[Sammelthread] ASRocks Fatal1ty P67 Professional
image.php
[/url]http://[/IMG]
  1. ASRock > Produkte > Fatal1ty P67 Professional
    *] Preise und Verfügbarkeit
    ASRock Fatal1ty P67 Professional, P67 (B3) (dual PC3-10667U DDR3) | Geizhals.at Deutschland
    ASRock Fatal1ty P67 Professional Sockel 1155 Mainboard: Mainboard Preisvergleich - Preise bei idealo.de
  2. Spezifikationen
    Sockel
    1155 Sandy Bridge​
    Prozessor
    Intel® Core™ i7-2600K/2600​
    Intel® Core™ i5-2300-2500/2500K​
    Intel® Core™i3-2100-2120​
    Chipsatz
    Intel® P67 Express​
    Steckplätze
    2x PCI 32 Bit Steckplätze
    32 Bit 5 Volt 33 Mhz
    2x PCIe 2.0 x1
    3x PCIe 2.0 x16 /1x16 oder 2 x8/x8 ; PCIE5: x4​
    BIOS
    64Mb AMI UEFI Legal BIOS with GUI support
    - Supports "Plug and Play"
    - ACPI 1.1 Compliance Wake Up Events
    - Supports jumperfree
    - SMBIOS 2.3.1 Support
    - DRAM, PCH, CPU PLL, VTT, VCCSA Voltage Multi-adjustment
    Arbeitsspeicher
    Dual Channel DDR3 memory technology
    4 x DDR3 DIMM slots Max. 32GB
    Supports DDR3 2133(OC)/1866(OC)/1600/1333/1066 non-ECC, un-buffered memory​
    Supports Intel® Extreme Memory Profile (XMP)​
    Audio
    7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
    - Premium Blu-ray audio support
    - Supports THX TruStudio PRO™​
    LAN
    - PCIE x1 Gigabit LAN 10/100/1000 Mb/s
    - Realtek RTL8111E
    - Supports Wake-On-LAN
    - Supports LAN Cable Detection
    - Supports Energy Efficient Ethernet 802.3az
    - Supports Dual LAN with Teaming function​
    SATA3
    2 x SATA3 6.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and "Hot Plug" functions
    - 4 x SATA3 6.0 Gb/s connectors by Marvell SE9120, support NCQ, AHCI and "Hot Plug" functions (SATA3_M4 connector is shared with eSATA3 port)​
    USB 3.0
    - 4 x Rear USB 3.0 ports by Etron EJ168A, support USB 1.0/2.0/3.0 up to 5Gb/s
    - 1 x Front USB 3.0 header (supports 2 USB 3.0 ports) by Etron EJ168A, supports USB 1.0/2.0/3.0 up to 5Gb/s
    - 4 x SATA2 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and Hot Plug functions​
    Anschlüsse Board
    - 6 x SATA3 6.0 Gb/s connectors
    - 1 x ATA133 IDE connector (supports 2 x IDE devices)
    - 1 x Floppy connector
    - 1 x IR header
    - 1 x COM port header
    - 1 x HDMI_SPDIF header
    - 1 x IEEE 1394 header
    - 1 x Power LED header
    - CPU/Chassis/Power FAN connector
    - 24 pin ATX power connector
    - 8 pin 12V power connector
    - CD in header
    - Front panel audio connector
    - 4 x USB 2.0 headers (support 8 USB 2.0 ports)
    - 1 x USB 3.0 header (supports 2 USB 3.0 ports)
    - 1 x Dr. Debug with LED​
    Anschlüsse ATX-Blende
    - 1 x PS/2 Mouse Port
    - 1 x PS/2 Keyboard Port
    - 1 x Coaxial SPDIF Out Port
    - 1 x Optical SPDIF Out Port
    - 3 x Ready-to-Use USB 2.0 Ports
    - 1 x Fatal1ty Mouse Port (USB 2.0)
    - 1 x eSATA3 Connector
    - 4 x Ready-to-Use USB 3.0 Ports
    - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
    - 1 x IEEE 1394 Port
    - 1 x Clear CMOS Switch with LED
    - HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone​
    Mitgeliefertes Zubehör
    1 x SLI_Bridge
    1 x Drivers and Utilities CD
    1 x Front USB 3.0 Panel mit Aufnahme für 1.SSD !!
    1 x Rear USB 3.0 Bracket , einfach nur umschrauben !
    1 x Floppy/ATA 133 Kabel
    6 x SATA Data Kabel
    2 x SATA 1 to 1 Powerkabel​
  3. Bilder uneingebaut und eingebaut
  4. Bilder Bios Übersicht
  5. Bilder Bios OC Tweaker und Advanced
  6. RAM Liste
    ASRock > Produkte > Fatal1ty P67 Professional > Speicher Support Liste
  7. Getesteter Ram
    Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) | Geizhals.at Deutschland
    G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL)
    Corsair XMS3 DIMM Kit 8GB PC3-16000U CL9-10-9-27 (DDR3-2000) (CMX8GX3M2A2000C9)
    Corsair XMS3 Dominator GT DIMM Kit 4GB PC3-16000U CL8-9-8-24 (DDR3-2000) (CMT4GX3M2A2000C8)
    G.Skill ECO DIMM Kit 4GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-4GBECO)
  8. Download BIOS + Treiber
    ASRock > Produkte > Fatal1ty P67 Professional > Download
    Rest kommt nocht
    MfG
Also macht das UEFI 3.21A Trim?
das 3.21a macht kein trim es ist nur bescheiden anzupassen da die "bios-Struktur" durch das eingebaute Fast Boot sich extrem geändert hat.
Wahrscheinlich dauert es noch eine zeit bis man an ein Satabios rankommt das aus einem Z-Board herraus ist dass bereits fast boot hat
Man kann auch mit CpuZ auslesen was man für ein Board hat.
Weil bei mir gibt es nicht den Aufkleber.
Aber laut CpuZ habe ich Rev. B3.
Und was bewirkt dieses fastboot ?
Geht das auch mit Win7?
Auf dem Board ist ein Aufkleber mit B3, dieser sitzt auf dem Maus/Tastaturanschluss.
Fastboot geht nur mit Win 8 da Win 7 kein UEFI unterstütz.
Wo wir schon beim Thema sind "Lord Wotan" stimmt deine Signatur eigentlich noch?
wenn ja dann geht bei dir eh kein Fastboot.
Gruß Marc
@ Dracal2002
Kann mich leider erst jetzt melden, da der Windows Phone 8 IE10 Bug in der Forensoftware immer noch nicht gefixt wurde.
So nun zum Thema
Das Windows 7 kein UEFI kann, stimmt so nicht. Windows 7 bootet sogar per UEFI Installation als GPT HD. Was stimmt ist das Windows 7 nichts mit denn Windows 8 Funktionen in UEFI 2.5 anfangen kann und damit nicht läuft. Also mit Fast Boot /Ultra Fast Boot und Secure Boot.
Zu deiner Frage, mein System kann Fast Boot mit meiner Hardware aus meinen Profil unter Windows 8.
Was nicht läuft ist Ultra Fast Boot.
In Modus Fast Boot wird in UEFI nämlich nur die Erkennung für USB abgeschaltet, bei ASRock, was zum schnelleren Booten führt.
Für Ultra Fast Boot bräuchte ich aber eine Grafikkarte, die eine GOB Firmware hat. Was ich zur Zeit nicht habe.
Somit läuft mein System per Fast Boot und Secure Boot 1A unter Windows 8 Pro!
Habe mir jetzt das neue Bios auch mal drauf gemacht und dazu gleich Windows 8 ^^.
Fast Boot geht aber bei mir auch kein Ultra Fast Boot.
Für Ultra Fast Boot braucht man eine Grafikkarte mit GOB Bios.
Und welche Grafikkarten haben so ein BIOS ?
@Dracal2002
hier gibt es eine Mod Version des UEFI 3.21A
http://forum.pctreiber.net/attachment.php?attachmentid=774&d=1371122656
Geändert würden
-Changed Splash screen to "Battlefield 4" wallpaper
-Updated Intel Option ROM to 12.7.0.1910
-Updated Intel EFI Raid "Satadriver" to 12.7.0.1910
-Updated Intel sVGA bios to v2158 *
-Updated Intel Lan PXE Bios to v1.5.13 *
-Updated Marvel FW to 1.0.0.1033
-Updated Realtek Lan FW to v2.55
-Updated CPU 306A9 (IvyBridge) microcode to Rev. 17 -
Ist vom diesen User
Informationen bzg. Windows 8 UEFI für ASRock P67 und Z68 Boards - Seite 16
Hast du es installiert ?
nee habe ich noch nicht.
Ich will nicht der erste sein :d
Ich auch nicht!;)
ist drauf.
Bei mir hat sich die Leseleistung verbessert aber schreiben wurde etwas schlechter und das BF4 sieht shit aus
Na gut.
Wenn das BF4 mies aussieht dann mach ich es nicht drauf.
Und danke für das testen.
Lass mir noch 2-3 tage zum testen damit ich die Garbage Collection etwas triezen kann.
PS Wotan seitem ich 3.21 drauf habe kann ich nicht mehr von CD Booten ist das bei dir auch so?
Ich würd sagen trim geht, aber ich muss zugeben das die Garbage meiner Vertex4 ziemlich gut ist, also kann ich es nicht mit sicherheit sagen
Hast recht mit der Modversion kann man die internen Optischen Laufwerke nicht zum Booten auswählen. (in Windows 8 sind die Laufwerke aber vorhanden, sowie in Intel Raid Controller Menü des UEFI. Nur in Boot Menü des UEFI sind die nicht vorhanden.) Da kann man dann nur CD/DVD über externes USB Booten. Mit der original Version gab es da keine Probleme. Ich schreibe denn papatsonis in AsRock-Forum mal am, damit er das fixt.
Noch was, so schlecht wie du sagst, sieht das Battlefield 4 Logo aber nicht aus.
Aber OK hier gibt es denn nicht gefixten Mod mit AsRock Logo.
http://forum.pctreiber.net/attachment.php?attachmentid=776&d=1371949195
-Updated Intel Option ROM to 12.7.0.1936
-Updated Intel EFI Raid "Satadriver" to 12.7.0.1936 (if you succeed to use it drop me pm)
-Updated Intel Lan PXE Bios to v1.5.35 *
* I've no idea why Asrock has these modules in this P67 m/b UEFI -
Bei mir kann ich mein DVD-Laufwerk anwählen im Boot Menü.
Oder was meint ihr ?
Habe das Mod Bios ohne BF4 Bild.
Hi Wotan ich hab einfach das Bios noch 2mal reset und seitdem sind die Laufwerke erkannt worden.
Das BF4 ist mir jetzt egal. ich hab das Logo einfach ausgeschalten was gut ist ich konnte mit dem Bios meine vCore um 0.03 senken und das find ich klasse
@Dracal2002
OK nach zwei mal resetten sind die Laufwerke da. Nach ein Neustart sind sie dann wieder weg!
---------- Post added at 21:57 ---------- Previous post was at 21:54 ----------
Du hast ja IDE DVD Laufwerke.
Ich habe SATA Blu Ray und DVD Laufwerk am Intel Controller.
Ahhh Ok.
Alles klar :d
Danke dir.
Gibt aber auch schon den hier: 12.8.0.1008 Beta
Bei mir hat sich gerade mein 1 Lan Adapter verabschiedet :eek:
Habe Windows neugestartet und auf einmal ging es nicht mehr.
Der Anschluss leuchtet auch nicht mehr.
Der 2 funktioniert einwandfrei.
Der 1 ist im Bios aktiviert.
Habe ja nichts verändert.
Edit: Geht wieder :d
Lag an Ubuntu was ich mal kurz getestet habe.
wollte gerade ne neue graka einbauen: ASUS ROG MATRIX-HD7970-P-3GD5 Platinum, Radeon HD 7970 GHz Edition, 3GB GDDR5, 2x DVI, 4x DisplayPort (90YV02P0-M0NA00) Preisvergleich | Geizhals Deutschland
gesagt... getan... rechner eingeschaltet... lüfter laufen -> aber kein bild
das mainboard zeigt mir den fehler 97 an.. die dazugehörige beschreibung sagt mir aber nichts (Console Output devices connect)
als netzteil benutze ich das hier: Enermax LibertyECO II 720W ATX 2.3 (ELT720AWT-ECO II) Preisvergleich | Geizhals EU
bios version ist noch 1.80 soweit ich weiß.. hat es evtl was damit zu tun, dass die graka pcie3.0 hat?
bin gerade etwas ratlos
