c35be505fdf7bd563f521
Dec 21 19:18:40 srvhome sbkeysync[954]: 8ad64859f195b5f58dafaa940b6a6167acd67a886e8f469364177221c55945b9
Dec 21 19:18:40 srvhome sbkeysync[954]: 895a9785f617ca1d7ed44fc1a1470b71f3f1223862d9ff9dcc3ae2df92163daf
Dec 21 19:18:40 srvhome sbkeysync[954]: 82db3bceb4f60843ce9d97c3d187cd9b5941cd3de8100e586f2bda5637575f67
Dec 21 19:18:40 srvhome sbkeysync[954]: 81a8b965bb84d3876b9429a95481cc955318cfaa1412d808c8a33bfd33fff0e4
Dec 21 19:18:40 srvhome sbkeysync[954]: 7827af99362cfaf0717dade4b1bfe0438ad171c15addc248b75bf8caa44bb2c5
Dec 21 19:18:40 srvhome sbkeysync[954]: 72e0bd1867cf5d9d56ab158adf3bddbc82bf32a8d8aa1d8c5e2f6df29428d6d8
Dec 21 19:18:40 srvhome sbkeysync[954]: 726b3eb654046a30f3f83d9b96ce03f670e9a806d1708a0371e62dc49d2c23c1
Dec 21 19:18:40 srvhome sbkeysync[954]: 71f2906fd222497e54a34662ab2497fcc81020770ff51368e9e3d9bfcbfd6375
Dec 21 19:18:40 srvhome sbkeysync[954]: 6f1428ff71c9db0ed5af1f2e7bbfcbab647cc265ddf5b293cdb626f50a3a785e
Dec 21 19:18:40 srvhome sbkeysync[954]: 6c8854478dd559e29351b826c06cb8bfef2b94ad3538358772d193f82ed1ca11
Dec 21 19:18:40 srvhome sbkeysync[954]: 6b1d138078e4418aa68deb7bb35e066092cf479eeb8ce4cd12e7d072ccb42f66
Dec 21 19:18:40 srvhome sbkeysync[954]: 5ae949ea8855eb93e439dbc65bda2e42852c2fdf6789fa146736e3c3410f2b5c
Dec 21 19:18:40 srvhome systemd[1]: secureboot-db.service: Succeeded.
Dec 21 19:18:40 srvhome rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd. [v8.2001.0]
Dec 21 19:18:40 srvhome sbkeysync[954]: 518831fe7382b514d03e15c621228b8ab65479bd0cbfa3c5c1d0f48d9c306135
Dec 21 19:18:40 srvhome sbkeysync[954]: 47cc086127e2069a86e03a6bef2cd410f8c55a6d6bdb362168c31b2ce32a5adf
Dec 21 19:18:40 srvhome sbkeysync[954]: 4397daca839e7f63077cb50c92df43bc2d2fb2a8f59f26fc7a0e4bd4d9751692
Dec 21 19:18:40 srvhome sbkeysync[954]: 3fce9b9fdf3ef09d5452b0f95ee481c2b7f06d743a737971558e70136ace3e73
Dec 21 19:18:40 srvhome sbkeysync[954]: 3841d221368d1583d75c0a02e62160394d6c4e0a6760b6f607b90362bc855b02
Dec 21 19:18:40 srvhome sbkeysync[954]: 3608edbaf5ad0f41a414a1777abf2faf5e670334675ec3995e6935829e0caad2
Dec 21 19:18:40 srvhome sbkeysync[954]: 306628fa5477305728ba4a467de7d0387a54f569d3769fce5e75ec89d28d1593
Dec 21 19:18:40 srvhome sbkeysync[954]: 2e70916786a6f773511fa7181fab0f1d70b557c6322ea923b2a8d3b92b51af7d
Dec 21 19:18:40 srvhome sbkeysync[954]: 2c73d93325ba6dcbe589d4a4c63c5b935559ef92fbf050ed50c4e2085206f17d
Dec 21 19:18:40 srvhome sbkeysync[954]: 2bbf2ca7b8f1d91f27ee52b6fb2a5dd049b85a2b9b529c5d6662068104b055f8
Dec 21 19:18:40 srvhome sbkeysync[954]: 2b99cf26422e92fe365fbf4bc30d27086c9ee14b7a6fff44fb2f6b9001699939
Dec 21 19:18:40 srvhome sbkeysync[954]: 18333429ff0562ed9f97033e1148dceee52dbe2e496d5410b5cfd6c864d2d10f
Dec 21 19:18:40 srvhome sbkeysync[954]: 174e3a0b5b43c6a607bbd3404f05341e3dcf396267ce94f8b50e2e23a9da920c
Dec 21 19:18:40 srvhome sbkeysync[954]: 106faceacfecfd4e303b74f480a08098e2d0802b936f8ec774ce21f31686689c
Dec 21 19:18:40 srvhome sbkeysync[954]: 0dc9f3fb99962148c3ca833632758d3ed4fc8d0b0007b95b31e6528f2acd5bfc
Dec 21 19:18:40 srvhome sbkeysync[954]: 0d0dbeca6f29eca06f331a7d72e4884b12097fb348983a2a14a0d73f4f10140f
Dec 21 19:18:40 srvhome sbkeysync[954]: 0c189339762df336ab3dd006a463df715a39cfb0f492465c600e6c6bd7bd898c
Dec 21 19:18:40 srvhome sbkeysync[954]: 0bbb4392daac7ab89b30a4ac657531b97bfaab04f90b0dafe5f9b6eb90a06374
Dec 21 19:18:40 srvhome sbkeysync[954]: 09df5f4e511208ec78b96d12d08125fdb603868de39f6f72927852599b659c26
Dec 21 19:18:40 srvhome sbkeysync[954]: 07e6c6a858646fb1efc67903fe28b116011f2367fe92e6be2b36999eff39d09e
Dec 21 19:18:40 srvhome sbkeysync[954]: 075eea060589548ba060b2feed10da3c20c7fe9b17cd026b94e8a683b8115238
Dec 21 19:18:40 srvhome sbkeysync[954]: 90fbe70e69d633408d3e170c6832dbb2d209e0272527dfb63d49d29572a6f44c
Dec 21 19:18:40 srvhome sbkeysync[954]: 29c6eb52b43c3aa18b2cd8ed6ea8607cef3cfae1bafe1165755cf2e614844a44
Dec 21 19:18:40 srvhome sbkeysync[954]: d063ec28f67eba53f1642dbf7dff33c6a32add869f6013fe162e2c32f1cbe56d
Dec 21 19:18:40 srvhome sbkeysync[954]: d626157e1d6a718bc124ab8da27cbb65072ca03a7b6b257dbdcbbd60f65ef3d1
Dec 21 19:18:40 srvhome sbkeysync[954]: 5391c3a2fb112102a6aa1edc25ae77e19f5d6f09cd09eeb2509922bfcd5992ea
Dec 21 19:18:40 srvhome sbkeysync[954]: 58fb941aef95a25943b3fb5f2510a0df3fe44c58c95e0ab80487297568ab9771
Dec 21 19:18:40 srvhome sbkeysync[954]: c3a99a460da464a057c3586d83cef5f4ae08b7103979ed8932742df0ed530c66
Dec 21 19:18:40 srvhome sbkeysync[954]: e6ca68e94146629af03f69c2f86e6bef62f930b37c6fbcc878b78df98c0334e5
Dec 21 19:18:40 srvhome systemd[1]: Finished Secure Boot updates for DB and DBX.
Dec 21 19:18:40 srvhome rsyslogd: rsyslogd's groupid changed to 110
Dec 21 19:18:40 srvhome sbkeysync[954]: 1aec84b84b6c65a51220a9be7181965230210d62d6d33c48999c6b295a2b0a06
Dec 21 19:18:40 srvhome sbkeysync[954]: 363384d14d1f2e0b7815626484c459ad57a318ef4396266048d058c5a19bbf76
Dec 21 19:18:40 srvhome sbkeysync[954]: c5d9d8a186e2c82d09afaa2a6f7f2e73870d3e64f72c4e08ef67796a840f0fbd
Dec 21 19:18:40 srvhome sbkeysync[954]: f52f83a3fa9cfbd6920f722824dbe4034534d25b8507246b3b957dac6e1bce7a
Dec 21 19:18:40 srvhome sbkeysync[954]: 80b4d96931bf0d02fd91a61e19d14f1da452e66db2408ca8604d411f92659f0a
Dec 21 19:18:40 srvhome sbkeysync[954]: 402c750b8670fb7ec73e9407b0732c57ad5cb54907aef81e3b2180ea4fce7b2b
Dec 21 19:18:40 srvhome sbkeysync[954]: filesystem keys:
Dec 21 19:18:40 srvhome sbkeysync[954]: from /usr/share/secureboot/updates/dbx/MS-2016-08-08.bin
Dec 21 19:18:40 srvhome rsyslogd: rsyslogd's userid changed to 104
Dec 21 19:18:40 srvhome rsyslogd: [origin software="rsyslogd" swVersion="8.2001.0" x-pid="933" x-info="
https://www.rsyslog.com"] start
Dec 21 19:18:40 srvhome smartd[942]: smartd 7.1 2019-12-30 r5022 [x86_64-linux-5.4.0-56-generic] (local build)
Dec 21 19:18:40 srvhome smartd[942]: Copyright (C) 2002-19, Bruce Allen, Christian Franke,
www.smartmontools.org
Dec 21 19:18:40 srvhome smartd[942]: Opened configuration file /etc/smartd.conf
Dec 21 19:18:40 srvhome sbkeysync[954]: New keys in filesystem:
Dec 21 19:18:40 srvhome systemd[1]: grub-initrd-fallback.service: Succeeded.
Dec 21 19:18:40 srvhome smartd[942]: Drive: DEVICESCAN, implied '-a' Directive on line 21 of file /etc/smartd.conf
Dec 21 19:18:40 srvhome systemd[1]: Finished GRUB failed boot detection.
Dec 21 19:18:40 srvhome smartd[942]: Configuration file /etc/smartd.conf was parsed, found DEVICESCAN, scanning devices
Dec 21 19:18:40 srvhome [949]: udisks daemon version 2.8.4 starting
Dec 21 19:18:40 srvhome smartd[942]: Device: /dev/sda, type changed from 'scsi' to 'sat'
Dec 21 19:18:40 srvhome systemd[1]: gpu-manager.service: Succeeded.
Dec 21 19:18:40 srvhome smartd[942]: Device: /dev/sda [SAT], opened
Dec 21 19:18:40 srvhome systemd[1]: Finished Detect the available GPUs and deal with any system changes.
Dec 21 19:18:40 srvhome smartd[942]: Device: /dev/sda [SAT], WDC WD20EFRX-68AX9N0, S/N:WD-WMC300543875, WWN:5-0014ee-058d018f8, FW:80.00A80, 2.00 TB
Dec 21 19:18:40 srvhome systemd[1]: Started System Logging Service.
Dec 21 19:18:40 srvhome smartd[942]: Device: /dev/sda [SAT], found in smartd database: Western Digital Red
Dec 21 19:18:40 srvhome systemd[1]: Started LSB: Record successful boot for GRUB.
Dec 21 19:18:40 srvhome smartd[942]: Device: /dev/sda [SAT], is SMART capable. Adding to "monitor" list.
Dec 21 19:18:40 srvhome systemd[1]: accounts-daemon.service: start operation timed out. Terminating.
Dec 21 19:18:40 srvhome smartd[942]: Device: /dev/sda [SAT], state read from /var/lib/smartmontools/smartd.WDC_WD20EFRX_68AX9N0-WD_WMC300543875.ata.state
Dec 21 19:18:40 srvhome systemd[1]: avahi-daemon.service: start operation timed out. Terminating.
Dec 21 19:18:40 srvhome smartd[942]: Device: /dev/sdb, type changed from 'scsi' to 'sat'
Dec 21 19:18:40 srvhome systemd[1]: networkd-dispatcher.service: start operation timed out. Terminating.
Dec 21 19:18:40 srvhome smartd[942]: Device: /dev/sdb [SAT], opened
Dec 21 19:18:40 srvhome systemd[1]: polkit.service: start operation timed out. Terminating.
Dec 21 19:18:40 srvhome smartd[942]: Device: /dev/sdb [SAT], WDC WDS120G2G0A-00JH30, S/N:194138449210, WWN:5-001b44-4a808279f, FW:UE220400, 120 GB
Dec 21 19:18:40 srvhome systemd[1]: accounts-daemon.service: Failed with result 'timeout'.
Dec 21 19:18:40 srvhome smartd[942]: Device: /dev/sdb [SAT], found in smartd database: WD Blue and Green SSDs
Dec 21 19:18:40 srvhome systemd[1]: Failed to start Accounts Service.
Dec 21 19:18:40 srvhome smartd[942]: Device: /dev/sdb [SAT], can't monitor Current_Pending_Sector count - no Attribute 197
Dec 21 19:18:40 srvhome systemd[1]: networkd-dispatcher.service: Failed with result 'timeout'.
Dec 21 19:18:40 srvhome smartd[942]: Device: /dev/sdb [SAT], can't monitor Offline_Uncorrectable count - no Attribute 198
Dec 21 19:18:40 srvhome systemd[1]: Failed to start Dispatcher daemon for systemd-networkd.
Dec 21 19:18:40 srvhome systemd[1]: polkit.service: Failed with result 'timeout'.
Dec 21 19:18:40 srvhome systemd[1]: Failed to start Authorization Manager.
Dec 21 19:18:40 srvhome systemd[1]: Dependency failed for Modem Manager.
Dec 21 19:18:40 srvhome systemd[1]: ModemManager.service: Job ModemManager.service/start failed with result 'dependency'.
Dec 21 19:18:40 srvhome systemd[1]: smartmontools.service: start operation timed out. Terminating.
Dec 21 19:18:40 srvhome systemd[1]: snapd.service: start operation timed out. Terminating.
Dec 21 19:18:40 srvhome systemd[1]: NetworkManager.service: start operation timed out. Terminating.
Dec 21 19:18:40 srvhome systemd[1]: switcheroo-control.service: Unexpected error response from GetNameOwner(): Connection terminated
Dec 21 19:18:40 srvhome systemd[1]: ModemManager.service: Unexpected error response from GetNameOwner(): Connection terminated
Dec 21 19:18:40 srvhome systemd[1]: thermald.service: Unexpected error response from GetNameOwner(): Connection terminated
Dec 21 19:18:40 srvhome systemd[1]: wpa_supplicant.service: Unexpected error response from GetNameOwner(): Connection terminated
Dec 21 19:18:40 srvhome systemd[1]: systemd-logind.service: Unexpected error response from GetNameOwner(): Connection terminated
Dec 21 19:18:40 srvhome systemd[1]: avahi-daemon.service: Unexpected error response from GetNameOwner(): Connection terminated
Dec 21 19:18:40 srvhome systemd[1]: accounts-daemon.service: Unexpected error response from GetNameOwner(): Connection terminated
Dec 21 19:18:40 srvhome systemd[1]: polkit.service: Unexpected error response from GetNameOwner(): Connection terminated
Dec 21 19:18:40 srvhome systemd[1]: gdm.service: Unexpected error response from GetNameOwner(): Connection terminated
Dec 21 19:18:40 srvhome systemd[1]: udisks2.service: Unexpected error response from GetNameOwner(): Connection terminated
Dec 21 19:18:40 srvhome systemd[1]: NetworkManager.service: Unexpected error response from GetNameOwner(): Connection terminated
Dec 21 19:18:40 srvhome systemd[1]: NetworkManager.service: Failed with result 'timeout'.
Dec 21 19:18:40 srvhome systemd[1]: Failed to start Network Manager.
Dec 21 19:18:40 srvhome systemd[1]: Dependency failed for Network Manager Wait Online.
Dec 21 19:18:40 srvhome systemd[1]: NetworkManager-wait-online.service: Job NetworkManager-wait-online.service/start failed with result 'dependency'.
Dec 21 19:18:40 srvhome systemd[1]: snapd.service: Failed with result 'timeout'.
Dec 21 19:18:40 srvhome systemd[1]: Failed to start Snap Daemon.
Dec 21 19:18:40 srvhome systemd[1]: Starting Wait until snapd is fully seeded...
Dec 21 19:18:40 srvhome systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 1.
Dec 21 19:18:40 srvhome systemd[1]: snapd.service: Scheduled restart job, restart counter is at 1.
Dec 21 19:18:40 srvhome systemd[1]: Stopped Network Manager.
Dec 21 19:18:40 srvhome systemd[1]: Starting Network Manager...
Dec 21 19:18:40 srvhome systemd[1]: Stopped Snap Daemon.
Dec 21 19:18:40 srvhome systemd[1]: Starting Snap Daemon...
Dec 21 19:18:40 srvhome systemd[1]: smartmontools.service: Failed with result 'timeout'.
Dec 21 19:18:40 srvhome systemd[1]: Failed to start Self Monitoring and Reporting Technology (SMART) Daemon.
Dec 21 19:18:40 srvhome systemd[1]: switcheroo-control.service: start operation timed out. Terminating.
Dec 21 19:18:40 srvhome systemd[1]: systemd-logind.service: start operation timed out. Terminating.
Dec 21 19:18:40 srvhome systemd[1]: udisks2.service: start operation timed out. Terminating.
Dec 21 19:18:40 srvhome [949]: udisks daemon version 2.8.4 exiting
Dec 21 19:18:40 srvhome systemd[1]: thermald.service: start operation timed out. Terminating.
Dec 21 19:18:40 srvhome systemd[1]: wpa_supplicant.service: start operation timed out. Terminating.
Dec 21 19:18:40 srvhome systemd[1]: switcheroo-control.service: Failed with result 'timeout'.
Dec 21 19:18:40 srvhome systemd[1]: Failed to start Switcheroo Control Proxy service.
Dec 21 19:18:40 srvhome systemd[1]: udisks2.service: Failed with result 'timeout'.
Dec 21 19:18:40 srvhome systemd[1]: Failed to start Disk Manager.
Dec 21 19:18:40 srvhome systemd[1]: wpa_supplicant.service: Failed with result 'timeout'.
Dec 21 19:18:40 srvhome systemd[1]: Failed to start WPA supplicant.
Dec 21 19:18:40 srvhome systemd[1]: Condition check resulted in Manage Sound Card State (restore and store) being skipped.
Dec 21 19:18:40 srvhome systemd[1]: Starting Save/Restore Sound Card State...
Dec 21 19:18:40 srvhome systemd[1]: Finished Save/Restore Sound Card State.
Dec 21 19:18:40 srvhome systemd[1]: Reached target Sound Card.
Dec 21 19:18:40 srvhome systemd[1]: thermald.service: Failed with result 'timeout'.
Dec 21 19:18:40 srvhome systemd[1]: Failed to start Thermal Daemon Service.
Dec 21 19:18:40 srvhome systemd[1]: systemd-logind.service: Failed with result 'timeout'.
Dec 21 19:18:40 srvhome systemd[1]: Failed to start Login Service.
Dec 21 19:18:40 srvhome systemd[1]: systemd-logind.service: Scheduled restart job, restart counter is at 1.
Dec 21 19:18:40 srvhome systemd[1]: Stopped Login Service.
Dec 21 19:18:40 srvhome systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
Dec 21 19:18:40 srvhome systemd[1]: Starting Login Service...
Dec 21 19:18:40 srvhome dbus-daemon[888]: [system] AppArmor D-Bus mediation is enabled
Dec 21 19:18:40 srvhome systemd[1]: Started Login Service.
Dec 21 19:18:40 srvhome avahi-daemon[884]: Successfully called chroot().
Dec 21 19:18:40 srvhome avahi-daemon[884]: Successfully dropped remaining capabilities.
Dec 21 19:18:40 srvhome avahi-daemon[884]: write() failed: Broken pipe
Dec 21 19:18:40 srvhome avahi-daemon[884]: Failed to open /etc/resolv.conf: Broken pipe
Dec 21 19:18:40 srvhome avahi-daemon[884]: No service file found in /etc/avahi/services.
Dec 21 19:18:40 srvhome avahi-daemon[884]: Joining mDNS multicast group on interface eno1.IPv6 with address fe80::1e87:2cff:fe5a:bf74.
Dec 21 19:18:40 srvhome avahi-daemon[884]: New relevant interface eno1.IPv6 for mDNS.
Dec 21 19:18:40 srvhome avahi-daemon[884]: Joining mDNS multicast group on interface eno1.IPv4 with address 192.168.1.107.
Dec 21 19:18:40 srvhome avahi-daemon[884]: New relevant interface eno1.IPv4 for mDNS.
Dec 21 19:18:40 srvhome avahi-daemon[884]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Dec 21 19:18:40 srvhome avahi-daemon[884]: New relevant interface lo.IPv4 for mDNS.
Dec 21 19:18:40 srvhome avahi-daemon[884]: Network interface enumeration completed.
Dec 21 19:18:40 srvhome avahi-daemon[884]: Registering new address record for fe80::1e87:2cff:fe5a:bf74 on eno1.*.
Dec 21 19:18:40 srvhome avahi-daemon[884]: Registering new address record for 192.168.1.107 on eno1.IPv4.
Dec 21 19:18:40 srvhome avahi-daemon[884]: Registering new address record for 127.0.0.1 on lo.IPv4.
Dec 21 19:18:40 srvhome avahi-daemon[884]: Got SIGTERM, quitting.
Dec 21 19:18:40 srvhome avahi-daemon[884]: Leaving mDNS multicast group on interface eno1.IPv6 with address fe80::1e87:2cff:fe5a:bf74.
Dec 21 19:18:40 srvhome avahi-daemon[884]: Leaving mDNS multicast group on interface eno1.IPv4 with address 192.168.1.107.
Dec 21 19:18:40 srvhome avahi-daemon[884]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Dec 21 19:18:40 srvhome avahi-daemon[884]: avahi-daemon 0.7 exiting.
Dec 21 19:18:40 srvhome systemd[1]: avahi-daemon.service: Failed with result 'timeout'.
Dec 21 19:18:40 srvhome systemd[1]: Failed to start Avahi mDNS/DNS-SD Stack.
Dec 21 19:18:40 srvhome NetworkManager[1071]: <info> [1608574720.9827] NetworkManager (version 1.22.10) is starting... (for the first time)
Dec 21 19:18:40 srvhome NetworkManager[1071]: <info> [1608574720.9827] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 10-dns-resolved.conf, 10-globally-managed-devices.conf, no-mac-addr-change.conf) (run: netplan.conf) (etc: default-wifi-powersave-on.conf)
Dec 21 19:18:40 srvhome systemd[1]: Started Network Manager.
Dec 21 19:18:40 srvhome NetworkManager[1071]: <info> [1608574720.9890] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Dec 21 19:18:40 srvhome systemd[1]: Reached target Network.
Dec 21 19:18:40 srvhome snapd[1072]: AppArmor status: apparmor is enabled and all features are available
Dec 21 19:18:40 srvhome systemd[1]: Reached target Network is Online.
Dec 21 19:18:40 srvhome systemd[1]: Started Glances.
Dec 21 19:18:40 srvhome systemd[1]: Starting Samba NMB Daemon...
Dec 21 19:18:41 srvhome systemd[1]: Condition check resulted in Login to default iSCSI targets being skipped.
Dec 21 19:18:41 srvhome systemd[1]: Reached target Remote File Systems (Pre).
Dec 21 19:18:41 srvhome systemd[1]: Reached target Remote File Systems.
Dec 21 19:18:41 srvhome systemd[1]: Starting The Apache HTTP Server...
Dec 21 19:18:41 srvhome systemd[1]: Starting LSB: automatic crash report generation...
Dec 21 19:18:41 srvhome systemd[1]: Starting Deferred execution scheduler...
Dec 21 19:18:41 srvhome systemd[1]: Starting Availability of block devices...
Dec 21 19:18:41 srvhome NetworkManager[1071]: <info> [1608574721.0240] manager[0x563dbe74b040]: monitoring kernel firmware directory '/lib/firmware'.
Dec 21 19:18:41 srvhome NetworkManager[1071]: <info> [1608574721.0241] monitoring ifupdown state file '/run/network/ifstate'.
Dec 21 19:18:41 srvhome systemd[1]: Started Regular background program processing daemon.
Dec 21 19:18:41 srvhome systemd[1]: Starting LSB: disk temperature monitoring daemon...
Dec 21 19:18:41 srvhome systemd[1]: Starting The PHP 7.4 FastCGI Process Manager...
Dec 21 19:18:41 srvhome dbus-daemon[888]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.3' (uid=0 pid=1071 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined")
Dec 21 19:18:41 srvhome systemd[1]: Starting Plex Media Server...
Dec 21 19:18:41 srvhome systemd[1]: Condition check resulted in Pollinate to seed the pseudo random number generator being skipped.
Dec 21 19:18:41 srvhome cron[1136]: (CRON) INFO (pidfile fd = 3)
Dec 21 19:18:41 srvhome systemd[1]: Starting PostgreSQL Cluster 12-main...
Dec 21 19:18:41 srvhome systemd[1]: Starting Advanced key-value store...
Dec 21 19:18:41 srvhome systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
Dec 21 19:18:41 srvhome systemd[1]: Starting Service for snap application lxd.activate...
Dec 21 19:18:41 srvhome systemd[1]: Starting OpenBSD Secure Shell server...
Dec 21 19:18:41 srvhome systemd[1]: Starting Permit User Sessions...
Dec 21 19:18:41 srvhome systemd[1]: Started Unattended Upgrades Shutdown.
Dec 21 19:18:41 srvhome systemd[1]: Starting xrdp session manager...
Dec 21 19:18:41 srvhome systemd[1]: Started Deferred execution scheduler.
Dec 21 19:18:41 srvhome systemd[1]: Finished Availability of block devices.
Dec 21 19:18:41 srvhome systemd[1]: Finished Permit User Sessions.
Dec 21 19:18:41 srvhome apport[1131]: * Starting automatic crash report generation: apport
Dec 21 19:18:41 srvhome systemd[1]: Starting GNOME Display Manager...
Dec 21 19:18:41 srvhome systemd[1]: Starting Hold until boot process finishes up...
Dec 21 19:18:41 srvhome systemd[1]: Starting Hostname Service...
Dec 21 19:18:41 srvhome apport[1131]: ...done.
Dec 21 19:18:41 srvhome systemd[1]: Started LSB: disk temperature monitoring daemon.
Dec 21 19:18:41 srvhome systemd[1]: Started LSB: automatic crash report generation.
Dec 21 19:18:41 srvhome systemd[1]: plymouth-quit-wait.service: Succeeded.
Dec 21 19:18:41 srvhome systemd[1]: Finished Hold until boot process finishes up.
Dec 21 19:18:41 srvhome cron[1136]: (CRON) INFO (Running
@Reboot jobs)
Dec 21 19:18:41 srvhome systemd[1]: Starting Set console scheme...
Dec 21 19:18:41 srvhome systemd[1]: Started Plex Media Server.
Dec 21 19:18:41 srvhome systemd[1]: Finished Set console scheme.
Dec 21 19:18:41 srvhome systemd[1]: Created slice system-getty.slice.
Dec 21 19:18:41 srvhome xrdp-sesman[1169]: (1169)(140347816441408)[DEBUG] libscp initialized
Dec 21 19:18:41 srvhome dbus-daemon[888]: [system] Successfully activated service 'org.freedesktop.hostname1'
Dec 21 19:18:41 srvhome systemd[1]: Started Hostname Service.
Dec 21 19:18:41 srvhome NetworkManager[1071]: <info> [1608574721.2263] hostname: hostname: using hostnamed
Dec 21 19:18:41 srvhome NetworkManager[1071]: <info> [1608574721.2264] hostname: hostname changed from (none) to "srvhome"
Dec 21 19:18:41 srvhome NetworkManager[1071]: <info> [1608574721.2267] dns-mgr[0x563dbe732290]: init: dns=systemd-resolved rc-manager=symlink, plugin=systemd-resolved
Dec 21 19:18:41 srvhome NetworkManager[1071]: <info> [1608574721.2270] manager[0x563dbe74b040]: rfkill: Wi-Fi hardware radio set enabled
Dec 21 19:18:41 srvhome NetworkManager[1071]: <info> [1608574721.2271] manager[0x563dbe74b040]: rfkill: WWAN hardware radio set enabled
Dec 21 19:18:48 srvhome xrdp-sesman[1169]: (1169)(140347816441408)[DEBUG] Testing if xrdp-sesman can listen on 192.168.1.107 port 3350.
Dec 21 19:18:51 srvhome systemd[1]: Started OpenBSD Secure Shell server.
Dec 21 19:19:06 srvhome NetworkManager[1071]: <info> [1608574746.3468] Loaded device plugin: NMAtmManager (/usr/lib/x86_64-linux-gnu/NetworkManager/1.22.10/libnm-device-plugin-adsl.so)
Dec 21 19:19:06 srvhome xrdp-sesman[1169]: (1169)(140347816441408)[DEBUG] Closed socket 5 (AF_INET6 ::ffff:192.168.1.107 port 3350)
Dec 21 19:19:11 srvhome systemd[1]: systemd-hostnamed.service: Succeeded.
Dec 21 19:19:22 srvhome systemd[1]: snapd.service: start operation timed out. Terminating.
Dec 21 19:19:28 srvhome systemd[1]: snapd.service: Failed with result 'timeout'.
Dec 21 19:19:28 srvhome snapd[1245]: AppArmor status: apparmor is enabled and all features are available
Dec 21 19:19:28 srvhome systemd[1]: Failed to start Snap Daemon.
Dec 21 19:19:28 srvhome systemd[1]: snapd.service: Scheduled restart job, restart counter is at 2.
Dec 21 19:19:28 srvhome systemd[1]: Stopped Snap Daemon.
Dec 21 19:19:28 srvhome systemd[1]: Starting Snap Daemon...
Dec 21 19:19:31 srvhome systemd[1]: Started GNOME Display Manager.
Dec 21 19:19:31 srvhome dbus-daemon[888]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service' requested by ':1.5' (uid=0 pid=1197 comm="/usr/sbin/gdm3 " label="unconfined")
Dec 21 19:19:31 srvhome systemd[1]: Starting Accounts Service...
Dec 21 19:19:33 srvhome NetworkManager[1071]: <info> [1608574773.9977] Loaded device plugin: NMTeamFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/1.22.10/libnm-device-plugin-team.so)
Dec 21 19:19:36 srvhome systemd[1]: redis-server.service: Can't open PID file /run/redis/redis-server.pid (yet?) after start: Operation not permitted
Dec 21 19:19:41 srvhome xrdp-sesman[1282]: (1282)(140347816441408)[INFO ] starting xrdp-sesman with pid 1282
Dec 21 19:19:49 srvhome systemd[1]: Started xrdp session manager.
Dec 21 19:19:49 srvhome systemd[1]: Starting xrdp daemon...
Dec 21 19:19:56 srvhome gdm3: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Failed to activate service 'org.freedesktop.Accounts': timed out (service_start_timeout=25000ms)
Dec 21 19:19:56 srvhome systemd[1]: gdm.service: Main process exited, code=exited, status=1/FAILURE
Dec 21 19:19:56 srvhome systemd[1]: gdm.service: Failed with result 'exit-code'.
Dec 21 19:19:56 srvhome systemd[1]: Started Advanced key-value store.
Dec 21 19:19:57 srvhome systemd[1]: gdm.service: Scheduled restart job, restart counter is at 1.
Dec 21 19:19:57 srvhome systemd[1]: Stopped GNOME Display Manager.
Dec 21 19:19:57 srvhome systemd[1]: Starting Detect the available GPUs and deal with any system changes...
Dec 21 19:20:01 srvhome systemd[1]: gpu-manager.service: Succeeded.
Dec 21 19:20:01 srvhome systemd[1]: Finished Detect the available GPUs and deal with any system changes.
Dec 21 19:20:01 srvhome systemd[1]: Starting GNOME Display Manager...
Dec 21 19:20:02 srvhome systemd[1]: Started GNOME Display Manager.
Dec 21 19:20:02 srvhome dbus-daemon[888]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service' requested by ':1.7' (uid=0 pid=1358 comm="/usr/sbin/gdm3 " label="unconfined")
Dec 21 19:20:06 srvhome xrdp-sesman[1282]: (1282)(140347816441408)[INFO ] listening to port 3350 on 192.168.1.107
Dec 21 19:20:09 srvhome NetworkManager[1071]: <info> [1608574806.8656] Loaded device plugin: NMWwanFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/1.22.10/libnm-device-plugin-wwan.so)
Dec 21 19:20:11 srvhome systemd[1]: nmbd.service: start operation timed out. Terminating.
Dec 21 19:20:11 srvhome systemd[1]: nmbd.service: Failed with result 'timeout'.
Dec 21 19:20:11 srvhome systemd[1]: Failed to start Samba NMB Daemon.
Dec 21 19:20:11 srvhome systemd[1]: apache2.service: start operation timed out. Terminating.
Dec 21 19:20:11 srvhome systemd[1]: Starting Samba SMB Daemon...
Dec 21 19:20:11 srvhome systemd[1]: php7.4-fpm.service: start operation timed out. Terminating.
Dec 21 19:20:11 srvhome systemd[1]: apache2.service: Failed with result 'timeout'.
Dec 21 19:20:11 srvhome systemd[1]: Failed to start The Apache HTTP Server.
Dec 21 19:20:19 srvhome xrdp[1312]: (1312)(139799814739776)[INFO ] address [0.0.0.0] port [3389] mode 1
Dec 21 19:20:19 srvhome NetworkManager[1071]: <info> [1608574819.5302] Loaded device plugin: NMWifiFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/1.22.10/libnm-device-plugin-wifi.so)
Dec 21 19:20:27 srvhome gdm3: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Failed to activate service 'org.freedesktop.Accounts': timed out (service_start_timeout=25000ms)
Dec 21 19:20:27 srvhome systemd[1]: gdm.service: Main process exited, code=exited, status=1/FAILURE
Dec 21 19:20:27 srvhome systemd[1]: gdm.service: Failed with result 'exit-code'.
Dec 21 19:20:32 srvhome systemd[1]: gdm.service: Scheduled restart job, restart counter is at 2.
Dec 21 19:20:32 srvhome dbus-daemon[888]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.6' (uid=0 pid=1261 comm="/usr/lib/accountsservice/accounts-daemon " label="unconfined")
Dec 21 19:20:32 srvhome systemd[1]: Stopped GNOME Display Manager.
Dec 21 19:20:32 srvhome systemd[1]: Starting Detect the available GPUs and deal with any system changes...
Dec 21 19:20:32 srvhome systemd[1]: Starting Authorization Manager...
Dec 21 19:20:32 srvhome systemd[1]: php7.4-fpm.service: Failed with result 'timeout'.
Dec 21 19:20:32 srvhome systemd[1]: Failed to start The PHP 7.4 FastCGI Process Manager.
Dec 21 19:20:34 srvhome systemd[1]: gpu-manager.service: Succeeded.
Dec 21 19:20:34 srvhome systemd[1]: Finished Detect the available GPUs and deal with any system changes.
Dec 21 19:20:34 srvhome systemd[1]: Starting GNOME Display Manager...
Dec 21 19:20:34 srvhome systemd[1]: Started GNOME Display Manager.
Dec 21 19:20:34 srvhome dbus-daemon[888]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service' requested by ':1.9' (uid=0 pid=1430 comm="/usr/sbin/gdm3 " label="unconfined")
Dec 21 19:20:47 srvhome xrdp[1312]: (1312)(139799814739776)[INFO ] listening to port 3389 on 0.0.0.0
Dec 21 19:20:54 srvhome NetworkManager[1071]: <info> [1608574847.3456] Loaded device plugin: NMBluezManager (/usr/lib/x86_64-linux-gnu/NetworkManager/1.22.10/libnm-device-plugin-bluetooth.so)
Dec 21 19:20:54 srvhome dbus-daemon[888]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=1071 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined")
Dec 21 19:20:54 srvhome lxd.activate[1381]: sanity timeout expired: Interrupted system call
Dec 21 19:20:54 srvhome NetworkManager[1071]: <info> [1608574847.3460] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Dec 21 19:20:54 srvhome polkitd[1403]: started daemon version 0.105 using authority implementation `local' version `0.105'
Dec 21 19:20:54 srvhome NetworkManager[1071]: <info> [1608574847.3461] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Dec 21 19:20:54 srvhome dbus-daemon[888]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Dec 21 19:20:54 srvhome NetworkManager[1071]: <info> [1608574847.3461] manager: Networking is enabled by state file
Dec 21 19:20:54 srvhome accounts-daemon[1261]: started daemon version 0.6.55
Dec 21 19:20:54 srvhome NetworkManager[1071]: <info> [1608574847.3463] dhcp-init: Using DHCP client 'internal'
Dec 21 19:20:54 srvhome dbus-daemon[888]: [system] Successfully activated service 'org.freedesktop.Accounts'
Dec 21 19:20:54 srvhome systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 21 19:20:54 srvhome systemd[1]: Started Authorization Manager.
Dec 21 19:20:54 srvhome systemd[1]: Started Accounts Service.
Dec 21 19:20:54 srvhome NetworkManager[1071]: <info> [1608574854.8811] settings: Loaded settings plugin: ifupdown ("/usr/lib/x86_64-linux-gnu/NetworkManager/1.22.10/libnm-settings-plugin-ifupdown.so")
Dec 21 19:20:54 srvhome NetworkManager[1071]: <info> [1608574854.8812] settings: Loaded settings plugin: keyfile (internal)
Dec 21 19:20:54 srvhome NetworkManager[1071]: <info> [1608574854.8813] ifupdown: management mode: unmanaged
Dec 21 19:20:57 srvhome systemd[1]: snapd.service: start operation timed out. Terminating.
Dec 21 19:20:59 srvhome NetworkManager[1071]: <info> [1608574859.9070] ifupdown: interface-parser: parsing file /etc/network/interfaces
Dec 21 19:20:59 srvhome NetworkManager[1071]: <info> [1608574859.9071] ifupdown: interface-parser: finished parsing file /etc/network/interfaces
Dec 21 19:20:59 srvhome systemd[1]: snapd.service: Failed with result 'timeout'.
Dec 21 19:20:59 srvhome systemd[1]: Failed to start Snap Daemon.
Dec 21 19:21:02 srvhome systemd[1]: snapd.service: Scheduled restart job, restart counter is at 3.
Dec 21 19:21:02 srvhome systemd[1]: Stopped Snap Daemon.
Dec 21 19:21:02 srvhome snapd[1469]: AppArmor status: apparmor is enabled and all features are available
Dec 21 19:21:02 srvhome systemd[1]: Starting Snap Daemon...
Dec 21 19:21:02 srvhome NetworkManager[1071]: <info> [1608574862.4461] device (lo): carrier: link connected
Dec 21 19:21:02 srvhome NetworkManager[1071]: <info> [1608574862.4470] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Dec 21 19:21:02 srvhome NetworkManager[1071]: <info> [1608574862.4489] device (eno1): carrier: link connected
Dec 21 19:21:02 srvhome NetworkManager[1071]: <info> [1608574862.4497] manager: (eno1): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Dec 21 19:21:07 srvhome NetworkManager[1071]: <warn> [1608574867.4815] Error: failed to open /run/network/ifstate
Dec 21 19:21:07 srvhome xrdp[1312]: (1312)(139799814739776)[INFO ] xrdp_listen_pp done
Dec 21 19:21:10 srvhome dbus-daemon[888]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Dec 21 19:21:10 srvhome systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 21 19:21:10 srvhome NetworkManager[1071]: <info> [1608574870.0247] manager: startup complete
Dec 21 19:21:10 srvhome systemd[1]: tmp-snap.rootfs_0cpxqi.mount: Succeeded.
Dec 21 19:21:12 srvhome xrdp[1312]: (1312)(139799814739776)[DEBUG] Closed socket 7 (AF_INET6 :: port 3389)
Dec 21 19:21:21 srvhome systemd[1]: xrdp.service: start operation timed out. Terminating.
Dec 21 19:21:30 srvhome CRON[1509]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 19:21:33 srvhome systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Dec 21 19:21:37 srvhome systemd[1]: xrdp.service: Failed with result 'timeout'.
Dec 21 19:21:37 srvhome systemd[1]: Stopped xrdp daemon.
Dec 21 19:21:37 srvhome xrdp-sesman[1282]: (1282)(140347816441408)[INFO ] shutting down sesman 1
Dec 21 19:21:37 srvhome systemd[1]: Stopping xrdp session manager...
Dec 21 19:21:37 srvhome systemd[1]: xrdp-sesman.service: Control process exited, code=exited, status=1/FAILURE
Dec 21 19:21:41 srvhome systemd[1]: smbd.service: start-pre operation timed out. Terminating.
Dec 21 19:21:41 srvhome systemd[1]: smbd.service: Control process exited, code=killed, status=15/TERM
Dec 21 19:21:41 srvhome systemd[1]: smbd.service: Failed with result 'timeout'.
Dec 21 19:21:41 srvhome systemd[1]: Failed to start Samba SMB Daemon.
Dec 21 19:22:03 srvhome xrdp-sesman[1282]: (1282)(140347816441408)[DEBUG] Closed socket 7 (AF_INET6 ::ffff:192.168.1.107 port 3350)
Dec 21 19:24:52 srvhome lxd.activate[1152]: cannot send command 1 to helper process: Broken pipe
Dec 21 19:24:52 srvhome snap[1048]: error: cannot communicate with server: timeout exceeded while waiting for response
Dec 21 19:24:52 srvhome postgresql@12-main[1148]: Removed stale pid file.
Dec 21 19:24:52 srvhome postgresql@12-main[1148]: Error: /usr/lib/postgresql/12/bin/pg_ctl /usr/lib/postgresql/12/bin/pg_ctl start -D /var/lib/postgresql/12/main -l /var/log/postgresql/postgresql-12-main.log -s -o -c config_file="/etc/postgresql/12/main/postgresql.conf" exited with status 1:
Dec 21 19:24:52 srvhome postgresql@12-main[1148]: pg_ctl: server did not start in time
Dec 21 19:24:52 srvhome systemd[1]: xrdp-sesman.service: Failed with result 'exit-code'.
Dec 21 19:24:52 srvhome snapd[1570]: AppArmor status: apparmor is enabled and all features are available
Dec 21 19:24:52 srvhome snapd[1570]: daemon.go:347: started snapd/2.48.1 (series 16; classic) ubuntu/20.04 (amd64) linux/5.4.0-56-generic.
Dec 21 19:24:52 srvhome snapd[1570]: daemon.go:440: adjusting startup timeout by 45s (pessimistic estimate of 30s plus 5s per snap)
Dec 21 19:24:52 srvhome systemd[1]: Stopped xrdp session manager.
Dec 21 19:24:52 srvhome systemd[1]: snapd.service: start operation timed out. Terminating.
Dec 21 19:24:52 srvhome cloud-init[1616]: Cloud-init v. 20.3-2-g371b392c-0ubuntu1~20.04.1 running 'modules:config' at Mon, 21 Dec 2020 18:22:48 +0000. Up 852.29 seconds.
Dec 21 19:24:52 srvhome systemd[1]: snapd.service: Failed with result 'timeout'.
Dec 21 19:24:52 srvhome systemd[1]: Failed to start Snap Daemon.
Dec 21 19:24:52 srvhome systemd[1]: snapd.service: Scheduled restart job, restart counter is at 4.
Dec 21 19:24:52 srvhome systemd[1]: Stopped Snap Daemon.
Dec 21 19:24:52 srvhome systemd[1]: Starting Snap Daemon...
Dec 21 19:24:52 srvhome systemd[1]: snapd.seeded.service: Main process exited, code=exited, status=1/FAILURE
Dec 21 19:24:52 srvhome systemd[1]: snapd.seeded.service: Failed with result 'exit-code'.
Dec 21 19:24:52 srvhome systemd[1]: Failed to start Wait until snapd is fully seeded.
Dec 21 19:24:52 srvhome systemd[1]: Starting Apply the settings specified in cloud-config...
Dec 21 19:24:52 srvhome systemd[1]: snap.lxd.activate.service: Main process exited, code=exited, status=1/FAILURE
Dec 21 19:24:52 srvhome systemd[1]: snap.lxd.activate.service: Failed with result 'exit-code'.
Dec 21 19:24:52 srvhome systemd[1]: Failed to start Service for snap application lxd.activate.
Dec 21 19:24:52 srvhome systemd[1]: dmesg.service: Succeeded.
Dec 21 19:24:52 srvhome systemd[1]: Finished Apply the settings specified in cloud-config.
Dec 21 19:24:52 srvhome systemd[1]: Starting Cleanup of Temporary Directories...
postgresql@12-main.service: Can't open PID file /run/postgresql/12-main.pid (yet?) after start: Operation not permitted
Dec 21 19:24:52 srvhome systemd[1]: Created slice User Slice of UID 124.
Dec 21 19:24:52 srvhome systemd[1]: Starting User Runtime Directory /run/user/124...
Dec 21 19:24:52 srvhome systemd[1]: Finished User Runtime Directory /run/user/124.
Dec 21 19:24:52 srvhome systemd[1]: Starting User Manager for UID 124...
Dec 21 19:24:52 srvhome systemd[1]: tmp-sanity\x2dmountpoint\x2d615923337.mount: Succeeded.
Dec 21 19:25:01 srvhome CRON[1715]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec 21 19:25:01 srvhome CRON[1716]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 19:25:27 srvhome snapd[1570]: main.go:155: Exiting on terminated signal.
Dec 21 19:25:54 srvhome systemd[1]: snapd.service: State 'stop-sigterm' timed out. Killing.
Dec 21 19:25:54 srvhome systemd[1]: snapd.service: Killing process 1570 (snapd) with signal SIGKILL.
Dec 21 19:25:55 srvhome systemd[1]: snapd.service: Main process exited, code=killed, status=9/KILL
Dec 21 19:25:55 srvhome systemd[1]: snapd.service: Failed with result 'timeout'.
Dec 21 19:25:55 srvhome systemd[1]: Failed to start Snap Daemon.
Dec 21 19:25:55 srvhome systemd[1]: Condition check resulted in Auto import assertions from block devices being skipped.
Dec 21 19:25:55 srvhome systemd[1]: snapd.service: Scheduled restart job, restart counter is at 5.
Dec 21 19:25:55 srvhome systemd[1]: Stopped Snap Daemon.
Dec 21 19:25:55 srvhome systemd[1]: Starting Snap Daemon...
Dec 21 19:25:55 srvhome snapd[1749]: AppArmor status: apparmor is enabled and all features are available
Dec 21 19:25:57 srvhome systemd[1]:
user@124.service: start operation timed out. Terminating.
Dec 21 19:26:02 srvhome systemd[1]:
user@124.service: State 'stop-sigterm' timed out. Killing.
user@124.service: Killing process 1685 (systemd) with signal SIGKILL.
user@124.service: Main process exited, code=killed, status=9/KILL
user@124.service: Failed with result 'timeout'.
Dec 21 19:26:02 srvhome systemd[1]: Failed to start User Manager for UID 124.
Dec 21 19:26:02 srvhome systemd[1]: Started Session c1 of user gdm.
Dec 21 19:26:30 srvhome systemd[1]: Started PostgreSQL Cluster 12-main.
Dec 21 19:26:30 srvhome systemd[1]: Starting PostgreSQL RDBMS...
Dec 21 19:26:30 srvhome systemd[1]: Finished PostgreSQL RDBMS.
Dec 21 19:26:52 srvhome snapd[1749]: daemon.go:347: started snapd/2.48.1 (series 16; classic) ubuntu/20.04 (amd64) linux/5.4.0-56-generic.
Dec 21 19:26:52 srvhome snapd[1749]: daemon.go:440: adjusting startup timeout by 45s (pessimistic estimate of 30s plus 5s per snap)
Dec 21 19:26:52 srvhome systemd[1]: tmp-sanity\x2dmountpoint\x2d534256514.mount: Succeeded.
Dec 21 19:26:52 srvhome systemd[1]: Started Snap Daemon.
Dec 21 19:26:52 srvhome systemd[1]: Reached target Multi-User System.
Dec 21 19:26:52 srvhome systemd[1]: Reached target Graphical Interface.
Dec 21 19:26:52 srvhome systemd[1]: Starting Execute cloud user/final scripts...
Dec 21 19:26:52 srvhome systemd[1]: Starting Update UTMP about System Runlevel Changes...
Dec 21 19:26:52 srvhome systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
Dec 21 19:26:52 srvhome systemd[1]: Finished Update UTMP about System Runlevel Changes.
Dec 21 19:26:56 srvhome systemd[1]: Started Getty on tty2.
Dec 21 19:26:57 srvhome systemd[1]: Started Getty on tty3.
Dec 21 19:26:58 srvhome systemd[1]: Started Getty on tty4.
Dec 21 19:27:05 srvhome systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
Dec 21 19:28:40 srvhome cloud-init[1912]: Cloud-init v. 20.3-2-g371b392c-0ubuntu1~20.04.1 running 'modules:final' at Mon, 21 Dec 2020 18:26:55 +0000. Up 1099.14 seconds.
Dec 21 19:28:40 srvhome cloud-init[1912]: Cloud-init v. 20.3-2-g371b392c-0ubuntu1~20.04.1 finished at Mon, 21 Dec 2020 18:27:55 +0000. Datasource DataSourceNoCloud [seed=/var/lib/cloud/seed/nocloud-net][dsmode=net]. Up 1159.69 seconds
Dec 21 19:28:40 srvhome snapd[1749]: autorefresh.go:472: Cannot prepare auto-refresh change: Post
https://api.snapcraft.io/v2/snaps/refresh: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
Dec 21 19:28:40 srvhome systemd[1]: Finished Cleanup of Temporary Directories.
Dec 21 19:28:40 srvhome systemd[1]: Created slice User Slice of UID 1000.
Dec 21 19:28:40 srvhome systemd[1]: Starting User Runtime Directory /run/user/1000...
Dec 21 19:28:40 srvhome systemd[1]: Finished User Runtime Directory /run/user/1000.
Dec 21 19:28:40 srvhome systemd[1]: Starting User Manager for UID 1000...
Dec 21 19:28:40 srvhome systemd[1]: Finished Execute cloud user/final scripts.
Dec 21 19:28:40 srvhome systemd[1]: Reached target Cloud-init target.
Dec 21 19:28:48 srvhome dbus-daemon[888]: [system] Connection has not authenticated soon enough, closing it (auth_timeout=30000ms, elapsed: 30020ms)
Dec 21 19:29:03 srvhome /usr/lib/gdm3/gdm-wayland-session[1809]: dbus-daemon[1809]: [session uid=124 pid=1809] Activating service name='org.freedesktop.systemd1' requested by ':1.0' (uid=124 pid=1785 comm="/usr/lib/gdm3/gdm-wayland-session dbus-run-session" label="unconfined")
Dec 21 19:29:05 srvhome /usr/lib/gdm3/gdm-wayland-session[1809]: dbus-daemon[1809]: [session uid=124 pid=1809] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Dec 21 19:29:08 srvhome /usr/lib/gdm3/gdm-wayland-session[1785]: Unable to register display with display manager
Dec 21 19:29:08 srvhome gdm3: Child process -1785 was already dead.
Dec 21 19:29:08 srvhome systemd[1]: session-c1.scope: Succeeded.
Dec 21 19:29:08 srvhome systemd[1]: Stopping User Runtime Directory /run/user/124...
Dec 21 19:29:08 srvhome systemd[1]: run-user-124.mount: Succeeded.
user-runtime-dir@124.service: Succeeded.
Dec 21 19:29:08 srvhome systemd[1]: Stopped User Runtime Directory /run/user/124.
Dec 21 19:29:08 srvhome systemd[1]: Removed slice User Slice of UID 124.
Dec 21 19:29:09 srvhome systemd[1]:
user@1000.service: start operation timed out. Terminating.
Dec 21 19:29:15 srvhome systemd[1]:
user@1000.service: State 'stop-sigterm' timed out. Killing.
user@1000.service: Killing process 1965 (systemd) with signal SIGKILL.
user@1000.service: Main process exited, code=killed, status=9/KILL
user@1000.service: Failed with result 'timeout'.
Dec 21 19:29:15 srvhome systemd[1]: Failed to start User Manager for UID 1000.
Dec 21 19:29:15 srvhome systemd[1]: Started Session 5 of user clisclis.
Dec 21 19:29:33 srvhome snapd[1749]: stateengine.go:150: state ensure error: Post
Dec 21 19:30:01 srvhome CRON[2110]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 19:31:39 srvhome systemd[1]: phpsessionclean.service: Succeeded.
Dec 21 19:31:39 srvhome systemd[1]: Finished Clean php session files.
Dec 21 19:31:39 srvhome systemd[1]: Startup finished in 6.479s (firmware) + 7.656s (loader) + 2min 51.086s (kernel) + 20min 12.020s (userspace) = 23min 17.242s.
Dec 21 19:33:24 srvhome systemd[1]: Starting User Manager for UID 1000...
Dec 21 19:33:24 srvhome systemd[2308]: Reached target Paths.
Dec 21 19:33:42 srvhome dbus-daemon[888]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.20' (uid=1000 pid=2331 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo" label="unconfined")
Dec 21 19:33:42 srvhome systemd[2308]: Reached target Timers.
Dec 21 19:33:42 srvhome systemd[2308]: Starting D-Bus User Message Bus Socket.
Dec 21 19:33:42 srvhome systemd[2308]: Listening on GnuPG network certificate management daemon.
Dec 21 19:33:42 srvhome systemd[2308]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Dec 21 19:33:42 srvhome systemd[2308]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Dec 21 19:33:42 srvhome systemd[2308]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Dec 21 19:33:42 srvhome systemd[2308]: Listening on GnuPG cryptographic agent and passphrase cache.
Dec 21 19:33:42 srvhome systemd[2308]: Listening on debconf communication socket.
Dec 21 19:33:42 srvhome systemd[2308]: Listening on Sound System.
Dec 21 19:33:42 srvhome systemd[2308]: Listening on REST API socket for snapd user session agent.
Dec 21 19:33:42 srvhome systemd[2308]: Listening on D-Bus User Message Bus Socket.
Dec 21 19:33:42 srvhome systemd[2308]: Reached target Sockets.
Dec 21 19:33:42 srvhome systemd[2308]: Reached target Basic System.
Dec 21 19:33:42 srvhome systemd[1]: Started User Manager for UID 1000.
Dec 21 19:33:42 srvhome systemd[1]: Started Session 7 of user clisclis.
Dec 21 19:33:42 srvhome systemd[2308]: Starting Sound Service...
Dec 21 19:33:42 srvhome systemd[2308]: Starting Tracker metadata extractor...
Dec 21 19:33:42 srvhome systemd[2308]: Starting Tracker file system data miner...
Dec 21 19:33:42 srvhome systemd[1]: Starting RealtimeKit Scheduling Policy Service...
Dec 21 19:33:42 srvhome dbus-daemon[888]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
Dec 21 19:33:42 srvhome systemd[1]: Started RealtimeKit Scheduling Policy Service.
Dec 21 19:33:42 srvhome rtkit-daemon[2359]: Successfully called chroot.
Dec 21 19:33:42 srvhome rtkit-daemon[2359]: Successfully dropped privileges.
Dec 21 19:33:42 srvhome rtkit-daemon[2359]: Successfully limited resources.
Dec 21 19:33:42 srvhome rtkit-daemon[2359]: Running.
Dec 21 19:33:42 srvhome rtkit-daemon[2359]: Watchdog thread running.
Dec 21 19:33:42 srvhome rtkit-daemon[2359]: Canary thread running.
Dec 21 19:33:42 srvhome tracker-miner-f[2333]: Set scheduler policy to SCHED_IDLE
Dec 21 19:33:42 srvhome tracker-miner-f[2333]: Setting priority nice level to 19
Dec 21 19:33:42 srvhome tracker-extract[2332]: Set scheduler policy to SCHED_IDLE
Dec 21 19:33:42 srvhome tracker-extract[2332]: Setting priority nice level to 19
Dec 21 19:33:42 srvhome systemd[2308]: Started D-Bus User Message Bus.
Dec 21 19:33:42 srvhome dbus-daemon[2383]: [session uid=1000 pid=2383] AppArmor D-Bus mediation is enabled
Dec 21 19:33:42 srvhome dbus-daemon[2383]: [session uid=1000 pid=2383] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.1' (uid=1000 pid=2333 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Dec 21 19:33:42 srvhome systemd[2308]: Starting Virtual filesystem service...
Dec 21 19:33:50 srvhome dbus-daemon[2383]: [session uid=1000 pid=2383] Successfully activated service 'org.gtk.vfs.Daemon'
Dec 21 19:33:50 srvhome systemd[2308]: Started Virtual filesystem service.
Dec 21 19:33:50 srvhome dbus-daemon[2383]: [session uid=1000 pid=2383] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service' requested by ':1.1' (uid=1000 pid=2333 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Dec 21 19:33:50 srvhome systemd[2308]: Starting Virtual filesystem service - disk device monitor...
Dec 21 19:33:50 srvhome dbus-daemon[888]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.32' (uid=1000 pid=2412 comm="/usr/libexec/gvfs-udisks2-volume-monitor " label="unconfined")
Dec 21 19:33:50 srvhome systemd[1]: Starting Disk Manager...
Dec 21 19:33:50 srvhome udisksd[2418]: udisks daemon version 2.8.4 starting
Dec 21 19:33:52 srvhome snapd[1749]: 2020/12/21 19:33:52 Unsolicited response received on idle HTTP channel starting with "HTTP/1.0 408 Request Time-out\r\nCache-Control: no-cache\r\nConnection: close\r\nContent-Type: text/html\r\n\r\n<html><body><h1>408 Request Time-out</h1>\nYour browser didn't send a complete request in time.\n</body></html>\n"; err=<nil>
Dec 21 19:33:55 srvhome udisksd[2418]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
Dec 21 19:34:10 srvhome dbus-daemon[888]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.34' (uid=1000 pid=2331 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo" label="unconfined")
Dec 21 19:34:13 srvhome systemd[1]: Condition check resulted in Bluetooth service being skipped.
Dec 21 19:34:15 srvhome gvfs-udisks2-vo[2412]: monitor says it's not supported
Dec 21 19:34:15 srvhome systemd[2308]: Started Virtual filesystem service - disk device monitor.
Dec 21 19:34:15 srvhome dbus-daemon[2383]: [session uid=1000 pid=2383] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Dec 21 19:34:15 srvhome dbus-daemon[2383]: [session uid=1000 pid=2383] Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service' requested by ':1.1' (uid=1000 pid=2333 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Dec 21 19:34:15 srvhome tracker-miner-f[2333]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:34:18 srvhome udisksd[2418]: Failed to load the 'mdraid' libblockdev plugin
Dec 21 19:34:18 srvhome systemd[2308]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
Dec 21 19:34:23 srvhome udisksd[2418]: Applying configuration from /etc/udisks2/WDC-WD20EFRX-68A-WD-WMC300543875.conf to /dev/sda
Dec 21 19:34:23 srvhome udisksd[2418]: Set standby timer to 300 seconds (value 60) on /dev/sda [WDC-WD20EFRX-68A-WD-WMC300543875]
Dec 21 19:34:28 srvhome rtkit-daemon[2359]: Supervising 0 threads of 0 processes of 0 users.
Dec 21 19:34:40 srvhome rtkit-daemon[2359]: Supervising 0 threads of 0 processes of 1 users.
Dec 21 19:34:45 srvhome tracker-miner-fs[2333]: Error creating proxy: Error calling StartServiceByName for org.gtk.vfs.GoaVolumeMonitor: Timeout was reached (g-io-error-quark, 24)
Dec 21 19:34:45 srvhome rtkit-daemon[2359]: Supervising 0 threads of 0 processes of 1 users.
Dec 21 19:34:45 srvhome rtkit-daemon[2359]: message repeated 2 times: [ Supervising 0 threads of 0 processes of 1 users.]
Dec 21 19:34:45 srvhome dbus-daemon[2383]: [session uid=1000 pid=2383] Activating service name='org.gnome.OnlineAccounts' requested by ':1.6' (uid=1000 pid=2461 comm="/usr/libexec/gvfs-goa-volume-monitor " label="unconfined")
Dec 21 19:34:45 srvhome dbus-daemon[2383]: [session uid=1000 pid=2383] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service' requested by ':1.1' (uid=1000 pid=2333 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Dec 21 19:34:48 srvhome systemd[2308]: Starting Virtual filesystem service - Apple File Conduit monitor...
Dec 21 19:34:55 srvhome systemd[2308]: pulseaudio.service: start operation timed out. Terminating.
Dec 21 19:34:55 srvhome systemd[2308]: tracker-extract.service: start operation timed out. Terminating.
Dec 21 19:34:55 srvhome systemd[2308]: tracker-miner-fs.service: start operation timed out. Terminating.
Dec 21 19:34:55 srvhome systemd[2308]: tracker-miner-fs.service: Failed with result 'timeout'.
Dec 21 19:34:55 srvhome systemd[2308]: Failed to start Tracker file system data miner.
Dec 21 19:34:55 srvhome systemd[2308]: tracker-extract.service: Failed with result 'timeout'.
Dec 21 19:34:55 srvhome systemd[2308]: Failed to start Tracker metadata extractor.
Dec 21 19:34:55 srvhome systemd[2308]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 1.
Dec 21 19:34:55 srvhome systemd[2308]: tracker-extract.service: Scheduled restart job, restart counter is at 1.
Dec 21 19:34:55 srvhome systemd[2308]: Stopped Tracker metadata extractor.
Dec 21 19:34:55 srvhome systemd[2308]: Starting Tracker metadata extractor...
Dec 21 19:34:55 srvhome systemd[2308]: Stopped Tracker file system data miner.
Dec 21 19:34:55 srvhome systemd[2308]: Starting Tracker file system data miner...
Dec 21 19:34:55 srvhome tracker-extract[2494]: Set scheduler policy to SCHED_IDLE
Dec 21 19:34:55 srvhome tracker-miner-f[2495]: Set scheduler policy to SCHED_IDLE
Dec 21 19:34:55 srvhome tracker-extract[2494]: Setting priority nice level to 19
Dec 21 19:34:55 srvhome tracker-miner-f[2495]: Setting priority nice level to 19
Dec 21 19:34:55 srvhome gvfs-udisks2-vo[2412]: monitor says it's not supported
Dec 21 19:34:55 srvhome tracker-miner-f[2495]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:34:55 srvhome gvfs-goa-volume[2461]: monitor says it's not supported
Dec 21 19:34:55 srvhome dbus-daemon[2383]: [session uid=1000 pid=2383] Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
Dec 21 19:34:55 srvhome systemd[2308]: Started Virtual filesystem service - GNOME Online Accounts monitor.
Dec 21 19:34:55 srvhome tracker-miner-f[2495]: remote volume monitor with dbus name org.gtk.vfs.GoaVolumeMonitor is not supported
Dec 21 19:35:01 srvhome dbus-daemon[2383]: [session uid=1000 pid=2383] Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Dec 21 19:35:01 srvhome systemd[2308]: Started Virtual filesystem service - Apple File Conduit monitor.
Dec 21 19:35:01 srvhome dbus-daemon[2383]: [session uid=1000 pid=2383] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service' requested by ':1.8' (uid=1000 pid=2495 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Dec 21 19:35:01 srvhome CRON[2523]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec 21 19:35:01 srvhome CRON[2524]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 19:35:03 srvhome systemd[2308]: Starting Virtual filesystem service - digital camera monitor...
Dec 21 19:35:11 srvhome systemd[2308]: pulseaudio.service: Failed with result 'timeout'.
Dec 21 19:35:11 srvhome systemd[2308]: Failed to start Sound Service.
Dec 21 19:35:11 srvhome systemd[2308]: pulseaudio.service: Scheduled restart job, restart counter is at 1.
Dec 21 19:35:11 srvhome systemd[2308]: Stopped Sound Service.
Dec 21 19:35:11 srvhome systemd[2308]: Starting Sound Service...
Dec 21 19:35:11 srvhome dbus-daemon[888]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.53' (uid=1000 pid=2532 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo" label="unconfined")
Dec 21 19:35:11 srvhome systemd[1]: Condition check resulted in Bluetooth service being skipped.
Dec 21 19:35:11 srvhome rtkit-daemon[2359]: Supervising 0 threads of 0 processes of 1 users.
Dec 21 19:35:11 srvhome rtkit-daemon[2359]: message repeated 4 times: [ Supervising 0 threads of 0 processes of 1 users.]
Dec 21 19:35:11 srvhome systemd[2308]: Started Sound Service.
Dec 21 19:35:20 srvhome systemd[1]: udisks2.service: start operation timed out. Terminating.
Dec 21 19:35:23 srvhome dbus-daemon[2383]: [session uid=1000 pid=2383] Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Dec 21 19:35:23 srvhome systemd[2308]: Started Virtual filesystem service - digital camera monitor.
Dec 21 19:35:23 srvhome dbus-daemon[2383]: [session uid=1000 pid=2383] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service' requested by ':1.8' (uid=1000 pid=2495 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Dec 21 19:35:28 srvhome systemd[2308]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Dec 21 19:35:28 srvhome dbus-daemon[2383]: [session uid=1000 pid=2383] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Dec 21 19:35:28 srvhome systemd[2308]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Dec 21 19:35:28 srvhome dbus-daemon[888]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service' requested by ':1.59' (uid=1000 pid=2495 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Dec 21 19:35:31 srvhome systemd[1]: Starting Daemon for power management...
Dec 21 19:35:41 srvhome pulseaudio[2532]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Dec 21 19:35:56 srvhome tracker-miner-f[2495]: Couldn't connect to proxy: Error calling StartServiceByName for org.freedesktop.UPower: Failed to activate service 'org.freedesktop.UPower': timed out (service_start_timeout=25000ms)
Dec 21 19:35:56 srvhome tracker-miner-f[2495]: Unable to connect to UPower
Dec 21 19:36:25 srvhome systemd[2308]: tracker-extract.service: start operation timed out. Terminating.
Dec 21 19:36:25 srvhome systemd[2308]: tracker-miner-fs.service: start operation timed out. Terminating.
Dec 21 19:36:25 srvhome systemd[2308]: tracker-miner-fs.service: Failed with result 'timeout'.
Dec 21 19:36:25 srvhome systemd[2308]: Failed to start Tracker file system data miner.
Dec 21 19:36:25 srvhome systemd[2308]: tracker-extract.service: Failed with result 'timeout'.
Dec 21 19:36:25 srvhome systemd[2308]: Failed to start Tracker metadata extractor.
Dec 21 19:36:25 srvhome systemd[2308]: Reached target Main User Target.
Dec 21 19:36:25 srvhome systemd[2308]: Startup finished in 3min 5.643s.
Dec 21 19:36:25 srvhome systemd[2308]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 2.
Dec 21 19:36:25 srvhome systemd[2308]: tracker-extract.service: Scheduled restart job, restart counter is at 2.
Dec 21 19:36:25 srvhome systemd[2308]: Stopped Tracker metadata extractor.
Dec 21 19:36:25 srvhome systemd[2308]: Starting Tracker metadata extractor...
Dec 21 19:36:25 srvhome systemd[2308]: Stopped Tracker file system data miner.
Dec 21 19:36:25 srvhome systemd[2308]: Starting Tracker file system data miner...
Dec 21 19:36:25 srvhome tracker-extract[2625]: Set scheduler policy to SCHED_IDLE
Dec 21 19:36:25 srvhome tracker-miner-f[2626]: Set scheduler policy to SCHED_IDLE
Dec 21 19:36:25 srvhome tracker-extract[2625]: Setting priority nice level to 19
Dec 21 19:36:25 srvhome tracker-miner-f[2626]: Setting priority nice level to 19
Dec 21 19:36:25 srvhome gvfs-udisks2-vo[2412]: monitor says it's not supported
Dec 21 19:36:25 srvhome tracker-miner-f[2626]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:36:25 srvhome gvfs-goa-volume[2461]: monitor says it's not supported
Dec 21 19:36:25 srvhome tracker-miner-f[2626]: remote volume monitor with dbus name org.gtk.vfs.GoaVolumeMonitor is not supported
Dec 21 19:36:25 srvhome dbus-daemon[888]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service' requested by ':1.60' (uid=1000 pid=2626 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Dec 21 19:36:50 srvhome systemd[1]: udisks2.service: State 'stop-sigterm' timed out. Killing.
Dec 21 19:36:50 srvhome systemd[1]: udisks2.service: Killing process 2418 (udisksd) with signal SIGKILL.
Dec 21 19:36:50 srvhome systemd[1]: udisks2.service: Killing process 2486 (dumpe2fs) with signal SIGKILL.
Dec 21 19:36:50 srvhome systemd[1]: udisks2.service: Killing process 2429 (gmain) with signal SIGKILL.
Dec 21 19:36:50 srvhome systemd[1]: udisks2.service: Main process exited, code=killed, status=9/KILL
Dec 21 19:36:50 srvhome tracker-miner-f[2626]: Couldn't connect to proxy: Error calling StartServiceByName for org.freedesktop.UPower: Failed to activate service 'org.freedesktop.UPower': timed out (service_start_timeout=25000ms)
Dec 21 19:36:50 srvhome tracker-miner-f[2626]: Unable to connect to UPower
Dec 21 19:37:01 srvhome systemd[1]: upower.service: start operation timed out. Terminating.
Dec 21 19:37:01 srvhome systemd[1]: upower.service: Failed with result 'timeout'.
Dec 21 19:37:01 srvhome systemd[1]: Failed to start Daemon for power management.
Dec 21 19:37:01 srvhome systemd[1]: upower.service: Scheduled restart job, restart counter is at 1.
Dec 21 19:37:01 srvhome systemd[1]: Stopped Daemon for power management.
Dec 21 19:37:01 srvhome systemd[1]: Starting Daemon for power management...
Dec 21 19:37:51 srvhome upowerd[2687]: Could not acquire inhibitor lock: Timeout was reached
Dec 21 19:37:51 srvhome systemd[1]: Started Daemon for power management.
Dec 21 19:37:56 srvhome systemd[2308]: tracker-extract.service: start operation timed out. Terminating.
Dec 21 19:37:56 srvhome systemd[2308]: tracker-miner-fs.service: start operation timed out. Terminating.
Dec 21 19:37:56 srvhome systemd[2308]: tracker-miner-fs.service: Failed with result 'timeout'.
Dec 21 19:37:56 srvhome systemd[2308]: Failed to start Tracker file system data miner.
Dec 21 19:37:56 srvhome systemd[2308]: tracker-extract.service: Failed with result 'timeout'.
Dec 21 19:37:56 srvhome systemd[2308]: Failed to start Tracker metadata extractor.
Dec 21 19:37:56 srvhome systemd[2308]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 3.
Dec 21 19:37:56 srvhome systemd[2308]: tracker-extract.service: Scheduled restart job, restart counter is at 3.
Dec 21 19:37:56 srvhome systemd[2308]: Stopped Tracker metadata extractor.
Dec 21 19:37:56 srvhome systemd[2308]: Starting Tracker metadata extractor...
Dec 21 19:37:56 srvhome systemd[2308]: Stopped Tracker file system data miner.
Dec 21 19:37:56 srvhome systemd[2308]: Starting Tracker file system data miner...
Dec 21 19:37:56 srvhome tracker-extract[2713]: Set scheduler policy to SCHED_IDLE
Dec 21 19:37:56 srvhome tracker-extract[2713]: Setting priority nice level to 19
Dec 21 19:37:56 srvhome tracker-miner-f[2714]: Set scheduler policy to SCHED_IDLE
Dec 21 19:37:56 srvhome tracker-miner-f[2714]: Setting priority nice level to 19
Dec 21 19:37:56 srvhome gvfs-udisks2-vo[2412]: monitor says it's not supported
Dec 21 19:37:56 srvhome tracker-miner-f[2714]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:37:56 srvhome gvfs-goa-volume[2461]: monitor says it's not supported
Dec 21 19:37:56 srvhome tracker-miner-f[2714]: remote volume monitor with dbus name org.gtk.vfs.GoaVolumeMonitor is not supported
Dec 21 19:38:21 srvhome systemd[1]: udisks2.service: State 'stop-final-sigterm' timed out. Killing.
Dec 21 19:45:37 srvhome systemd[1]: udisks2.service: Killing process 2486 (dumpe2fs) with signal SIGKILL.
Dec 21 19:47:32 srvhome systemd[1]: udisks2.service: Failed with result 'timeout'.
Dec 21 19:47:32 srvhome kernel: [ 2335.678602] sdd: sdd1
Dec 21 19:47:32 srvhome systemd[1]: Failed to start Disk Manager.
Dec 21 19:47:32 srvhome systemd[1]: Starting Clean php session files...
Dec 21 19:47:32 srvhome /usr/lib/gdm3/gdm-wayland-session[2751]: dbus-daemon[2751]: [session uid=124 pid=2751] Activating service name='org.freedesktop.systemd1' requested by ':1.0' (uid=124 pid=2749 comm="/usr/lib/gdm3/gdm-wayland-session dbus-run-session" label="unconfined")
Dec 21 19:47:32 srvhome /usr/lib/gdm3/gdm-wayland-session[2751]: dbus-daemon[2751]: [session uid=124 pid=2751] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Dec 21 19:47:32 srvhome systemd[1]: systemd-logind.service: Watchdog timeout (limit 3min)!
Dec 21 19:47:32 srvhome /usr/lib/gdm3/gdm-wayland-session[2749]: Unable to register display with display manager
Dec 21 19:47:32 srvhome systemd[1]: systemd-logind.service: Killing process 1089 (systemd-logind) with signal SIGABRT.
Dec 21 19:47:32 srvhome gdm3: Child process -2749 was already dead.
Dec 21 19:47:32 srvhome systemd[1]: phpsessionclean.service: Succeeded.
Dec 21 19:47:32 srvhome systemd[1]: Finished Clean php session files.
Dec 21 19:47:32 srvhome CRON[2762]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Dec 21 19:47:32 srvhome systemd[2308]: tracker-extract.service: start operation timed out. Terminating.
Dec 21 19:48:36 srvhome systemd[2308]: tracker-miner-fs.service: start operation timed out. Terminating.
Dec 21 19:48:36 srvhome systemd[2308]: tracker-miner-fs.service: Failed with result 'timeout'.
Dec 21 19:48:36 srvhome CRON[2867]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 19:48:36 srvhome systemd[2308]: Failed to start Tracker file system data miner.
Dec 21 19:48:36 srvhome systemd[2308]: tracker-extract.service: Failed with result 'timeout'.
Dec 21 19:48:36 srvhome systemd[2308]: Failed to start Tracker metadata extractor.
Dec 21 19:48:36 srvhome systemd[2308]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 4.
Dec 21 19:48:36 srvhome systemd[2308]: tracker-extract.service: Scheduled restart job, restart counter is at 4.
Dec 21 19:48:36 srvhome systemd[2308]: Stopped Tracker metadata extractor.
Dec 21 19:48:36 srvhome systemd[2308]: Starting Tracker metadata extractor...
Dec 21 19:48:36 srvhome systemd[2308]: Stopped Tracker file system data miner.
Dec 21 19:48:36 srvhome systemd[2308]: Starting Tracker file system data miner...
Dec 21 19:48:36 srvhome [2832]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:36 srvhome [2832]: Setting priority nice level to 19
Dec 21 19:48:36 srvhome tracker-miner-fs[3211]: Error creating proxy: Error calling StartServiceByName for org.gtk.vfs.GoaVolumeMonitor: Timeout was reached (g-io-error-quark, 24)
Dec 21 19:48:36 srvhome [2833]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:36 srvhome [2833]: Setting priority nice level to 19
Dec 21 19:48:36 srvhome gvfs-udisks2-vo[2412]: monitor says it's not supported
Dec 21 19:48:36 srvhome /usr/lib/gdm3/gdm-x-session[3250]: (--) Log file renamed from "/var/lib/gdm3/.local/share/xorg/Xorg.pid-3250.log" to "/var/lib/gdm3/.local/share/xorg/Xorg.0.log"
Dec 21 19:48:36 srvhome /usr/lib/gdm3/gdm-x-session[3250]: X.Org X Server 1.20.8
Dec 21 19:48:36 srvhome /usr/lib/gdm3/gdm-x-session[3250]: X Protocol Version 11, Revision 0
Dec 21 19:48:36 srvhome /usr/lib/gdm3/gdm-x-session[3250]: Build Operating System: Linux 4.15.0-124-generic x86_64 Ubuntu
Dec 21 19:48:36 srvhome /usr/lib/gdm3/gdm-x-session[3250]: Current Operating System: Linux srvhome 5.4.0-56-generic #62-Ubuntu SMP Mon Nov 23 19:20:19 UTC 2020 x86_64
Dec 21 19:48:36 srvhome /usr/lib/gdm3/gdm-x-session[3250]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4.0-56-generic root=UUID=ab6a586a-7b31-4719-aaab-88efa3a719f8 ro consoleblank=0
Dec 21 19:48:36 srvhome /usr/lib/gdm3/gdm-x-session[3250]: Build Date: 30 November 2020 05:56:33PM
Dec 21 19:48:36 srvhome /usr/lib/gdm3/gdm-x-session[3250]: xorg-server 2:1.20.8-2ubuntu2.6 (For technical support please see
http://www.ubuntu.com/support)
Dec 21 19:48:36 srvhome /usr/lib/gdm3/gdm-x-session[3250]: Current version of pixman: 0.38.4
Dec 21 19:48:36 srvhome /usr/lib/gdm3/gdm-x-session[3250]: #011Before reporting problems, check
http://wiki.x.org
Dec 21 19:48:36 srvhome /usr/lib/gdm3/gdm-x-session[3250]: #011to make sure that you have the latest version.
Dec 21 19:48:36 srvhome /usr/lib/gdm3/gdm-x-session[3250]: Markers: (--) probed, (**) from config file, (==) default setting,
Dec 21 19:48:36 srvhome /usr/lib/gdm3/gdm-x-session[3250]: #011(++) from command line, (!!) notice, (II) informational,
Dec 21 19:48:36 srvhome /usr/lib/gdm3/gdm-x-session[3250]: #011(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Dec 21 19:48:36 srvhome /usr/lib/gdm3/gdm-x-session[3250]: (==) Log file: "/var/lib/gdm3/.local/share/xorg/Xorg.0.log", Time: Mon Dec 21 19:48:36 2020
Dec 21 19:48:36 srvhome [2833]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:48:36 srvhome gvfs-goa-volume[2461]: monitor says it's not supported
Dec 21 19:48:36 srvhome [2833]: remote volume monitor with dbus name org.gtk.vfs.GoaVolumeMonitor is not supported
Dec 21 19:48:36 srvhome systemd[1]: systemd-logind.service: State 'stop-watchdog' timed out. Terminating.
Dec 21 19:48:36 srvhome systemd[2308]: tracker-extract.service: start operation timed out. Terminating.
Dec 21 19:48:36 srvhome systemd[2308]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 5.
Dec 21 19:48:36 srvhome systemd[2308]: tracker-extract.service: Scheduled restart job, restart counter is at 5.
Dec 21 19:48:36 srvhome dbus-daemon[3215]: [session uid=124 pid=3215] AppArmor D-Bus mediation is enabled
Dec 21 19:48:36 srvhome dbus-daemon[3215]: [session uid=124 pid=3215] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.2' (uid=124 pid=3211 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Dec 21 19:48:36 srvhome rtkit-daemon[2359]: Successfully made thread 3209 of process 3209 owned by '124' high priority at nice level -11.
Dec 21 19:48:36 srvhome rtkit-daemon[2359]: Supervising 1 threads of 1 processes of 1 users.
Dec 21 19:48:36 srvhome dbus-daemon[3215]: [session uid=124 pid=3215] Successfully activated service 'org.gtk.vfs.Daemon'
Dec 21 19:48:36 srvhome [2974]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:36 srvhome dbus-daemon[3215]: [session uid=124 pid=3215] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service' requested by ':1.2' (uid=124 pid=3211 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Dec 21 19:48:36 srvhome [2975]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:36 srvhome dbus-daemon[888]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.82' (uid=124 pid=3228 comm="/usr/libexec/gvfs-udisks2-volume-monitor " label="unconfined")
Dec 21 19:48:36 srvhome [2974]: Setting priority nice level to 19
Dec 21 19:48:36 srvhome [2975]: Setting priority nice level to 19
Dec 21 19:48:36 srvhome CRON[3270]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec 21 19:48:36 srvhome [2975]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:48:36 srvhome CRON[3271]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 19:48:36 srvhome [2975]: remote volume monitor with dbus name org.gtk.vfs.GoaVolumeMonitor is not supported
Dec 21 19:48:36 srvhome systemd[1]: systemd-logind.service: Main process exited, code=dumped, status=6/ABRT
Dec 21 19:48:36 srvhome systemd[1]: systemd-logind.service: Failed with result 'watchdog'.
Dec 21 19:48:36 srvhome dbus-daemon[3215]: [session uid=124 pid=3215] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Dec 21 19:48:36 srvhome systemd[1]: systemd-logind.service: Scheduled restart job, restart counter is at 2.
Dec 21 19:48:36 srvhome dbus-daemon[3215]: [session uid=124 pid=3215] Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service' requested by ':1.2' (uid=124 pid=3211 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Dec 21 19:48:36 srvhome systemd[1]: Stopped Login Service.
Dec 21 19:48:36 srvhome dbus-daemon[3215]: [session uid=124 pid=3215] Activating service name='org.gnome.OnlineAccounts' requested by ':1.5' (uid=124 pid=3279 comm="/usr/libexec/gvfs-goa-volume-monitor " label="unconfined")
Dec 21 19:48:36 srvhome systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
Dec 21 19:48:36 srvhome dbus-daemon[3215]: [session uid=124 pid=3215] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service' requested by ':1.2' (uid=124 pid=3211 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Dec 21 19:48:36 srvhome systemd[1]: Starting Login Service...
Dec 21 19:48:36 srvhome dbus-daemon[3215]: [session uid=124 pid=3215] Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Dec 21 19:48:36 srvhome dbus-daemon[3215]: [session uid=124 pid=3215] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service' requested by ':1.2' (uid=124 pid=3211 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Dec 21 19:48:36 srvhome dbus-daemon[3215]: [session uid=124 pid=3215] Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Dec 21 19:48:36 srvhome dbus-daemon[3215]: [session uid=124 pid=3215] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service' requested by ':1.2' (uid=124 pid=3211 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Dec 21 19:48:36 srvhome dbus-daemon[3215]: [session uid=124 pid=3215] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Dec 21 19:48:36 srvhome dbus-daemon[3215]: [session uid=124 pid=3215] Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
Dec 21 19:48:36 srvhome dbus-daemon[888]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.86' (uid=124 pid=3209 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo" label="unconfined")
Dec 21 19:48:36 srvhome systemd[2308]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 6.
Dec 21 19:48:36 srvhome systemd[2308]: tracker-extract.service: Scheduled restart job, restart counter is at 6.
Dec 21 19:48:36 srvhome rtkit-daemon[2359]: Successfully made thread 3344 of process 3209 owned by '124' RT at priority 5.
Dec 21 19:48:36 srvhome rtkit-daemon[2359]: Supervising 2 threads of 1 processes of 1 users.
Dec 21 19:48:36 srvhome rtkit-daemon[2359]: Successfully made thread 3346 of process 3346 owned by '124' high priority at nice level -11.
Dec 21 19:48:36 srvhome [3097]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:36 srvhome dbus-daemon[888]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.90' (uid=124 pid=3346 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo" label="unconfined")
Dec 21 19:48:36 srvhome [3096]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:36 srvhome [3097]: Setting priority nice level to 19
Dec 21 19:48:36 srvhome rtkit-daemon[2359]: Successfully made thread 3347 of process 3346 owned by '124' RT at priority 5.
Dec 21 19:48:36 srvhome [3096]: Setting priority nice level to 19
Dec 21 19:48:36 srvhome [3097]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:48:36 srvhome [3097]: remote volume monitor with dbus name org.gtk.vfs.GoaVolumeMonitor is not supported
Dec 21 19:48:36 srvhome systemd[1]: systemd-logind.service: start operation timed out. Terminating.
Dec 21 19:48:36 srvhome systemd[2308]: tracker-extract.service: Scheduled restart job, restart counter is at 7.
Dec 21 19:48:36 srvhome systemd[2308]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 7.
Dec 21 19:48:36 srvhome [3147]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:36 srvhome [3146]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:36 srvhome [3146]: Setting priority nice level to 19
Dec 21 19:48:36 srvhome [3147]: Setting priority nice level to 19
Dec 21 19:48:36 srvhome [3147]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:48:36 srvhome [3147]: remote volume monitor with dbus name org.gtk.vfs.GoaVolumeMonitor is not supported
Dec 21 19:48:36 srvhome systemd[1]: systemd-logind.service: Failed with result 'timeout'.
Dec 21 19:48:36 srvhome systemd[1]: Failed to start Login Service.
Dec 21 19:48:36 srvhome systemd[1]: systemd-logind.service: Scheduled restart job, restart counter is at 3.
Dec 21 19:48:36 srvhome systemd[1]: Started Login Service.
Dec 21 19:48:36 srvhome systemd[1]: Created slice User Slice of UID 124.
Dec 21 19:48:36 srvhome systemd[1]: Starting User Runtime Directory /run/user/124...
Dec 21 19:48:36 srvhome systemd[1]: Finished User Runtime Directory /run/user/124.
Dec 21 19:48:36 srvhome systemd[1]: Starting User Manager for UID 124...
Dec 21 19:48:36 srvhome systemd[3200]: Reached target Paths.
Dec 21 19:48:36 srvhome systemd[3200]: Reached target Timers.
Dec 21 19:48:36 srvhome systemd[3200]: Starting D-Bus User Message Bus Socket.
Dec 21 19:48:36 srvhome systemd[3200]: Listening on GnuPG network certificate management daemon.
Dec 21 19:48:36 srvhome systemd[3200]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Dec 21 19:48:36 srvhome systemd[3200]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Dec 21 19:48:36 srvhome systemd[3200]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Dec 21 19:48:36 srvhome systemd[3200]: Listening on GnuPG cryptographic agent and passphrase cache.
Dec 21 19:48:36 srvhome systemd[3200]: Listening on debconf communication socket.
Dec 21 19:48:36 srvhome systemd[3200]: Listening on Sound System.
Dec 21 19:48:36 srvhome systemd[3200]: Listening on REST API socket for snapd user session agent.
Dec 21 19:48:36 srvhome systemd[3200]: Listening on D-Bus User Message Bus Socket.
Dec 21 19:48:36 srvhome systemd[3200]: Reached target Sockets.
Dec 21 19:48:36 srvhome systemd[3200]: Reached target Basic System.
Dec 21 19:48:36 srvhome systemd[1]: Started User Manager for UID 124.
Dec 21 19:48:36 srvhome systemd[3200]: Starting Sound Service...
Dec 21 19:48:36 srvhome systemd[1]: Started Session c1 of user gdm.
Dec 21 19:48:36 srvhome systemd[3200]: Starting Tracker metadata extractor...
Dec 21 19:48:36 srvhome systemd[3200]: Starting Tracker file system data miner...
Dec 21 19:48:36 srvhome [3210]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:36 srvhome [3210]: Setting priority nice level to 19
Dec 21 19:48:36 srvhome [3211]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:36 srvhome [3211]: Setting priority nice level to 19
Dec 21 19:48:36 srvhome systemd[3200]: Started D-Bus User Message Bus.
Dec 21 19:48:36 srvhome systemd[3200]: Starting Virtual filesystem service...
Dec 21 19:48:36 srvhome systemd[3200]: Started Virtual filesystem service.
Dec 21 19:48:36 srvhome [3211]: Unable to get XDG user directory path for special directory &DOCUMENTS. Ignoring this location.
Dec 21 19:48:39 srvhome [3211]: Unable to get XDG user directory path for special directory &MUSIC. Ignoring this location.
Dec 21 19:48:39 srvhome [3211]: Unable to get XDG user directory path for special directory &PICTURES. Ignoring this location.
Dec 21 19:48:39 srvhome [3211]: Unable to get XDG user directory path for special directory &VIDEOS. Ignoring this location.
Dec 21 19:48:39 srvhome [3211]: Unable to get XDG user directory path for special directory &DOWNLOAD. Ignoring this location.
Dec 21 19:48:39 srvhome [3211]: Unable to get XDG user directory path for special directory &DOCUMENTS. Ignoring this location.
Dec 21 19:48:39 srvhome systemd[3200]: Starting Virtual filesystem service - disk device monitor...
Dec 21 19:48:39 srvhome systemd[1]: Starting Disk Manager...
Dec 21 19:48:39 srvhome [3231]: udisks daemon version 2.8.4 starting
Dec 21 19:48:39 srvhome [3231]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
Dec 21 19:48:39 srvhome [3231]: Failed to load the 'mdraid' libblockdev plugin
Dec 21 19:48:39 srvhome [3231]: Applying configuration from /etc/udisks2/WDC-WD20EFRX-68A-WD-WMC300543875.conf to /dev/sda
Dec 21 19:48:39 srvhome [3231]: Set standby timer to 300 seconds (value 60) on /dev/sda [WDC-WD20EFRX-68A-WD-WMC300543875]
Dec 21 19:48:39 srvhome gvfs-udisks2-vo[3228]: monitor says it's not supported
Dec 21 19:48:39 srvhome systemd[3200]: Started Virtual filesystem service - disk device monitor.
Dec 21 19:48:39 srvhome [3211]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:48:39 srvhome systemd[3200]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
Dec 21 19:48:39 srvhome systemd[2308]: tracker-extract.service: start operation timed out. Terminating.
Dec 21 19:48:39 srvhome systemd[2308]: tracker-miner-fs.service: start operation timed out. Terminating.
Dec 21 19:48:39 srvhome systemd[2308]: tracker-miner-fs.service: Failed with result 'timeout'.
Dec 21 19:48:39 srvhome systemd[2308]: Failed to start Tracker file system data miner.
Dec 21 19:48:39 srvhome systemd[2308]: tracker-extract.service: Failed with result 'timeout'.
Dec 21 19:48:39 srvhome systemd[2308]: Failed to start Tracker metadata extractor.
Dec 21 19:48:39 srvhome systemd[2308]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 8.
Dec 21 19:48:39 srvhome systemd[2308]: tracker-extract.service: Scheduled restart job, restart counter is at 8.
Dec 21 19:48:39 srvhome systemd[2308]: Stopped Tracker metadata extractor.
Dec 21 19:48:39 srvhome systemd[2308]: Starting Tracker metadata extractor...
Dec 21 19:48:39 srvhome systemd[2308]: Stopped Tracker file system data miner.
Dec 21 19:48:39 srvhome systemd[2308]: Starting Tracker file system data miner...
Dec 21 19:48:39 srvhome [3287]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:39 srvhome [3288]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:39 srvhome [3287]: Setting priority nice level to 19
Dec 21 19:48:39 srvhome [3288]: Setting priority nice level to 19
Dec 21 19:48:39 srvhome gvfs-udisks2-vo[2412]: monitor says it's not supported
Dec 21 19:48:39 srvhome [3288]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:48:39 srvhome gvfs-goa-volume[2461]: monitor says it's not supported
Dec 21 19:48:39 srvhome [3288]: remote volume monitor with dbus name org.gtk.vfs.GoaVolumeMonitor is not supported
Dec 21 19:48:39 srvhome systemd[3200]: Starting Virtual filesystem service - Apple File Conduit monitor...
Dec 21 19:48:39 srvhome systemd[3200]: Started Virtual filesystem service - Apple File Conduit monitor.
Dec 21 19:48:39 srvhome systemd[3200]: Starting Virtual filesystem service - digital camera monitor...
Dec 21 19:48:39 srvhome systemd[3200]: Started Virtual filesystem service - digital camera monitor.
Dec 21 19:48:39 srvhome systemd[3200]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Dec 21 19:48:39 srvhome systemd[3200]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Dec 21 19:48:39 srvhome gvfs-goa-volume[3279]: monitor says it's not supported
Dec 21 19:48:39 srvhome systemd[3200]: Started Virtual filesystem service - GNOME Online Accounts monitor.
Dec 21 19:48:39 srvhome systemd[1]: Condition check resulted in Bluetooth service being skipped.
Dec 21 19:48:39 srvhome systemd[3200]: pulseaudio.service: start operation timed out. Terminating.
Dec 21 19:48:39 srvhome systemd[3200]: tracker-extract.service: start operation timed out. Terminating.
Dec 21 19:48:39 srvhome systemd[3200]: tracker-miner-fs.service: start operation timed out. Terminating.
Dec 21 19:48:39 srvhome systemd[3200]: tracker-miner-fs.service: Failed with result 'timeout'.
Dec 21 19:48:39 srvhome systemd[3200]: Failed to start Tracker file system data miner.
Dec 21 19:48:39 srvhome systemd[3200]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 1.
Dec 21 19:48:39 srvhome systemd[3200]: Stopped Tracker file system data miner.
Dec 21 19:48:39 srvhome systemd[3200]: Starting Tracker file system data miner...
Dec 21 19:48:39 srvhome [3324]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:39 srvhome [3324]: Setting priority nice level to 19
Dec 21 19:48:39 srvhome [3324]: Unable to get XDG user directory path for special directory &DOCUMENTS. Ignoring this location.
Dec 21 19:48:39 srvhome [3324]: Unable to get XDG user directory path for special directory &MUSIC. Ignoring this location.
Dec 21 19:48:39 srvhome [3324]: Unable to get XDG user directory path for special directory &PICTURES. Ignoring this location.
Dec 21 19:48:39 srvhome [3324]: Unable to get XDG user directory path for special directory &VIDEOS. Ignoring this location.
Dec 21 19:48:39 srvhome [3324]: Unable to get XDG user directory path for special directory &DOWNLOAD. Ignoring this location.
Dec 21 19:48:39 srvhome [3324]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:48:39 srvhome [3324]: remote volume monitor with dbus name org.gtk.vfs.GoaVolumeMonitor is not supported
Dec 21 19:48:39 srvhome systemd[3200]: tracker-extract.service: Failed with result 'timeout'.
Dec 21 19:48:39 srvhome systemd[3200]: Failed to start Tracker metadata extractor.
Dec 21 19:48:39 srvhome systemd[3200]: tracker-extract.service: Scheduled restart job, restart counter is at 1.
Dec 21 19:48:39 srvhome systemd[3200]: Stopped Tracker metadata extractor.
Dec 21 19:48:39 srvhome systemd[3200]: Starting Tracker metadata extractor...
Dec 21 19:48:39 srvhome [3329]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:39 srvhome [3329]: Setting priority nice level to 19
Dec 21 19:48:39 srvhome systemd[3200]: pulseaudio.service: Failed with result 'timeout'.
Dec 21 19:48:39 srvhome systemd[3200]: Failed to start Sound Service.
Dec 21 19:48:39 srvhome systemd[3200]: pulseaudio.service: Scheduled restart job, restart counter is at 1.
Dec 21 19:48:39 srvhome systemd[3200]: Stopped Sound Service.
Dec 21 19:48:39 srvhome systemd[3200]: Starting Sound Service...
Dec 21 19:48:39 srvhome systemd[3200]: Started Sound Service.
Dec 21 19:48:39 srvhome systemd[1]: udisks2.service: start operation timed out. Terminating.
Dec 21 19:48:39 srvhome systemd[2308]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 9.
Dec 21 19:48:39 srvhome systemd[2308]: tracker-extract.service: Scheduled restart job, restart counter is at 9.
Dec 21 19:48:39 srvhome [3359]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:39 srvhome [3359]: Setting priority nice level to 19
Dec 21 19:48:39 srvhome [3360]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:39 srvhome [3360]: Setting priority nice level to 19
Dec 21 19:48:39 srvhome [3360]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:48:39 srvhome [3360]: remote volume monitor with dbus name org.gtk.vfs.GoaVolumeMonitor is not supported
Dec 21 19:48:39 srvhome systemd[3200]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 2.
Dec 21 19:48:39 srvhome tracker-miner-f[3380]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:39 srvhome tracker-miner-f[3380]: Setting priority nice level to 19
Dec 21 19:48:39 srvhome tracker-miner-f[3380]: Unable to get XDG user directory path for special directory &DOCUMENTS. Ignoring this location.
Dec 21 19:48:39 srvhome tracker-miner-f[3380]: Unable to get XDG user directory path for special directory &MUSIC. Ignoring this location.
Dec 21 19:48:39 srvhome tracker-miner-f[3380]: Unable to get XDG user directory path for special directory &PICTURES. Ignoring this location.
Dec 21 19:48:39 srvhome tracker-miner-f[3380]: Unable to get XDG user directory path for special directory &VIDEOS. Ignoring this location.
Dec 21 19:48:39 srvhome tracker-miner-f[3380]: Unable to get XDG user directory path for special directory &DOWNLOAD. Ignoring this location.
Dec 21 19:48:39 srvhome tracker-miner-f[3380]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:48:39 srvhome tracker-miner-f[3380]: remote volume monitor with dbus name org.gtk.vfs.GoaVolumeMonitor is not supported
Dec 21 19:48:39 srvhome systemd[3200]: tracker-extract.service: Scheduled restart job, restart counter is at 2.
Dec 21 19:48:39 srvhome tracker-extract[3385]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:39 srvhome tracker-extract[3385]: Setting priority nice level to 19
Dec 21 19:48:39 srvhome [3231]: Applying configuration from /etc/udisks2/WDC-WD40EFRX-68W-WD-WCC4E0208006.conf to /dev/sdc
Dec 21 19:48:39 srvhome [3231]: Set standby timer to 300 seconds (value 60) on /dev/sdc [WDC-WD40EFRX-68W-WD-WCC4E0208006]
Dec 21 19:48:39 srvhome systemd-resolved[854]: Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.
Dec 21 19:48:39 srvhome [3231]: Applying configuration from /etc/udisks2/WDC-WD20EFRX-68A-WD-WMC300541792.conf to /dev/sdd
Dec 21 19:48:39 srvhome [3231]: Set standby timer to 300 seconds (value 60) on /dev/sdd [WDC-WD20EFRX-68A-WD-WMC300541792]
Dec 21 19:48:39 srvhome systemd[1]: udisks2.service: State 'stop-sigterm' timed out. Killing.
Dec 21 19:48:39 srvhome systemd[1]: udisks2.service: Killing process 3231 (udisksd) with signal SIGKILL.
Dec 21 19:48:39 srvhome systemd[1]: udisks2.service: Main process exited, code=killed, status=9/KILL
Dec 21 19:48:39 srvhome systemd[1]: udisks2.service: Failed with result 'timeout'.
Dec 21 19:48:39 srvhome systemd[1]: Failed to start Disk Manager.
Dec 21 19:48:39 srvhome systemd[2308]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 10.
Dec 21 19:48:39 srvhome systemd[2308]: tracker-extract.service: Scheduled restart job, restart counter is at 10.
Dec 21 19:48:39 srvhome tracker-extract[3456]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:39 srvhome tracker-miner-f[3457]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:39 srvhome tracker-extract[3456]: Setting priority nice level to 19
Dec 21 19:48:39 srvhome tracker-miner-f[3457]: Setting priority nice level to 19
Dec 21 19:48:39 srvhome tracker-miner-f[3457]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:48:39 srvhome tracker-miner-f[3457]: remote volume monitor with dbus name org.gtk.vfs.GoaVolumeMonitor is not supported
Dec 21 19:48:45 srvhome systemd[3200]: tracker-miner-fs.service: start operation timed out. Terminating.
Dec 21 19:48:45 srvhome systemd[3200]: tracker-miner-fs.service: Failed with result 'timeout'.
Dec 21 19:48:45 srvhome systemd[3200]: Failed to start Tracker file system data miner.
Dec 21 19:48:45 srvhome systemd[3200]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 3.
Dec 21 19:48:45 srvhome systemd[3200]: Stopped Tracker file system data miner.
Dec 21 19:48:45 srvhome systemd[3200]: Starting Tracker file system data miner...
Dec 21 19:48:45 srvhome tracker-miner-f[3482]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:45 srvhome tracker-miner-f[3482]: Setting priority nice level to 19
Dec 21 19:48:45 srvhome tracker-miner-f[3482]: Unable to get XDG user directory path for special directory &DOCUMENTS. Ignoring this location.
Dec 21 19:48:45 srvhome tracker-miner-f[3482]: Unable to get XDG user directory path for special directory &MUSIC. Ignoring this location.
Dec 21 19:48:45 srvhome tracker-miner-f[3482]: Unable to get XDG user directory path for special directory &PICTURES. Ignoring this location.
Dec 21 19:48:45 srvhome tracker-miner-f[3482]: Unable to get XDG user directory path for special directory &VIDEOS. Ignoring this location.
Dec 21 19:48:45 srvhome tracker-miner-f[3482]: Unable to get XDG user directory path for special directory &DOWNLOAD. Ignoring this location.
Dec 21 19:48:45 srvhome gvfs-udisks2-vo[3228]: monitor says it's not supported
Dec 21 19:48:45 srvhome tracker-miner-f[3482]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:48:45 srvhome gvfs-goa-volume[3279]: monitor says it's not supported
Dec 21 19:48:45 srvhome tracker-miner-f[3482]: remote volume monitor with dbus name org.gtk.vfs.GoaVolumeMonitor is not supported
Dec 21 19:48:46 srvhome systemd[3200]: tracker-extract.service: start operation timed out. Terminating.
Dec 21 19:48:46 srvhome systemd[3200]: tracker-extract.service: Failed with result 'timeout'.
Dec 21 19:48:46 srvhome systemd[3200]: Failed to start Tracker metadata extractor.
Dec 21 19:48:46 srvhome systemd[3200]: tracker-extract.service: Scheduled restart job, restart counter is at 3.
Dec 21 19:48:46 srvhome systemd[3200]: Stopped Tracker metadata extractor.
Dec 21 19:48:46 srvhome systemd[3200]: Starting Tracker metadata extractor...
Dec 21 19:48:46 srvhome tracker-extract[3487]: Set scheduler policy to SCHED_IDLE
Dec 21 19:48:46 srvhome tracker-extract[3487]: Setting priority nice level to 19
Dec 21 19:49:02 srvhome /usr/lib/gdm3/gdm-x-session[3250]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Dec 21 19:49:45 srvhome /usr/lib/gdm3/gdm-x-session[3250]: (==) No Layout section. Using the first Screen section.
Dec 21 19:49:45 srvhome /usr/lib/gdm3/gdm-x-session[3250]: (==) No screen section available. Using defaults.
Dec 21 19:49:45 srvhome /usr/lib/gdm3/gdm-x-session[3250]: (**) |-->Screen "Default Screen Section" (0)
Dec 21 19:49:45 srvhome /usr/lib/gdm3/gdm-x-session[3250]: (**) | |-->Monitor "<default monitor>"
Dec 21 19:49:48 srvhome /usr/lib/gdm3/gdm-x-session[3250]: (==) No monitor specified for screen "Default Screen Section".
Dec 21 19:49:48 srvhome /usr/lib/gdm3/gdm-x-session[3250]: #011Using a default monitor configuration.
Dec 21 19:50:08 srvhome systemd[2308]: tracker-extract.service: start operation timed out. Terminating.
Dec 21 19:50:08 srvhome systemd[2308]: tracker-miner-fs.service: start operation timed out. Terminating.
Dec 21 19:50:08 srvhome systemd[2308]: tracker-extract.service: Failed with result 'timeout'.
Dec 21 19:50:08 srvhome systemd[2308]: Failed to start Tracker metadata extractor.
Dec 21 19:50:08 srvhome systemd[2308]: tracker-miner-fs.service: Failed with result 'timeout'.
Dec 21 19:50:08 srvhome systemd[2308]: Failed to start Tracker file system data miner.
Dec 21 19:50:08 srvhome systemd[2308]: tracker-extract.service: Scheduled restart job, restart counter is at 11.
Dec 21 19:50:08 srvhome systemd[2308]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 11.
Dec 21 19:50:08 srvhome systemd[2308]: Stopped Tracker metadata extractor.
Dec 21 19:50:08 srvhome systemd[2308]: Starting Tracker metadata extractor...
Dec 21 19:50:08 srvhome systemd[2308]: Stopped Tracker file system data miner.
Dec 21 19:50:08 srvhome systemd[2308]: Starting Tracker file system data miner...
Dec 21 19:50:08 srvhome tracker-extract[3503]: Set scheduler policy to SCHED_IDLE
Dec 21 19:50:08 srvhome tracker-extract[3503]: Setting priority nice level to 19
Dec 21 19:50:08 srvhome tracker-miner-f[3504]: Set scheduler policy to SCHED_IDLE
Dec 21 19:50:08 srvhome CRON[3524]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 19:50:08 srvhome tracker-miner-f[3504]: Setting priority nice level to 19
Dec 21 19:50:08 srvhome gvfs-udisks2-vo[2412]: monitor says it's not supported
Dec 21 19:50:08 srvhome tracker-miner-f[3504]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:50:08 srvhome gvfs-goa-volume[2461]: monitor says it's not supported
Dec 21 19:50:08 srvhome tracker-miner-f[3504]: remote volume monitor with dbus name org.gtk.vfs.GoaVolumeMonitor is not supported
Dec 21 19:50:15 srvhome systemd[3200]: tracker-miner-fs.service: start operation timed out. Terminating.
Dec 21 19:50:15 srvhome systemd[3200]: tracker-miner-fs.service: Failed with result 'timeout'.
Dec 21 19:50:15 srvhome systemd[3200]: Failed to start Tracker file system data miner.
Dec 21 19:50:16 srvhome systemd[3200]: tracker-miner-fs.service: Scheduled restart job, restart counter is at 4.
Dec 21 19:50:16 srvhome systemd[3200]: Stopped Tracker file system data miner.
Dec 21 19:50:16 srvhome systemd[3200]: Starting Tracker file system data miner...
Dec 21 19:50:16 srvhome tracker-miner-f[3530]: Set scheduler policy to SCHED_IDLE
Dec 21 19:50:16 srvhome tracker-miner-f[3530]: Setting priority nice level to 19
Dec 21 19:50:16 srvhome tracker-miner-f[3530]: Unable to get XDG user directory path for special directory &DOCUMENTS. Ignoring this location.
Dec 21 19:50:16 srvhome tracker-miner-f[3530]: Unable to get XDG user directory path for special directory &MUSIC. Ignoring this location.
Dec 21 19:50:16 srvhome tracker-miner-f[3530]: Unable to get XDG user directory path for special directory &PICTURES. Ignoring this location.
Dec 21 19:50:16 srvhome tracker-miner-f[3530]: Unable to get XDG user directory path for special directory &VIDEOS. Ignoring this location.
Dec 21 19:50:16 srvhome tracker-miner-f[3530]: Unable to get XDG user directory path for special directory &DOWNLOAD. Ignoring this location.
Dec 21 19:50:16 srvhome gvfs-udisks2-vo[3228]: monitor says it's not supported
Dec 21 19:50:16 srvhome tracker-miner-f[3530]: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
Dec 21 19:50:16 srvhome gvfs-goa-volume[3279]: monitor says it's not supported
Dec 21 19:50:16 srvhome tracker-miner-f[3530]: remote volume monitor with dbus name org.gtk.vfs.GoaVolumeMonitor is not supported
Dec 21 19:50:16 srvhome systemd[3200]: tracker-extract.service: start operation timed out. Terminating.
Dec 21 19:50:16 srvhome systemd[3200]: tracker-extract.service: Failed with result 'timeout'.
Dec 21 19:50:16 srvhome systemd[3200]: Failed to start Tracker metadata extractor.
Dec 21 19:50:17 srvhome systemd[3200]: tracker-extract.service: Scheduled restart job, restart counter is at 4.
Dec 21 19:50:17 srvhome systemd[3200]: Stopped Tracker metadata extractor.
Dec 21 19:50:17 srvhome systemd[3200]: Starting Tracker metadata extractor...
Dec 21 19:50:17 srvhome tracker-extract[3535]: Set scheduler policy to SCHED_IDLE
Dec 21 19:50:17 srvhome tracker-extract[3535]: Setting priority nice level to 19
Dec 21 19:50:18 srvhome /usr/lib/gdm3/gdm-x-session[3250]: (==) Automatically adding devices
Dec 21 19:50:18 srvhome /usr/lib/gdm3/gdm-x-session[3250]: (==) Automatically enabling devices
Dec 21 19:50:18 srvhome /usr/lib/gdm3/gdm-x-session[3250]: (==) Automatically adding GPU devices
Dec 21 19:50:18 srvhome /usr/lib/gdm3/gdm-x-session[3250]: (==) Automatically binding GPU devices
Dec 21 19:50:18 srvhome /usr/lib/gdm3/gdm-x-session[3250]: (==) Max clients allowed: 256, resource mask: 0x1fffff
Dec 21 19:50:42 srvhome /usr/lib/gdm3/gdm-x-session[3250]: (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
root@srvhome:/home/clisclis# nano /var/log/syslog
GNU nano 4.8 /var/log/syslog
Dec 21 00:00:16 srvhome systemd[1]: logrotate.service: Succeeded.
Dec 21 00:00:16 srvhome systemd[1]: Finished Rotate log files.
Dec 21 00:00:24 srvhome fstrim[130131]: /boot/efi: 503.2 MiB (527630336 bytes) trimmed on /dev/disk/by-uuid/4678-1A6C
Dec 21 00:00:24 srvhome fstrim[130131]: /: 89.5 GiB (96137801728 bytes) trimmed on /dev/disk/by-uuid/ab6a586a-7b31-4719-aaab-88efa3a719f8
Dec 21 00:00:24 srvhome systemd[1]: fstrim.service: Succeeded.
Dec 21 00:00:24 srvhome systemd[1]: Finished Discard unused blocks on filesystems from /etc/fstab.
Dec 21 00:03:24 srvhome smartd[885]: Device: /dev/sda [SAT], is in STANDBY mode, suspending checks
Dec 21 00:03:24 srvhome smartd[885]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 70 to 71
Dec 21 00:05:01 srvhome CRON[130366]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec 21 00:05:01 srvhome CRON[130367]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 00:09:01 srvhome CRON[130385]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Dec 21 00:09:04 srvhome systemd[1]: Starting Clean php session files...
Dec 21 00:09:04 srvhome systemd[1]: phpsessionclean.service: Succeeded.
Dec 21 00:09:04 srvhome systemd[1]: Finished Clean php session files.
Dec 21 00:10:01 srvhome CRON[130484]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 00:15:01 srvhome CRON[130509]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec 21 00:15:01 srvhome CRON[130510]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 00:17:01 srvhome CRON[130526]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Dec 21 00:20:01 srvhome CRON[130542]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 00:25:01 srvhome CRON[130566]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec 21 00:25:01 srvhome CRON[130567]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 00:30:01 srvhome CRON[130750]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 00:33:19 srvhome smartd[885]: Device: /dev/sda [SAT], is back in ACTIVE or IDLE mode, resuming checks (1 check skipped)
Dec 21 00:33:19 srvhome smartd[885]: Device: /dev/sda [SAT], SMART Prefailure Attribute: 3 Spin_Up_Time changed from 172 to 171
Dec 21 00:33:19 srvhome smartd[885]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 118 to 119
Dec 21 00:33:19 srvhome smartd[885]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 71 to 72
Dec 21 00:35:01 srvhome CRON[130785]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec 21 00:35:01 srvhome CRON[130786]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 00:39:01 srvhome CRON[130804]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Dec 21 00:39:04 srvhome systemd[1]: Starting Clean php session files...
Dec 21 00:39:04 srvhome systemd[1]: phpsessionclean.service: Succeeded.
Dec 21 00:39:04 srvhome systemd[1]: Finished Clean php session files.
Dec 21 00:40:01 srvhome CRON[130902]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 00:45:01 srvhome CRON[131054]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec 21 00:45:01 srvhome CRON[131055]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 00:50:01 srvhome CRON[131079]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 00:55:01 srvhome CRON[131217]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec 21 00:55:01 srvhome CRON[131218]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 01:00:01 srvhome CRON[131365]: (root) CMD (timeshift --check --scripted)
Dec 21 01:00:01 srvhome CRON[131366]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 01:00:06 srvhome crontab[131403]: (root) LIST (root)
Dec 21 01:00:06 srvhome crontab[131404]: (root) LIST (root)
Dec 21 01:03:19 srvhome smartd[885]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 72 to 71
Dec 21 01:05:01 srvhome CRON[131433]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec 21 01:05:01 srvhome CRON[131434]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 01:09:01 srvhome CRON[131455]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Dec 21 01:09:05 srvhome systemd[1]: Starting Clean php session files...
Dec 21 01:09:05 srvhome systemd[1]: phpsessionclean.service: Succeeded.
Dec 21 01:09:05 srvhome systemd[1]: Finished Clean php session files.
Dec 21 01:10:01 srvhome CRON[131548]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 01:15:01 srvhome CRON[131576]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec 21 01:15:01 srvhome CRON[131577]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 01:17:01 srvhome CRON[131706]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Dec 21 01:20:01 srvhome CRON[131796]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 01:25:01 srvhome CRON[131824]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec 21 01:25:01 srvhome CRON[131825]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 01:30:01 srvhome CRON[131848]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
Dec 21 01:33:19 srvhome smartd[885]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 119 to 118
Dec 21 01:35:01 srvhome CRON[131983]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
