AI Overclock Tuner [Manual]
CPU Ratio Setting [AUTO]
FSB Frequency [366]
PCI-E Frequency [100]
FSB Strap to North Bridge [333] *
DRAM Frequency [DDR2 - 733]
DRAM CLK Skew on Channel A1 [Auto]
DRAM CLK Skew on Channel A2 [Auto]
DRAM CLK Skew on Channel B1 [Auto]
DRAM CLK Skew on Channel B2 [Auto]
DRAM Timing Control [Manual] <-- auf Manuell stellen um die Ramtimings nach Herstellerangaben einzustellen
1st Information : X-X-X-XX-X-XX-X-X
CAS# Latency [5] <-- siehe Herstellerangaben des Rams
DRAM RAS# to CAS# Delay [5] <-- siehe Herstellerangaben des Rams
DRAM RAS# Precharge [5] <-- siehe Herstellerangaben des Rams
DRAM RAS# Activate to Precharge [15] <-- siehe Herstellerangaben des Rams
RAS# to RAS# Delay [Auto]
Row Refresh Cycle Time [Auto]
Write Recovery Time [Auto]
Read to Precharge Time [Auto]
2nd Information : X-X-X-X-X-X-X
READ to WRITE Delay (S/D) [Auto]
Write to Read Delay (S) [Auto]
WRITE to READ Delay (D) [Auto]
READ to READ Delay (S) [Auto]
READ to READ Delay (D) [Auto]
WRITE to WRITE Delay (S) [Auto]
WRITE to WRITE Delay (D) [Auto]
3rd Information : XX-X-X-X-X
WRITE to PRE Delay [Auto]
READ to PRE Delay [Auto]
PRE to PRE Delay [Auto]
ALL PRE to ACT Delay [Auto]
ALL PRE to REF Delay [Auto]
DRAM Static Read Control [Disabled] *
DRAM Read Training [Disabled] *
MEM. OC Charger [Enabled] *
AI Clock Twister [Moderate] *
AI Transaction Booster [Manual] *
Common Performance Level [6] *
Pull-In of CHA PH1 [Disabled]
Pull-In of CHA PH2 [Disabled]
Pull-In of CHA PH3 [Disabled]
Pull-In of CHA PH4 [Disabled]
Pull-In of CHB PH1 [Disabled]
Pull-In of CHB PH2 [Disabled]
Pull-In of CHB PH3 [Disabled]
Pull-In of CHB PH4 [Disabled]
******** Please key in numbers directly! ********
CPU Voltage [1,32500]
CPU GTL Voltage Reference (0/2) [AUTO]
CPU GTL Voltage Reference (1/3) [AUTO]
CPU PLL Voltage [1,5]
FSB Termination Voltage [1,2]
DRAM Voltage [1,92]
NB Voltage [1,10]
NB GTL Reference [AUTO]
SBridge Voltage [1.10]
PCIE SATA Voltage [1.50]
Load Line Calibration [Disabled] *
CPU Spread Spectrum [Disabled] *
PCIE Spread Spectrum [Disabled] *
CPU Clock Skew [Auto]
NB Clock Skew [Auto]
CPU Margin Enhancement [Optimized] *
.:Advanced - CPU Configuration:.
CPU Ratio Setting [Auto]
C1E Suppport [Enabled]
Max CPUID Value Limit [Disabled]
Intel (R) Virtualization Tech [Enabled] *
CPU TM Function [Enabled]
Execute Disable Bit [Enabled]
Ich werde mir bei Alternate den Noctua NH-D14 holen und hoffe, dass da dann die WLP dabei ist.
Was sind eingenlich diese zwei Ultra-Low-Noise-Adapter (U.L.N.A.) ???
Was muss ich machen, wenn ich das System overclocked betreiben will.
CPU Voltage [1,32500] so lassen
CPU GTL Voltage Reference (0/2) [AUTO] dito
CPU GTL Voltage Reference (1/3) [AUTO] dito
CPU PLL Voltage [1,5] dito
FSB Termination Voltage [1,2] dito
DRAM Voltage [1,92] dito
NB Voltage [1,10] -> 1,20V
NB GTL Reference [AUTO] lassen
SBridge Voltage [1.10] lassen
PCIE SATA Voltage [1.50] lassen
CPU Ratio Setting [Auto] niedrigster Wert
@basti
das mit deinem Angebot muss ich mir noch überlegen, Investitionen in den Pc sind eigentlich in nächster Zeit nicht geplant, aber danke dafür
Mit der Graka hatte ich diesmal keine Probleme, nur meine Minianwendungen in der Sidebar habem immer regelmäßig geflackert![]()
Wie sieht eigentlich deine Gehäusekühlung aus? Bringt auch nix wenn du dir den teuersten und leistungsfähigsten CPU-Kühler kaufst und der die heiße Gehäuseluft nur umwälzt. Alle großen CPU-Lüfter (Achtung Bauhöhe -> passen die in dein Gehäuse?) sind leistungsfähiger als das was du hast. Können aber nur wirken, wenn es einen vernünftigen Luftstrom im Gehäuse gibt. Kannst ja auch mal im LuKü-thread schauen. Ich würde jedenfalls einen Lüfter mit 4-Pol PWM-Anschluß für das Asus-board holen, dann kann die Lüfterregelung des boards auch hoch und runter regeln. Das hast bei den Noctuas leider nichtIch werde mir bei Alternate den Noctua NH-D14 holen und hoffe, dass da dann die WLP dabei ist.
Wenn die 533Mhz wieder stabil laufen und ich wieder etwas in der Materie drin bin, dann gehts Richtung 566MhzIst kein Thema.
Ich dachte halt nur, dass Du (wenn die Teile denn irgendwann mal kommen sollten) evtl. dann Interesse an einer günstigen HD5850 hättest, bevor ich sie nicht abhole oder zurückschicke
Man, jetzt hats mich wieder gepackt, nachher gleich mal die 533x7,5 in Angriff nehmen
Gruß Basti
PS.: Bist schon fleißig am Dirt 2 zocken?
@basti
hab eine neue Geheimwaffemit der NB GTL kann man die vNB schön absenken.
Wie viel man die vNB runter bringen kann, kann ich noch nicht genau sagen und wie es genau geht die richtige zu finden auch nicht.
