[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
Ich schätze den teuersten Bulldozer bis zu 150€ über dem 1100T.
Oder wird der neue Chef nun einen auf Intel machen, was die Preise angeht?
Wahrscheinlich eher nicht. Auf der Preisleistungsschiene fuhr man ja in der letzten Zeit eigentlich recht gut. Intelpreise würden sich wohl nicht so gut machen.
Ich mein ja nur. Vielleicht sieht die neue Leitung das ja anders. Unter "alter" Leitung wurden schließlich die anderen Modelle rausgebracht.
Hab gerade versucht das iRog App zum laufen zu bekommen. Jedoch geht werde AI Suite II zu installieren noch Mobilink.
Geht es doch nur für das Extreme?
MfG Fluck
iRog geht also doch nur per BT.
Kann ich mit meinem Iphone 4 leider nicht bestätigen. :hmm:
Habe es auf meinem Crosshair getsetet, weder USB noch BT funktionieren.
Auch Wlan weigert seinen Dienst über die IROG App fürs Iphone.
Da habe ich mich etwas auf der Seite von Asus informiert. Ist auch kein
Wunder. Denn die Iphone APPs funktionieren nur in Verbindung mit
der AI Suite II. Und dieser läuft nur auf einem einem Crosshair IV
Extreme. Das wird wohl an der komischen Marketingtaktik von Asus liegen.:motz:
Finde es echt schade das es selbst über USB nicht läuft, obwohl der CIV Formula extra einen IROG Hub hat. :shake:
MfG
komisch ist ja, das genau dieses Feature auch beim Formula aufgeführt ist.....
und zwar mit dem selben Text wie beim Extreme...
iROG
Intelligent multiple control at hand
The iROG is a special IC which enables several ROG highlitghted functions that gives users full disposal of the motherboard at any stage! This design allows advanced user control and management to be processed purely at a hardware level. iROG greatly increases fun during overclocking for PC enthusiasts and it offers system maintainence and management with more control and efficiency.
Jo leider aber nur ein ähnliches Feature wie das Steuern des Boardes über
einen externes Gerät. In unserem Fall ist nur mit einem anderen Computer
also auch ein Laptop mit gemeint und möglich.
Das ganze geht dann mit der Software von Asus: ROG Connect
Muß auf einen anderen Computer oder Notebook installiert werden. Dies
ermöglicht das externe Steuern des CIV Formula.
MfG
Rc Bluetooth ist aber beim Formula nicht dabei. Das lässt sich nich fernsteuern - Ist ja auch nicht die Extreme Variante.
ROG Connect geht beim Formula nur übern USB Stecker und auch nur mit anderen PC's und passender Software.
Genau So kann man das auch formulieren. Kurz und Knapp. ;)
Habe soeben gesehen das es wieder ein neues Bios für das Formula raus ist.
Beschreibung | Asus
Crosshair IV Formula 1902 BIOS (07.04.2011)
Support new CPUs
Hat es jemand schon druff und getstet? Und wo sind die Unterschiede zum Bios 3012
btw welcher ist empfehlenswerter?!
Schade das ROG IDirect App nicht mit dem Forumla funktioniert. Wäre wieder ne super spielerei für mich gewesen ;)
Also ich hab das neue Bios bereits geupdatet.
Aber ich hab das Board ja erst seit Samstag. Deswegen kann ich leider nicht all zuviel dazu sagen bzw. was die Unterschiede sind :d
Grüße
Genau, das ist es ja...
Wie CH4F und auch Watercoolio versucht haben , es zu klären...
Nennt mich blöd...oder "der begreift ehh nichts"...
aber mich verwirrt dies...
ROG Connect wird extra im Board-Überblick ,auf der Asusseite,aufgeführt...
und auch so beschrieben, wie es mir "CH4F" und "Watercoolio" es mir beibringen wollten...
das ist ja auch total logisch und richtig...
das habe ich auch so verstanden wie es unter "ROG-Connect" beschrieben steht....
ASUS sagt zusammenfassend
Aber es steht natürlich nichts von Blauzahn dabei...
was natürlich bei dem "Extreme" dabei steht...
und I-ROG bezieht sich nur auf die verschiedenen Möglichkeiten der Überwachung und Übertaktung....
also --hat der alte Mann die Features nicht in dem richtigen Context gebracht....
Halli Hallo,
vor ab erst mal "Sorry", wenn ich mit diesem Thread etwas falsch gemacht habe, bin neu hier.
Hier mal meine Rechnerdaten:
Asus Crosshair Formula IV
X6 1060T AMD CPU
8 GB XMS DDR3 1666
Seagate Baracude 1 TB
2 x MSI 5770 Hawk Crossfire ohne Übertaktung
1 Ext Festplatte via USB 500 GB
1 USB Hub (6fach)
Creative Soundsystem 2.1
be Quiet P9 850 W Plus 80
2x DVD-Brenner
Lüftersteuerung
Silverstone Raven 01 mit 4 Lüftern
System Windows 7 64 Bit
Mein Problem besteht darin, dass wenn ich das automatische OC-Programm starte (TurboV Evo) und es dann abgeschlossen ist, kommt ein achtbares Ergebnis von 6x 3700 Mhz dabei wird allerdings die Geschwindigkeit der des Rams auf 1566 herabgesetzt. Sowit nicht unbedingt dass problem. wenn ich aber dann längere ein Spiel zocke (leider trat das nur da auf und nicht auf der windows oberfläche) gibts ein komisches terrendes Geräusch, kurz einen kräuselnden Bildschirn und dann ein BlueScreen, wo unten der Ram gecheckt wird. Die Hauptmeldung ist IRQL_ NOT_LESS_OR_EQUAL. und danach bootet das System neu.
Was ist da das problem? Wenn ich das OC zurücksetze ist wieder alles ok.
Hoffe auf eine gute Antwort. Danke im Voraus.
Die gleiche CPU-RAM-MB-Kombination habe ich auch. Ich nehme mal an Du hast lediglich den Bustakt erhöht (Genaue OC-Angaben wären hier hilfreicher).
Ich habe das selbe Problem, wenn ich die DRAM-Frequenz zu hoch einstelle. Geh hier mal eine Stufe runter und das Problem sollte gelöst sein. Alternativ regel den Bustakt herunter. Bei mir läufts mit 232 Mhz "relativ" stabil.
Übertakte einfach über den Multiplikator im Bios. Viel stabiler als über Software.
@: TicoTorres
jo kenne das Problem mit der Software TurboEvo nur gut. ;)
Das Prog ist nicht schlecht wenn man die ungefähren Spannungen der Vcore
ermitteln will, aber Stabilität kennt die Software nicht ganz gut. :)
Meistens ist es nur soweit stabil, das man Windows starten kann, aber teste mal
Prime, schmiert meistens nach kurzer Zeit ab, wenn mit Turbo EVO eingestellt.
Daher immer über Bios einstellen und anschließend mit Prime oder Linx auf Stabilität testen.
PS: Habe bereits das neue Bios 1902 druff und keinerlei negatives aufgefallen.
Hatte mit meinem System noch kein OC'ing betrieben. Nur seit paar
Tagen beschäftige ich mich mit den Settings im Bios und will etwas OCing betreiben. :fresse2:
Nur eine Frage hätte ich...
Wenn man den CPU-NB Takt anhebt und gleichzeitig mehr Spannung auf die CPU-NB gibt,
ist es auch zwingend erforderlich die Northbridge Voltage zusätzlich anzuheben oder
reicht es wenn man nur mit der CPU-NB Voltage arbeitet?
Den Ht-Link werde ich unter die 2000Nhz belassen, da es ja nicht viel bringen soll?!
MfG
jap, HT auf 2k und bei cpu-nb nur die cpu-np spannung erhöhen. nur hab ich festegestellt das auch cpu-nb erhöhen keine spürbare mehrleistung bringt
Jo danke dir.
Nur habe ich festgestellt wenn ich nur die CPU/NB erhöhe erreiche ich bei
Prime btw Linx keine Stabilität. Erst als ich die NB erhöhte lief Linx durch
und Prime Large über 1,5 Std. Sonst hatte ich bei Prime vorher immer probs.
Ich hatte das auch so in Erinnerung das nur die CPU/NB ausreiche.
Ich habe ja nicht über den Multi getaktet sondern über den Referenztakt.
Kann das vielleicht daran liegen das die NB Hunger auf Spannung hat? :)
Momentane Settings:
Ref: 238 (16xMulti) = 3.82 Ghz
Dram: 1.65 V
Vcore: 1.365 V
CPU/NB: 1.175 V
NB: 1.175 V
HT Voltage: Standard: 1.21 V
Die HT Voltage habe ich so belassen, weil der HT-Link ja nicht erhöht wurde.
PS: CPU/NB Erhöhung soll doch mehr FPS bei Spielen bringen und insgesamt die Speicherbandbreite erhöhen?
ich teste grad mein 2000er ram bei 1333 mit entsprechend tiefen latenzen und das system läuft spürbar flotter. cpu-nb hab ich auf 2800. werd ich dann auch noch auf stoc nehmen und testen wie weit ich mit der spannung runter komme weil die leistung reicht wirklich aus für meine 6950 @ 6970 oc
Ich bin immernoch der Meinung, man sollte aus Speichertakt und CPU/NB Takt einen Weg finden, wo weder Timings noch Takt zu niedrig sind.
---------- Beitrag hinzugefügt um 19:56 ---------- Vorheriger Beitrag war um 19:55 ----------
Ich hab die CPU/NB bei ca. 2900MHz laufen bei 1.2v alles stabil und so weiter. RAM-Takt/Timings sieht man ja in Sig.
@: Smokeyskull
2000er Ram mit 1333, oh man ist das nicht schade. :) Klar Latenzen sind auch wichtig,
aber ob man das auch wirklich spürt. ;)
Habe soeben in deiner Sig gesehen, das dein Phenom 1090 mit 1,2375 @3,6 läuft.
Das sind ja echt Traumwerte, sehr wenig an Vcore. :cool:
Was hast du für eine CPU-VID?
Und wie hast du im Bios LLC und OCP eingestellt?
also ich muss sagen, laut aida64 bench hat sich nich viel geändert, außer eben bei der bandbreite, von 30k auf 21,3k runter.... aber ich mein, ich zock von ssd und sys läuft auch auf ssd und mittlerweile bin ich am benchen mit 1,525v statt 1,65v aufm ram.... das is schon n unterschied und wie gesagt, das sys läuft flotter....
LLC hab ich auf full und spannung eben mit offset auf komplett minus. und dann hab ich ausgelotet was er damit macht.
Sei froh, dass deiner kalt bleibt, meiner muss noch aufs DF-85 warten, bis er kalt bleibt. ;)
nuja, case-mäßig wird bei mir auch noch umgerüstet..... kommt ein sylverstone fortress mit ner h60 für cpu und ne wakü mit tripple radi für gpu....
Speichertakt und CPU/NB Takt einen Weg finden, wo weder Timings noch Takt zu niedrig sind...
Ich teile deine Meinung, immer die goldene Mitte nehmen. ;)
...LLC hab ich auf full und spannung
CPU LLC auf Full oder beides also CPU und CPU/NB LLC auf Full?
Ich find CPU LLC auf Full, stellt das Board zu viel Vcore ein. Daher habe ich
CPU LLC auf 50% gesetzt und die CPU/NB auf Auto gelassen und die beiden Voltage OCP's deaktiviert.
Da fällt mir noch die Einstellung Extreme-OV ein, was hat das damit auf sich eigentlich? Sollte man das aktivieren?
M.f.G Watercoolio
PS: Smokey gute Case Wahl, SST ist immer 1. Wahl. :drool:
LLC hab ich beides auf full, weil brauch ja die volle leistung nur unter volllast, also warum dann im idle mehr spannung geben als nötig? (meine meinung)
Logische Meinung... Nur soweit ich weiß kalibriert doch LLC nur unter Vollast, oder auch im IDle??? :confused:
Sorry habe mich damit nicht viel beschäftigt, mit dem Thema LLC.
