[Sammelthread] ASRock Fatal1ty X370 Gaming K4
(lt. Berichten bereits EOL!)
- Spezifikationen:
Gaming ArmorPower
  • Hi-Density Power Connectors (24 pin and 8 pin)
Memory
  • 15μ Gold Contact in DIMM Slots
VGA Card
  • 15μ Gold Contact in VGA PCIe Slot (PCIE2)
Internet
  • Intel® LAN
Cooling
  • XXL Aluminum Alloy Heatsink
Audio
  • Creative Sound Blaster™ Cinema 3
Unique FeatureASRock USB 3.1
  • ASRock USB 3.1 Type-A Port (10 Gb/s)
  • ASRock USB 3.1 Type-C Port (10 Gb/s)
ASRock Super Alloy
  • Premium 45A Power Choke
  • Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
  • I/O Armor
  • Matte Black PCB
  • High Density Glass Fabric PCB
  • 2oz Copper PCB
ASRock Steel Slots
ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
ASRock Live Update & APP Shop
CPU
  • Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge)
  • IR Digital PWM
  • 12 Power Phase design
  • Supports 95W Water Cooling
Chipset
  • AMD Promontory X370
Memory
  • Dual Channel DDR4 Memory Technology
  • 4 x DDR4 DIMM Slots
  • AMD Ryzen series CPUs support DDR4 2933+(OC)2667/2400/2133 ECC & non-ECC, un-buffered memory*
  • AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory*
  • Max. capacity of system memory: 64GB**
*Please refer to Memory Support List on ASRock's website for more information.
**Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
BIOS
  • 128Mb AMI UEFI Legal BIOS with GUI support
  • Supports "Plug and Play"
  • ACPI 5.1 compliance wake up events
  • Supports jumperfree
  • SMBIOS 2.3 support
  • CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
Graphics
  • Integrated AMD Radeon™ R-Series Graphics in A-series APU*
  • DirectX 12, Pixel Shader 5.0
  • Max. shared memory 2GB
  • Supports HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
  • Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Port (Compliant HDMI monitor is required)
  • Supports HDCP with HDMI Port
  • Supports Full HD 1080p Blu-ray (BD) playback with HDMI Port
*Actual support may vary by CPU
Audio
  • 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
  • Premium Blu-ray Audio support
  • Supports Surge Protection
  • Nichicon Fine Gold Series Audio Caps
  • 120dB SNR DAC with Differential Amplifier
  • TI® NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
  • Pure Power-In
  • Direct Drive Technology
  • PCB Isolate Shielding
  • Impedance Sensing on Line Out port
  • Individual PCB Layers for R/L Audio Channel
  • Gold Audio Jacks
  • Supports Creative Sound Blaster™ Cinema 3
LAN
  • Gigabit LAN 10/100/1000 Mb/s
  • GigaLAN Intel® I211AT
  • Supports Wake-On-LAN
  • Supports Lightning/ESD Protection
  • Supports Energy Efficient Ethernet 802.3az
  • Supports PXE
SlotsAMD Ryzen series CPUs
  • 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE4))*
AMD 7th A-Series APUs
  • 1 x PCI Express 3.0 x16 Slot (single at x8 (PCIE2))*
  • 4 x PCI Express 2.0 x1 Slots
  • Supports AMD Quad CrossFireX™ and CrossFireX™**
  • Supports NVIDIA® Quad SLI™ and SLI™**
  • 1 x M.2 Socket (Key E), supports type 2230 WiFi/BT module
*Supports NVMe SSD as boot disks
**This feature is only supported with Ryzen Series CPUs (Summit Ridge).
Storage
  • 6 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
  • 1 x Ultra M.2 Socket (M2_1), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)*
  • 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen2 x2 (10 Gb/s)*
*Supports ASRock U.2 Kit Supports NVMe SSD as boot disks
Connector
  • 1 x COM Port Header
  • 1 x TPM Header
  • 1 x Power LED and Speaker Header
  • 1 x AMD Fan LED Header
  • 2 x RGB LED Headers*
  • 1 x CPU Fan Connector (4-pin)**
  • 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
  • 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
  • 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)****
  • 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
  • 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
  • 1 x Front Panel Audio Connector
  • 1 x AMD LED Fan USB Header
  • 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
  • 2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
  • 1 x Dr. Debug with LED
*Supports up to 12V/3A, 36W LED Strip
**The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
Rear Panel I/O
  • 2 x Antenna Ports
  • 1 x PS/2 Mouse Port
  • 1 x PS/2 Keyboard Port
  • 1 x HDMI Port
  • 1 x Optical SPDIF Out Port
  • 1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
  • 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
  • 6 x USB 3.0 Ports (Supports ESD Protection)* 1 x Fatal1ty Mouse Port (USB 3.0) is included
  • 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
  • HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
Software and UEFI
Software
  • ASRock F-Stream
  • ASRock RGB LED
  • ASRock Key Master
  • ASRock APP Charger
  • ASRock XFast LAN*
UEFI
  • ASRock Full HD UEFI
  • ASRock Instant Flash
  • ASRock Internet Flash
  • ASRock Crashless BIOS
  • ASRock Easy RAID Installer
*These utilities can be downloaded from ASRock Live Update & APP Shop.
Support CD
  • Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
Accessories
  • Quick Installation Guide, Support CD, I/O Shield
  • 4 x SATA Data Cables
  • 1 x ASRock SLI_HB_Bridge_2S Card
  • 3 x Screws for M.2 Sockets
Hardware Monitor
  • Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
Form Factor
  • ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
OS
  • Microsoft® Windows® 10 64-bit*
*For the updated Windows® 10 driver, please visit ASRock's website for details.
Certifications
  • FCC, CE
  • ErP/EuP ready (ErP/EuP ready power supply is required)
[td]
Quelle: ASRock-Webseite
- RAM Kompatibilität:
Liste der geprüften RAM-Riegel des Herstellers
weitere KITs von Forenmitgliedern:
G.Skill Flare X 16GB Kit (8GBx2) 3200MhzF4-3200C14D-16GFX@3200Mhz (XMP-Profile)
G.Skill Trident Z 32GB Kit (16GBx2) 3200MhzF4-3200C14D-32GTZ@2933Mhz 18-16-16-16-40 1.35V
G.Skill Trident Z 16GB Kit (8GBx2) 3200MhzF4-3200C14D-16GTZ@2933Mhz (XMP-Profile)
G.Skill Trident Z 16GB Kit (8GBx2) 3600MhzF4-3600C15D-16GTZ@3200Mhz 14-14-14-14-34 1.36V
G.Skill RipJaws V 16GB Kit (8GBx2) 3600MhzF4-3600C16D-16GVK@2933Mhz 14-14-14-14-34 1.35V
Crucial Ballistix Tactical 16GB Kit (8GBx2) 2666MhzBLT2C8G4D26AFTA@2666Mhz (XMP-Profile)
Crucial Ballistix Sport LT 16GB Kit (8GBx2) 2400MhzBLS2C8G4D240FSE@2933Mhz 20-20-20-20-48 1.35V
Tipps von "paui":
CAS-Timing:
Es können nur gerade Zahlen dort eingegeben werden.
Sobald man eine 15 einstellt wird diese aufgerundet. Also entweder 14 oder 16 aber keine 15 CAS.
RAM-Stabilität:
Die SOC Spannung erhöhen z.b. auf 1,1V oder 1,2V und überall immer LLC auf Level3
Bei SingleRank Modulen den Bankgroupswap auf disabled stellen.
Die Spannung auf 1,360V für 1,352V unter Last für den ram setzen, VTT_DDR ist immer die Hälfte davon!
Als Beispiel beim G.Skill F4-3600C15D-16GTZ:
3200MHz bei 14-14-14-14-34 mit 1,36V, Bankgroupswap disabled, SOC 1,112V
(wenn es nicht läuft, dann auf 2933MHz da läuft er definitiv stabil)
- BIOS-Versionen:
BIOS-Download von der Herstellerseite
BIOS-Download (auch alte Versionen) bei Computertechnik JZelectronic
V4.70 - Enhance compatibility for Raven CPU with Intel WiFi.
V4.60 - 1.Update AMD AGESA to PinnaclePI-AM4_1.0.0.1a. 2.Improve M.2 SSD compatibility.
V4.50 - Update AGESA for upcoming processors.
Wenn man eine Version unter V3.50 auf eine Versionen über V3.50 flashen möchte, muss man einen Zwischenschritt auf V3.50 machen!
V3.50 - Bridge BIOS
V3.40 - 1.Sync the H/W Monitor and Dr.Debug code Temp source to tCTL 2. Gray out Instant Flash when fTPM is enabled.
V3.30 - 1. With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
V3.20 - 1.Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes. 2.Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature.
V3.10 - Add AMD PBS Primary Video Adapter to control Bristol Ridge CPU display order.
V3.00 - Update AGESA to 1.0.0.6a
V2.50 - Update AGESA to 1.0.0.6
V2.40 - Enhance OC setting for advanced Overclocker
V2.30 - Verbesserte System und Speicher Kompatibilität
V2.20 - Update AGESA Version string SummitPI-AM4 1.0.0.4a
V2.10 - Verbesserte System Kompatibilität
V2.00 - AGESA-Code aktualisiert - Verbesserung für Ryzen 5 & Precision Boost - Taktraten können jetzt in 25MHz-Schritten im BIOS-Setup eingestellt werden
V1.70 - Improve XMP DRAM compatibility & Add Simultaneous Multi-Threading(SMT) item in BIOS setup
V1.60 - Add Instant flash function & Add CPU Frequency Multiplier Change item
V1.50 - Support CPU Frequency Multiplier function
- Übertakten (CPU/RAM):
Laut dem Video von AMD sollte man bei einem Dauerbetrieb die CPU nicht über VCORE 1.425V betreiben.
Oft kann man auch lesen, dass Werte von 1.45V oder gar bis zu 1.5V ok sind. Hier sollte man aber bedenken, dass dies die Lebensdauer der CPU verkürzt werden kann.
Der SoC kann super mit 1.1V betrieben werden. Oft kann man auch lesen, dass 1.2V noch ok sind.
- Testberichte / Reviews:
Altes Startposting:
Hallo!
Sie wie es aussieht scheint kaum wer ein ASRock X370 Gaming K4 zu haben. Entsprechend spärlich sind auch die Infos, die ich bis jetzt so finden konnte...
Weiß jemand, ob die Backplate des ASRock X370 Gaming K4 verschraubt oder verklebt ist? Da ich einen Lüfter mit eigener Backplate holen möchte, wäre dies wirklich gut zu wissen.
Des weiteren wollte ich fragen, ob man bei ASRock X370 Gaming K4 im BIOS die DRAM Timings manuell einstellen kann und natürlich auch die Taktfrequenz?
Optisch und Preislich spricht mich das Mainboard sehr an, technisch kann ich leider nicht beurteilen, wobei die "Werbeaussagen" ja nicht schlecht sind.
Vielen Dank
SneakyPie
Kann mir jemand sagen, wie hier und beim Killer SLI der derzeitige Stand bei der ECC-Unterstützung ist - welche Optionen/Logs gibt es da im BIOS?
Hab jetzt mal das 2.50er Bios drauf gespielt ähhhh UEFI mein ich :)
-2x16GB laufen bei 3200 CL14 :)
-bootet endlich wieder so schnell wie es sein soll (Fast Boot, 10s bis Windows 10 Willkommens Bildschirm und 14s bis Desktop). Hatte davor 2.30 glaub ich und da waren es Minuten...
Welche CPU und welches RAM hast du genau?
Habe auch die Ripjaws V aber als 16gb Kit und bekomme die nur auf 2667Mhz (14-14-14-14-34 1T, 1.2V) zum Laufen, kannst du vielleicht mal deine Einstellungen posten.
Anonsten bin ich beim R7 1700 noch Stock und würde den gern übertakten mit dem Macho Rev B als Kühler. Was ist hier zum empfehlen 3.7Ghz oder 3.8 Ghz oder noch höher?
Kann mir auch hier einer seine Einstellungen für das K4 posten. Hab 2.5 Uefi drauf.
Ich hab genau den RAM wie im Eingangsthread erwähnt, CMK16GX4M2B3000 2*8GB in Steckplatz A2 und B2. BIOS ist das aktuellste 2.50er drauf.
Bei mir läuft der nur mit 2133Mhz, wenn ich das XMP-Profile lade, steht da zwar 2933Mhz, aber 1. braucht er dann ewig um zu booten und startet immer wieder neu bis ich mal n Bild bekomme, und 2. steht in Windows in CPU-Z und Ryzen Master, dass der RAM weiterhin nur mit 1067Mhz läuft.
Kann mir jemand sagen was genau ich einstellen muss, dachte eigentlich ich wähle das XMP-Profil und das wars.
Hab ich so eingestellt, ob CL14 oder 16 und 1,35 oder 1,355V, jedes mal so ne Art bootloop und der Rechner braucht ewig zum Starten. Amd Ryzen und CPU-Z zeigen auch weiterhin dann 1066Mhz an.
Wenn ich UEFI Default nehme startet der Rechner direkt, RAM hat dann 2133Mhz.
Aber was ich auch nicht verstehe, wenn ich den Rechner mit Prime voll auslaste, dann erreiche ich maximal 3,5Ghz. Energiesparplan ist auch Ryzen Balanced. Und max. Prozessorgeschwindigkeit steht auf 100%. Von der Temperatur passt auch alles.
Müsste der nicht standardmäßig bis 3,8Ghz gehen?
wenn du nach dem bootloop ins bios schauen würdest, siehst du auch das er wieder mit 2133 arbeitet. Event. den falschen Ram gekauft oder mit 2666 leben.
schon mal Bios reset gemacht?
optional den SOC manuell setzen auf 1,10v falls er nicht mit angepasst wird
Okay, danke.
Hab genau genommen den RAM hier von Mindfactory gekauft: CMK16GX4M2B3000C15
Hab irgendwo in ner Rezension gelesen, dass der mit 2933Mhz ohne Probleme auf dem Board laufen soll.
Andere Frage zum 1700X. Alle Kerne auf 100% taktet der nur mit 3,5Ghz? Die 3,8Ghz hab ich bisher noch nirgends erreicht. Meiner hat eine VID von 1,35V. im Ryzen Tool schwankt die VCore extrem bis 1,42V. Ist das normal?
Wo wäre denn ein guter Punkt um sich mal ans übertakten ranzuwagen, dann bei 1.35V starten?
Reiskorn Master nutze ich nicht. Stell im Bios auf 3800, fixed vcore 1,4v und LLC3 meinetwegen. RAM halt erst mal soweit er geht z.b. 2666. Ich nehm auch keine halben Multis.
so habs nun geschafft den r1700 auf 3.7ghz zu übertakten (im idle geht er auf 1,5 runter) aber den ram (16 gb ripjaws v 3200 cl 16) bekomm ich einfach nicht über 2667 mit cl14
Welches Ripjaws V Kit hast du denn genau und wieviel Spannung gibst du dem RAM? Du schriebst in einem früheren Post etwas von 1,2V.
hab die hier F4-3200C16D-16GVKB, die 1.2v hab ich bei 2667, wenn ich höher mit der mhz gehe, gebe ich ihm auch mehr spannung hab 1.3 und 1.35 probiert, aber bekomme nur die bootloop.
Ah schade, ich habe die Module nicht mehr. Liefen mit dem alten AGESA Code auch nur 2667 CL14 bei mir.
Meine aktuellen Module F4-3200C16D-16GVK liefen mit dem alten Code aber auch nur max 2667MHz CL14.
Mit dem aktuellen Bios, 1,36V RAM Spannung, SOC Spannung +0,05V und SOC LLC 3 laufen 2933MHz CL14 stabil, teste gerade bei 3066MHz.
Mal eine Frage: Obwohl im Bios (2.50) Cool'n'Quiet aktiv ist, taktet mein 1600X im Leerlauf nicht runter. Takt bleibt konstant bei 3,6GHz. Ist das normal?
Edit: Sorry, hat sich erledigt. Im AMD Ryzen-Energiesparplan war als Minimaler Leistungszustand 90% eingestellt. Das habe ich mal auf 10% geändert, jetzt geht er zumindest auf 2,1GHz runter.
bin hart am überlegen auf das ASRock Fatal1ty X370 Gaming X zu wechseln. Vom ASRock Fatal1ty X370 Gaming K4.
erst mal wird die Tage jetzt das Cougar GX600 in Rente geschickt da es schon knapp über 6 Jahre zuverlässig seinen Dienst verrichtet hat.
es wird auf ein Seasonic Prime Titanium 850W gewechselt.
Ist hier außer mir noch jemand mit einen X370 Killer SLI unterwegs? Falls ja, welchen Speicher verwendest Du/Ihr? Bitte genaue Bezeichnung (besser Link bei GH), Menge und aktuelle Geschwindigkeit angeben.
Das K4 ist das erste AM4 Board, das den EOL Status erreicht hat, sollte Erwähnung im Startpost finden. Bios Support soll noch einige Zeit forgesetzt werden, aber Zen 2 Support ist damit nicht garantiert.
Board wird nun durch das Modell X ersetzt.
Asrock Gaming K4 X370 is now EOL as stated by Asrock : Amd
Lachen ohne Ende, hab ja schon vor Tagen gesagt an dem Board ist was faul. Hab daraufhin schon am Samstag das Asus ROG Crosshair VI Hero verbaut und was soll ich sagen Out of the Box nur ein Bios Update ein paar Einstellungen und alles rennt... Tja ASRock ist für mich gestorben, nen Board geht EOL was noch nichteinmal 4 Wochen in meinem Besitz war, einfach unglaublich.
Hab mir ja auch das Gaming X mal bestellt, aber derzeit sind die Bios Optionen ein Witz (kein LLC etc. siehe Post 388 auf Seite 16).
Speicher geht auf jeden Fall mehr, aber ich persönlich hab keine Lust drauf zu spekulieren ob sich da im Bios noch was tut oder nicht, von daher geht meins direkt wieder zurück.
Im ASRock Forum hieß es, daß höherwertige Komponenten eingebaut wurden und deshalb kein LLC nötig sei (Mein droop beim testen hat was anderes gesagt ^^) , evtl. aber mit späteren Updates kommen könnte.
Das ist wirklich unschön, da Ich auch erstmals auf asrock gesetzt habe und auch gehofft hatte das damit ein Ryzen 2 Support möglich wäre. Dann hätte es auch ein b-board getan oder mein favorisierten msi
Wobei ich sagen muss das bei mir bisher alles läuft, auch der RAM mit 3200 cl14
Wir wollten eine andere Bezeichung und nicht wie andere Hersteller einfach nur die Revision aufaddieren von 1.00, 1.02 und dann 2.00 oder 3.00.
Das lag auch daran, dass das Killer SLI auch kein USB3.1 hatte und man wollte eine Trennung K4 dann zu X :)
Laut Handbuch beherrscht X370 Killer SLI kein USB3.1, laut PCGH beherrschen zwei Ports am I/O Panel Geschwindigkeiten von über 800MB/s, was deutlich über USB 3.0 liegt. Was stimmt nun?
AMD R7 1700
AsRock X370 Killer SLI Bios 2.50
G.Skill F4-3200C16D-16GVK DDR4-3200 CL16-16-16-36
G.Skill RipJaws V schwarz DIMM Kit 16GB, DDR4-3200, CL16-16-16-36 (F4-3200C16D-16GVK) Preisvergleich Geizhals Deutschland
Stabil:
DDR4-2933 CL14-14-14-34
DDR4-3066 CL16-16-16-36
Boot aber instabil: DDR4-3200 CL16
(Ich bekomme im Bios die Command Rate nicht auf 2T übernommen, scheint ein Bug)
bei den Stabilen Werten, fährst du da mit 1T ? Welche Soc und welche dram spannung liegt an?
Das ist jetzt ein Witz/Fake oder?
Hab von Asrock viel gehalten (eigentlich meine erste Wahl) aber jetzt...
Hatte mir das neue Asrock X370 Gaming X heute genauer angesehen (weil das Asus Prime nen mickrigen/heißen Chipsatzkühler hat und MSI X370 Carbon Pro kein Voltage Offset im Bios bietet), aber nach der Krücke mit dem K4 EOL ist Asrock für mich bei der Board-Wahl für AM4 jetzt komplett raus.
Besonders abartig finde ich, dass kein Klartext gesprochen wird, wenn es um die Gründe für das EOL vom K4 geht. Das stärkt natürlich das Vertrauen zum Hersteller, es bei anderen Boards besser zu machen.
