[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
Hi
Ok das in der Richtung meinte ich ja. Immo habe ich 8GB Team Elite 1333 9-9-9-24 2T drauf. Die laufen immo @1600MHZ 9-9-9-24 1T und das stabil soweit.
Dann kann ich den 2ten Kit nach dem Update auch mit einbauen denn mit 16GB strikte das Board bei 1600MHZ 2T.
Grüße
Bisher hab ich meine Maschine so laufen:
250FSB
Multi 15
= 3750Mhz
Bei 1,296 V-Core :d (Prime Screen im X6 OC Thread)
(Für 4Ghz brauch er aber abnormal viel V im Vergleich - ca. 1,4V darum lass ich ihn auf 3750 laufen.)
Ram auf 2000 @ CL9 und 1T
NB auf 3000Mhz bei 1,325V
HT Link Standart auf 2000Mhz.
Läuft bisher Problemlos.
Dieses Xtreme Setting was neu aufgetaucht ist hab ich einfach mal angelassen.
Mit dem alten Bios konnte ich das nur @CL10 ereichen bei 2T.
Mal schauen ob es im Alltag jetzt auch keine Probleme mehr Speicherbezogen gibt bei 1T und 16GB.
Schauen wir mal :)
Ich muss meinen kleinen BD die Tage auch endlich mal auf dem Brett Testen. Ich hoffe da geht er etwas besser als aufm CHIV.
auf den vergleich bin ich mal gespannt, wobei ich glaube das sich die beiden bretter nix nehmen.
Glaube ich ehrlich gesagt auch nicht.
So gehen gibt es ja nichts wirklich neues am V - außer dem Offiziellen Support für BD - gegenüber dem IV.
Die BIOS 3027 Version für's CHIVF ist aber immer noch
eine Beta - Version. Also noch mit Vorsicht zu genießen. :confused:
Wer setzt denn hier einen BD auf einem CHIVFormula mit obigen BIOS ein.
Freiwillige vor. :wink: :banana:
Auf einen großen Unterschied setze ich auch nicht wirklich aber wie hier schon gesagt wurde, ist das CHV ein Offizielles BD Board und das wird sich in der Handhabung bemerkbar machen.
Wenn man einen BD auf einem CHIV nutzen möchte, ist es zwar möglich aber vom nutzen her nicht wirklich Ratsam.
Mir kanns ja auch egal sein da mein CHIV jetzt als Alltags System mit einem X4 975 seinen Dienst bei mir verrichtet :drool:
ich meinte ja nur das er eben auf dem iv mit dem 3027 bios laeuft. da es noch kein final ist wird man bestimmt noch probs haben. aber es laeuft.
Man kann sich auch alles schön reden die meisten in diesem Forum wissen wieviel BD aus der Dose zieht. Link
Mal eine ganz andere frage, welches BIOS nutzt ihr in Verbindung mit einem BD auf dem CHV?
Ich habe gesehen das es auch Mod BIOSe gibt, nur was die bewirken, habe ich noch nicht erlesen.
ich habe das 1003 am laufen mit einen fx8120, in diesem bios gibt es auch eine neue option (Xtreme Tweaking) was diese bewirkt weiss ich nicht.
das 1003 laeuft genauso wie das 0903 bei mir. wo finde ich diese MOD BIOSE?
Ich habe es endlich geschafft mein System in Betrieb zu nehmen :drool:
Mit welchem Takt lässt du den Bulli für 24/7 laufen?
Habe keinen 24/7 Takt bei dem System, das ist nur um Fun zu haben. Meine Regulären Systeme findet man in der SIG ;)
Hm find die werte vom Bulli da jetzt nicht so pralle? Zumindest bei dem Takt unterschied. Gut ist auch nur der 6er. Trotzdem, so eine Takt/Leistung Performance bin ich von AMD nicht gewohnt.
Wohl noch zu viel die guten alten XP vs P4 zeiten im Kopf :shot:
Wobei ich immer noch auf den Standpunkt stehe das der Bulli eigentlich ein Server Prozzi ist und da ist er auch gut.
Für Desktop wird das wohl erst mit Piledriver wieder wirklich was.
Dann mal schauen ob der noch auf AM3+ kommt oder nicht.
Von meinem X6.
NB läuft bei 3Ghz.
Wobei ich im Moment den Speicher noch extrem runter gefahren habe da ich immer noch ein anständiges 16GB Setting versuche bei 1T und CL9 (so wie es mit 8GB möglich war bei 2000Mhz)
Bin da noch viel am rum experementieren.
Ich bekomme das Board in den nächsten tagen, Weiß aber nicht ob ich es einbauen soll.
Kann mal einer die Temperatur des chipsatz bewerten? Ist die Kühlung für richtigen silent betrieb ausreichend?
Bitte mit angaben zu OCC antworten.
hi jojo, da brauchst du wirklich keine angst haben. mein system ist auch auf ultra silent getrimmt. und des mit 4,4 ghz am bulli. unter prime NB und SB max 50 grad. von daher brauchst du dir keine sorgen machen.
Servus,
wuerde mich gern kurz einklinken.
Habe folgendes Entscheidungs-Problem und wollte mal fragen ob jemand schon Erfahrung mit diesen beiden RAM-Riegeln in Kombination mit dem Formula V gemacht hat.
KHX1866C9D3T1BK2/8GX - KHX1600C9D3X1K2/8GX
Ob der 1866er laufen wird, natuerlich mit Spielerei. Bzw. der 1600er auf 1866.
Schon mal vielen Dank fuer die Antworten. Wuerde mich freuen wenn ich bis Montag eine Antwort haette, dann kann naemlich das Projekt AMD-Spielerei beginnen.
Mit freundlichen Grueßen
Freaky27
die speicher laufen mit sicherheit, nur ob 1866 laufen liegt an der cpu. da hilft nur testen.
welche cpu wird den verbaut?
Der X6 1100T, FX-8150 ist bestellt. Je nachdem wann der FX eintrifft wird selbstverstaendlich dieser verbaut.
mit dem x6 wird es schwer, aber mit dem FX sollte es kein prob sein.
Mein Speicher lief auf 2000 @ CL9 bei 3Ghz NB takt auf 1,3V Stabil.
Manchmal sollte man ihn nicht unterschätzen :fresse:
Bin jetzt aber zum null Tarif auf ein ASRock z67 Extrem 3 Gen 3 samt i5 2500k gewechselt.
Hab das Formula V aber im bekannten kreis samt X6. Ist also nicht schwer da weiter hin und wieder was zu testen ;)
Probieren wir es mal aus. Vorerst wohl der X6 1100T wenn die nicht auf 1866 wollen, dann halt 1333.
Schon mal ein Dank an dich.
Frohe Weihnachten und Guten Rutsch. ;)
ich habe ja net gesagt das es net geht. aber es is schwer.
jo ich wechsel auch wieda zu intel.
---------- Beitrag hinzugefügt um 21:40 ---------- Vorheriger Beitrag war um 21:40 ----------
bitte, wuensch ich dir auch.
