[Sammelthread] Assetto Corsa
Für die Gran Turismo Fans, neues AC Evo Update:
Assetto Corsa Evoluzione - Release 1.4
Was ist AC Evo ? Quasi AC Backend mit Gran Turismo Frontend also ein GT Karriere Modus Klon für AC ^^
Video der älteren 1.0 Version noch ohne Tuning usw. aber gut um zu sehen was genau AC Evo ist:
Tuning kam mit der v1.2:
Mächtiger Changelog zum Custom Shader Patch v0.2.3 preview211
https://gist.github.com/gro-ove/9c31ca2b8b5ba6e139cc510ae926e11a
Pure 0.270 - new features​
Zu den neuen shadern hat Peter aber auch noch was geschrieben:
Peter Boehse schrieb:
For now i recommend to use CSP 0.2 till CSP 0.2.3p1. And i think that is for the next months.
The new CSP version has a new feature called Linear Gamme Space (LCS). It will solve issues with AC rendering, BUT therefore the core shaders were reinvented. CSP now have 2 shader sets, the old shaders like CSP 0.2 - 0.2.3p1 and new shaders which support LCS.
The shaders are switched by activating/deactivating LCS in weatherFX settings. So actually it could be possible to run the old mode with Pure without problems.
Pure will not have LCS in the NEXT MONTHS. Pure must be rewritten from the ground, because everything is changed with the core shaders and currently i'm not sure if this is worth it.
It is the biggest change since the first release of CSP and it affects all parts of Pure in a very negative way. It will need a huge amount of time to fix all new problems with it.
So actually CSP without LCS should be compatible with Pure, but there are other changes in CSP which will influence it negatively.
So I ask for your understanding, that Pure is only compatible for CSP versions from 0.2 to 0.2.3p1 for a long time. If you discover any problems with the new CSP and Pure, please switch back to a supported CSP version and try again, before you report problems.
If you want to test LCS and its differences to the old shaders, please use the "default" weather style. You can switch LCS in weatherFX settings "Use linear color spcae fix". And please also switch back to Pure and make your own thoughts about what is more realistic...
Er wird das schon anpassen nur dauert es eben. LCS ist lange überfällig und wäre von vornherein eigentlich der bessere Weg gewesen. Aber ja ^^
Er schreibt doch ganz klar, dass er noch nicht weiß, ob es den Aufwand wert ist. Kann also gut sein, dass die Versionen jetzt auseinanderlaufen und nicht mehr zusammenpassen werden.
Nun, aktuell klingt das wieder anders :d
Hier mit drin der Part:
Neues CSP Update...
RSS hat wieder einen rausgehauen ^^
da bin ich ja mal gespannt drauf.
Habs in die Wunschliste gepackt insofern (y)
Den Bildern nach zu entnehmen ist die NOS mit dabei (wäre auch ein Aufschrei geworden wenn nicht...)
Guerilla Mods GT4 Update
Pure 1.4 New Features + LCS
Bin etwas verwirrt - AC Evo kommt ja bald - und es gibt einen Mod mit dem wohlklingenden Namen AC Evo?
Und dieser stellt eine Karriere / Spielbarkeit wie GT7 dar?
Die mod heißt Evoluzione, vermutlich angelehnt an competizione :)
Hab mal reingeschnuppert, wäre voll mein Ding, aber das Patreon Zeug ist doch schon wieder Käse.
Was muss ich denn nu bezahlen wenn ich das spielen will? :d
Kann man eigentlich in ACC die Meisterschaft auch unter seinen eigenen Namen fahren oder geht das nur im Karrieremodus ? Keine Lust als Rossi oder sonst so nen Heini zu fahren.
sehr cool , fährt jemand LFM hier ?
fahre seit 2021 ACC und AC seit 2014 .. puhh ist das lange her
LG
Bei 8:00 etwa spricht er vom SPS (single pass stereo Verfahren) und in der Tat das benötigt weniger Rechenleistung.
Diese Option gibt es zum Beispiel auch in den iRacing Grafikoptionen.
Aber nach meinem Verständnis ist das nur für ältere Headsets gut, die noch einen Bildschirm für beide Augen haben, und nicht für die meist neueren, bei denen jedes Auge seinen eigenen Bildschirm hat?
Da bei 2 Bildschirmen eine leichte Verschiebung beider Bildschirme durch die Bauart vorkommen kann, müsste das Stereobild ohne SPS besser sein als mit SPS.
(Bin das zur Zeit selbst am Testen mit der Q3, aber noch nicht ganz sicher, ob es nur ein Placeboeffekt ist).
>> https://iliaskapouranis.com/2020/07/13/is-single-pass-stereo-worth-it/
>> https://iliaskapouranis.com/2020/08...ng-depth-cues-discomfort-and-potential-risks/
"Update 17/9/2020: The newly announced Oculus Quest 2 by Facebook will not have any problems because it uses a single display for both eyes."
Und btw. was geht bei AC? Das sieht ja immer besser aus mit den Jahren, wenn das nur nicht so kompliziert wäre mit all den Launchern und Sachen.
Da schaut man sich 10min einen Guide an und fertig. aC hat so viele Spieler wie nie und 6x oder noch mehr wie zu Kunos Zeiten. Zeiten in denen 10 Versionen Tire Modell genau gar nicht brachten xD Naja zum Glück gibts Genie Ilja und Extended Physics. Dagegen sieht ein professionelles Dev Team aus Italien und was sie ablieferten ziemlich albern aus. :d
Du brauchst doch nur exakt einen einzigen. Und die Mods zu installieren schafft ein Luxx-User im Schlaf ;)
Ansonsten helfe ich dir gerne.
Ähnliche Themen
