[Sammelthread] Asus P5N-D (nForce 750i)
Sammelthread zum ASUS P5N-D
1.Spezifikationen:
CPU:
Intel Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® Extreme/Pentium® D/Pentium® 4 Processors
Compatible with Intel® 05B/05A/06 processors
Support Intel® next generation 45nm CPU
Chipsatz:
NVIDIA nForce 750i SLI
FSB:
1333/1066/800 MHz
Speicher:
4 x DIMM, Max. 8 GB, DDR2 800/667/533 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
Erweiterung Steckplätze:
2 x PCIe 2.0 x16
- Single VGA mode: x16
- SLI mode: Hardware ready for x16, x16
2 x PCIe x1
2 x PCI 2.2
SLI:
Support two identical NVIDIA SLI-Ready graphics cards (Hardware ready for x16, x16)
Festplattenanschlüsse:
1 xUltraDMA 133/100/66/33
4 xSATA 3 Gb/s ports NVIDIA MediaShield™ RAID: Support RAID 0,1,0+1,5,JBOD span cross Serial ATA drives
LAN:
NVIDIA nForce® 750i SLI built-in Gigabit MAC with external PHY
Audio:
Realtek ALC883 8 -Channel High Definition Audio CODEC
Coaxial / Optical S/PDIF out ports
Support Jack-Sensing, Enumeration, Multi-streaming
IEEE 1394:
VIA6308P controller supports 2 x 1394a ports (one at mid-board; one at back panel)
USB:
8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel)
Rückwärtige Anschlüsse:
1 x Parallel
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x IEEE 1394a
1 x LAN(RJ45) port
4 x USB 2.0/1.1
8 -Channel Audio I/O
Interne Anschlüsse:
2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x IEEE 1394a connector
1 x CPU Fan connector
1 x Chassis Fan connector
1 x Power Fan connector
1 x S/PDIF Out connector
1 x4-pin ATX 12V Power connector
1 x 24 -pin ATX Power connector
Front panel audio connector
Chassis Intrusion connector
CD/AUX audio in
System Panel Connector
Zubehör:
SLI connector
SATA cables
IDE cable
FDD cable
ASUS Q-shield
2-port USB 2.0 module
2 in 1 ASUS Q-Connector kit
1 x Optional Fan for Water-Cooling or Passive-Cooling only
User's manual
Support CD:
Drivers
ASUS PC Probe II
ASUS AI Suite
Anti-virus software (OEM version)
ASUS Update
Abmessungen:
ATX, 30.5 cm x 24.5 cm
2.Treiber & BIOS:
Die aktuellsten Treiber und das aktuellste BIOS für das Mainboard findet man unter folgendem Link:
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5N-D
3.Fragen & Antworten
Frage: Wieso bekomme ich immer einen Bluescreen mit der Fehlermeldung das die nvgts.sys defekt sei?
Antwort: Unter XP32Bit und Vista 64Bit darf man die Sata-Treiber nicht mitinstallieren, diese Treiber verursachen den Fehler.
Frage: Wieso stürzt mein PC öfter ab, wenn ich Videos anschaue? Es bilden sich auf dem Bildschirm bunte Streifen und nichts geht mehr.
Antwort: Bei XP unter: "Systemsteuerung" -> "Anzeige" -> "Einstellungen" -> "Erweitert" -> "Problembehandlung" -> den Haken bei "Write Combining aktivieren" entfernen. Dann kann man zumindest noch weiter am Rechner arbeiten wenn die Videos abstürzen. Das Problem verursacht wahrscheinlich der Forcewaretreiber bei 8800er Grakas.
Bei den neuen Forcewaretreibern, die Anfang Mai erscheinen, soll das Problem behoben sein.
Frage: Wieso zeigt mir CPU-Z einen zu niedrigen Takt meiner CPU an?
Antwort: Wahrscheinlich ist "C1E" im BIOS aktiviert, dadurch taktet der PC zum stromsparen runter. Sobald die CPU unter Last ist, taktet sie wieder voll.
Frage: Wo bekomme ich das Mainboard am günstigsten?
Antwort: http://geizhals.at/deutschland/a303460.html
Das Mainboard hat nen V Droop von etwa 0,05V, deshalb sind 1,4V eingestellt real unter Last nur 1,34V ... Der optionale NB Kühler zerstört den Luftstrom, was sich negativ auf das restliche System auswirkt, hab ich selber bei mir feststellen müssen...
MfG TheX
@frsschmidt
So wie Du ihn eingebaut hast bekommt die Northbridge natürlich keinen Luftstrom ab.
Auf der Site von hartware.de http://www.hartware.de/review_723_5.html ist er aber um 45 Grad gedreht aufgebaut, was den Luftstrom mit Spoiler auf den Chipsatz lenkt. Ich denke das wäre vielleicht besser. Andererseits, wenn der CPU-Lüfter in Richtung Rückwand blässt, würde die Luft fast direkt aus dem Gehäuse geführt, was auch gut wäre.
Habe mir jedenfalls jetzt den HDT S1283 Red Scorpion Edition mit einem leiseren Lüfter bestellt (38 Euronen bei Bestseller.de) und werde mal sehen wie ich denn einbaue.
P.S.: Wie laut ist den der klene Lüfter von Asus auf der NB und wie liegen deine Temps damit?
Ich habe zwar nicht ausprobiert, wie die Temperaturen sind, wenn ich den Lüfter um 90 Grad drehe, aber ich denke eher nicht, dass es besser ist, den warmen Luftstrom Richtung Grafikkarte bzw. Richtung Netzteil zu blasen ;). Mit den Temperaturen bin ich im moment so erstmal zufrieden, daher habe ich auch keine Lust, alles wieder auszubauen und auszuprobieren, wie die Temperaturen sind, wenn ich den Lüfter drehe, aber Du kannst es dann ja gerne probieren und Deine Erfahrungen mitteilen :).
Wie laut der kleine Lüfter ist, ist denke ich eine relative Sache, empfindet sicher jeder anders und ein Gerät um die db zu messen besitze ich leider nicht.
Ich kann mit den Geräuschen, die die Lüfter von sich geben sehr gut leben, da ich das surren nicht als störend, sondern leise empfinde. Allerdings bin ich auch kein "silent" Fanatiker, mir ist es am wichtigsten, dass alles stabil läuft. Andere mögen die Geräusche der Lüfter anders empfinden.
Die Temps der NB sind zur Zeit hervorragend, IDLE zeigt mir die AI Suite von Asus 38 Grad an. Kurz nach Start von Prime hat sie mir 43 Grad angezeigt und ich rechnete mit einem Anstieg der Temperatur, jedoch ist sie nun nach gut 30 Minuten sogar auf 39 Grad gefallen, während die CPU Temperatur bei 54 Grad liegt.
Wie es ohne den NB Lüfter von Asus aussieht, habe ich noch nicht ausprobiert, evtl. werde ich später mal testen, ob ohne ihn die CPU vielleicht noch besser gekühlt wird. Allerdings war ich mit den Temperaturen nach dem Wechsel des boxed Lüfters erstmal so zufrieden, daher habe ich gar nicht erst ausprobiert, wie es ohne den NB Lüfter aussieht. Gut möglich, dass die CPU ohne ihn ein wenig kühler ist, allerdings denke ich, dass dann dafür die NB Temperatur ansteigen würde.
ich habe auch erst seit gestern das Asus P5N-D. Und hatte mir dabei gehofft, dass ich endlich die Probleme vom P5B vergessen kann. Leider ist dem nach was anderes an Problemen hinzugekommen.
Zum einen, wenn ich mit einem Multimedia Player Musik abspielen will und ich in der Suchzeile vorspulen will, dann knackt es kurz, je nach Tonfrequenz. Je höher desto lauter knackt es. :( Auch das komische "Summen" wenn ich den Cursor bewege oder halt Fenster vergrößere oder verkleinere, kommt ein Summen aus den Lautsprechern. Beim Frontpanel ist der Ton über Kopfhörer am schlimmsten! Desweiteren vermisse ich den Mikrofon Boost! Wo kann ich den Microfonverstärker finden? Ich habe halt die Treiber-CD installiert und alles funktioniert soweit, nur die Mikrofonverstärkung fehlt mir!
Sonst bin ich mit der Performance echt zufrieden. Und endlich FireWire OnBoard und NVidia SLI! :)
Tschö, Parker
FireFire??
also zu dem sound problem: ahst du ein 32 bit betriebssystem? dann ließ mal etwas vorher, glaub da haben andere ähnliches problem
mein frontpanel von TT geht bzgl sound fast gar nicht, muss nochmal schaun ob ich die pins irgendwie anderes hinbaue...
summen aus den lautsprechern??? ist mir total neu, hast du das realtek hd audio richtig installiert??
mit dem mic hab ich wenn es hinten drin steckt null probleme,
TS geht SUPER
in CSS das mmic geht super und kanns auch super aufnehmen....
FireWire hab ich einmal gebraucht, um was von ner Kamera aufen PC zu kopieren ...
Summen in den Lautsprechern? Eventuell irgendwie irgendwas mit dem Mikrofon Eingang verstellt bzw. falsch eingestellt oder nen falsches Gerät drangehängt?
MfG TheX
Den Mikrofon Boost kannst Du z. B. aktivieren, indem Du die Windows Lautstärkenregelung startest und dort unter Optionen->Eigenschaften->Mixer den Realtek HD Audio output auswählst und dann einen Haken bei Mikrofon machst. Dann wird das Mikrofon bei den Lautstärkereglern angezeigt und da drunter erscheint der Button "Erweitert". Dort kannst Du dann den Boost aktivieren. Dasselbe müsste aber auch mit dem Realtek Sound-Manager möglich sein. Unter Vista 64 kann man sogar wählen, ob man einen 20 db Boost oder einen 30 db Boost aktivieren möchte.
Was nutzt du für einen CPU Kühler?
Ich hatte bei mir diesen kleinen Lüfter auch mal drauf aber die Temps von der NB haben sich gar nicht verändert:hmm:
so wie ich das ganze jetzt beobachte scheint es bei dem Board recht deutliche Unterschiede zu geben was die Temperatur der North Bridge angehen. IM Asus Forum schreiben alle was von 35° bis hin zu 75°C du schreibst was von 39°C. Ich habe im Idle konstant 45° und unter Last 48° bis 50°
ist schon komisch:stupid:
@Parker25
Hol Dir mal hier die neuesten Treiber für Realtek HD Audio: http://www.computerbase.de/downloads/treiber/soundkarten/realtek_hd_audio_treiber/.
Das sollte eigentlich helfen. War anfangs bei mir auch ein Problem (hab jetzt meine gute Audigy 2 ZS wieder aktiviert. Der Onboardsound ist meiner Meinung nach total mies.
@frsschmidt
Werde ich sehen, wie das mit dem neuen CPU-Kühler funzt. Sobald ich ihn habe, werd' ich berichten.
Gruß hacki65
@frsschmidt
Vielen, vielen Dank für den Erfolgreichen Tipp des Mikro-Verstärkers! Das mit dem neuen Soundtreiber werde ich gleich mal testen. Werde dann berichten.
EDIT: So, hab den neuen Treiber von der Computerbase Homepage heruntergeladen. Dabei ist mir echt aufgefallen, dass noch nichtmal für die eigenen Asus-Kunden auf der Homepage die aktuellsten Treiber angeboten werden! Computerbase hat V. 1.90 und von der Asus Homepage war es V. 1.89. Ich glaube so langsam reicht es mir mit Asus! Der Service, sowie die Qualität haben echt nachgelassen! Was ist mit euch los Leute, bei Asus? AUFWACHEN! Naja auf jeden Fall ist erstmal das Summen weg, Toll! :) Nur noch das Knacken ist da, wenn ich im Lied mit dem Media Player hin und her in der Suchleiste switche.
Tschö, Parker
@Parker25
Welche Version des Mediaplayers benutzt Du den? Hastes mal mit nem anderen Player probiert? Und: mach mal alle Quellen außer Wave auf stumm und versuch dann mal, ob es weg geht. Desweiteren kannste die Hardbeschleunigung mal ne Stufe kleiner stellen.
Frage: Wie siehts bei dir eigentlich mit der Videowiedergabe aus (DivX,Xvid,etc.). Stürzt der PC bei dir auch ab?
Gruß hacki65
Seit heute gibs die Version 1.91 bei ComputerBase zu Download:
Geht lieber auf Realtek, da CB sehr langsam ist:
http://www.realtek.com.tw/downloads/downloadsCheck.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
@LavaLampe
Beziehst Du dich auf die Videoproblematik? Wenn ja, dann muss ich sagen, das ich K-Lite MegaPack installiert hab, es aber nicht geholfen hat. Es ist egal welchen Player ich benutze (Media Player 11, Media Player Classic, Winamp, vlc,etc.). Das Problem bleibt.
Bei mir meistens, wenn ich von Vollbild zurück auf Desktop schalte.
Gruß hacki65
EDIT: Bei Sound hab ich wie gesagt im Moment keine Probleme (Audigy 2 ZS).
@LavaLampe
Gruß hacki65
Sorry, aber ja die meine ich. Ich denke da müssen wir auf NVidia warten bis die mal den Treiber korrekt hinbekommen. Ich denke da ist der Hund begraben...
@LavaLampe
Tja, das ist das Problem. Wie ich schon weiter oben geschrieben habe, ist der Chipsatztreiber eigentlich nur eine .inf-Datei. Wie soll da eine Änderung gemacht werden? Diese .inf-Datei schreibt nur einige Werte in die Registry, und das isses auch schon. Ich denke, da es ja bei Vista X64 nicht auftritt (laut team-o-see), das es nur ein BIOS-Update oder ein Patch von Microsoft richten kann. Bleibt zu hoffen, daß das Problem schon hinreichend bekannt gemacht wurde, sodas die Verantwortlichen reagieren. Falls es allerdings ein genereller, in der Hardware begründeter Fehler ist, könnte es schwierig werden, das auszubügeln. Vielleicht gibs ja wie in der Autobranche ne Rückrufaktion, hehe.
Gruß hacki65
P.S.: Hast Du denn ähnliche Probleme?
@LavaLampe
Gruß hacki65
Ne, gar nicht. Bin leider davon abgekommen mir das Board zu kaufen nach den ganzen Probs die hier zu lesen sind. Ich lass mein P35 drin. Hab mir jetzt erst mal nen HP2207 bestellt und wenns meine GTS G80 in der nativen Auflösung nicht bringt dann kommt was stärkeres rein.
@LavaLampe
Du Glückspilz! Hab das Board vorher gekauft und erst später im Forum auf diese Probleme aufmerksam geworden (und natürlich aus eigener Erfahrung). Aber mir sagte das Feature SLI halt zu (später ne 2. GTS rein und so). Und natürlich der gute Preis.
btw: Bin mit meinem Samsung SyncMaster 226BW gar nicht zufrieden. Das Panel leuchtet an den Seiten und oben und unten viel zu stark (Hintergrundbeleuchtung).
Die Helligkeitsverteilung ist auch nicht so toll. Hab gelesen, das die neueren Panels nicht mehr von Samsung kommen, und die Qualität darunter leidet. Aber sonst (z.b.: bei Spielen) ist die Reaktionszeit hervorragend.
Gruß hacki65
Ich hab mir das Board ebenfalls vor ca. einem Monat gekauft nach einigen kleineren Problemen vor allem mit meinem Ramspeicher läuft mein Pc nun entlich soweit recht stabil. Allerdings hab ich auch mal eine kleine Frage, ich wollte mir von der Nvidia Hp mal neue Mainboard Treiber downloaden und wenn ich das dort machen will zeigt er mir nur 1 Treiber zum Download an nämlich den nForce 650i SLI , das Board hat doch eigentlich nen 750SLI. ??? Hat wer ne Ahnung woran das liegen könnte.
Mein restliches System:
4Gb GEIl DD2-800 CL4 Blackdragon
Asus-P5N-D
2* EVGA GF8800GTS SSC
Dual Core E6850
Biosversion hab das 402. Hatte vorher das 302 allerdings hatte ich mit der Version immer nen Bluescreen wenn ich Vista installieren wollte. sobalt ich beide Ramblöcke nutzen wollte.
Mfg Dear
wenn du den 650i anklickst dteht dann 750I da bzw unterstütze chipsätze 750i musst mal etwas schaun, da haben se eben vorne die falsche bezeichnung genommen...
@Dearwish
Du meinst wahrscheinlich den 8.43 auf englisch? Das ist eigentlich der falschen Treiber für das Board. Warum nVidia nicht in der Lage ist, einen passenden Treiber anzubieten, versteh ich bis heute nicht. Der 750i basiert zwar auf dem 650i, aber Treibermäßig geht bei dem 8.43 nur der SMBus-Treiber (Version 4.57) . Beim Netzwerktreiber geht es nur mit dem 9.46 für den 780i (SMBus Version 4.60). Es gibt zwar schon den 9.64, aber auch hier funzt nur der SMBus-Treiber (SMBus Version 4.62). Will man das Chipsatz-Treiberpaket installieren, bleibt nur der 9.46er (obwohl nVidia den 750i unter unterstützte Produkte gar nicht angibt). Aber damit funzt SMBus & Netzwerk. Vom IDE-Treiber würde ich die Finger lassen (Abstürze wegen dem ntgts.sys - Bluescreens).
Bleibt zu hoffen, das nVidia mal in ihren Treiber klar Schiff macht, damit wir nicht ständig rumsuchen (und als Beta-Tester herhalten) müssen.
Wie sieht es den bei dir mit dem Videoproblem aus (bunte Streifen, PC freeze beim abspielen von Divx, Xvid,etc.)? Teste mal ein bisschen, ob das bei Dir auch auftritt.
P.S.: Welches Vista benutzt du den (x86 oder x64)?
Gruß hacki65
Danke für die schnellen Antworten :)
So zum einen verwende ich 2 Betriebssysteme zum einen Vista 64bit und zum anderen Windows XP. Also mit Freeze Streifen ect habe ich zumindest unter Vista keine Probleme. Nur unter XP Freezed mir hin und wieder mein System ein wenn ich vergesse die Lüfter von meinen beiden Grakas manuel ein wenig schneller laufen zu lassen.
ok, endlich noch iener mit vsita 64
also eine frage an dich, die "IDE-Treiber" sind doch beim gräte manager unter IDE ATA/ATAPI- Controller erkennbaer/löschbar?!
was hast du denn da stehen
denn ich habe ein wenig prob mit meiner e-sata platten, denn ab und zu friert mir mit der das system ein...
grüße
@team-o-see
versuch mal bei nVidia.de irgendeinen Treiber für den 750i zu bekommen!!! (Sprache: Deutsch)!!!
Egal welches Windows Betriebssystem. :shot:
Ist schon traurig...
Gruß hacki65
grüße
Jo ich hab da gerade mal nach gekuckt, man kann sie unter dem Gerätemanager a: erkennen und b: Jo zum löschen kann ich dir nix sagen die Funktion hat man auf jedenfall aber das möchte ich eigentlich nicht ausprobieren.
lg
Dear
@ Dearwish: ok, kann man schon machen hab ich scho nein paar mal um zu ergründen wo das prob bei mir leigt...
@hacki65:
jop ganz easy für vsita 64: geh auf nForce 650i SLI und auf vsita 64 und taha, wei ich sagte ist der falsch eingeordnete 750i da.. steht bei unterstützten geräten: 750i
@hacki65:
@team-o-see
wie ich schon mal gepostet hab: ich finde es traurig, das man für ein 750i-Board unter 650i nach Treibern suchen soll. Das man dann was findet, hab ich auch rausgefunden, nur darauf kommen muss man auch erst.
Zumal auf der englischen Seite ja was ausgespukt wird, nur halt ein Treiberpaket (8.43 XP) bei dem der Netzwerktreiber auf dem 750i nicht funzt.
ICH HABE NUN MAL EIN 750i GEKAUFT, KEIN 650i....
Graaauß hacki65
Moin moin,
habe auch das P5N-D (Bios 0203), allerdings Vista x64 (Business N Edition), auch bei mir tritt der Fehler mit den bunten Streifen in Videos mit anschließendem Freeze auf. Scheint also 64bit Vista nicht verschont zu sein :asthanos:
Meine restliche Konfig:
Q6600@3Ghz
MSI 8800GT
2x2GB Corsair 4-4-4-12 800Mhz
zzt kann ich aber noch mit dem Fehler leben, da er nur sporadisch auftritt, d.h. ein Video, bei dem der Fehler auftritt, kann beim nächsten Versuch trotzdem ohne Fehler durchlaufen...
