[Sammelthread] Asus Maximus V Gene R.O.G (Intel Z77)
Willkommen im Sammelthread zum ...
Layout:
weitere Bilder:
Spezifikationen:
Chipset Intel® Z77
Memory 4 x DIMM, Max. 32GB, DDR3 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic Integrated Graphics Processor
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support Supports NVIDIA® SLI™ Technology
Supports AMD CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *1
Expansion Slots 2 x PCIe 3.0/2.0 x16 (x16 or dual x8, red) *2
1 x PCIe 2.0 x4 (black)
1 x mini-PCIe 2.0 x1 *3
Storage Intel® Z77 chipset : *4
2 x SATA 6Gb/s port(s), red
2 x SATA 3Gb/s port(s), black
1 x eSATA 3Gb/s port(s), red
1 x mini-SATA 3Gb/s port(s), black
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *5
ASMedia® PCIe SATA controller : *6
LAN Intel®, 1 x Gigabit LAN Controller(s)
Audio SupremeFX III built-in 8-Channel High Definition Audio CODEC
- Output Signal-to-Noise Ratio (A-Weighted): 110 dB
- Output THD+N at 1kHz: 95 dB
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- SupremeFX Shielding™ Technology
- 1500 uF Audio Power Capacitor
- Gold-plated jacks
- X-Fi® Xtreme Fidelity™
- EAX® Advanced™ HD 5.0
- THX® TruStudio PRO™
- Creative ALchemy
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
USB Ports Intel® Z77 chipset :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
8 x USB 2.0 port(s) (4 at back panel, black+white, 4 at mid-board)
ASMedia® USB 3.0 controller :
2 x USB 3.0 port(s) (2 at back panel, blue)
Overclocking Features mPCIe Combo™ (mPCIe/mSATA combo card)
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase QPI/DRAM power design
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
GameFirst
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Backpanel:
1 x DisplayPort
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
4 x USB 3.0
4 x USB 2.0 (one port can be switched to ROG Connect)
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x Clear CMOS button(s)
1 x ROG Connect On/ Off switch(es)
OnBoard-Anschlüsse:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
4 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
8 x ProbeIt Measurement Points
1 x Power-on button(s)
1 x Reset button(s)
1 x Go Button(s)
1 x mPCIe Combo header(s)
Lieferumfang:
User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x ROG Connect cable(s)
1 x 12 in 1 ROG Cable Label(s)
1 x ROG Door Hanger(s)
UEFI SCREENS:
Links:
Preisvergleich
Produktseite / Info beim Hersteller
Downloads: Bios, Treiber, Handbuch,...
Downloads: Bios, Treiber, Handbuch... Direktlinks
+ Handbuch MAXIMUS V GENE User's Manual (English)
+ Maximus V GENE Bios 0402 - [First Release Bios]
+ Maximus V GENE Bios 0503 - [1.Improve system stability. 2.Enhance compatibility with some USB devices.]
+ Maximus V GENE Bios 0602 - [Official Beta Bios Asus FTP]
+ Maximus V GENE Bios 0650 - [Beta Bios Shamino]
+ Maximus V GENE Bios 0701 - [Beta Bios Shamino]
+ Maximus V GENE Bios 0805 - [Added DRAM Tuning Improved Performance Default enable thunder bolt support IRST Update]
+ Maximus V GENE Bios 0880 - [Updates system compatibility Improves performance Improves DRAM Overclocking]
+ Maximus V GENE Bios 0881 - [fixed data vref bug ]
+ Treiber Chipsatz: Intel Chipset Software Installation Utility V9.3.0.1019 XpVistaWin7
+ Treiber Chipsatz: Intel Chipset Software Installation Utility V9.3.0.1020 XpVistaWin7
+ Treiber Chipsatz: Intel Management Interface Engine V8.0.0.1262 XpVistaWin7
+ Treiber Chipsatz: Intel Management Interface Engine V8.0.4.1441 Win7 32bit & 64bit
+ Treiber Chipsatz: Intel Management Interface Engine V8.0.10.1464 Win7 32bit & 64bit Windows XP HE MCE Pro 32bit & 64 Bit
+ Treiber SATA: Intel® Rapid Storage Technology V11.0.0.1032 Windows XP/7 32bit & 64bit (WHQL)
+ Treiber SATA: Intel® Rapid Storage Technology V11.1.0.1006 Windows XP/7 32bit & 64bit.(WHQL)
+ Treiber SATA: Intel® Rapid Start Technology Software V1.0.0.1022 for Windows 7 32bit & 64bit
+ Treiber SATA: Asmedia SATA Controller V1.3.4.0 Windows XP 32bit & XP 64bit & Win7 32bit & Win7 64bit (WHQL)
+ Treiber USB: Intel USB 3.0 Driver V1.0.1.209 Win7 32bit & Win7 64bit (WHQL)
+ Treiber USB: Intel USB 3.0 Driver V1.0.4.220 Win7 32bit & Win7 64bit (WHQL)
+ Treiber USB: Asmedia USB 3.0 V1.14.3.0 Windows XP 32bit & XP 64bit & Win7 32bit & Win7 64bit (WHQL)
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.6.0.0 WHQL XpWin7
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.8.1 Win7 32-Bit
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.8.1 Win7 64-Bit
+ Treiber LAN: Intel Gigabit Ethernet Driver V17.0.0 Win7 32-Bit
+ Treiber LAN: Intel Gigabit Ethernet Driver V17.0.0 Win7 64-Bit
+ Treiber Video: Intel Graphics Accelerator V8.15.10.2598 Windows Win7 32bit & Win7 64bit (WHQL)
+ Treiber Video: Intel® HD Graphics Driver V8.15.10.2712 Win7 32-Bit
+ Treiber Video: Intel® HD Graphics Driver V8.15.10.2712 Win7 64-Bit
+ Treiber Video: Intel® HD Graphics Driver 15.26.8.2696 Win7 32-Bit
+ Treiber Video: Intel® HD Graphics Driver 15.26.8.64.2696 Win7 64-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.112.20176 Win7 32-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.112.20176 Win7 64-Bit
+ Treiber Video: Lucidlogix VIRTU V2111120856 Win7
+ Utility Video: LucidLogix Virtu MVP Wizard V1.00.08 for Windows Win7 32bit & Win7 64bit
+ Utility Video: Lucid Virtu Universal MVP Software V2.1.110.19997
+ Treiber Audio: Realtek Audio Driver Version 5.10.0.6570 & 6.0.1.6570 WHQL XpVistaWin7
+ Treiber Audio: Realtek Audio Driver Version 5.10.0.6602 & 6.0.1.6602 WHQL XpVistaWin7
+ Utility Audio: Sound Blaster X-Fi 2 Utility Package V1.0 (R11) Windows 7
+ ASUS AI Suite II 1.0.2.27 Windows XP Win7
+ ASUS AI Suite II 1.0.2.29 Windows XP Win7
+ ROG GameFirst V1.0.1.09
+ ROG ConnectPlus V1.0.0.14
+ ROG Connect V1.0.6.03
+ ROG CPU-Z V1.59.2
+ ROG Theme V1.0.0.12
+ DAEMON Tools Pro V44003120221 XP Win7
Besonderheiten:
Reviews:
[url=http://www.overclockers.com/asus-maximus-v-gene-motherboard-review/]ASUS Maximus V GENE Motherboard Review | Overclockers.com
ASUS Maximus V GENE (Intel Z77) Motherboard Review | TweakTown USA Edition
ASUS Maximus V GENE Motherboard review | guru3d.com
ASUS Maximus V Gene Overclocking Review And Benchmarks | motherboards.org
Asus Maximus Gene V Preview | lanoc.org
ASUS Maximus V GENE Review | votez.net
Asus Maximus V Gene (Z77) Motherboard Sandy Bridge Review | eTeknix.com
Intel Z77 Chipset Launch Roundup - ASUS Maximus V Gene | hardwareheaven.com
ASUS Maximus V Gene| AwardFabrik.de
Au-Ja! - ASUS Maximus V Gene | au-ja.de
Weitere Infos und nützliche Links:
- Maximus IV GENE-Z BIOS Guide - Overclocking
Kompatibilität Arbeitsspeicher:
QVL - QUALIFIED VENDOR LIST - DOWNLOAD
User Berichte:
Kompatibilität CPU Kühler:
+ Corsair H60 (Preisvergleich)(Foto von Emiras)
+ Corsair H70 (Preisvergleich)
+ EKL Alpenföhn K2 (Preisvergleich)
+ Noctua NH-C14 (Preisvergleich)
+ Noctua NH-D14 (Preisvergleich)
+ Prolimatech Genesis (Preisvergleich)
+ Prolimatech Megahalems (Preisvergleich)
+ Prolimatech Black Series Megahalems (Preisvergleich)
+ Thermalright Venomous-x (Preisvergleich)
+ Thermalright HR-02 Macho (Preisvergleich)
+ Thermalright Silver Arrow (Preisvergleich)
Overclocking Ergebnis:
Da ich meinen schönen 3770K abgegeben hab werde ich auch kaum mehr als 4.8 packen - daher lasse ich auch das 1604 drauf.
Hoffe dass es für Sockel 1150 und Haswell wieder ein Gene gibt.
Habe jetzt die TridentX Cl9 2400 am start.
Mit 2600 Mhz komme ich zwar ins Windows aber nach kurzer Zeit wird das Bild zu Klötzchen und die Kiste hängt kurze Zeit
später. Liegt das daran das ich die iGPU mit nutze oder kann es sein das die CPU limitiert?
Habe für die 2400 die Tight Samsung Settings geladen, Performance ist ohne tweaking echt bescheiden. Habe echt Probleme die Dinger Primstable zu bekommen.
Willkommen @Wernersen
Mit der iGPU wird das schon schwieriger. Und die Presets sind zu scharf für 2600 - also ohne manuelle Sub-Timings wird das eher nichts.
hmm, zu scharf ist gut. Finde die Performance eher mies bei 2400 mit den Presets. Wenn ich die Timings noch weiter runter schrauben muss bringt mir der Takt auch nichts mehr. Meine G.Skill PIs haben da bedeutend mehr power bei bei CL7 2200.
Weisst Du ob die TridentX mit Boundary 5 laufen?
Dass der Durchsatz der Hyk0 Net so gut ist wie mit hch9 bei vergleichbaren Timings ist auch nix neues.
Welche Veränderungen hast bei den Einstellungen für die CPU vorgenommen ?
Die 800K scheinen jetzt zu laufen, sind gleich hoffentlich das 2te mal durch.
Scheinbar brauchen die ein wenig mehr VCCSA.
Guckst Du:
Ist klar,
nachdem ich die VCCSA auf 1,100 und VTT auf 1,125 gesetzt habe ist der 800K lauf jetzt 2mal durch.
War scheinbar zu geizig damit :)
Mal gucken wie weit ich die Dinger noch tweaken kann
Aber nicht die mit 1,26VCC oder? Das war ja echt nen schickes Teil.
Ist klar,
VCCSA auf 1,1 ? Finde ich nen bisschen hoch. Geht es gar nicht darunter?
So habe nun ein wenig mit den TridentX getestet,
CL 9 - 2400 brauchen Sie bei mir 1,650 Volt VDimm.
CL 10-11-11-21 laufen mit 1,525 Volt VDimm die 800K Prime. Habe die Timings noch ein wenig gestrafft und muss sagen das der Unterschied zwischen CL9-12-12 und CL10-11-11 minimal ist.
@GT3, ja finde ich auch ein wenig hoch deshalb habe ich mich auch so schwer getan die Dinger 800K Prime stable zu bekommen.
Allerdings bezieht sich das auf CL9 und wenn ich mir den Unteschied bei der Vdimm zwischen CL9 und CL10 ansehe, erhoffe ich mir die VCCSA noch zu drücken.
Werde nochmal gucken ob die CL10 mit 2600 und vernünftigen zu realisieren sind.
Doch der is weg - freut sich dann ein anderer Luxxer drüber.
Der neue benötigt für den selben Takt mal eben 0,1 mehr VCore.
Passt er also so das ich den ersten nutzten kann?
Ich musste bei meinem Genesis was zwischen den Kühler und die Grafikkarte im oberen Slot
stecken, sonst liegt der Genesis an der Grafikkarte-Platinenseite an
Sind sehr gute, na schaun wir mal 1.575V wäre auch noch ok, sonst besser CL10 fahren.
Lol die ganze Zeit war alles ok aber vorher hab ich es auch festgestellt. So ein Dreck man :banghead::(
Der sich wie äußert ? Irgendwie habe ich das Problem nicht ... mit fixer VCore und fixem Multi - Turbo disabled. ;)
Äußert sich einfach damit dass wenn z.b von Multi 45 auf Multi 49 stellst er im CPUZ aber nur 4500Mhz anzeigt :) Im Bios stimmt der Takt aber er übernimmt ihn nicht.
Turbo aus und Offset.
Andere frage, hat die Supreme fx III eigentlich Dolby digital live ?
Also wenn per optischen Ausgang an 5.1 Receiver anschliessen will zum zocken
Stell mal die Loadline auf Auto und schau ob das Verhalten noch immer auftritt. Musst natürlich die VCore anpassen, damit es unter Last wieder passt.
Werd ich mal testen. Kann ich nun per optischen Ausgang 5.1 nutzen über Anlage oder brauch ich's ne Soundkarte mit DDL/DTS? Hab gelesen man hat wohl nur Stereo dann weil Board über Toslink kein 5.1 ausgibt. Stimmt das oder kann ich auch so mit Surround spielen ? Hab kein Platz mehr im Pc für extra Soundkarte :(
Bei mir läuft's mit der Beta 1604 besser.. Ich muss weniger vcore geben für 4.8GHZ. Bringt es überhaupt sein Ram zu übertakten in Game welche Vorteile hat man. Ich habe als System platte eine SSD und meine Spiele sind auch auf einer SSD
Das ist doch individuell je nach Ram anders. Es gibt sehr gute Ram die 2400MHz @ 1.525V mit strammen Timings machen.
Selektierte Samsung-Chips können das.....
Empfohlen wird max 1.575Vdimm
Nicht ram Spannung sondern Board Spannung steige gerade vom Gene-z aufs v um da aktuell nur 2133mhz drin sind
Mein Speicher sollte die 2400 cl10 mit machen, gehen Recht gut
