[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
ja ich hab halt immer noch das Broblem mit dem sound wennich Digital eingang mache das bekomme ich das Krechzen in denn boxen wider und ich kann nicht ins Bios booten mit der USB Tastatur
Ich hab auch eine USB Tastatur von Logitech.
Damit komm ich schon seit dem ersten Bios (0404 glaub ich) ins Bios.
Einzige Problem was ich anfangs hatte war, das ich Asus gewohnt USB / Maus in den obersten USB Anschlüßen gestopft habe. Dann hatte ich im BS nie eine funktionstüchtige Tastatur/ Maus.
Was dann aber an den fehlenden USB 3.0 Treibern lag :fresse:
Hab sie jetzt Standart mässig in den 2.0 Plätzen und läuft Top. (In den 3.0ern aber auch seit die Treiber drauf sind ;) )
Mit dem Digital Ausgang klappt bei mir auch hervorragend.
BluRays etc. werden Optisch an meinem AVR weiter geleitet und korrekt in DTS 5.1 / DD5.1 wiedergegeben.
Noch ne kleine frage wenn ich in denn Rhue stand gehe dann drück mann ja normal die Lerstaste das win wider auf startet wenn ich das macha dan tut sich garnigs was kann ich dagegen tun
Hast Du C&Q aktiviert? Hatte ich an, da gings bei mir auch nicht mehr, nur noch am Power- bzw. Resetknopf am Gehäuse. Hab versehentlich wieder alles auf default in BIOS gestellt :grrr:, da gings wieder.
em du meinst cool end qwit ja das hab ich aktivirt soll ich das mall auf deaktiviren stehlen
Mal eine Frage an die CH V Besitzer:
Hatte wer von euch vorher ein CH IV und gibt es bis auf bis auf das UEFI Bios, SLI und mehr USB 3 Stechplätze relevante Unterschiede?
Bulldozer wie er jetzt ist werd ich getrost ubergehen, mein 1090 macht 3.8GHz undervoltet das reicht von daher, SLI brauch ich auch nicht und UEFI - naja kein Intresse, das Layout des IV gefällt mir besser wie das des V, von daher sind irgendwelche Leistungswerte besser mit dem V bei euch?
Da ich das V selber habe und das IV in meinem näheren Umfeld im Einsatz ist, kann ich dir sagen das du getrost zum IV greifen kannst wenn dir UEFI / SLI egal sind.
Das IV unterstüzt auch den Bulli von daher nicht mal dafür ein argument. (Hätte ich das vorher gewusst das Asus das Supportet hätte ich selber das V nicht gekauft sondern mein IV behalten) Frage wäre wie es mit dem Pileriver ausschaut. Aber da weiß eh noch kein Mensch ob der überhaupt für AM3+ kommt.
Leistungstechnisch liegt alles im Rahmen der Messgenauigkeit. Was auch kein großes Wunder ist , da zwar der Chipsatz anders heißt, aber generell der gleiche ist wie beim V.
Greif ruhig zum IV.
Das V ist ein geiles Board und jetzt noch mal zurück wechseln würde ich nicht. Dafür hat man dann die extra Vorteile alla UEFI etc.
Stünde ich aber mit dem Wissen von heute da und müsste eins Kaufen, würde ich das IV kaufen statt das V ;)
moin zusammen,
das V ist wirklich ein geiles stueck hardware, aber der vergleich IV gegen V wuerde ich an deiner stelle das IV behalten.
Greif ruhig zum IV.
Moin,
ist die Aussage amtlich? Hat jemand den BD auf einem CHIV Formula am laufen? Welches BIOS? 3017 oder 3027?
oki doki
fuzzy
Mal ne Frage in die Runde, das Board hat ja nen 12V 8 Pin Anschluss und nen 12V 4 Pin Anschluss. Habt ihr die beide angeschlossen?
Bin mit meinem n bisschen am takten und hab mich gefragt ob das irgendwas bringt.
Den 8 Pin hab ich angeschlossen, neustes Bios drauf. Bekomme meinen 1090T aber noch nicht mal bei 1,45V@3,8 ghz 100% stabil.
Könnte es damit zusammen hängen? Hab 16 Gb Ram drin.
Frag doch einfach mal im IV Thread? Denke die werden das besser wissen als wir paar leute hier im V thread.
Auch wenn die Frage hier für den ein oder andere etwas Fremd erscheint, aber hat hier wer auf dem Board erfolgreich mit einem ESX Server die Funktion des PCI passthrough genutzt?
Bei mir sagt er immer "HW unterstützt das nicht". IOMMU ist ja im BIOS aktiv.
(hat hier wer evtl andere Optionen beim IOMMU außer dis. und 64MB?)
Nutzt hier eigentlich wer einen 6-Kern Bulldozer auf dem Board?
Ich bekomme vorerst nur den 8 kerner rein...
Werde ein Roundup mit Gigabyte, Asus, Asrock und MSI machen (alles 990FX'ler)
Kann dann mal berichten....
im 1003 gibt es eine neue Option.
Xtreme Tweaking, was soll die genau bringen?
Moin Jungens
Schon jemand das neue Bios drauf und getestet ?
Habe immo noch das 813er drau. Gibs große spürbare Verbesserungen ?
Grüße
Große Spürbare Verbesserungen?
Worauf bezogen?
Läuft mit dem neuen genauso hammer Stabil wie mit dem alten.
Krieg nun auch mit dem neuen Bios meine 16GB S.Skill 1866er auf 2000mhz cl9 ans laufen.
(Vorher nur mit 8GB möglich gewesen)
