[Sammelthread] ASRocks Fatal1ty P67 Professional
image.php
[/url]http://[/IMG]
  1. ASRock > Produkte > Fatal1ty P67 Professional
    *] Preise und Verfügbarkeit
    ASRock Fatal1ty P67 Professional, P67 (B3) (dual PC3-10667U DDR3) | Geizhals.at Deutschland
    ASRock Fatal1ty P67 Professional Sockel 1155 Mainboard: Mainboard Preisvergleich - Preise bei idealo.de
  2. Spezifikationen
    Sockel
    1155 Sandy Bridge​
    Prozessor
    Intel® Core™ i7-2600K/2600​
    Intel® Core™ i5-2300-2500/2500K​
    Intel® Core™i3-2100-2120​
    Chipsatz
    Intel® P67 Express​
    Steckplätze
    2x PCI 32 Bit Steckplätze
    32 Bit 5 Volt 33 Mhz
    2x PCIe 2.0 x1
    3x PCIe 2.0 x16 /1x16 oder 2 x8/x8 ; PCIE5: x4​
    BIOS
    64Mb AMI UEFI Legal BIOS with GUI support
    - Supports "Plug and Play"
    - ACPI 1.1 Compliance Wake Up Events
    - Supports jumperfree
    - SMBIOS 2.3.1 Support
    - DRAM, PCH, CPU PLL, VTT, VCCSA Voltage Multi-adjustment
    Arbeitsspeicher
    Dual Channel DDR3 memory technology
    4 x DDR3 DIMM slots Max. 32GB
    Supports DDR3 2133(OC)/1866(OC)/1600/1333/1066 non-ECC, un-buffered memory​
    Supports Intel® Extreme Memory Profile (XMP)​
    Audio
    7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
    - Premium Blu-ray audio support
    - Supports THX TruStudio PRO™​
    LAN
    - PCIE x1 Gigabit LAN 10/100/1000 Mb/s
    - Realtek RTL8111E
    - Supports Wake-On-LAN
    - Supports LAN Cable Detection
    - Supports Energy Efficient Ethernet 802.3az
    - Supports Dual LAN with Teaming function​
    SATA3
    2 x SATA3 6.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and "Hot Plug" functions
    - 4 x SATA3 6.0 Gb/s connectors by Marvell SE9120, support NCQ, AHCI and "Hot Plug" functions (SATA3_M4 connector is shared with eSATA3 port)​
    USB 3.0
    - 4 x Rear USB 3.0 ports by Etron EJ168A, support USB 1.0/2.0/3.0 up to 5Gb/s
    - 1 x Front USB 3.0 header (supports 2 USB 3.0 ports) by Etron EJ168A, supports USB 1.0/2.0/3.0 up to 5Gb/s
    - 4 x SATA2 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and Hot Plug functions​
    Anschlüsse Board
    - 6 x SATA3 6.0 Gb/s connectors
    - 1 x ATA133 IDE connector (supports 2 x IDE devices)
    - 1 x Floppy connector
    - 1 x IR header
    - 1 x COM port header
    - 1 x HDMI_SPDIF header
    - 1 x IEEE 1394 header
    - 1 x Power LED header
    - CPU/Chassis/Power FAN connector
    - 24 pin ATX power connector
    - 8 pin 12V power connector
    - CD in header
    - Front panel audio connector
    - 4 x USB 2.0 headers (support 8 USB 2.0 ports)
    - 1 x USB 3.0 header (supports 2 USB 3.0 ports)
    - 1 x Dr. Debug with LED​
    Anschlüsse ATX-Blende
    - 1 x PS/2 Mouse Port
    - 1 x PS/2 Keyboard Port
    - 1 x Coaxial SPDIF Out Port
    - 1 x Optical SPDIF Out Port
    - 3 x Ready-to-Use USB 2.0 Ports
    - 1 x Fatal1ty Mouse Port (USB 2.0)
    - 1 x eSATA3 Connector
    - 4 x Ready-to-Use USB 3.0 Ports
    - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
    - 1 x IEEE 1394 Port
    - 1 x Clear CMOS Switch with LED
    - HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone​
    Mitgeliefertes Zubehör
    1 x SLI_Bridge
    1 x Drivers and Utilities CD
    1 x Front USB 3.0 Panel mit Aufnahme für 1.SSD !!
    1 x Rear USB 3.0 Bracket , einfach nur umschrauben !
    1 x Floppy/ATA 133 Kabel
    6 x SATA Data Kabel
    2 x SATA 1 to 1 Powerkabel​
  3. Bilder uneingebaut und eingebaut
  4. Bilder Bios Übersicht
  5. Bilder Bios OC Tweaker und Advanced
  6. RAM Liste
    ASRock > Produkte > Fatal1ty P67 Professional > Speicher Support Liste
  7. Getesteter Ram
    Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) | Geizhals.at Deutschland
    G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL)
    Corsair XMS3 DIMM Kit 8GB PC3-16000U CL9-10-9-27 (DDR3-2000) (CMX8GX3M2A2000C9)
    Corsair XMS3 Dominator GT DIMM Kit 4GB PC3-16000U CL8-9-8-24 (DDR3-2000) (CMT4GX3M2A2000C8)
    G.Skill ECO DIMM Kit 4GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-4GBECO)
  8. Download BIOS + Treiber
    ASRock > Produkte > Fatal1ty P67 Professional > Download
    Rest kommt nocht
    MfG
is älter wie 14 tage halt nur RMA aber ich werd das mit MF anbklären noch 2 ma dann gibts eh geld
ich habe meins wie immer bei mf gekauft gehabt und nach 30 tagen abgegeben.
Wird die ssd denn im bios angezeigt?
So beim letzten Neustart gibts wieder ein Ausrufezeichen im Geräte-Manager. :wall:
In welcher Version 2.12. Gibt es eine neue UEFI Version für das Mainboard?
Zur RAM-Kompatibilität füge ich mal auch noch was hinzu:
Corsair Vengeance rot DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMZ8GX3M2A1600C9R)
Auch 2 dieser Kits laufen wunderbar auf dem Fatal1ty P67 Pro.
so Leute, nach dem so viele von euch die Vengeance LP erfolgreich nutzen und anscheinend meine nicht so gelaufen sind wie sie sollten habe ich mir die noch mal zu Brust genommen.
Nach geschätzten 4-5std Tests stellte ich fest das nicht der RAM das Problem war sonder ein HUB für mein Drucker der an USB3.0 Port angeschlossen war :wall:
@MpsDriver wie sind denn so die Temps mit deiner Corsair H100 unter Last oder beim primeln?Würd mich echt mal interessieren:wink:
Ich hab 4 Lüfter auf H100. Die 2 Corsair Lüfter blasend und 2 BeQuiet SilentWings saugend. Das ergab folgende Temps. (Alle Gehäuselüfter auf Minimum, mindestens 2 Stunden Prime bei Custom Inplace)
Ich hab nicht die minimale Spannung ermittelt, bis 4,5Ghz gings bei mir mit Offset +0,005V und LLC auf Level5 (niedrigste Einstellung)
3,4Ghz 40 Grad
4,0Ghz 48 Grad
4,2Ghz 50 Grad
4,3Ghz 52 Grad
4,4Ghz 55 Grad
4,5Ghz 57 Grad
4,6Ghz 59 Grad
Weiter hab ich noch nicht gebencht. Die 4,6 Ghz waren aber über 3 Stunden stabil
Na bei 4,4Ghz komm ich auf 57grad mit dem NH-D14 bei prime x64 custom/Run FFT´s in place,(bei 5GHz waren es so um die 75,76grad)allerdings liefen da alle Lüffis@max.Bin da echt zufrieden damit, obwohl mich die H100 auch bissl reitzt aber für die paar grad weniger ist mir dann doch der preis zu hoch;)
Naja, den Preis find ich schon okay und man kann ein paar Grad weniger als Lukü haben - bei weniger Lautstärke. Der Einbau passt halt nur in wenigen Gehäusen...
Seit dem ich das Asus Genee-z habe, muss ich schon sagen, das dass OC mit dem Asrock besser war. Was die Spannungen angeht, ist da der Asus stabiler, aber mit dem Asrock brauchte ich weniger spannungen. Das nur mal so nebenbei.
Denke das Asus gerade bei höherer Ghz etwas stabiler ist als Asrock. Das ist auch meist der Grund warum die OC Freaks mehr Asus verwenden als Asrock. Ich finds aber klasse das Asrock den Absprung von Asus geschaft haben und tolle Boards bauen :wink:
Ja, toll ist. Nur bei genauer Betracht ist das rote auch nicht wirklich das wahre rot. Das war auch ein Grund, warum ich mir dann das asus genommen habe.
Bleib jetzt bei meinem. Soviel OC habe ich nicht nötig, nicht fürs erste.
5ghz sind zwar im bios gespeichert, im enddeffekt ist es mir dann auch wurscht, ob er 1,368v braucht, oder 1,384 mit dem gene-z.
War sowieso übergangs cpu bis der ivy rauskommt.
Hm, ich versuche mich grad ein bischen an meinem neuen Board. Bekomme aber auf Biegen und Brechen meinen Speicher nicht mit als DDR1600 zum laufen. Dann bootet der Rechner nicht mehr und das Board bleibt mit Fehlercode 45 stehen. Die XMP settings meines Speichers sind ja sogar 1600er und werden vom Bios auch korrekt ausgelesen, nur laufen tun sie dann nicht als 1600er. Fehler vom Board oder was kann das sein?
Speicher ist der hier.
Steht der RAM den auf der Liste von asrock? Weil Fehler 45 könnte wirklich RAM sein.
Der Speicher steht auf der Liste vom Asrock mit bei, jedoch steht er dort als F3-12800CL7D und meine sind F3-12800CL7Q. Keine Ahnung ob das was zu sagen hat...
*edit* Die Buchstaben sind lediglich die Kits, D = 2 Riegel und Q = 4 Riegel.
Joa, vollbestückung. Mit zwei herausnehmen könnte ich testen, stehen aber auf der Asrock liste ebenfalls in Vollbestückung drin :(
ausprobieren, vllt hat einer einen weg oder ein slot will nicht richtig. Kannst auch mal ein paar pics vom Bios machen. Einfach ins Bios und F12 drücken ;)
Na die einzelnen Slots testen kann ja was werden. Jedesmal den CPU Kühler wegbauen :x
nimm erst mal zwei raus so das die anderen im dual laufen. Wenn die laufen einen dazu stecken und schauen was passiert.
Oh ich hab das Problem entdeckt und gelöst :)
Die XMP Settings meines Speichers sind @1.35V. Intel gibt aber mindestens 1.425V bis maximal 1.575V vor. Hab nun mal die XMP Settings im Bios ausgewählt und siehe da er dreht dem Speicher auch den Saft auf 1.35V runter. Habs dann auf runde 1.5V gestellt und es rennt wunderbar.
Trotzdem danke für deine Bemühungen.
MfG
Abend..
Würde gerne wissen wie man die OC frei schaltet bzw wo man es einstellen kann. Ich finde die Einstellungen für Turbo nicht.
Bei mir zeigt er die Einstellung Load Optimized CPU OC setting nicht an..
Poste doch mal deine UEFI Bilder
