[Sammelthread] ASRocks Fatal1ty P67 Professional
image.php
[/url]http://[/IMG]
  1. ASRock > Produkte > Fatal1ty P67 Professional
    *] Preise und Verfügbarkeit
    ASRock Fatal1ty P67 Professional, P67 (B3) (dual PC3-10667U DDR3) | Geizhals.at Deutschland
    ASRock Fatal1ty P67 Professional Sockel 1155 Mainboard: Mainboard Preisvergleich - Preise bei idealo.de
  2. Spezifikationen
    Sockel
    1155 Sandy Bridge​
    Prozessor
    Intel® Core™ i7-2600K/2600​
    Intel® Core™ i5-2300-2500/2500K​
    Intel® Core™i3-2100-2120​
    Chipsatz
    Intel® P67 Express​
    Steckplätze
    2x PCI 32 Bit Steckplätze
    32 Bit 5 Volt 33 Mhz
    2x PCIe 2.0 x1
    3x PCIe 2.0 x16 /1x16 oder 2 x8/x8 ; PCIE5: x4​
    BIOS
    64Mb AMI UEFI Legal BIOS with GUI support
    - Supports "Plug and Play"
    - ACPI 1.1 Compliance Wake Up Events
    - Supports jumperfree
    - SMBIOS 2.3.1 Support
    - DRAM, PCH, CPU PLL, VTT, VCCSA Voltage Multi-adjustment
    Arbeitsspeicher
    Dual Channel DDR3 memory technology
    4 x DDR3 DIMM slots Max. 32GB
    Supports DDR3 2133(OC)/1866(OC)/1600/1333/1066 non-ECC, un-buffered memory​
    Supports Intel® Extreme Memory Profile (XMP)​
    Audio
    7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
    - Premium Blu-ray audio support
    - Supports THX TruStudio PRO™​
    LAN
    - PCIE x1 Gigabit LAN 10/100/1000 Mb/s
    - Realtek RTL8111E
    - Supports Wake-On-LAN
    - Supports LAN Cable Detection
    - Supports Energy Efficient Ethernet 802.3az
    - Supports Dual LAN with Teaming function​
    SATA3
    2 x SATA3 6.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and "Hot Plug" functions
    - 4 x SATA3 6.0 Gb/s connectors by Marvell SE9120, support NCQ, AHCI and "Hot Plug" functions (SATA3_M4 connector is shared with eSATA3 port)​
    USB 3.0
    - 4 x Rear USB 3.0 ports by Etron EJ168A, support USB 1.0/2.0/3.0 up to 5Gb/s
    - 1 x Front USB 3.0 header (supports 2 USB 3.0 ports) by Etron EJ168A, supports USB 1.0/2.0/3.0 up to 5Gb/s
    - 4 x SATA2 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and Hot Plug functions​
    Anschlüsse Board
    - 6 x SATA3 6.0 Gb/s connectors
    - 1 x ATA133 IDE connector (supports 2 x IDE devices)
    - 1 x Floppy connector
    - 1 x IR header
    - 1 x COM port header
    - 1 x HDMI_SPDIF header
    - 1 x IEEE 1394 header
    - 1 x Power LED header
    - CPU/Chassis/Power FAN connector
    - 24 pin ATX power connector
    - 8 pin 12V power connector
    - CD in header
    - Front panel audio connector
    - 4 x USB 2.0 headers (support 8 USB 2.0 ports)
    - 1 x USB 3.0 header (supports 2 USB 3.0 ports)
    - 1 x Dr. Debug with LED​
    Anschlüsse ATX-Blende
    - 1 x PS/2 Mouse Port
    - 1 x PS/2 Keyboard Port
    - 1 x Coaxial SPDIF Out Port
    - 1 x Optical SPDIF Out Port
    - 3 x Ready-to-Use USB 2.0 Ports
    - 1 x Fatal1ty Mouse Port (USB 2.0)
    - 1 x eSATA3 Connector
    - 4 x Ready-to-Use USB 3.0 Ports
    - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
    - 1 x IEEE 1394 Port
    - 1 x Clear CMOS Switch with LED
    - HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone​
    Mitgeliefertes Zubehör
    1 x SLI_Bridge
    1 x Drivers and Utilities CD
    1 x Front USB 3.0 Panel mit Aufnahme für 1.SSD !!
    1 x Rear USB 3.0 Bracket , einfach nur umschrauben !
    1 x Floppy/ATA 133 Kabel
    6 x SATA Data Kabel
    2 x SATA 1 to 1 Powerkabel​
  3. Bilder uneingebaut und eingebaut
  4. Bilder Bios Übersicht
  5. Bilder Bios OC Tweaker und Advanced
  6. RAM Liste
    ASRock > Produkte > Fatal1ty P67 Professional > Speicher Support Liste
  7. Getesteter Ram
    Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) | Geizhals.at Deutschland
    G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL)
    Corsair XMS3 DIMM Kit 8GB PC3-16000U CL9-10-9-27 (DDR3-2000) (CMX8GX3M2A2000C9)
    Corsair XMS3 Dominator GT DIMM Kit 4GB PC3-16000U CL8-9-8-24 (DDR3-2000) (CMT4GX3M2A2000C8)
    G.Skill ECO DIMM Kit 4GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-4GBECO)
  8. Download BIOS + Treiber
    ASRock > Produkte > Fatal1ty P67 Professional > Download
    Rest kommt nocht
    MfG
wenn alles default, dann hats mit der cpu nichts zu tun.
Kannst ja mal memtest laufen lassen. Vielleicht liegts am speicher, aber nicht an der cpu ;).
@MrDick, hi du hast im UEFI beim "Storage Configuration" eine Option "SATA Aggresive Power Link Mode" stell das mal bitte auf "Disabled" und schau ob Deine Probleme noch bestehen. :wink: mfg omni
@omniman
Danke für den Tipp. Soweit ich weiß ist das Enabled. Ich werde es mal ausschalten und dann wieder berichten.
@djnoob
Speicher wurde schon getauscht, the same ...
Also das mit dem SATA Aggresive Power Link Mode hat nicht die gewünschte Besserung gebracht. Ich hab das Board jetzt eingepackt und schicke es zurück. Das Asus Board läuft seit heute Vormittag ohne Beanstandungen absolut stabil bei gleicher Konfiguration. Nur das Ruckeln der Maus tritt auch dort auf. Es liegt aber wohl an meinen USB-Funkmäusen, denn mit einer schnurgebundenen USB-Maus habe ich keine Ruckler.
Bleibt feszuhalten: Mit Asus-Board keine Bluescreens mehr, Programme starten problemlos (obwohl Win7 nicht mehr neu installiert wurde) und Firefox hängt nicht mehr. Lag wohl wirklich am Mainboard.
nein alles rumprobiert immer andere einstellungen andauernt freezes ohne bluescreen festplatten werden nicht erkannt usw usw ist wohl ne asrock krankheit mehrere cpus/rams netzteile immer das gleiche
mit einfach rumprobieren ist das immer so ne sache. Hast du den mal alles auf Stock laufen lassen?
stock oc underclock alles gemacht
festplatten gehen nur unter ide bei ahci sofort blauen
hab nun schon das 2te von MF und immernoch das gleiche -.-
Habe jetzt nur ne SSD dran aber das die nicht erkannt werden ist schon komisch. Meine Vertex2 hat mir zb. Probleme bereitet obwohl sie nur als schnelle DatenHD gedient hat. Jetzt ist sie seit ner Woche defekt und alles läuft ohne mucken. AHCI war eigentlich nie ein Problem. Welche Anschlüsse hast du für die HD verwendet?
Also die oberen SATA Ports. Hast du mal umgesteckt oder andere Kabel probiert? Die neusten Treiber drauf?
immer die neuesten treiber neuestes bios nix hilft nach öfterem cmos clear gehts 1 boot lang danach wieder nicht aber ich habe auch keine lust mehr rumzuprobieren oder umstecken ich wechsel bei der nächsten gelegenheit weil kb das der pc alle 30 min neugestartet werden muss -.-
Als meine Vertex2 einen weg hatte brauchte der PC ne halbe Ewigkeit zum booten mit der Crusial 4M. Vertex abgeklemmt und alles lief wieder.
ja nur das kann nicht sein kauf ich mir ne boot ssd dann kann ich die nichmals verwenden xD
Also ich muss auch sagen, dass das ASRock Board bei fast Vollbestückung schon ein paar Probleme macht. Hab inzwischen auch mein zweites Board und es läuft bei mir inzwischen alles soweit, aber es gibt immer mal wieder Hänger oder es taucht ein unbekanntes Gerät im Geräte-Manager auf. Mal abwarten ob die Bluescreens irgendwann auch wieder auftauchen.
Ich habe 4x4GB DDR3 RAM drin, eine GTX560Ti, eine Creative X-Fi Titanium (im unteren PCIe Steckplatz) und eine TeVii TV-Karte im darüberliegenden PCI-Steckplatz. Das Problem mit den ruckelnden Funkmäusen (2x Microsoft und 1x Logitech probiert) hat sich jetzt geklärt: Schuld war das Aluminium-Mauspad von Lian Li !!!
ich hab sogar nur 2 riegel gskill ram hatte schon corsair dominator vollbestückt und xms 3 einzelriegel macht alles kein unterschied
kannst du ja nicht sagen das das dann nicht klappt mit ner SSD. Ist nur komisch das du solche Probleme hast. Hatte vorher ja auch mal ne normale HD dran gehabt und das lief auch.
Selbst beim Kollegen der ein Asrock Z68 hat läuft alles. Vllt hast du wirklich richtig pech mit dem Board gehabt. Welches Asus soll es den werden ?
@Marcel, das ist natürlich net schön zu lesen das du solche probs mit dem Brett hast.Bei mir lüppt das Teil ohne mit der wimper zu zucken, kann mich echt net beschweren:)Du kannst ja auch nochmal ASrock ne chance geben und dir das Z68 Fatal1ty holen,ist um einiges billiger wie das Z-MIVE.Und die meisten haben damit auch keine probs laut bewertungen in den shops.Hast ja 14 tage rückgabe recht.
