[Sammelthread] ASUS M4A88TD-M Evo/USB3, 880G
Link Geizhals ab: 87€
Herstellerlink
Spezifikationen:
Code:
[b]CPU[/b]
AMD Supports 45nm CPU
AMD Cool 'n' Quiet™ Technology Socket AM3 ;Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
[b]Chipsatz[/b]
AMD 880G/SB850
System Bus	5200/Up to ; HyperTransport™ 3.0 MT/s
[b]Memory[/b]
4 x DIMM, 16 GB, DDR3 2000*/1600/1333/1066 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Due to CPU spec., AMD 100 and 200 series CPUs support up to DDR3 1066Mhz. With ASUS design, this motherboard can support up to DDR3 1333MHz.
**Due to OS limitation, when installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
***Refer to www.asus.com for the memory QVL (Qualified Vendors Lists).
[b]Expansion Slots[/b]
1 x PCIe 2.0 x16
2 x PCI e x1
1 x PCI
[b]VGA[/b]
Integrated ATI Radeon™ HD 4250 GPU
SidePort Memory - onboard 128MB DDR3 1333 memory
Dual independent displays support with HDMI/DVI and D-Sub
Supports HDMI with max. resolution 1920 x 1200 (1080P)
Supports DVI with max. resolution 2560x1600 @60Hz
Supports D-Sub with max. resolution 2560x1440 @75Hz
Supports Microsoft® DirectX 10.1, OpenGL 2.0, Shader Model 4.1
Hardware Decode Acceleration for H.264, VC-1, and MPEG-2
Max. shared memory of 1GB
Hybrid CrossFireX™ Support
[b]Storage[/b]
SB850 Chipset
1 x eSATA port (6Gb/s ready)
5 x SATA 6.0 Gb/s ports 0,1,5,10 Support RAID VIA VT6415 PATA controller
UltraDMA 133/100 for up to 2 PATA devices
1 x
[b]LAN[/b]
Realtek® 8111E Gigabit LAN controller featuring AI NET2
[b]Audio[/b]	Realtek® ALC 892 8-Channel High Definition Audio CODEC
- Supports 192kHz/ 24bit BD Lossless Sound
- Supports Jack-Detection, Multi-Streaming, and Front Panel Jack-Retasking
- Optical S/PDIF Out port at back I/O
[b]IEEE 1394[/b]
2 VIA® VT6315N controller supports x 1394a ports (1 at mid-board, 1 at back panel)
[b]USB[/b]
2 x USB 3.0 ports (@PCIE USB3 card)
14 x USB 2.0/1.1 ports (8 ports at mid-board, 6 ports at back panel)
[b]ASUS AI Lifestyle Features[/b]
ASUS Xtreme Design
ASUS Hybrid Processor - TurboV EVO
- Turbo Unlocker, Auto Tuning, TurboV, CPU Level UP, and GPU Boost
ASUS Hybrid Switch
- Core Unlocker
- Turbo Key II
ASUS Hybrid OS -- Express Gate
ASUS Power Solutions
- 4+1 Phase Power Design
- ASUS Anti-Surge Protection
- ASUS EPU
ASUS Exclusive Features
- MemOK!
ASUS Quiet Thermal Solution
- ASUS Fanless Design: Heat sink solution
- ASUS FanXpert
ASUS EZ DIY
- ASUS Q-Shield
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS MyLogo 2
- Multi-language BIOS
[b]Overclocking Features[/b]
Precision Tweaker - vCore: Adjustable CPU voltage at 0.003125V increment
- vDIMM: 64-step DRAM voltage control
- vChipset (NB): 64-step Chipset voltage control
2
SFS (Stepless Frequency Selection)
- HT tuning from 100MHz up to 550MHz at 1MHz increment
- PCI Express frequency tuning from 100MHz 150MHz at 1MHz
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
[b]Back Panel I/O Ports[/b]
x DVI
1 x D-Sub
1 x PS/2 Keyboard/Mouse Combo port
1 2 x USB 3.0 ports (@PCIE USB3 card)
6 x USB 2.0/1.1 ports 1 x HDMI
x External SATA
1 (Optical)
x S/PDIF Out 1 x IEEE 1394a
1 x RJ45 port
1 8 Channel Audio I/O
[b]Internal I/O Connectors[/b]
x USB connectors support additional 8 USB 2.0/1.1 ports
4 5 x SATA 6Gb/s connectors
1 x CPU Fan connector
1 x Chassis Fan connector
1 x Power Fan connector
1 x IEEE1394a connector
1 x S/PDIF Out Header
1 x Core Unlocker Switch
1 x Turbo Key II Switch
1 x MemOK! Button
Front panel audio connector
1 x COM connector
1 x LPT connector
1 x Clear CMOS jumper
1 x 24-pin ATX Power connector
1 x 4-pin ATX 12V Power connector
System Panel
x IDE connector
1
[b]BIOS[/b]
16 Mb Flash ROM , AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a
[b]Manageability[/b]
WOR by Ring,WOL by PME,WOR by PME,WOR by PME
[b]Accessories	[/b]
1 x PCIE USB3 card
1 x Ultra DMA 133/100 cable
2 x Serial ATA 6.0Gb/s cables
1 x Q-Shield
1 x User's manual & Support DVD for M4A88TD-M EVO
1 x User's manual & Support DVD for PCIE USB3
[b]Support CD[/b]
Drivers
ASUS Utilities
Anti-virus software (OEM version)
ASUS Update
[b]Form Factor[/b]
uATX Form Factor
9.6 inch x 9.6 inch 24.4 cm x 24.4 cm )
Das Bios:
Impressionen:
Übertaktung:
wird nachgereicht
Kühler welche passen oder nicht:
Luftkühlung:
Wasserkühlung:
Bios:
Version 1602
Update LAN option ROM to 2.35.
Version 1502
Set C1E function to enable as default.
Version 1404
Improve Auto Tuning function.
Version 1301
Improve system preformance.
Version 1012
Initial release.
Downloads:
- Bios / Treiber / Handbuch
Was ist denn die minimale Speicherspannung, die man im BIOS einstellen kann?
ich kann folgendes einstellen beim RAM
1,200
1,275
1,350
1,425
1,500
ab hier gehts in 0,015 Schritten weiter
Habe das Brett bei bekannten verbaut. Günstiger kommt man imo nicht an eine SB850 heran ;)
Das Board hat mir sehr gut gefallen. Habe ich sicher nicht zum letzten mal empfohlen.
Danke für den Sammelfred.
Bios Screens eingefügt
Schaut euch mal die Bilder an und achtet auf die DIMM Sockel!
MB und USB 3.0 Karte waren in einer normalen antistatischen Hülle, die nicht verschlossen (der normale Tesastreifen) war.
die Karte ist bei mir auch nur in der Folie gewesen, aber nicht versiegelt. Das mit den RAM Slots sieht schon komisch aus.
Ich schicke das Board zurück, das ist mir echt zu mysteriös.
Hat noch jemand diese von mir gepostete Variante (siehe Bilder!)?
wird einfach ein Rückläufer sein... würds erstmal testen, bevor ich mir den Streß mache alles zurück zu senden.
Ich hatte es von Drivecity, war auch nur noch 1 Stück lagernd zum Zeitpunkt der Bestellung.
Da auch dem Mainboard auch noch massenhaft Fingerabdrücke waren, ist das mit dem Rückläufer nicht ausgeschlossen.
Egal, den Stress der keiner ist, tue ich mir gerne an, denn ich will Neuware die ich schließlich auch bezahlt hatte.
Das neue Board ist gerade angeliefert worden, ging ja wieder mal fix.
Ich werde heute Nachtmittag berichten.
Tada, das neue Board ist angekommen, aufgemacht und nicht schlecht gestaunt: 100% identisch, also auch die gleichen DIMM Sockets wie unter #6.
Anscheinend wird Asus die Serie enstsprechend verändert haben.
Jetzt gehts es an den Zusammenbau des Rechners :-)
Moin Leute,
ich hab euch eben über Google gefunden. ;)
Das Board hab ich gestern verbaut bei meiner Freundin...
Folgende Konfiguration:
- Gehäuse: Lian Li PC-V351A
- Mainboard: Asus M4A88TD-M EVO
- CPU: AMD Athlon II X2 240 2,8Ghz
- RAM: Kingston ValueRAM KVR4666D3N9K2/2G
- Cooler: Scythe Big Shuriken
- Netzteil: Seasonic S12II-330 Bronze 330W
- HDD: Samsung HD204UI 2TB
- Brenner: Optiarc AD-5260S-0S SATA Silber
- WLAN: Linksys WMP600N
- OS: Win 7 Home Premium 32bit
Nun, das war so eine Mischung aus Vernunft und gutem Design ;) Wir brauchen quasi nur einen Office-Rechner, der auch mal einen HD Film abspielen kann. In meinen Augen reicht die Konfiguration dafür aus.
Kommen wir mal zu meinem Problem:
Kann ich die Lüfter vom Lian Li Gehäuse (3 an der Zahl, einer hinten, der die Festplatten kühlt und 2 vorne, die kalte Luft ansaugen) alle an den einen Anschluß am Mainboard (CHA_FAN) anschließen?
Oder wie handhabt ihr das? Momentan hängen Sie direkt am Strom. Sind nicht sonderlich laut, aber muss ja nicht sein.
Ach ja: und wieso hat das Seasonic keinen PWR_FAN-Anschluß? Hat das einen Sensor eingebaut?
Danke für die Hilfe!
Seasonic hat das normalerweise nicht drin, bzw haben die wenigsten.
Würde nicht mehr als 2 Lüfter pro Anschluss dran machen.
Mach doch den Hinteren Lüfter an den Anschluss beim Soundport und die 2 vorderen Lüfter an den Anschluss neben den CPU_Fan Anschluss dran.
Ich habe eine ähnliche Konfiguration, siehe Signatur ;-)
Ich würde nicht alle Lüfter an einen Anschluß anklemmen, das packt der eine Pin Anschluß nicht dauerhaft.
Ich habe es mit einem 12 auf 7 Volt Adpater gelöst, alle Lüfter laufen also permanent auf 7 Volt und sind somit flüsterleise.
Kannst du dir mal bitte meinen Beitrag #6 ansehen und checken, ob deine DIMM Anschlüsse identisch sind wie auf meinem Bild.
Danke! :wink:
Moin!
Danke für die Tipps, woher bekommt man einen 12V auf 7V-Adapter?
Theoretisch könnte ich doch ein Poti dazwischen setzen? Aber eigentlich hätte ich schon gern Ruhe im Rechner... :/
Also ihre DIMM-Plätze sehen genau so aus. Der Aufkleber war etwas gewellt aber das Board war 100%ig neu... hab fast alles von Mindfactory, den Lüfter und den RAM von CSV Berlin... Ach ja das Gehäuse ist von Hardwareversand, da wir erst ein falsches bestellt hatten (bin mit den Boardgrößen etwas durcheinander gekommen...) ;)
was genau haben die denn geändert?
Ich persönlich verwende nur Intel-Zeugs, so dass ich das eher schlecht beurteilen kann...
Also ich hab nun folgendes gemacht:
Den Lüfter für die Festplatten (hinten) hab ich auf PWR_FAN gesteckt und die beiden vorderen auf CHA_FAN mit einer Y-Weiche. Funktioniert prima.
:fresse2:
In #15 hatte ich dich gebeten, meine in #6 geposteten Bilder des Boards wegen der DIMM Sockel zu checken, ob die bei deinem Board identisch sind!
Schaue dir das Bild noch einmal an, hast du wie auf dem Bild auch unterschiedliche Befestigungsklammern auf deinem Board?
okay, nun weiß ich was du meinst ;) Das kann ich Dir erst sagen, wenn ich den Rechner mal wieder aufmache - ich hoffe nicht so bald ;) Sorry...
Moin!
Sagt mal was läuft hier falsch? Verbraucht das AMD-System im Standby bzw. wenn es AUS (!) ist wirklich 45 Watt?
Liegt das am Netzteil? Oder am Board? Oder generell an AMD?
Anbei mal ein Messergebnis von heute. Gemessen wurde mit einem hochwertigen Strommeßgerät.
Zum Vergleich links mal mein Core i7-System, welches bald 2 Jahre alt wird... bin ja etwas schockiert.
Könnt ihr ähnliches berichten?
Im Anhang mal ein Screenshot!!
Danke!!
Womit wurde das gemessen? Die Messergebnisse sind ja alle komplett daneben, selbst die für Last.
45 Watt im ausgeschalteten Zustand kann nicht sein, da muss ein Fehler vorliegen.
Das hat nichts mit Intel oder AMD zu tun.
...und über 100w idle? Wie gesagt, da stimmt keiner der Messwerte.
Asus epu
Mein ASUS M4A88TD-M Evo/USB3 unterstützt EPU und ich habe eben mit einem Strommessgerät die beiden Einstellungen Hochleistungsmodus und maximaler Energiesparmodus gestestet (System siehe Signatur):
Hochleistungsmodus IDLE: 95 Watt
Maximaler Energiesparmodus: 56 Watt
Im max. Energiesparmodus takten alle vier Kerne bis max. 800MHz, was für Internet, Office, Youtube und selbst .mkv Full HD Wiedergabe vollkommen reicht.
Natürlich kann man auch per BIOS undervolten, aber für alle denen dies nicht möglich ist oder sich unsicher sind, ist EPU ein leicht zu bedienenes Tool mit echtem Stromspareffekt.
Bislang habe ich mit dem Tool keine Schwierigkeiten und würde gerne euren Eindruck hören.
ich muss meine Messung doch noch relativieren.
Im Standby verbraucht unser Athlon-PC doch nur unter 2 Watt und wenn er aus ist geht auch der Verbrauch auf 0.
Wahrscheinlich hätten wir das Meßgerät etwas länger in der Steckdose lassen sollen....
Den Idle- und Maximalverbrauch werde ich noch einmal neu messen und dann meine Grafik updaten!
Mein System mit Be Quiet Straight Power E8 400 Watt bleibt unter 1 Watt im Standby.
Deine Werte waren auch echt unrealistisch ;-)
Hallo zusammen,
das M4A88TD-M EVO/USB3 habe ich nun seit einem halben Jahr in Verwendung mit Windows 7 x64. Nun habe ich mich wegen diverser Macken (Catalyst Control Center stürzt ab, Minianwendungen auf dem Desktop stürzen ab, Bluescreens wegen Speicherproblemen) zu einem bereits erfolgten BIOS-Update entschieden. Lief alles glatt.
Nun stehe ich davor, mein OS neu zu installieren. Auf der Asus-Homepage sind leider viele Treiber veraltet. Daher möchte ich diese aktuelle Catalyst Software Suite (10.12) installieren. Spricht da etwas gegen? In deutscher Sprache scheint sie allerdings nicht verfügbar zu sein - egal. Auf der Asus-Downloadseite gibt es nämlich nur "AMD VGA Driver V8.710.0.0"
Zudem stellt die Asus-Sete einen Chipsatztreiber namens "AMD Chipset Driver V1.3.2.54" zur Verfügung. Muss ich diesen installieren, oder besteht die Möglichkeit auch da etwas neueres zu nehmen. Auf der AMD-Seite gibt es hier einen South Bridge Driver. Ist das der Chipsatztreiber?
Auf der Asus-Downloadseite gibt es drei verschiedene "Realtek LAN-Driver" in unterschiedlichen Versionen. Gehe ich richtig in der Annahme dass der "Realtek 10/100/1000 PCI-E LAN Driver V7.23.623.2010" hier der aktuellste und damit richtige ist?`Oder gibt es da von Realtek direkt etwas aktuelles und vor allem kompatibles?
Viele Grüße!
SH
