[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
Hast du mal den schwarzen versucht, anstatt den Roten? Das ist nämlich ein anderer Controller :fresse:
Ich bin sehr interessiert an der Crosshair Formula,
aber der Preis ist noch nicht da wo ich ihn haben will (150 Euro),
meint ihr das es demnächst eine Preissenkung bei diesem Modell gibt ?
ps. natürlich kann ich auch den jetzigen Preis locker bezahlen, aber ich will das gefühl haben, ein kleines Schnäppchen gemacht zu haben.
Da das Crosshair V Formula nun so gut wie erhältlich ist, kann man eine leichte Preissenkung erwarten :)
Nur so zum Vergleich: Ich habe damals 184,24€ bezahlt ;).
Da bin ich mal wieder und lese hier die alten posts von euch. Und muss mal auch mein senf dazu geben als alter hase.
1.ich brauch 4ghz, da ich defentive einen unterschied zwischen 3,6ghz und 4 spüre. Allein schon beim start. mit SSD und ohne SSD!
2. 5Jahre mit dem System zocken ist sicherlich möglich aber sicherlich auch schrecklich.
Portierung heist noch lange nicht das, das game richtig läuft nur weil unsere HW der piss Konsole überlegen ist. Die spiele sind meist derart shit portiert das es eher schlechter läuft.
3. bezüglich offset einstellungen kann ich Bios post schicken. Ist garnet so schwer musst halt die schritte auch testen. Einfach PM. Hab schon ein paar mal gepostet bringt anscheind nichts ;)
@smokey du schotte welche Auflösung benutzt du bei 1,6Ghz@Dirt3 und stellst du im Bios immer um bevor du loslegst? Oder haste nen anderen trick ;)
4. Gskill ECO sind geil habe meine 4x2GB aber gegen 2x4GB Vengancy 1866 oder wie auch immer die teile heissen getauscht. Laufen auch sehr gut mit 1864Mhz bei mir.
So jute nacht
Sent from my LG-P990 using Tapatalk
181€ direkt nach release!
für mich geilste board alive!
und alsbald, alsbald, alsbald hessisch babble. Jungeee
;) am Sonntag verlasse ich Wiesbaden Richtung Heimat die Muddastadt nach 4Jahren da wird mir alsbald einiges fehlen ;)
und welcher unterschied wäre das? also ich merke keinen, außer bei den temps und dem stromverbrauch.
nope, ich nutz einfach die energieeinstellungen im windows.... easy sache das.
und auflösung natürlich das was mein moni packt, also 2048x1152
Gibt's überhaupt schon einen Crosshair V Formula Sammelthread?
Hi, ich hab mal ne Frage:
kann ich diese Corsair 2x4 GB DDR3 1333 für das Crosshair Formula IV verwenden,
Link dazu: 8GB Corsair XMS3 DDR3-1333 DIMM CL9 Dual Kit - Computer Shop - Hardware, Notebook
weil in der QVL List finde ich die nicht, jedenfalls nicht als 2x4 Riegel,
bitte um schnelle Antwort, da ich noch heute bestellen möchte,
ihr wisst ja die Preise ändern sich schnell bei MF, danke
Hi
-frage wenn ich OC bei Board mache stortert der Sound dann beim Muke abspielen bzw. auch in den Games usw. wenn alles auf normal ist geht es,würde es was bringen auf eine Soundkarte zu setzen oder nicht?
Grüße
Rocci75
---------- Beitrag hinzugefügt um 09:14 ---------- Vorheriger Beitrag war um 09:11 ----------
1. Du befindest dich hier im Crosshair IV thread! ;)
2. Schau mal in dein Handbuch auf Seite 123 von 194 im Kapitel 3.10 findest du Angaben zur Sicherung des BIOS. Siehe Abb. des ^^Fingerzeig^^
grEEtz
fuzzy
Hi
sorry es gibt noch keinen V-Sammelthread:rolleyes:
Grüße
Rocci75:wink:
@Rocci75
Keine Ahnung. Glaube nicht. Hier ist noch keines zu finden!
Mainboard-Sammelthreads - Forum de Luxx
fuzzy
Vom Sabertooth 990FX gibt's ja auch noch keines.
Evtl. erbarmt sich ja jemand und macht einen für's Crosshair V u. Sabertooth FX auf da ja beide von ASUS und sehr ähnlich sind.
Hi
Grüße
Rocci75
Ist dein Netzteil möglicherweise zu schwach? Sowas hatte ich mal mit meinem Pentium IV System [3,85ghz @ 1,25v da in der Richtung] und einem 200W NT. :fresse:
Wir haben noch keinen Sammelthread zum Crosshair V Formula. Es wird sich aber sicherlich jemand freiwillig dazu bereiterklären, einen zu starten.
hallo, ich habe ein Problem mit einen Formula IV Board.wenn ich das Board starten möchte passiert garnichts,es leuchtet lediglich nur reset,start,dass schloss und oc auf dem Mainboard,es leuchten keine leds.Mein seytem ist volgendes.
AMD Phenom II x6 1090T
4x A-Data XPG G v2.0 DDR3-2000G
zotac gtx 470
bequiett 750w
hat vielleicht jemand ne idee? bevor ich es RMA zurück schicke?
Vor allem -> benutzt du den 8Pin EPS Stecker oder den 4Pin ATX Stöpsel?
Nimm den 8Pin, wenn möglich. Ansonten -> Prüfe, ob der 24Pin Mainboard Stecker richtig sitzt.
hallo,Stecker waren alle ok! habe das Mainboard wieder ausgebaut und werde es morgen zur RMA schicken.Danke für eure antworten.
Ich brauche dringend hilfe! Diese verfi**** Samsung hd103sj lassen sich nicht flashn daher kann ich meim system mit der neuen vertex 3 nicht auf sata 3 laufen lassen
Habe komplett sb850 ausgeschaltet und nun mit jmicron probiert keine chance! In der piss Anleitung auf der samsung seite steht use commad patch dieser ist keine richtiger dos befehl wer hat den koreanen ins hirngeschissen?
AGGGGGRRRRRROOOOOOO!!!!!
Das Bild bitte noch verkleinern.:wink:
mit f3eg
Und mit F3
Auf dieser drecksseite steht noch nicht mal welche firmwareversion.
Ahhhh ich kann das net vom tel!!!!! Gib mir bitte ein paar min! Rechner is im dos!
PS DIE PLATTEN KLACKEN WIE IRRE.
Ok habs geschaft!
da ich 2 platten habe, habe ich die platte die mit aktueller FW versucht zu flashen. Das habe ich leider viel zu spät bemerkt!
Hallo,hätte noch eine frage zu der zotac gtx 470.Muss man vom Netzteil 2xVGA1 nehmen oder VGA1 und VGA2 für die Grafikkarte.Benutze jetzt ein BE Quiett 850 W.
Ist egal, Hauptsache genug Strom.
Servus Leute, ich möchte mein Board verkaufen.
Was kann man dafür verlangen?
Ich dachte an 130€
Ist doch ok oder? Hab immer Standart Spannung bei MB settings benutzt.
Vielen Dank für eure Hilfe :-)
