[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
Dem Board fehlt nurnoch dieses "thermal Radar" vom Sabertooth und es wäre perfekt :p
Beim booten kommt immer "can't find any device".
Wenn ich dann ins Bios gehe und bei Boot auf override/aussetzen gehe startet er sofort Windows.
Boot Prioritäten habe ich richtig eingestellt.
hast du install? oder bist du mit der platte umgezogen?
Ich habe Windows NICHT neu installiert falls du das meinst.
Kann es sein, dass die Platten zu spät Saft bekommen? Habe sowas beim überfliegen anderer englischer Threads gemeint gesehen zu haben...
jo das habe ich gemeint, das mit dem saft kann ich dir nicht beantworten. da ich das nicht hatte.
Es hat sich geändert:
Asus Bild
Cant find any device
Asusu Bild
Auflistung der Geräte
Windows
mach doch mal an cmos . und da default setting laden. speicheren neustarten und da stellst du dann stellst du alles ein.
Werde dann vielleicht mal Windows drauf machen...
aber noch was:
4,4@1,33V gehen nicht. Da zeigt Prime sofort Fehler an (Illegal Sumout) in mehreren Kernen.
Wie hast du das zum laufen bekommen?
ich suche heute mal a paar screen´s
mit was kuehlst du? und wie heiss wird er bei dir`??
Wasserkühlung... der Heatkiller 3.0
Wassertemp 30°C. CPU im Idle 40°C.
Ich werde mal versuchen auf 4,0 ghz zu primeln...
Edit:
Und mit musik hören wars das auch - hab in der Sekunde mindestens 1x ein Knacken...
Knacken war nach einem neustart wieder weg :rolleyes:
weder das prob mit dem hochfahren noch das Knacksen ist mir bekannt.
zum hochfahren, da denk ich fast das die einstellungen voltage-takt nicht passt.
So gerade rausgefunden, dass einer meiner neuen Ramriegel defekt ist...
Joa war aber schwer zu erkenne, oft wurde er ja richtig erkannt :-/
Ärgerlich, vielleicht hätte ich bei dem Asrock bleiben können^^
40°C im Idle. Hast du dich da verschrieben? Ist selbst mit deaktiviertem C&Q ziemlich hoch.
Vielleicht kommst deswegen auch Taktmäßig nicht so hoch.
Wegen dem Ton:
Ich kann höchstens 16bit 44,1khz einstellen. Alles drücker fängt an zu knacken... das hatte ich noch bei keinem Board.
Und selbst da habe ich es noch ab und zu... wenn das so weiter geht muss ich mir ein viertes Board kaufen^^
Angeschlossen ist der AVR über ein optisches Kabel...
Ich vermute das liegt an den ganzen verschiedenen Treiber der anderen Boards welche nie gelöscht wurden. Hab schon versucht Windows neu drauf zu machen... aber natürlich funktioniert das nicht :rolleyes:
Liegt eventuell an der 5 Jahre alten WLP. Muss da vllt. mal nachbessern^^
Cool and Quiet ist aktiviert.
Jo wäre wähl besser. So um die 30°C im Idle sollten laut Boarddiode mind. möglich sein. Mit deinen Boards hast du aber auch ein Pech^^
Ist doch alles super... so kann ich anhand der unverständlichkeit von Liedern oder Spielen die Prozessorauslastung abschätzen!
Sobald ich prime anwerfe höre ich praktisch nurnoch ab und zu ein lautes kratzen :(
Asus P5B Deluxe: Problem mit dem JMicron SATA-RAID-Controller
Im Zusammenspiel mit dem JMicron-Controller gab es bei mir leider heftige Probleme, die sich unter anderem darin äußerten, dass der Sound das berüchtigte Crackling-Noise-Problem hatte. Meint: die Soundausgabe rattert und stottert übelst. Nachdem ich den SATA-Controller von JMicron deaktiviert hatte, war alles gut (nach einer Neuinstallation!). Man benötigt den Controller nur dann, wenn man SATA-RAID betreiben will. Der Intel-Chipsatz selbst hält 6 SATA2-Ports bereit, die problemlos funktionieren, auch mit der Soundkarte.
Ist zwar etwas älter, aber vielleicht hilft mir das irgendwie? So wie ich das sehe wird dazu geraten den Raid controller auszuschalten... aber wie übertrage ich das auf mein Board?
Das Problem mit "cant find any device" ist behoben :)
Es gibt einfach alles kein Sinn:
Ich hab den "defekten" Riegel wieder eingebaut um sicher zu gehen. Habe memtest 2 Stunden die kompletten 8gb testen lassen - ohne fehler!
Hatte dann mein PC nur 5 Minuten aus und was ist? Er fährt wieder nicht hoch... dachte mir also "ok, mach ich einfach den defekten Riegel wieder raus". Gesagt getan und er fährt trotzdem nicht hoch :rolleyes:
Ich habe noch mehr herausgefunden:
CPU Load Line Calibration: Die bestimmt über die Absenkung der CPU Spannung bei Last. Wenn ich diese auf Extreme stelle (die CPU bekommt die volle Spannung) ist die CPU prime stable. Mit einer erhöhten Spannung wird das knacken allerdings auch intensiver.
Jetzt stellt sich mir die Frage, wie kann ich mit dem besten Am3+ Board beides haben? Ein bischen OC und Ton?
Es ist zum ko*** Manchmal fährt er hoch, manchmal nicht wenn ich fast nach jedem mal BIOS 3x NT An/Aus machen muss bekomm ich lust das Board aus dem Fenster zu werfen.
echt komisch, weder knacksen oder an-aus noch sonst was hatte ich mit dem brett.
das mit LLC habe ich nie getestet. ich habe sie auf high gehabt.
1.) teste doch mal das 0903 bios.
2.) LLC auf high - warum hoeher?
3.) und stelle am besten alles per hand ein. damit solltest der an-aus bug wech sein.
1.) Klingt für mich unwarscheinlich...werde das zuletzt probieren.
2.) Selbst bei high hatte ich kein TOn mehr, ich muss das ganz unten lassen damit ich noch was höre. Wie schon gesagt, umso höher die Spannung desto weniger Ton.
Dazu muss es doch unbedingt eine Lösung geben?
3.) Also nichts im OS über dieses OC Programm=
2.) keine ahnung, aber sehr komisch.
3.) per hand einstellen meine ich im bios-uefi also nix mit oc tool.
Kann mir mal jemand erklären wie die Funktion "BIOS Print" funktioniert? Überall steht nur, dass es geht, aber nirgends steht wie es geht :d
Windows ist jetzt neu drauf - die Erwartungen sind groß :)
Wie hast du das bloß rausgefunden? :fresse:
Zum Knacken. Das Problem besteht, schon bei 1,33V und Volllast ist es unerträglich...
Was kann ich da noch machen?
Jetzt habe ich das "beste" AM3+ Board und kann damit nicht mal Musik hören? Geschweigedenn meine Ruhe haben... das störgeräusch ist einfach immer da.
nutzt du den onboard chip? oder mit soundkarte??
ich versteh das net, bei mir war da bis 1,45 vcore ruhig mehr habe ich auch nie anliegen gehabt.
Onboard Chip. Eine extra soundkarte bei digitaler Übertragung macht kein Sinn.
Wieso? Der Onboardchip würde doch viel mehr unter Spannungsschwankunden/... leiden als eine seperate Soundkarte :-/
ja das is mir scho klar, nur versteh ich nicht warum ich das nicht hatte. egal wieviel vcore ich da anliegen hatte.
