@Wynter dann fang an zu basteln , warte schon gespannt auf das Postville Ergebnis
Vielleicht für den einen oder anderen interessant, Vergleich zwischen MIVE und UD7 was die Spannungsversorgung, Temps usw angeht....
Sandy Bridge : Let the battle begin... - kingpincooling.com
@Wynter dann fang an zu basteln , warte schon gespannt auf das Postville Ergebnis![]()
von wann waren die infos von Asus zu Mix Computer , hatten die heute diesbezüglich Kontakt mit Asus ?
Welche batch und was braucht die bei 4,5 und 5?
---------- Beitrag hinzugefügt um 15:51 ---------- Vorheriger Beitrag war um 15:50 ----------
Welches BIOS habt Ihr und welche Einstellungen?
Try this please, shutdown the system. Remove power from the power supply for a minute or two, clear CMOS, then reattach power. Startup, enter UEFI and input your required settings, for your memory please manually change the memory speed, timings and dram voltage based on your kit specifications. Reboot, enter Windows, then shutdown again. Now restart the system. This will clear the ME and memory/CPU tables. It could be that after flashing the BIOS up from a lower version that the tables were never properly cleared. This is especially true if the MEI driver is not loaded. Let me know if this helps, if not we will go to step two.
In testing I found that the voltages are slightly lower overall but stability was still maintained. We also changed how the auto settings work on C1E, C3, and C6 and are dependent now on EIST being enabled or not. In addition LLC was fine tuned so previous settings might not work as before. If you continue to have problems, please PM me and we will work it out offline.
Stoppt euerBoard beim Booten auch häufiger mal bei der 64?
