[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
nabend , bekomme das crosshair mit einen neu aufgesetzten win 7 64 bit nich anständig zum laufen
bei jeden Neustart schmiert er beim Logo ab
Wenn ich danach die Option Windowsstarthilfe benutze kommt ein Bluescreen mit dem fehlercode 0x000000A5, dann hilft nur die Reset Taste
Dann kann ich wieder Windows normal starten, jemand ne Idee was es sein könnte
Bios defaults geladen und nur nichtbenötigte Geräte entfernt
Hardware:
1090t
Samsung HD103SJ
WD6400AAKS
HD5850
4 Gb Ram
Hardware:
1090t
Samsung HD103SJ
WD6400AAKS
HD5850
4 Gb Ram
Hallo :wink:
schau mal bitte, wenn du dein Sys startest, ob alle Kontroll LEDs durchlaufen ( CPU, RAm, VGA, Boot Device ) oder ob es bei einer LED stehen bleibt.
MfG
auch wenn du den Bluescreen bekommst?
In welchen Slots stecken deine RAM- Riegel?
ja auch beim Bluescreen, ist alles auf grün
denke nich das es ein hardwareproblem ist
wenn ich im windows neustarten angeklickt habe, und beim POST resete kommt kein bluescreen
ram ist in den roten slots installiert
graka- defekt
---------- Beitrag hinzugefügt um 02:56 ---------- Vorheriger Beitrag war um 02:24 ----------
ich poste nur WIN 7 64Bit Treiber , wer was anderes nutzt selbst schuld.
Alles auf der AMD Seite (OPTIONAL DOWNLOADS)
http://sites.amd.com/us/game/downloads/Pages/integrated_win7-64.aspx#3
AMD SB 10.12:
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-12_vista_win7_32-64_sb.exe
AMD AHCI 10.12
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-12_win7_32-64_ahci.exe
AMD RAID 10.12 (nicht für SSD benutzen)
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-12_win7_32-64_raid.exe
Marvel Yukon 11.30.1.3 (88E8059)
Marvell: Download Drivers
finde auf der super schlechten seite von NEC den Treiber nicht. hab zwar die datei aber nicht von dort. vielleicht hat jemand eine seite mit akutellen Treibern den man vertrauen kann?
---------- Beitrag hinzugefügt um 02:59 ---------- Vorheriger Beitrag war um 02:24 ----------
hmm die links gehen, dann mal wieder nicht. scheiss amd links....
hi,
habt ihr LLC an oder aus?
Bin gerade bei 4,2 Ghz mit LLC an bei 1,51v.
Restliche Spannungen alle Auto.
Tawwa
PS: welche Programme kann man für die Messung der CPUtemp benutzen?
@Tawwa
Core Temp oder AIDA64
Kannst du mal etwas mehr über dein System preisgeben?
Mainboard, CPU, RAM ect.
oki doki
fuzzy
war zu voreilig, die 4,2 ghz sind nich stabil, bin jetzt bei 4,12 ghz bei 1,55 v mit llc an.
Das scheint zu laufen.
Wie würdet ihr die 4,2 ghz erreichen?` 21*200? 20*210 oder 19*221?
welche Spannungen sind noch wichtig und sollten nicht auf auto stehen?
System:
1090T Phenom X6
Asus Crosshair Formula IV
8 GB Kit Adata cl9
120 GB Extrememory SSD
1000 GB 7200 Umdrehungen/min Samsung
3 5850 3 Wege Crossfire
750 Watt Corsair
Tawwa
Ich denke dass du die 4,2 GHz garnicht stabil bekommst.
Egal ob du per Multi 19,20,21 oder den Bus Speed 200, 210 oder 221 wählst.
Womit kühlst du die CPU? Luft, Wasser o.a.?
Die 1,55 V als Core Voltage sind auf Dauer sicher auch nicht ^^gesund^^ für deine CPU. ;)
grEEtz
fuzzy
Meine 24/7 Settings mit 'nem 970 BE C3
1,5V ? :fresse:
Na, wenn Du LuKü haben solltest, wäre ich mal heiss auf Temperaturwerte :d
Ich brauch für 4 GHz unter Luft 1,380V.
Max-Temp liegt dann bei 61 Grad im Prime95, im Schnitt bei 55-56 Grad (gemessen mit NH-D14).
Das ganze hab ich mit nem 223 MHz-Referenztakt und nem 18er Multi.
NB-Takt liegt bei etwas über 3100 Mhz. Prime-Stable nach rund 8 Stunden CPU-Tortour.
Bei mir isses so, dass ich für stabile Werte jenseits der 4,1 GHz deutlich über 1,4V müsste, was die Temperatur weiter hoch treiben würde.
Aus meiner Sicht ist der Unterschied zwischen 4,0 und 4,1 GHz gar nicht mal so hoch. Dann lieber den NB-Takt pushen ;)
Habe jetzt 1,5 v und 4,11 ghz, im IDLE 28 °C, unter last so 55 rum.
Kühle mit einem Scythe Mugen Rev 2B.
gruß
Tawwa
lüfterspeed und raumtemp?
und vor allem: core-sensor oder cpu-sensor?
raumtemp so 24 grad, lüfterspeed denke ich mal maximum, habe da nichts verändert und ja messe mit coretemp.
gruß
tawwa
Core temp ist Blödsinn, weil nicht geeicht! CPU temp ist entscheidend!
Sent from my iPhone using Hardwareluxx
1.55v is zu viel ich würde nicht über 1.45v bei luft gehen.
Sent from my HTC Hero using Tapatalk
*rofl* ... bei last sind meine sensor-werte rund 20-25° höher als die core-werte, was bei dir im besten fall 75°c, im schlechtesten 80°c CPU-Temperatur bedeutet. :haha:
das der noch nicht verglüht ist ... :fresse:
Ja, ist bei mir auch so. Wenn man aber nicht weiß dass die Core Werte die falschen Werte sind, kann das schwer ins Auge gehen.
Coxon, schon was von deinem Board gehört?
nope. board ging letzte woche in die post, versichert versteht sich, und jetzt warte ich halt mal ab. :(
Hoi...ich fahre nun zum test 17x240...vorher hatte ich 16x250...aber vorher hat er sich zum Teil auf 800 oder 1000mhz runtergetaktet.
Was war denn dafür nochmal verantwortlich ?
warum soll da was verglühn, die schalten sich doch erst ab 110 °C ab, um Schaden zu vermeiden?
Tawwa
Na wenn das so ist...dann gib ihm doch 1,7V. Da kriegste auch 4,5V hin...hihi
Immer diese beratungsressistenten User
Vermutlich dann aber nur einmal. Die 4,5 GHz bei 1,7 Volt unter Luft meine ich jetzt. :coolblue:
Ja, ich verstehe es auch nicht. Wer nicht hören will MUSS fühlen. :shake:
grEEtz
fuzzy
Ja, sorry ;)
Ich find's halt "dumm", wenn man nicht vorher mal im Forum nachfragt.
Ich find auch nicht immer alle Infos im entsprechenden Sammelthread aber dann frag ich kurz vorher mal oder in diesem Fall: Ich bemüh mal die Google-Suche und schau mir die Max-Temp an. Die liegt bei 62 Grad. Wenn ich nun davon ausgehe, dass der Chip auch 110 Grad aushält, also fast 100% zusätzliche Abwärme verkraftet, dann ist den Leuten nicht mehr zu helfen.
P.S. Das "dumm" bezieht sich nicht auf die Person, sondern auf die Vorgehensweise ;)
