[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
Ich denke , das diese Vorgehensweise abgeleitet wird, aus der Boardbeschreibung
Userguide 3-19
was sich eigentlich nur auf Schwierigkeiten mit den optischen Laufewerken bezieht, die sich während der Installation des Betriebssystems ergeben...
habe das gerade auch erste mal genau durchgelesen (vorher nur so überflogen)...
Ha, wußte doch, daß ich es irgendwo gelesen hab.
Habe aber gerade Win7 auf meine neue SSD inst. (alles auf ahci) und war alles problemlos.:d
Na dann sollte es auch so keine Probleme geben.
glaub du kannst dann nur bei der install keine treiber einbinden aber das mach ich wenn ichs brauch eh über nen stick
Nein, das ist für alte DVD-Geräte, wie das meine, welches noch über einen Adapter angebunden wird. Denke ich. :O
€dit -> Wie lang sollte Prime nochmal laufen um zu wissen, dass die CPU definitiv stabil ist? Ich mach mich nochmal an die 4GHz Dran. Momentan 4Ghz @ 1,369v und fängt grade mit self-test 768k an.
€dit² -> 2Minuten später gabs einen Clock interrupt BSOD. ò.ó Jetzt kommen ~1,379v unter Last an die Reihe.
Ach, warum kümmer ich mich da momentan nur drum... ich warte erstmal aufs DF-85.
mit dem DF-85 hatte ich auch geliebäugelt...
allein diese Klasse Klappen vorne .. ist genial gelöst...
und die Optik..
nuja man muß es mögen----->ich mag es... :drool:
hätte ich nicht kurz vor dem bestellen das NZXT Phantom gesehen...
Da hab ich mich direkt drin verliebt...
und dann musste ich doch noch eine Nacht drüber schlafen...
aber dann ist es doch das NZXT geworden
Ich möchte auch kein MIDI - Gehäuse mehr haben..
einfach kein Platz drin...macht den Luftaustausch auch erheblich einfacher...
....und für den Preis , hast Du ja ein wirkliches Schnäppchen gemacht...ist normalerweise erheblich teurer...
wenn ich mich nicht täusche hab ich es die Tage noch für so knapp über 100 Euro mit nur 3 Lüftern gesehen...
Eine wirklich gute Wahl Deinerseits--Glückwunsch
Off-Topic bitte nur noch in PM, sonst wird das hier ein Gehäuse-Talk. :d
*Letzten Senf dazu-geb* Ich bekomms für 60€ mit Serienmäßigen 7 Lüftern. :)
Ich hätte mir auch beinahe ein NZXT geholt, aber den Hades. Den fand ich auch ganz gut, aber meines ist nun ein Stückchen größer :).
Edit: Ups zuviel Offtopic nun ;).
Was ist der höchste Ref. Takt, den ihr mit dem Crosshair packt? Bei 318MHz macht meins dicht. Mach ich was falsch oder liegts am Thuban?? :confused:
Servus, habe auch mein crosshair bekommen mit nen 1090. Leider startet nix. Board leuchtet für 30 sec und das wars. Speicher sind 4 x 2 gb 2000 domis und ne 6970. Netzteil 750 von seasonic. Jemand ne Idee woran es hängen könnte? Hardware lief vor dem Umbau einwandfrei. Habe leider nix mehr zum testen da um Fehler aus zuschloesen. Sorry für die Schreibweise bin mit dem Handy online. Martin
mach mal nen bios reset und starte die sache mal nur mit einem ram riegel bzw mal ohne graka...
Oft wird gerne dieser 4polige Strom-Anschluß neben der CPU vergessen...
steht oft auf dem Stecker des Netzteils CPU1 oder CPU2 drauf...
Alles nochmals checken...
sitzt die CPU richtig im Sockel? der Lüfter ordentlich?...
Ramriegel bis unten durchgedrückt ?...weil diese bewegliche Nase nur auf einer Seite ist...
Bei diesem Board sogar 8-polig um genau zu sein.
Ich habe aber nur 4 polig angesteckt...
läuft aber auch im Moment mit 3,98 GHz stabil....
die anderen 4 Pole waren aber auch mit einem Blindstopfen werksseitig verschlossen...
War bei mir auch. Hab ich abgemacht und die andere Hälfte vom 8-poligen Stecker angeschlossen. Im Handbuch stands so drin, also hab ich es so gemacht ;).
Hast du mal geschaut wo die roten LED's anfangen, dauerhaft zu leuchten?
bekomme hoffentlich morgen mein Crosshair IV Formula, einen 1100t und 8GB DDR3 1600. Hatte davor nen i7 920 und ein Asus Rampae II Extreme!
Wollte nur fragen ob es irgendwas zu beachten gibt bei der Installation.
Ich freu mich schon:love::fresse2::bigok:
MfG Fluck
Super Wahl! Doch warum hast du nicht noch ein wenig gewartet...? ;)
Weil ich gehofft hab noch mehr für mein altes Sytem zu bekommen sollange es noch aktuell ist. Und ich hatte die Schnauze voll von diesen Halsbabschneidern von Intel. Jedes Jahr ein neuer Sockel ohne Abwärtskompatibilität usw. Da komm ich mir irgendwie verarscht vor.
wieso sollte man enttäuscht sein von intel auf amd ,wer die brachiale leistung vom cpu nicht braucht der ist doch bei amd gut aufgehoben
Leider ist DHL nicht so schnell gewesen wie gedacht. Ich hoffe das jetzt morgen endlich meine Hardware kommt! Das iRog App geht mit diesem Board oder? Halt über Wlan...
iRog ist doch nur über BT?
Das Warten war auf Bulldozer bezogen. ;)
natürlich funktioniert IROG...
Ist ja auch auf der ASUS Seite unter ROG Exclusive Features
aufgeführt....
Ich hatte auch gedacht, eventuell auf Bulldozer zu warten...
aber der Einführungspreis wird wohl jenseits von gut und böse liegen...
Außerdem kann man den Bulldozer dann wohl doch ins Formula klöppeln...wenn der Preis angenehm ist...den Phenom II verkaufen , verschenken oder sonst was...
