[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
wat? 45grad? bissl warm das brett bei dir. meins kommt nie über 35, normal sind 28-32 bei mir
welche auslesesoftware ist am besten fürs board geeignet?
und wie bekomme ich zwei audiostreams gleichzeitig hin? der chip kanns 100%, aber es geht einfach nicht wegen dem beknackten creative branding ... *tischkantemitzähnenbekanntmacht* ...
@SmokeySkull
Im Idle habe ich
CPU: 38
NB: 52
SB: 45
MB: 36
nach ca 8std im Betrieb finde die Temps aber recht O.K. Unter Last geht die NB auf 61 hoch nach paar stunden Prime
ist das auch alles zu hoch deiner Meinung??
hmm 45grad. muss schauen aber ich glaub das ist echt etwas zu viel.
was meinst du mit audio 2 streams?
Sent from my HTC Hero using Tapatalk
die temps sind ok. ich gebe morgen abend meine durch. geduld ick lieg, jetzt im bett ;)
i denks mir send with htc hero ^^ nur keine eile darfst ruhig im bett liegen und morgen arbeiten gehen und am abend die temps durch geben....
ich finde das ist vollkommen okay, ist schließlich kein wachs.
vielleicht liegt der sensor nicht im luftstrom von der graka wie bei mir.
ich würde mir jedenfalls keine gedanken machen! ;)
zwei audiostreams gleichzeitig abspielen, einer ausm grünen rear-out, einer ausm grünen front-out.
das geht bei allen biligen realtek chipsätzen und beim VT2020 der auf dem board ist auch, konnte das ASRock schließlich auch. bei ASUS heißts auch "multi-streaming" in den specs, nur ne einstellung dazu finde ich ums verrecken nicht.
@Koranu: Deine Temps sind ok.
Wenn deine Grafikkarte im Ersten Slot sitzt wirds eben wärmer (SB,NB)
Hab ich selber Probiert.
Probier es mal wenn die Karte in 3-ten Slot sitzt (ist auch x16)
Dann sind SB und NB kälter.
Auf jeden Fall hab ich mal gelesen auf XS Forum das Asus meint NB kann bis 75 Grad vertragen ohne Probleme.
je nach Belüftung (Gehäuse) sind die Temps aber normal
Der erste Slot ist direkt unterhalb der CPU oder oberhalb der Taster (OC, Reset, usw.)?
Hab ein Lian-Li-Gehäuse und das Board sitzt quasi verkehrt rum im Gehäuse.
Ich mache mir aber über die MoBo-Temps keine Sorgen.
Blöd ist nur, das ich meine CPU-Fan auf den dafür vorgesehenen Pin geklemmt habe. SpeedFan kann das aber scheinbar nicht auslesen.
Hab ich im BIOS evtl. was vergessen zu aktivieren?
Weiss jemand rat?
Der erste ist unterhalb der CPU.
Auslesen kannst mit dem Asus Toll der Mitgeliefert wird oder mit Everest / aida64.
Bekommst alles gezeigt (Voltages,Temps,RPM der Lüfter)
Versuch mal die Neueste Version.
Also bei mir gings von Anfang an.
Oder eben das Asus Probe.
Da Siehst auch alles
also ich hab bei 20° raumtemp board 28, cpu 30, NB 41 und SB 34. is das dann ein kälteschock bei euch?
@Runlevl5 okay gut passt jo meine 4870 sitzt im ersten slot(hab sie auch mal im 3ten gehabt nur wurde dort mir die Graka defenitiv viel zu warm) und da diese kühler oben drauf hat strahlt die eh schon eine enorme Hitze aus hab gestern abend noch bissel mit K10STAT gespielt (hat jemand mal da nen wert für 1ghz die min. Vcore? bin da bei 0,7750v)und bin doch jetzt echt extrem zufrieden. Muss jetzt nur meine Platten günstig ruhig bekommen und dann ist echt alles richtig leise kühl und schnell wenns drauf ankommt!
@SmokeySkull mit was liest du die Temps aus? Ich mach das mit R.O.G. also RC TweakIt weiß nicht ob das auch richtig ausliest!?
Die hier geposteten Werte bezogen sich auf Last, nicht auf Idle und - zumindest für meinen Teil - auf LuKü ;)
Raum-Temp ist ungefähr gleich +/- 1 Grad
@SmokeySkull
Im Idle habe ich
CPU: 38
NB: 52
SB: 45
MB: 36
als da steht das er seine idle werte schreibt und wenn du meine sig anschaust, siehst du das ich auch komplett lukü hab
---------- Beitrag hinzugefügt um 13:05 ---------- Vorheriger Beitrag war um 13:01 ----------
mit everest bekomme ich nur MB AUX ausgelessen und die einzelnen core temps
mußt du dir das aktuellste ziehen...
Freilich habe ich das gelesen, da Du Dich aber nicht via Quote auf den entsprechenden User bezogen hast, habe ich mich spontan angesprochen gefühlt, da ich eine ähnliche Fragestellung hatte.
Des Weiteren würden mich deine Last-Temperaturen interessieren, rein zum Vergleich.
hab ich jetz grad nich im kopf aber kann ich gegen abend mal posten wenn zwerg im bett is
Jo, is ja net eilig. interessiert mich nur mal spaßhalber, weil gleiches Board, gleiche CPU und gleicher Kühler. ;)
Mein Gehäuse ist nun endlich da (Lancool PC-K62)
Die Temperaturen haben sich STARK verbessert.
Heute Abend gehts dann mal wieder an OC :fresse2:
hmm .. warum sehe ich im aida64 beta 1519 die NB und SB temps nicht?
und der vcore wert stimmt auch nicht.
ich teste atm mit VID 1,38125, VCore 1,416v, LLC an - 1,23v CPU-NB (VID 1.2, CPU-NV LLC an) und 1,2v NB spanunung bei 267*15= 4005 MHz ... bisher läufts im prime large.
was haltet ihr von den werten?
nöp ... ist nur ein 1075T mit 15er multi.
---------- Beitrag hinzugefügt um 18:12 ---------- Vorheriger Beitrag war um 18:07 ----------
aso .. das mit aida hat sich dann erledigt. die extreme engineer edischun zeigt nur müll an, mit der business edition rockt dat. :d
---------- Beitrag hinzugefügt um 18:17 ---------- Vorheriger Beitrag war um 18:07 ----------
und nochmal nen nachtrag:
der gelb markierte wert darf nicht aktiv sein, sonst zeigt aida solche werte wie in meinem ersten post an.
wo stellst du die vid ein?
die VID ist der wert den du im bios einstellst, die VCore ist die spannung die dabei real rauskommt.
ich bin dafür, dass man diese beiden werte etwas strikter trennt und auch nennt weil sie sich oftmals ein wenig voneinander unterscheiden. :)
na wenn du meinst. meine vid bleibt in everest immer gleich, egal welche spannung ich im bios einstell
