[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
sagt mal lohnt es sich von meinem def. CH5 auf ein neues CH5-Z umzusteigen? Ist ne Menge Holz und das GB-Board macht eigentlich was es soll. Bin mir unsicher ob ich da nochmal den Schinken hinter dem ASUS her werfen sollte.
Bin von dem -Z absolut begeistert. Bin von ud3 zum ud7 dann bei Asus gelandet. Perfekt.
Absolut mit 3 geköpften FX Cpus die besten Ergebnisse gehabt. Zum normalen Ch5 kann ich nichts sagen.
Gruss
Gesendet von meinem GT-I9300 mit der Hardwareluxx App
Falls es noch interessiert
der Unterschied vom Formula-Z zum normalen Formula
keine PCI Steckplätze (nur PCIe)
eine 2 stellige LED Debug Anzeige
Extreme Engine DIGI + II - neue MOSFET-ICs und DIGI + VRM Speicherchip
LN2 Modus-Schalter
BIOS Flashback
verändertes PCB-Layout
10 SATA 6Gbps-Ports: 8 intern, 2 eSATA
Fast Boot Schalter der für Windows8 , Bootzeiten verkürzen soll
ThunderBolt_Header
Creative Sound SupremeFX III
GameFirst in der Version II
anderer Southbridge Kühlkörper
ein 64mb Bios
mfG
Achim
@Achim,
hy, kurze Frage, wo befindet sich der ThunderBolt_Header?
Find diesen leider nicht beim C5F-Z.
Mit freundlichen Grüßen
Ah, ok, ist vorhanden, vielen Dank. :-)
Gibts da auch schon ne Erweiterungskarte? Ich habe mal ein wenig in Netz gesucht und nur die ASUS ThunderboltEX gefunden, welche zu folgenden Boards kompatibel ist:
ROG MAXIMUS VI EXTREME
TUF SABERTOOTH Z87
ASUS Z87-PRO
ASUS Z87-PRO (V EDITION)
ASUS Z87-PLUS
ASUS Z87-PLUS (VivoMouse EDITION)
ASUS Z87-A
ASUS Z87-A (NFC EXPRESS EDITION)
Welche Controllerkarte oder was genau kann man denn da dann ueberhaupt anschliessen? Hat jemand damit Erfahrung gemacht?
MfG,
Housemarke
bevor hier keiner antwortet...
Ich persönlich habe mich mit Thunderbolt nur rudimär auseinandergesetzt...
Für mich ist die erbrachte Leistung , zum Kostenfaktor , sehr eklatant...
Eben ein Apple Produkt...
seit 2011 ist es offiziell eingeführt, außer bei Apple Produkten , ist kaum eine Verbreitung zu bemerken...
Das Crosshair , gab es auch mal , im Bundle, mit Thunderbolt , als Steckkarte...
hat sich wohl nicht so gut verkauft , weil es das , so nicht mehr gibt...
Wie schon erwähnt , ist erstmal die Thunderbolt-Karte , recht teuer, und die entsprechenden Geräte dazu (mit Thunderbolt Controller) auch noch mal...
Ansonsten einfach mal Herrn Google befragen...
mfG
Achim
Klasse ASUS...diese ausführlichen Veränderungen des neuen BIOS :-/
Vllt kann mir ja hier jemand helfen ich habe zwar das CvZ aber ist ist ja recbt gleich zum non z.
Und zwar habe ich sehr oft das problem das ich den rechner einschalte und nach ca 3sek geht er wieder aus.
Ich muss dann das bios resetten lade meine vorheriges profil und dann geht es wieder finde ich aber sehr nervig.
Abstandshalter habe ich schon kontrolliert.
Nt ausgetauscht.
Bios version 16** bis 2*** (das aktuelle halt)
Aber ohne erfolg
Momentan teste ich es mit den bios optim settings.
Und danach nochmal bios 15** (Shutdowns on Crosshair V Formula Z)
Hatte das problem schonmal jemand?
Oder eine idee woran es liegen könnte?
Gruß nobody
Danke.
Den verdacht das es die speicher sind hatte ich auch, dann teste ich wohl mal andere.
Hy,
was hab ihr so an Overclockingergebnisse erreicht?
Habe momentan nen FX 8350, welcher bei 4,2 GHz bereits kapituliert. :-(
Habe etliche Foren durchforstet und etliche Einstellungen durchprobiert, ohne Erfolg.
Als Kühler kommt ein Scythe Mugen 2 zum Einsatz.
Die Temperatur ist unter Vollast im Standardtakt bei 48 - 50 Grad Celsius.
Angeblich soll die CPU bei 65 Grad Celsius von allein abschalten?
Hatte auch schon die Spannung angehoben, HT-Link-Takt, NB-CPU-Takt, jeweilige Spannungen, etc.
Es gibt ja genug Walkthroughs, aber irgendwie will die CPU net so recht.
Hat jemand von euch eine ähnliche Konstellation? Habe auch schon überlegt, ne WaKü einzubauen,
nur sollte zumindest etwas mehr Takt noch drin sein.
Vielleicht hat ja einer von euch ne Lösung parat. Gern könnt ihr auch eure Settings mal bloggen.
Mit freundlichen Grüßen,
Housemarke
ich hab permanent auf 4,9 laufen, vielleicht ne schrott cpu?
Hy,
ganz ehrlich, hab ich auch schon vermutet und vor ner halben Stunde ist das Mistding hochgegangen, im Standardtakt!!!! mit Standardeinstellungen!!!!
Ich könnt gerad richtig ko....!!!
Ich werd das Ding morgen mal versuchen zu tauschen, gibt ja drei Jahre Garantie.
Drückt mir die Daumen.
Housemarke
Wie soll man sich vorstellen das er hoch gegangen ist? Abgeraucht?
Eigentlich haben Board und CPU Schutzfunktionen die Beschädigungen im (irregulären/regulären) Betrieb verhindern sollen. Sofern du die nicht ausgeschaltet hast, kann da eigentlich nichts so einfach "hochgehen".
Wie Reous schon schrieb: Wie äußerte sich das in deinem Fall genau? Denn vielleicht lag es an etwas ganz anderem...
Guten Morgen,
ich war gerad am Diablo3 zocken, da fing das Bild an zu ruckeln, Frames gingen von 60 auf 15 und geringer, dann ging der Rechner aus und nicht wieder an. Diablo 3 ist CPU-lastig, daher vermutete ich eine zu hohe Temperatur. Dies war nicht das erste mal, hab die CPU seit nicht ganz zwei Wochen und die Temperatur war meist höher, als normal. Im Schnitt bei 50 Grad. Unter Standardeinstellungen lief die CPU nichtmal bei Prime95 stabil. Die Kühlung ist aber aussreichend gross, habe ja wie gesagt nen Scythe Mugen 2 mit zwei 120 mm Lüftern dran. Airflow wird in Form von vier Gehäuselüfter umgesetzt, zwei ziehen rein, zwei drücken raus. Gehäuse chieftec ch601 oder so. Ich bin mir ziemlich sicher, dass es die CPU zerheizt hat, denn ole88 schrieb ja, dass er seinen bei 4,9GHZ am laufen hat, was bei meinen ja nicht mal bei 4,2 machbar war. Ich werde heute versuchen, die CPU zu tauschen, danach weiss ich mehr. Leider habe ich keine Möglichkeit, die CPU anderweitig zu testen. Das CPU und Board Sicherheitsschaltungen haben, ist mir bekannt, nur kann man diese doch gar nicht deaktivieren? Zumindest CPU-seitig, beim Board habe ich ehrlich gesagt, noch nicht nachgesehen, würde ich aber auch nicht deaktivieren. Ich habe etliche male Spannungen und Takte überprüft, Temperaturen im Bios und ím Windows überwacht, aber wie gesagt, ich vermute wirklich ne Ausschuss-CPU.
Mfg
Housemarke
Nach der Beschreibung kann es auch das Netzteil sein. Halte uns auf jeden Fall auf dem laufenden. Waren die 50 Grad eigentlich von dem Mainboard Sensor oder die Kern Temperatur?
Hy,
an das Netzteil habe ich auch schon gedacht. Ich bekomme in den nächsten drei Werktagen Bescheid, ob die CPU defekt ist oder nicht.
Die 50 Grad standen im Bios und im CoreTemp bzw. im ASUS-Tool.
Housemarke
So,
es gib Neuigkeiten.
Trommelwirbel...................es war das Netzteil. Die CPU funktioniert einwandfrei. Das Kuriose an der Sache ist, dass Festplatten, Lüfter und Grafikkartenlüfter anliefen und die LEDs auf dem Board auch an waren, egal. Jetzt werkelt er wieder fleissig.
Schönes Wochenende euch allen.
Housemarke
Klasse :). Hatte desletzt ein ähnlicher Fall, deswegen vermutete ich auch das NT.
Wie siehts jetzt mit dem übertakten aus? Gehen jetzt auch mehr wie 4.2GHz?
Hatte ihn kurz mal auf 4,4 4,6 und 4,8; leider net stabil. Muss ich mir mal in Ruhe anschauen, jetzt gehts erstmal auf die Piste mit den Jungs :P
Schönen Abend. ;-)
Hey,
also, momentan läuft er bei 4,4 GHz und VCore 1,35. NB Frequenz 2600 MHz. Mehr schafft er nicht stabil. Temperatur liegt zwischen 49 und 58 Grad laut Asus AI Suite und CoreTemp. Wie hoch habt ihr euren bekommen? Welche Kühlung benutzt ihr?
MfG,
Housemarke
Das sieht doch ganz gut aus. Und alles nur wegen dem Netzteil. Ich lasse die CPU fuer 24/7 auch nur auf 3.6GHz laufen. Prime Runs findest du im AMD GHz Club.
Ja, dann versuch ich doch mal die 4,5 GHz :-) Ich hab einen FA1349PGY Fx´ler, mal schauen, was da so fuer 4,5 GHz benoetigt wird.
MfG,
Housemarke
Top :d. Testest du noch weiter?
