[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
Einige BD exklusive Optionen dürften nicht laufen wie die neuen Stromsparsachen etc,aber ansonsten dürfte die Karre erstmal laufen :)
Läuft bei mir auch mit 1090T. Aber OC etc. ist etwas hinterher.
Ist deutlich schlechter was benötigte vCore und Ramtimings angeht.
Weil es eben für BD optimiert ist.
Wollte nur die Aussage wiederlegen: Läuft nicht mit AM3. ;)
Gruss.
Ja wie jetzt, entweder läufts oder nicht. :d Da fängt es wieder an, "einige Stromsparmechanismen" werden nicht gehen? :(
Also nicht Full Kompatibel, sondern nur zum Teil Kompatibel. hmm :hmm:
MfG
er wird laufen, halt nur die am3+ spezifischen Features nicht :) stand auch iwo mal son hinweis
Sind nur die Stromsparmechanismen von betroffen, oder auch andere gravierende
Sachen? Kenne jetzt noch nicht die genauen unterschiede vom AM3 zum AM3+.
Hoffentlich wird dadurch der Stromverbrauch nicht enorm?!
Gute Frage ob das die einzigen Sachen sind, ich hab mich damit auch nicht weiter befasst da ich eh auf das neue Crosshair V umsteige :)
Soweit ich weiß, sollte man schon aufgrund der höheren Stromspitzen wechseln. :fresse:
Statt 110A gut 140A maximale Stromstärke. Auf einmal macht's "BÄM!", es qualmt und Mainboard inklusive Prozessor und NT hinüber. Das alles ist aber reine Spekulation.
Btw wechselt jemand von euch auf Crosshair V Formula, wenns rauskommt?
xD jap ich steht aber auch in dem Post über dir :)
vorbestellt ist es schon, nun warte ich nur noch auf auslieferung
hmm :hmm: Also umsteigen auf CH V ist bei mir nicht drin. Weil das mit enormer Arbeit
verbunden wäre (Wegen dem Fullblock Kühler). Bin ja auch so eigentlich mit dem CHIV ganz zufrieden. ;)
O.K bei dem Bulldozer werde ich doch schwach. :fresse: Aber laß uns erstmal
abwarten, bis der BD rauskommt und die ersten den auf einem CHIV zum laufen gebracht haben. ;)
Würde mich freuen, wenn sich die ersten auch hier sofort melden, die es auf
einem CHIV zum laufen gebracht haben. Kanns noch nicht so glauben,
gerade bei Asus, also das es kompatibel sein soll. Gibt bestimmt wieder einen Haken..;)
MfG
naja nicht nur Asus bietet diesen "Service" an, auch MSI bietet das an und Gigabyte glaube ich auch,ich hatte mir das CHIV eh nur als Übergangsboard bis BD rauskommt geholt von daher hab ich direkt auf wakü aufm board verzichtet :)
Also meine WaKü möchte ich nicht mehr missen. ;) Weil die Temps bei mir wirklich traumhaft gut sind. ;)
Die Frage wäre eigentlich ob der Fullblock Kühler vom CH 4 auf den 5 passt, das wäre
doch mal eine gute Nachricht. ;) Wird aber bestimmt nur ein Wunsch von mir bleiben. :d
MfG
Hrhr, das wäre ja sehr nice, allerdings bastel EK laut ihrem Coolingconfigurator schon an einem neuen Boardkühler da hatte ich die Tage schon mal nachgesehen, da das CHV dann auch WaKü bekommen soll :)
@M0ped:
Echt schade, aber kein Wunder bei der Abzock-Politik der Hersteller, gerade
Asus und EK sind da führend, was das Geld machen angeht. :motz::)
Klar aber solange wir so blöde sind und uns das auch noch kaufen, wird das nicht enden :d
@M0ped:
Der war auf jeden Gut. :d
Aber so blöde sind viele doch nicht mehr, weil die Mainboard verkäufe in letzter Zeit
sehr rückgängig sein sollen. Also überlegen es sich einige mehrmals vor dem Kauf,
oder die warten alle auf das Erscheinen des Bulldozers. :d Wer weiß vielleicht gibt es
ja dann wieder ein MB Ansturm. :)
:wink:
Die warten wohl eher alle auf Sandy Bridge E, aber so kann man's auch sehen! :'D
Zumal seitens Intel dann auch noch ein schöner S-ATA Defekt gewesen ist, ich denke das hat bei vielen immernoch ein gewisses Entsetzen von ihrer ,,Über-Marke"hinterlassen.
Ganz ehrlich, ich merk da keinen Unterschied. Das einzige, was nun fehlt, ist der Windows-Anmeldebildschirm(der wird einfach übersprungen :fresse:), ansonsten alles wie immer. Und nein, ich habe keine SSD. Ich hab dazu allerdings mal einen Test gesehen, DDR3-1800 @ CL7-7-7-20 ist schneller als DDR3-1350 CL4-4-4-12.
Hier der Test dazu.
nuja, bei mir bremst meine tv karte mein sys aus und mein sys müsste vielleicht auch mal neu aufgesetzt werden..... aber ich finde mit niedrigeren latenzen läuft das system irgendwie entspannter als wenn alles so hochgeknüppelt is...
hat jemand die Einstellungen für Phenomtweaker parat. Keine Lust alles neu zu testen.
Habe meinen Max Takt @4Ghz eingestellt, wie könnte ich mit Phenomtweaker
einfachsten tweaken? also settings.. Kenne mich noch nicht mit aus, habe vorher K10Stat gehabt.
Phenom Tweaker für P-States? Ich stell alles im Bios ein.
