[Sammelthread] ASRocks Fatal1ty P67 Professional
image.php
[/url]http://[/IMG]
  1. ASRock > Produkte > Fatal1ty P67 Professional
    *] Preise und Verfügbarkeit
    ASRock Fatal1ty P67 Professional, P67 (B3) (dual PC3-10667U DDR3) | Geizhals.at Deutschland
    ASRock Fatal1ty P67 Professional Sockel 1155 Mainboard: Mainboard Preisvergleich - Preise bei idealo.de
  2. Spezifikationen
    Sockel
    1155 Sandy Bridge​
    Prozessor
    Intel® Core™ i7-2600K/2600​
    Intel® Core™ i5-2300-2500/2500K​
    Intel® Core™i3-2100-2120​
    Chipsatz
    Intel® P67 Express​
    Steckplätze
    2x PCI 32 Bit Steckplätze
    32 Bit 5 Volt 33 Mhz
    2x PCIe 2.0 x1
    3x PCIe 2.0 x16 /1x16 oder 2 x8/x8 ; PCIE5: x4​
    BIOS
    64Mb AMI UEFI Legal BIOS with GUI support
    - Supports "Plug and Play"
    - ACPI 1.1 Compliance Wake Up Events
    - Supports jumperfree
    - SMBIOS 2.3.1 Support
    - DRAM, PCH, CPU PLL, VTT, VCCSA Voltage Multi-adjustment
    Arbeitsspeicher
    Dual Channel DDR3 memory technology
    4 x DDR3 DIMM slots Max. 32GB
    Supports DDR3 2133(OC)/1866(OC)/1600/1333/1066 non-ECC, un-buffered memory​
    Supports Intel® Extreme Memory Profile (XMP)​
    Audio
    7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
    - Premium Blu-ray audio support
    - Supports THX TruStudio PRO™​
    LAN
    - PCIE x1 Gigabit LAN 10/100/1000 Mb/s
    - Realtek RTL8111E
    - Supports Wake-On-LAN
    - Supports LAN Cable Detection
    - Supports Energy Efficient Ethernet 802.3az
    - Supports Dual LAN with Teaming function​
    SATA3
    2 x SATA3 6.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and "Hot Plug" functions
    - 4 x SATA3 6.0 Gb/s connectors by Marvell SE9120, support NCQ, AHCI and "Hot Plug" functions (SATA3_M4 connector is shared with eSATA3 port)​
    USB 3.0
    - 4 x Rear USB 3.0 ports by Etron EJ168A, support USB 1.0/2.0/3.0 up to 5Gb/s
    - 1 x Front USB 3.0 header (supports 2 USB 3.0 ports) by Etron EJ168A, supports USB 1.0/2.0/3.0 up to 5Gb/s
    - 4 x SATA2 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and Hot Plug functions​
    Anschlüsse Board
    - 6 x SATA3 6.0 Gb/s connectors
    - 1 x ATA133 IDE connector (supports 2 x IDE devices)
    - 1 x Floppy connector
    - 1 x IR header
    - 1 x COM port header
    - 1 x HDMI_SPDIF header
    - 1 x IEEE 1394 header
    - 1 x Power LED header
    - CPU/Chassis/Power FAN connector
    - 24 pin ATX power connector
    - 8 pin 12V power connector
    - CD in header
    - Front panel audio connector
    - 4 x USB 2.0 headers (support 8 USB 2.0 ports)
    - 1 x USB 3.0 header (supports 2 USB 3.0 ports)
    - 1 x Dr. Debug with LED​
    Anschlüsse ATX-Blende
    - 1 x PS/2 Mouse Port
    - 1 x PS/2 Keyboard Port
    - 1 x Coaxial SPDIF Out Port
    - 1 x Optical SPDIF Out Port
    - 3 x Ready-to-Use USB 2.0 Ports
    - 1 x Fatal1ty Mouse Port (USB 2.0)
    - 1 x eSATA3 Connector
    - 4 x Ready-to-Use USB 3.0 Ports
    - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
    - 1 x IEEE 1394 Port
    - 1 x Clear CMOS Switch with LED
    - HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone​
    Mitgeliefertes Zubehör
    1 x SLI_Bridge
    1 x Drivers and Utilities CD
    1 x Front USB 3.0 Panel mit Aufnahme für 1.SSD !!
    1 x Rear USB 3.0 Bracket , einfach nur umschrauben !
    1 x Floppy/ATA 133 Kabel
    6 x SATA Data Kabel
    2 x SATA 1 to 1 Powerkabel​
  3. Bilder uneingebaut und eingebaut
  4. Bilder Bios Übersicht
  5. Bilder Bios OC Tweaker und Advanced
  6. RAM Liste
    ASRock > Produkte > Fatal1ty P67 Professional > Speicher Support Liste
  7. Getesteter Ram
    Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) | Geizhals.at Deutschland
    G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL)
    Corsair XMS3 DIMM Kit 8GB PC3-16000U CL9-10-9-27 (DDR3-2000) (CMX8GX3M2A2000C9)
    Corsair XMS3 Dominator GT DIMM Kit 4GB PC3-16000U CL8-9-8-24 (DDR3-2000) (CMT4GX3M2A2000C8)
    G.Skill ECO DIMM Kit 4GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-4GBECO)
  8. Download BIOS + Treiber
    ASRock > Produkte > Fatal1ty P67 Professional > Download
    Rest kommt nocht
    MfG
Ich würd entweder einfach auf gut Glück kaufen,
oder den Asrockservice anschreiben.
Suchs dir aus.
ImMo bin ich absolut unsicher, welches Board ich nehmen soll.
Bin etwas in die falsche Richtung gerutscht. Die Boards haben einen Floppyanschluß das habe ich verwechselt mit IDE. Somit kann ich meine IDE-Laufwerke auch nicht verwenden beim Wechsel zu Intel.
@Gohrbi der Ram wird schu laufen, keene angst;)und ja das brett hat auch einen IDE anschluß, also kannst dein altes IDE-Laufwerk weiterverwenden:wink:
Danke für den Zaunspfahl... :banana:
Habe gerade nocheinmal in einem Test - Fazit geschaut.....da steht IDE UND Floppy.:asthanos:
Na dann muß nur noch meine Haushaltsgeldvernichtungmaschine der Investition zustimmen. Hab mich schon durchgerungen den 2600k zu nehmen. Wenn schon denn schon:bigok:
Machste richtig;)wirst net entäuscht sein von dem Brett:)Beim Ram einfach die Timings, vdim und den Ram-Teiler manuell im UEFI einstellen und glücklich werden:wink:
@Gohrbi
schau mal ganz frisch aus der AsRock Schmiede, dass Z68 Fatal1ty Mainboard !
ASRock Fatal1ty Z68 Professional Gen3, Z68 (dual PC3-10667U DDR3) | Geizhals.at Deutschland
Ich hab auch vor mir das zu kaufen, wird mein P67 Extreme4 ersetzen.
Ohhh Hilfe mir wird schwindelig:fresse::fresse::fresse:
Ein stolzer Preis, oh je, aaaber bestimmt gut.:asthanos: Na gut ....."nur" 40.- Euronen mehr. Da muß ich mal ne Woche die Schokolade weg lassen.
Muß mal sehen, ob ich alles davon nutzen kann, sonst wäre es zu teuer. Nur weils geil aussieht......
EDIT
Ich glaube das Z68 übersteigt meine Hardwareansprüche. Aber es ist ja noch was hin, bis ich kaufe.
Hatte ASRock Support gestern wegen der Maße der NB Kühler angeschrieben und Paßform mit meinem CM V8.
Heute Antwort mit Bild und Text bekommen.
Gleich noch wegen der G.Skill nachgefragt und nach 1 Stunde Antwort für den Einbau.
Ich muß sagen, super Service:bigok:
AsRock hat einen Super Service, wenn man da mal an die ehemalige Konzernmutter denkt was die schon immer für einen bescheidenen Service haben.
Ausserdem habe und hatte ich bis jetzt bei allen 4 AsRock Mainboards die ich hatte null Probleme, die sind immer auf Anhieb gelaufen und Spacken nicht im geringsten rum.
Das Board wird bestimmt in ein paar Wochen preislich so um die 200 Euro sein, bis dahin wird es hoffentlich schon ein paar Reviews geben.
Bin schon in der heißen Phase mir das Board mit 2600k zu kaufen.
ImMo zweifle ich am Ram
RipJaws DIMM Kit 4GB PC3-12800U CL7-8-7-24 (DDR3-1600) (F3-12800CL7D-4GBRM)
Habe bei ASRock nachgeschaut, die stehn nicht drin bei kompatibel Rams.
Trotzdem probieren?
der ram wird dir keine vorteile bringen nimm den hier günstiger
und besser wird der preis kaum .:)
TeamGroup Elite DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (TED38192M1333HC9DC) | Geizhals.at Deutschland
MfG
ASRock hat mir geantwortet, dass es wohl keine Probs mit dem Speicher geben wird. Eventuell sollte ich die Spannung von "Auto" auf 1,6V stellen.
Die Rams sind nämlich noch nicht alt.
Ich hab mir jetzt mal das Z68 Gen 3 bestellt, bin mal auf den Unterschied zum P67 gespannt, soweit einer feststellbar ist. Wenn keiner da sein sollte, bin ich aber auf jeden Fall schonmal Ivy gerüstet. :d
So, 2600k und ASRock Fatal1ty P67 Performance bestellt.
Das wird ne heiße Woche werden. Baue ich nun alles zusammen und mache mit HDD Erase die C platt für Neuinstallation? Erst Treiber DVD starten und dann Win7 oder wie?
Wenn dann erst Win 7. Wenn Du mehrere HDDs dranhängen haben solltest, klemm am Besten alle, bis auf die Systemplatte ab. Bei mir wars so, dass ich sonst Win nicht installieren konnte. Achja, nicht auf meine Sig achten, ich hab das AsRock drin, ich bin nur zu 90% mit dem iPad unterwegs und vergess immer das zu ändern, wenn ich mal am PC sitz.
Ist bei dem Board noch eine Lüftersteuerung dabei? Habe da was gehört, aber bei ASRock finde ich nichts zu dem Thema?
So der 2600k und das ASRockboard rocken im PC. Umbau ohne Probleme geschafft.
UEFI versuche ich gerade zu raffen.
Der Spaß ist der, alles eingebaut, gestartet..Treiber geladen und alles läuft.
Ohne neuinstallieren von Win7 und anderen Programmen.
Wo kann ich die Einblendzeit des UEFI verkürzen?? Da muß ich ne halbe Minute warten, bis es weitergeht.
Editwenn ich den IDE (DVDs) abklemme gehts nach 5 sec. Betrifft den Brenner, warum auch immer.
Frage von mir, passen Thermalright Silver Arrow und/oder Noctua NH-D14 ohne größere Probleme oder versperren sie den ersten Slot oder stoßen am RAM oder sonst wo an?
Und welchen würdet ihr bevorzugen von den Beiden?
Also bei mir passt der NH-D14 ohne zu mucken aufs Brett, wenn er aber nach hinten zum Gehäuselüfter montiert ist dann ist der erste slot geschichte, wenn man den Kühler dreht also nach oben blasend dann müsste der erste slot noch benutzbar sein.Und mit ram hatt ich auch keine probleme denn der erste Lüfter ist ja ein 120iger und den kann man auch noch bissl am Kühler verschieben wenn der Ram etwas höher sein sollte;)Ich denk mal die zwei nehmen sich groß nix nur beim Silver Arrow hast halt 2x140mm Lüfter dabei(NH-D14 1x140mm/1x120mm Lüfter) und da könnt es schon wieder bissl eng werden beim ram zwecks platz.Sind beite top-Kühler, ich würde an deiner stelle den Promalitech Genesis nehmen, der kühlt auch spitze und du kannst noch den ersten slot benutzen und beim ram hast du auch noch genug platz:wink:
Ich war auch am überlegen eventuell nach oben blasend einzubauen, soll in einen Lian Li PC P50.
Hat jemand einen Tipp, gesucht ist ein Top Kühler, wenn möglich soll der erste Slot nicht unbrauchbar werden, und nach Möglichkeit nicht den Prolimatech Genesis.
Egal ob Tower oder Topblower
Habe mal zwei Fragen zu Einstellungen.
Hat sich erledigt wurden in AsRock Support Forum beantwortet.
Also ich hab die H70 von Corsair mit Artic Coolern aus dem Gehäuse, temps sind 29-46°, aber ich komme nach der nach neu installation auf SSD nicht über 5,9 weg,bei Vista x64 Ulti
