[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
Ist das nun ein Aprilscherz mit dem Treiber??
@Lonzo...
SB 850 Treiber sollen in Windows 7 integriert sein?...
das glaube ich nicht...Tim
@ Boomer147
Chipsatztreiber von 2010? die sind ja selbige die auf der beiliegenden CD sind...
Ich hatte ja nur die neuen von AMD gepostet gehabt...
die sind ja für den SB850.. eben vom Hersteller des Chipsatzes...
ob der sich mit denen von ASUS verträgt oder ob Asus hier daran etwas geändert hat, weiß ich ja nicht...
habe die selbst gerade installiert und alles gut...
er läuft noch genauso wie vorher....
Man macht ja auch die Grafiktreiber von Nvidia drauf , auch wenn die Karte von Zotac ist......
@all
So hab heute meine CPU bekommen...
Crosshair eingebaut
X6 1100T
mit Noctua NH -D14
CPU Temps (nicht übertaktet---kommt die Tage noch)
im Idle laut Aida
alle 6 Kerne 24-25 Grad Lüfter dreht auch nur 1251 RPM
NB 41 Grad
SB 35 Grad
unter Last
Kerne bei ca 36-38 Grad
EDIT
im silentmode...die obigen Werte unter Last...
den Noctua ohne diese Silent Verkabelung nur noch bei ca 32 Grad
na werde erst mal so testen und mich danach ans schrauben begeben...
Ich hab den Lüfter nicht gewechselt, Der PC sitzt in einem alten standard Case ohne Gehäuselüfter etc. sobald ich die Wand abnehme sinkt der Spaß auf 55°C und in diesem Zustand benche ich auch. Ich weiß eben nur noch nicht, ob lieber neues Gehäuse oder Neuen Kühler. Bei Ref. 300MHz arbeitet mein Sys. ein ganzes Stückchen schneller. vor allem Ram ist schnelller.
Du hast es an den Reaktionen sicher schon gemerkt: Du brauchst ein Gehäuse mit Lüftern. Wie ich schonmal vorher anmerkte kann selbst der beste Kühler nichts taugen wenn drumherum nichts läuft. Der CPU-Kühler fördert die Abwärme von der CPU weg, aber sie bleibt im Gehäuse wenn sie nicht hinaus geweht wird. Besorge Dir ein Gehäuse - muss gar nicht teuer sein - mit einem Lüfter vorne (min. 120mm) und einem hinten. Das langt in der Regel schon. Bei moderneren sitzt das Netzteil unten, hier kannst Du dann selbst wählen, ob das Netzteil die Luft von oben heraus hinaus befördert (unterstützt den Abwärmeabtransport der Grafikkarte) oder vom Gebäudeboden (Luftschlitze und Staubfilter am Boden vorausgesetzt) nach hinten raus. Wie man es am Besten macht ist eine Glaubensfrage. Ich persönliche sauge von oben von der Graka ab.
Ich wette mit Dir damit kannst Du Deine CPU-Temperatur um locker 20-30°C senken und dann kannst das Ding auch wieder ruhiger stellen und zwar ohne das Gehäuse offen zu haben. Bis Du so ein Gehäuse hast fahre Deine Einstellungen wieder auf Standard herunter. Du tust Dir damit ansonsten wirklich keinen Gefallen und ruinierst Deine Hardware!
Hm, gibt's Gehäuse die Empfehlenswert sind?
kannst Du denn nicht in dein jetziges Gehäuse vorne einen Lüfter der ansaugt und hinten einen der herausbläst einbauen?
wäre doch die preiswerteste Lösung...
Nein, leider nicht. :(
@CH4F
Mich würde mal interessieren wie warm deine NB wird?? (unter Last natürlich) Ohne ein kleines Lüften bei Dir im Case???
bis zu 54°C.
Nix gegen dich aber biste sicher Volllast Temps?? kann ich dir nicht glauben meine NB/SB/MB sind unter Volllast bei 60°C aber habe front/Heck und 2 cpu lüfter???
Bei mir im Leerlauf NB/SB/MB -> 37/33/26 Unter Last -> 54/45/32
Du hast ja auch WaKü. :P Ich hab grade eine Undervoltingaktion gestartet und nun läuft er bei 3300MHz und 1,16v unter Last ich brauch den V8 nicht mehr aufdrehen und es sind gut 47°C.
BTW -> Ich hab grade gemerkt der der V8 die Luft in Richtung DVD-Brenner jagt. Ich denke deswegen wird das alles so heiß.
Hallole:rolleyes:
sodele jetzt versuchste noch 3,6 GHz im undervolting Betrieb dann reicht die Power genauso und dein Proz wird nicht so heiß.
und mit der Kühlung was anderes Überlegen am besten ein neues Case.
das sollte eigentlich jeder schaffen.... und die kühlung mal ändern in richtung von vorn nach hinten oder von unten nach oben.
Den Lüfter werd ich wohl nicht heute umdrehen... In einer Woche gibt's ein neues Case.
Antec Dark Fleet DF-85
Wenn mans für 60€ neu Bekommt ein echtes Schnäppchen und hat USB 3.0 einmal vorne und ansonsten so ziemlich baugleich innerlich und hinten wie das Twelve Hundred. Dazu 7 regelbare Lüfter (5x120mm, Rote LED. 2x 140mm, Normal) Was will ich mehr für den Preis. Das alte Gehäuse bekommt ein Kumpel dann hat sich das für mich erledigt. :)
Btw -> Die 300MHz mehr oder weniger tuns nun auch nicht. :d
€dit -> Jetzt aber mal wieder back 2 Topic bitte. :d
Auch ein nettes Case. Bin mir aber nun nicht sicher, ob man beim CH4F einen USB3.0-Frontanschluss anbringen kann.
Hast Du meine PM gelesen?
USB 3.0 Vorne ist mir egal, es soll kalt halten. Ja, schau mal in deinem Posteingang nach. ;)
Mein Posteingang ist leer ;)
Das erklärt auch deine Antwort. :P
Hi!
Werde mir gleich eine SSD zulegen, weiß aber nicht genau, wie ich die jetzt am besten anschließe?
Habe auf 1 u. 2 meine DVD Brenner ohne ahci laufen und die HDD´s auf 2-6 mit ahci.
Sollte die SSD mit oder ohne AHCI laufen?
eine SSD sollte immer mit AHCI laufen...
mach es doch anderherum..
mache die optischen Laufwerke auf 5+6
und die HDDs auf 1-4.....
dann kannst Du auch die optischen ohne und die HDDs mit AHCI laufen lassen....
habe ich auch so gemacht...
auf 1 die SSD
auf 2 die Samsung 103 SJ
und auf 3 die WD15EARS
auf 5 den LG Brenner und auf 6 den Samsung Brenner....
funktioniert 1A
yo, thx. Dann habe ich meine HDD´s wohl auch auf 1-4 und das jetzt verwechselt;-)
Also SSD auf jeden Fall mit AHCI, das war was ich wissen wollte :-)
Ich hab´mal aufgeschnappt, daß man opt. Laufwerke nicht auf AHCI laufen lassen sollte.
Vielleicht irre ich mich da aber auch??
also ich hab festgestellt das die win install im ahci modus irgendwie schneller geht...
Werd ich gleich mal testen, muß jetzt erstmal in die Stadt mir ne SSD gönnen *freu*
Bei mir läuft alles im AHCI-Mode. Ich wüsste nicht warum ich auf IDE umstellen sollte.
