[Sammelthread] ASRocks Fatal1ty P67 Professional
image.php
[/url]http://[/IMG]
  1. ASRock > Produkte > Fatal1ty P67 Professional
    *] Preise und Verfügbarkeit
    ASRock Fatal1ty P67 Professional, P67 (B3) (dual PC3-10667U DDR3) | Geizhals.at Deutschland
    ASRock Fatal1ty P67 Professional Sockel 1155 Mainboard: Mainboard Preisvergleich - Preise bei idealo.de
  2. Spezifikationen
    Sockel
    1155 Sandy Bridge​
    Prozessor
    Intel® Core™ i7-2600K/2600​
    Intel® Core™ i5-2300-2500/2500K​
    Intel® Core™i3-2100-2120​
    Chipsatz
    Intel® P67 Express​
    Steckplätze
    2x PCI 32 Bit Steckplätze
    32 Bit 5 Volt 33 Mhz
    2x PCIe 2.0 x1
    3x PCIe 2.0 x16 /1x16 oder 2 x8/x8 ; PCIE5: x4​
    BIOS
    64Mb AMI UEFI Legal BIOS with GUI support
    - Supports "Plug and Play"
    - ACPI 1.1 Compliance Wake Up Events
    - Supports jumperfree
    - SMBIOS 2.3.1 Support
    - DRAM, PCH, CPU PLL, VTT, VCCSA Voltage Multi-adjustment
    Arbeitsspeicher
    Dual Channel DDR3 memory technology
    4 x DDR3 DIMM slots Max. 32GB
    Supports DDR3 2133(OC)/1866(OC)/1600/1333/1066 non-ECC, un-buffered memory​
    Supports Intel® Extreme Memory Profile (XMP)​
    Audio
    7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
    - Premium Blu-ray audio support
    - Supports THX TruStudio PRO™​
    LAN
    - PCIE x1 Gigabit LAN 10/100/1000 Mb/s
    - Realtek RTL8111E
    - Supports Wake-On-LAN
    - Supports LAN Cable Detection
    - Supports Energy Efficient Ethernet 802.3az
    - Supports Dual LAN with Teaming function​
    SATA3
    2 x SATA3 6.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and "Hot Plug" functions
    - 4 x SATA3 6.0 Gb/s connectors by Marvell SE9120, support NCQ, AHCI and "Hot Plug" functions (SATA3_M4 connector is shared with eSATA3 port)​
    USB 3.0
    - 4 x Rear USB 3.0 ports by Etron EJ168A, support USB 1.0/2.0/3.0 up to 5Gb/s
    - 1 x Front USB 3.0 header (supports 2 USB 3.0 ports) by Etron EJ168A, supports USB 1.0/2.0/3.0 up to 5Gb/s
    - 4 x SATA2 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and Hot Plug functions​
    Anschlüsse Board
    - 6 x SATA3 6.0 Gb/s connectors
    - 1 x ATA133 IDE connector (supports 2 x IDE devices)
    - 1 x Floppy connector
    - 1 x IR header
    - 1 x COM port header
    - 1 x HDMI_SPDIF header
    - 1 x IEEE 1394 header
    - 1 x Power LED header
    - CPU/Chassis/Power FAN connector
    - 24 pin ATX power connector
    - 8 pin 12V power connector
    - CD in header
    - Front panel audio connector
    - 4 x USB 2.0 headers (support 8 USB 2.0 ports)
    - 1 x USB 3.0 header (supports 2 USB 3.0 ports)
    - 1 x Dr. Debug with LED​
    Anschlüsse ATX-Blende
    - 1 x PS/2 Mouse Port
    - 1 x PS/2 Keyboard Port
    - 1 x Coaxial SPDIF Out Port
    - 1 x Optical SPDIF Out Port
    - 3 x Ready-to-Use USB 2.0 Ports
    - 1 x Fatal1ty Mouse Port (USB 2.0)
    - 1 x eSATA3 Connector
    - 4 x Ready-to-Use USB 3.0 Ports
    - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
    - 1 x IEEE 1394 Port
    - 1 x Clear CMOS Switch with LED
    - HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone​
    Mitgeliefertes Zubehör
    1 x SLI_Bridge
    1 x Drivers and Utilities CD
    1 x Front USB 3.0 Panel mit Aufnahme für 1.SSD !!
    1 x Rear USB 3.0 Bracket , einfach nur umschrauben !
    1 x Floppy/ATA 133 Kabel
    6 x SATA Data Kabel
    2 x SATA 1 to 1 Powerkabel​
  3. Bilder uneingebaut und eingebaut
  4. Bilder Bios Übersicht
  5. Bilder Bios OC Tweaker und Advanced
  6. RAM Liste
    ASRock > Produkte > Fatal1ty P67 Professional > Speicher Support Liste
  7. Getesteter Ram
    Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) | Geizhals.at Deutschland
    G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL)
    Corsair XMS3 DIMM Kit 8GB PC3-16000U CL9-10-9-27 (DDR3-2000) (CMX8GX3M2A2000C9)
    Corsair XMS3 Dominator GT DIMM Kit 4GB PC3-16000U CL8-9-8-24 (DDR3-2000) (CMT4GX3M2A2000C8)
    G.Skill ECO DIMM Kit 4GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-4GBECO)
  8. Download BIOS + Treiber
    ASRock > Produkte > Fatal1ty P67 Professional > Download
    Rest kommt nocht
    MfG
Ich habs direkt vom Support per Mail bekommen. Ist anscheinend ne Vorabversion.
Habe auch keinen Changelog.
Ich habs mal hochgeladen (Zippyshare.com es jemand will.
Könnt Ihr mich mal wissen lassen welche RAM Speicher Ihr verwendet? Ich bin auf der Such nach einem günstigen 8GB Kit...
Danke im voraus!
Ich würde die nehmen, G.Skill RipJaws DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBRL).
Habe zwei Kits verbaut, laufen 1A bei Vollbestückung als 16GB.
Habe ich auch und passen Optisch prima zum Board ;)
Was das betrifft, sieht nicht nur das Board und Speicher in der Kombination gut aus. Sondern es passt auch Optisch der Scythe Ninja 3 Kühler!
Nur die Installation dieses Kühlers ist eine Katastrophe, das kann EKL mit den Brocken viel besser!
Da bin ich mit meiner wakü besser bedient. Da brauche ich mir auch keine Gedanken über die Höhe RAM Riegel machen ;)
wird eigentlich die ASRock Fatal1ty P67 Pro Platine
von dem Tool AIDA64 Business 1.70 1400 erkannt ???
Ja wird es.
Hat schon jemand Erfahrungen mit den ASRock Treiber 3TB+Unlock für 3TB HDD?
Kann mir mal bitte jemand helfen? Wenn ich im Bios bei OC auf 4,4 GHz stelle, wird dies auch im Bios so angezeigt. In WIndows wiederum nicht. Everest sagt auch nur 3,4 GHz.
Hab nen 2600k drauf...
Danke im voraus!
Wird das unter last bei dir angezeigt? Wenn du alles auf Auto hast sollte es normal funktionieren.
Nein, im Idle...Ich sollte das System mal stressen und es erneut versuchen. Normalerweise sollte das System aber auch ohne Last den höheren Takt erkennen...?
CPU-Z erkennt nur den Takt der aktuell anliegt.
Aida ist da nicht anders da wird nur der "Standart turbo Takt in Klammern mit angegeben"
Maximal Takt wird nur unter voll Last erzogt. Das ist ja das Prinzip des Turbo-Boost. In Idle Modus kann man somit nicht die maximal Übertaktung erreichen.
Ich habe im Gerätemanger des
ASRock Fatal1ty P67 Pro, BIOS 1.80
noch ein Fragezeichen für PCI-Kommunikationscontroller,
welches für Intel ME (Intel Managment Driver)steht.
Installieren möchte ich das ME nicht.
Kann ich diese Option im BIOS folgenlos deaktivieren?
Und wenn ja wie?
Warum willst du den Treiber nicht Installieren?
Ich werde den ME nicht nutzen.
Bei meinem Gigabyte Board konnte ich das im BIOS deaktivieren.
Geht dies auch bei dem UEFI 1.80 ?
Ist mir nicht bekannt das man das in UEFI abschalten kann.
hab uf 1.80 bios updated und jetzt zeigt Windows 3.40 GHz obwohl multi bei mir 43(4300 GHz) ist. was ist das bitte her? Hat jemand auch Probs damit?
1. Hast du nach dem Update einen Reset des Bios durchgeführt?
und 2. in Windoof darfst du nur CPU-Z oder ähnliche Tools zum auslesen des Taktes nutzen denn windows zeigt nur Müll an.
Windows zeigt bei mir auch nur die 3,4 Ghz an. Das ist aber normal. Da Windows nur das anzeigt für was Intel die CPU eigentlich in normal Takt freigegeben hat. Mit dem Desktop Sidebar Gadget Intel Core Series oder mit AIDA64 wird mir die reale Übertaktung angezeigt.
1. Ja. nach dem und vor dem Update auch, habe ich ein Reset gemacht.
2. da die Sache mich genervt hat(mit falsche CPU Takt Anzeige):fire: habe ich erstmal zum 1.90a updated - auch falsche CPU Takt Windows Anzeige, danach zum 1.70 updated und seit dem leuft alles so wie es sein muss. Mit 1.60 war auch alles ok außer double Start. Habe mit Einstellungen alles rumprobiert wie hier im Forum zu lesen ist, hat mir nicht geholfen. Nun leuft es mit 1.70 Bios alles gut(Einstellungen sind gleich wie vorher) und kein double Start mehr:fresse2:.
jungs, ich hab nen prob. ich benutze gerade bios 1.90a, und komme nicht wirklich über multi 35, woran kann das liegen ?
Warum hast du das 1.90A rauf gemacht? Ist doch nur für User mit Problemen des Spulenpfeifen. Und außerdem ist es eine Beta Version.
Ansonsten wie sind deine Einstellungen in UEFI?
War OC mit UEFI Version 1,80 OK?
mit 1.90A konnte ich auch nicht 4,2GhZ prima stable bekommen. mit 1.7 Bios kann bis 4,9 ocen., alles stable.
