Dark Ice
Urgestein
deine BIOS-settings würden mich mal interessieren ...
Ratio CMOS Setting: 8
FSB Frequency: 450
CPU Clock Skew: Auto
NB Clock Skew: Auto
FSB Strap to North Bridge: Auto
DRAM Frequency: DDR2-1040MHz
DRAM CLK Skew on Channel A1: Auto
DRAM CLK Skew on Channel A2: Auto
DRAM CLK Skew on Channel B1: Auto
DRAM CLK Skew on Channel B2: Auto
DRAM Timing Control: Manual
1st Information:
CAS# Latency: 5 DRAM clocks
DRAM RAS# to CAS# Delay: 5 DRAM clocks
DRAM RAS# Precharge: 5 DRAM clocks
DRAM RAS# Activate to Precharge: 15 DRAM clocks
RAS# to RAS# Delay: Auto
Row Refresh Recycle Time: Auto
Write Recovery Time: Auto
Read to Precharge Time: Auto
2nd Information:
Read to Write Delay (S/D): Auto
Write to Read Delay (S): Auto
Write to Read Delay (D): Auto
Read to Read Delay (S): Auto
Read to Read Delay (D): Auto
Write to Write Delay (S): Auto
Write to Write Delay (D): Auto
3rd Information:
Write to PRE Delay: Auto
Read to PRE Delay: Auto
PRE to PRE Delay: Auto
All PRE to ACT Delay:Auto
All PRE to REF Delay: Auto
DRAM Static Read Control: Auto
DRAM Read Training: Auto
MEM. OC Charger: Auto
Ai Clock Twister: Auto
Ai Transaction Booster: Auto
Common Performance Level: Auto
PCIE Frequency: 101
CPU Voltage: 1.43
CPU PLL Voltage: 1.50
FSB Termination Voltage:1.15
DRAM Voltage:1.90
North Bridge Voltage: 1.14
South Bridge 1.5 Voltage: 1.5
South Bridge 1.1 Voltage: 1.1
CPU GTL Reference (0): Auto
CPU GTL Reference (1): Auto
CPU GTL Reference (2): Auto
CPU GTL Reference (3): Auto
NB GTL Reference: Auto
DDR2 ChA Reference Voltage: Auto
DDR2 ChB Reference Voltage: Auto
North Bridge DDR Reference: Auto
CPU Configuration:
C1E Support: Disabled
Max CPUID Value Limit: Disabled
Intel Virtualization Tech: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
Load-Line Calibration: Enabled
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
Moin Leute.
Ich habe mal 3 Fragen zu dem Board:
1. Das gemoddete Bios von e.v.o., wer hat das schon probiert und wie waren die Erfahrungen.
2. Das Thema gab es zwar auch beim Maximus Formula, aber um sicher zu gehen: Kann man den PCIex1 für die Board-Soundkarte auch für eine X-Fi PCIex1 verwendet werden oder funktioniert da nur die Karte vom Board?
3. Hat schon jemand vom X38 ein Raid0 auf den P45 mitgenommen oder es versucht?
MfG eSp!s0
# Welche Version der Northbridge verbaut Asus?
Seit mitte März 2009 gibt es scheinbar auch MIIF mit A3. Bisher nur im Ausland (USA).
und:# Audio
Sound Blaster X-Fi Utility - 1.0
???* SATA
SiI57x3 Firmware for Upgrade by GUI - 1.1576
Wofür genau ist eigentlich:
und:
OB es das SP2 war oder das ich den Mischbetrieb mit den HD´s geändert hatte. Oder einfach ein frisches neues OS kann ich nicht sagen. Nur das es z.Z. bei mir nicht mehr vorhanden ist. Ansonsten gibt es ja noch die Lösung mit den Silicon-Controller. Was meinst du mit der gesunkenen Geschwindigkeit? Beim abspielen oder brennen? Da ich auch eine Zeit lang da mein Brenner hatte, ist mir das nicht aufgefallen.Ist das Problem mit der Klappe jetzt also duch SP2 gelöst worden?! Ich hatte mit SP1 und dem Mod-BIOS weiterhin den Bug und habe ihn dadruch behoben, dass ich den RAID-Verbund an den Silicon-Controller gehangen habe ... was aber mit einer gesunkenen Geschwindigkeit verbunden ist.
Das erste ist für die Soundkarte damit wird eine Soundblaster Karte emuliert.
Das zweite ist für zweiten Raidcontroller (nicht Intel) zum Firmware Updaten.
danke für den shot. wie sieht es mit oc bei quad aus ? mit A3 chip sollte 500fsb mit quad kein problem sein denke ich oder ?
Die LED auf der Platine kann man im Bios ausschalten, aber nicht einzeln, wenn ich mich recht erinnere.
Hallo Leute,
kleine Frage: Ich bin stolzer Besitzer des Maximus II Formular und hab nen Q9550 drauf. Seit ich die neuste BIOS version drauf hab behauptet Everest und auch die BIOS Überwachung mein CPU hat aktuell 13°C unter Last auch mal 16°C. Wäre natürlich Klasse wenn die einzelnen Kerne nicht deutlich mehr hätten. Meist so zwischen 42 und 32.
Hat jemand änliche Probleme/Anzeigen oder weiß woran das Ganze liegt? Hoffe mal nicht dass mein CPU oder das Board im Eimer sind.
Gruss Jan
So nun brauch ich auch mal OC tipps! Also ich hab ja DDR1000er Ram auf dem Board erbaut die bis jetzt aber immer mit 800mhz liefen, da ich den FSB:Ram immer auf 1:1 hatte, wenn ich den aber verstelle hab ich nur noch Bluescreens!! Also woran kann das liegen? Die Ram hab ich schon mit 2,1V laufen, soll ich die NB oder SB Spannungen erhöhen (beide sind auf dem Standartwert)?
