[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
aso. na da binsch ja ma gespannt. film is glei zu ende, da hau ich erstma alle treiber runter und probiers ma neu zu machen
na da bin ich ja mal gespannt. hab nun erstma alles runtergehaun und sys gesäubert
so, nun hab ich den 8700er treiber drauf aber null und nix zum irgendwas einstelln.... merde
sry schade was möchtest du genau einstellen x-Fi und co ?
jo, dieses creative gedöhns was man halt aus der taskleiste startet
irgendwas haut hier nich hin.... der installiert mir das ding nich, auch nich von cd.... ich geh erstma penn, hab grad kein bock mehr auf den scheiß.... trotzdem danke für eure hilfe
piskopat, es wäre nett wenn du die links zu den herstellertreibern postest und nicht zu deinen uploads - außer du hast die treiber in ner bestimmten weise gemodet wie ich den von nvidia.
... weiter oben habe ich direkt den DL link zum aktuellsten schon gepostet ... direkt von via ...
so, kein plan wie ichs nun letztendlich hinbekomm hab aber hab den 8700er nun drauf und das creative gedöns funzt auch. gn8@all
Moin Moin,
Mir ist gestern aufgefallen dass meine CPU im Idle nicht runtertaktet. Im BIOS ist C&Q ausgegraut.
Wisst ihr was ich falsch mache?
Sent from my iPhone using Hardwareluxx
"falsch" getaktet oder spannung per manual eingestellt und nich per offset
Jo, Vcore steht auf manuell, soll also auf Offset?
wäre von vorteil. auch wenn dann die spannung nich mehr so schön einzustellen geht wie auf manuell
Ja, muss ich mir nochmal anschauen, hatte von Anfang an auf manuell, ist halt sehr angenehm. Allerdings möchte ich auf C&C nicht verzichten.
So meine neue Ecos sind jetzt endlich da :love:
Nur die Subtimings ärgern mich ein wenig.
Kann mir mal einer seine Ramsettings posten?
Ich bekomm es gebootet auf 1600mhz aber nur 8-8-8-24.
Also glub ich das die Subtimings nicht ok sind.
Oder mal ne doofe frage: kann ich das XMP Profil laden? Und wo genau ist die Option?
Rams sind: F3-12800CL7D-4GBECO
Sind also die 1600mhz 7-8-7-24
Please poste mal einer die Subtimings davon
also die subs hab ich auf auto, hab se in den schwarzen slots, weil in den roten wolln se nich so wie ich will und hab se auf 1800 8-9-8-24 bei 1,5v
Na gut mir reicht es 1600. Also wenn dann werden sie Default laufen.
Hab sie auch in Roten aber wollen nicht so ganz.
Habs in Schwarzen nicht Probiert.
Hab jetzt was gefunden und Probier es grad:
7-8-7-24
Subs: 5-33-10-4-8-10-5-4-3-110-7,8-1T
Mal sehen.
Booten konte ich schonmal und Prime Läuft grad
nuja, bei mir hats halt mit den restlichen settings (cpu, cpu-nb) perfekt gepasst
Hey Leute,
kann es sein das wenn man 16GB Ram Klick! auf das Board verbaut, dass dann das System nicht mehr bootfähig ist?
Heute kam ein Kumpel zu mir mit genau dem Problem. Nachdem wir testweiße nur 4GB verbaut hatten bootete das System ganz normal.
Gruß Blah123
bei 16GB wirst warscheinlich viel CPU-NB Spannung benötigen ? Habt Ihr das probiert ?
Bei meinen 8GB bootete er ganz normal mit Standard Spannung aber stabil lief es nur mit 1,15V
Nabend...musste mein System zwangs neuinstallieren...welchen SSD Treiber sollte ich nehmen ? Von der Mobo CD kann man ja diesen jmicron Treiber installieren ?
Du benötigst für die SSD keinen Treiber, wenn dann für den Chipsatz ;)
Du meinst vllt. den RAID Treiber...ich würde bei einer SSD besser den aktuellen Chipsatztreiber von AMD nehmen, denn er unterstützt TRIM.
Moin moin Gemeinde.
Wollte mich mal kurz in diesem bereich anmelden...
Habe eben nen "Gebrauchtes" Formula bei Elle gekäuft und abgeholt.
Bin nun dabei - meinen Thermaltake Xaser 3 Tower vom Sockel A System zu befreien.
Da rein soll das
ASUS Crosshair 4 formular
CPU x4 965
2x 4 GB Team Group Elite
Sapphire Radeon HD5770 m 1GB DDR5 ( mit Heidi Kühler oder so)
Samsung HDD 1TB HD103SJ
LG DVD Brenner
BeQuiet 580 W
Vieleicht könnte ich ja mal in kürze so den ein oder anderen tipp von Euch gebrauchen.
hihi
Gruß Marco
