[Sammelthread] Asrock AOD790GX/128M (AMD 790GX)
ASRock AOD790GX/128M, 790GX
1. Support for Socket AM2+ / AM2 processors: AMD Phenom™ FX / Phenom / Athlon 64 FX / Athlon 64 X2 Dual-Core / Athlon X2 Dual-Core / Athlon 64 / Sempron processor
2. Supports CPU up to 140W
3. ASRock DuraCap (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
4. AMD 790GX + SB750 Chipsets
5. AM3 CPU Ready!
* FSB 2600 MHz (5.2 GT/s)
* Supports AMD OverDrive™ with ACC feature (Advanced Clock Calibration)
* Supports Hyper-Transport 3.0 (HT 3.0) Technology
* Supports Dual Channel DDR2 1066 with AM2+ CPU , and DDR2 800/667/533 with AM2 CPU, with 4 DIMM slots, maximum capacity up to 16GB
* Integrated AMD Radeon HD 3300 graphics, DX10 class iGPU, Pixel Shader 4.0, Max. shared memory 512MB
* Integrated 128MB side port memory for iGPU
* Supports ATI™ CrossFire™ and Hybrid CrossFireX™
* 2 x PCI Express 2.0 x16 slots (green @ x16 mode, blue @ x8 mode)
* 6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 5, RAID 10 and JBOD), NCQ, AHCI and Hot Plug functions
* 1 x eSATAII 3.0 Gb/s connector
* 2 x IEEE1394 ports (one port on back panel, one header on board)
* PCIE Gigabit LAN 10/100/1000 Mb/s
* Three VGA Output options: D-Sub, DVI-D and HDMI with DVI-to-HDMI Converter
* Supports HDCP function
* Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback
* 1 x USB/WiFi header
* Supports Smart BIOS, ASRock OC Tuner, Intelligent Energy Saver, Extra ESD Protection
* Free Bundle: 1 x ASRock XFire Switch Card, 1 x DVI-to-HDMI Converter
* 7.1 CH Windows® Vista™ Premium Level HD Audio, DAC with 110dB dynamic range (ALC890 Audio Codec)
* Windows® Vista™ Premium 2008 Logo Ready
* I/O Panel: 1 x VGA/D-Sub Port, 1 x VGA/DVI-D Port, 1 x eSATAII Port, 1 x IEEE 1394 Port, 1 x RJ-45 LAN Port with LED, 6 x USB 2.0 Ports
2. FAQ - Frequently Asked Questions
- "Lassen sich 3 Pin Lüfter steuern?"
Nein das geht nicht.
- "Ist der Sideportspeicher alleine nutzbar?."
Jawohl das ist möglich.
3. Links & Downloads
3.1 Links zu Treibern, BIOS,Programmen
http://www.asrock.com/mb/download.asp?Model=AOD790GX/128M&s=AM2+
3.2 Reviews
http://www.pctreiber.net/thread.php?threadid=10224
http://www.cpu3d.com/review/5844-1/asrock-aod790gx-128m-motherboard/introduction.html
http://www.thinkcomputers.org/index.php?x=reviews&id=850
http://my.ocworkbench.com/2008/asrock/AOD790GX-128M/g1.htm
http://www.amdzone.com/index.php/reviews/66/10542-asrock-aod790gx128mb
3.3 Interessantes:
- Sideportspeicher ist alleine nutzbar
- Asrock OC Tuner unter Windows zum Übertakten
- Stromsparender als der Vorgänger 780G
- DVI auf HDMI Adapter im Lieferumfang enthalten
3.4. Overclocking
4. Preise
http://preisvergleich.hardwareluxx.de/deutschland/a365733.html
http://www.hardwareschotte.de/hardware/preise/proid_9775432/preis_ASROCK+AOD790GX128M
http://www.preistrend.de/suchen.php?q=AOD790GX&s=0&a=&z=&x=0&y=0
http://www.google.de/products?q=ASRock+AOD790GX&hl=de&scoring=p
5. Bekannte Probleme:
unter XP ist die 2D Performance bei allen 7er Chipsätzen nicht sehr hoch. Den Treiber aktualisieren bringt etwas. Ganz schlimm ist es mit Treibern unter dem 8.12er!
6. Fixes:
Lüfteregelung mit Speedfan:
http://www.hardwareluxx.de/community/showpost.php?p=13259216&postcount=587
7. Bios:
1.70er Version ist aktuell, doch gibt es hier Probleme mit der Core-Freischaltung
Jo... hab am Wochenende nen 720BE auf so'nem Board montiert. Ging ohne Probleme... Und der 940-er kam einiges vorher.
Das funktioniert selbst mit BIOS 1.0, da wird er nur als "Unknown CPU" erkannt, aber man kann das BIOS ja dann updaten. ;)
Scheint ja im Vergleich zu vorherigen ASRocks ein sehr gutes Brett geworden zu sein :)
Bin da ja selber super zufrieden mit - und wenn man dann noch den Preis bedenkt, dann ist das Board Spitzenklasse! :)
Was für Kühler bieten sich auch dem Board an? Ich habe einen Scythe Mine Rev B, da musste ich den NB-Kühler bei der Montage förmlich wegbiegen, sonst ließ sich der Arretierungsmechanismus vom Mine nicht befestigen. Ich dachte an einen Kühler wie den Xigmatek X1263S oder den Groß Clockner, könnt Ihr vielleicht einfach mal reinschreiben, womit Ihr kühlt und wie gut das passt?
Das hättest du nich machen müssen. Den identischen Kühler hab ich auch. Die Seite die zur NB hinzeigt muss nor vorher schon in die Stellung "Geschlossen" gebracht werden, dann eingehakt und dann mit ein bisschen Kraft (ABER VORSICHTIG) die andere Seite befestigt werden. Siehe meinen Beitrag hier. ;) Du könntest, wenn du den Mine Rev B. behalten willst, auch darüber nachdenken, den NB-Kühler zu ersetzen. Dachte da an den Alpenföhn, hab mir da aber den Befestigungsmechanismus noch nicht angesehen.
Ich habe letztens nen Arctic Freezer 64 für 13 Euro verbaut. (19.- Sfr). Prozzi ist ein 720BE. Ist alles sogar beim Primen absolut kühl. Mehr Geld ausgeben ist unsinnig, denne die Temps sind so tief, dass es einfach nicht rentiert, mehr Geld dafür auszugeben.
Und leise ist er auch. Das Montieren ging, aber war heikel. Wenn jemand aber eh weiss, wie solche Dinger zu montieren sind, dann sollte es kein Problem sein, solange ein zweiter Mann zum Beleuchten da ist.
Ich hab bisher noch nie ein zu einem Board inkompatibles Netzteil gesehen, wenn der Stecker mechanisch gepasst hat. ...
Es gibt nur ein paar Extremstromsparboards, die nicht richtig anlaufen.
Ich hab ein Seasonic S12 500W und habe keine Probleme ;)
Groß Glockner passt ohne Probleme und Inkompatibilitäten in Bezug auf Netzteile dürfte eine Internet-Ente sein.
Ich hab auch schon zig Boards und zig Netzteile gehabt und kann so etwas nicht nachvollziehen. Wenn Netzteil oder Board herstellerseitig vom ATX-Standard abweichen, ist das natürlich eine andere Sache.
Da hatten höchstens die Foxconn-Boards eine Macke.
Wie in deiner Signatur ersichtlich ist, hast du ja diverse Mainboards mit verschiedenen Netzteilen im Einsatz und bist beim Übertakten auch nicht zimperlich - Rechner 1.
Moin
Bevor ich mir das Board nun bestelle, wollte ich noch etwas wissen. Das Board ansich wird ja hochgelobt und die Ausstattung is genial. Aber wie verhalten sich AsRock boards mit Mushkin Speicher? Mein Derzeitiges MSI K9 macht nämlich zicken, naja das scheint eh hinüber zu sein
Wie ist das mit dem IES? Geht das nur für K10 oder auch für den K8 AM2?
System siehe Sig
Netzteil bleibt erstmal das 450W drin. Sollte dennoch reichen
Muss man bei den Spawas Acht geben wegen Temps? Meine MSI werden nämlich sauheiss, trotzt Kühlung. Ggf wie breit sind die Abstände und kann ich normale Spawakühler nehmen?
Gruss
Micha
@Urockstar
Bislang machen die Spawas keinen Ärger.
Normale Spawakühler kannst du nicht montieren.
Die einzige Option dürften die Mosfet-Kühler (Mos-C1) von Enzotech sein.
Leute, Spannungswandler sind doch für hohe Temperaturen ausgelegt. Das sollte auch ohne Kühler funktionieren.
Ich habe meinen 920er aktuell auf 3,22GHz, Temperatur unter Last bei ca. 48°C bei kanpp 900RPM, also ganz ordentlich. Was mit allerdings nicht gefällt, ist die Temperatur der NB mit circa 60°C. Was passt denn da an anderen, besseren Kühlern auf das Board? Meinetweg auch aktiv belüftet, sollte nur leise sein.
Ist es normal bei dem Board das es so stark übervoltet?
Wenn ich im BIOS 1.35V VCore einstelle, dann zeigen der ASRock OC Tuner und CPU-Z 1.5 eine zwischen 1.35 und 1.4V schwankende VCore an:hmm:
was ist denn der standard-takt der NB und die standard spannung?
Wenn ich im Bios nämlich auf Manuell stelle um den cpu-multi zu verstellen, "muss" ich auch die NB einstellen, deswegen möcht ich das gerne wissen :)
2000MHz@1.225V
danke, ich hätte da noch einige Fragen:
- Mit welchem Tool kann ich die Temps der CPU-Kerne auslesen? CoreTemp, Everest und AMD Overdrive funktionieren nicht.
Lediglich einen Wert für CPU bekomm ich bei Everest und AMD Overdrive angezeigt, dieser hat jedoch nen anderen Wert als das, was mir im BIOS angezeigt wird. Außerdem steigt der Wert bei Belastung nur ganz gemächlich an. Von meinem Core2Duo bin ich gewöhnt, dass die Temp bei Belastung sofort einen riesen Sprung macht.
- Welche Einstellungen habt ihr im BIOS verändert gegenüber den defaults?
- Übertaktet ihr die Phenoms nur per Multi und lasst den FSB auf 200?
Ich hab bestimmt noch mehr Fragen, die fallen mir sicherlich bald ein ;)
Bis dahin danke schonmal für die Antworten.
haste vielleicht den 4.ten Kern freigeschaltet?
dann funktioniert das auslesen nicht richtig.
jap, der is freigeschaltet.
Da ist auch schon gleich meine nächste Frage: kann man den vierten Kern auch wieder abschalten? :d
Wenn ich ACC wieder zurück auf disabled stelle, sind nämlich weiterhin alle vier Kerne da.
Komisch, oder?
