[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
Gabs da nicht ein Problem mit SB850 und Samsung Spinpoints?!
Da waren nur die F3 platten betroffen.
wenn ich n programm von der cd installiere dann mukrst das sys, das selbe gillt, wenn ich ne große datei von hdd1 (sysplatte) auf hdd2 oder 3 kopiere oder umgekehrt. von platte 2 auf 3 werd ich mal testen, muss aber erst mal guggn wieso ich heut kein sound mehr hab, gestern hatte ich noch sound, als ich das sys abgeschaltet hab.....
Das könnte natürlich was schwerwiegenderes sein. Versuch mal die betroffenen Platten an anderen SATA-Ports zu betreiben. Oftmals hilft sogar eine Enstaubungsaktion im Gehäuseinneren, aber da das Board ja nicht schon zig Jahre alt ist entfällt das wohl ;).
Hab nun mal n anderen port probiert aber es änder sich nix.
Hab mal HD Tune installiert und meine beiden F1 platten (320 sys und 1tb) haben beide einen C7 ultra dma crc error count error, da steht was, dass der kabel defekt sein könnte, was ich nicht glauben kann, zwei kabel die ich seit dem zusammenstellen des sys nimmer berührt hab gehen einfach so flöten???
Könnte es sonst was sein, vllt. chipsatztreiber oder so was??
Schönen Guten Abend,
kann mir Jemand erklären, wie ich mit der VCore Offset Volltage unter Last auf 1,475 V bekomme?
Ich kapiere dieses System überhaupt nicht.
Habe mich jetzt schon in vielen Foren eingelesen, doch irgendwie ist das für mich nicht nachvollziehbar.
Ziel dabei ist es, dass ich Cool´n´Quite und C1E aktiviert bekomme.
Vielen vielen Dank
na auf plus stellen und dann die 1,475 minus die vid deiner cpu rechnen und schon weißte was du dort einstellen mußt
Aber dadurch bekomme ich doch nur eine hohe IDLE-Spannung??
Aber doch keine Last-Spannung ??
Ich habe momentan ein bisschen Angst da etwas einzustellen.
Habe vorhin folgendes gemacht:
1,3 V ist die VID
Die war auch grau hinterlegt.
Dann habe ich die Offset-Spannung auf + 0,2V gestellt.
Im Windows sind mir dann die Augen ausgefallen als ich eine IDLE Spannung von 1,68V gelesen habe o_O
Klar werde ich heute Abend machen, wenn ich von der Arbeit wieder da bin...
EDIT:
Kann es sein, dass ich mein fertiges Setup nehmen muss, die Spannungen auf Offset [AUTO] stellen
und diese werte dann korrigieren muss??
Jedoch bootet er so schon gar nicht. Er gibt ihn einfach nicht genug Vcore auf Offset Auto.
Stell Offset mal auf +0,1125v. Dann sollte er doch theoretisch bei ~1,5v Idle und 1,475v @100% bei 50% LLC ligen
dann lieber full LLC und bissl weniger.... warum soll der im idle 1,5v anliegen ham....
so hab ichs auch geregelt full llc und dann die Spannung angepasst, so lieg ich bei 1.389 im idle und bei 1.43 unter Last @4.1ghz
War nur ein Bsp. Aber 100% LLC sind besser, du hast einfach weniger vCore im Idle.
jo, so hab ichs bei mir auch. hab vorhin ma gebencht mit dirt 3..... der unterschied von 3,6 zu 4ghz is echt minimal, bei de min fps 1 und bei de durchschnitts fps 2..... dafür mußte ich aber die spannung immens anheben und auch die temps gingen für mein bedarf fasst durch die decke....
Temps und Spannung sind dann wie hoch?
1,42v unter Last oder Idle? x] Temps über 50... Heftig! oO
unter last. naja, wobei ich sagen muss das alle lüfter auf low laufen, will ja ruhe ham.... aber mit 3,6ghz komm ich mit ach und krach auf 42° unter last
Ich hab nach 1 Std. Crysis 2 MP 34°C bei 4Ghz @ ca. 1,395v. Aber auf dem CPU Ding nicht auf den Core Dioden.
Allerdings hab ich die selbe Temp so lange, bis ich etwas mit über 50% Last anschalte. Dann geht das fast schon um Faktor 1.5 nach oben.
naja, kommt ja auch auf die raumtemp an....normal sitz ich bei 19° aber langsam gehts wieder richtung 23°
Oh... meine weiß ich leider grad gar nicht. Aber es ist mittlerweile definitiv min. 19°C. Die CPU Core Temp ist bei mir im Idle immer = Raumtemp.
€dit -> 20°C sind's. Wenn ich den PC einschalte sind das im Verhältnis dazu fast 30% mehr...
die core temp intressiert mich garnich, die liegt bei mir derzeit bei 17° und das bei 22° raumtemp, bissl unwahrscheinlich....
Ich wohn auch in einer Lehmbude mit Denkmalschutz. :fresse:
is auch wieder war...
ich habe auch vor kurzem erst wieder gebencht und da kam nicht viel mehr dabei raus....
von 3,5GHz bis zu den 4,2 GHz.....und die 4,2 brauche ich persöhnlich im moment eh nicht
noch ne Frage anbei:
Wie kommt Ihr so mit dem neuen BIOS zurecht hat es ernstzunehmende änderungen???
